No Aircraft Showing on map
Started by EIME2, July 03, 2015, 03:51:56 PM
EIME2
Evening
I Have been using Air Nav Radarbox3D for the last 4 years with no issues until yesterday
I have the usual screen with my flights populating ok but not showing on my map
to the best of my knowledge i have not changed any setting or tinkered around  with my computer
any help would be much appreciated
Mick
Is that in 3D, how is it in 2D?
EIME2
Evening Alan
nope i don't use the 3D its too messy for my little old netbook by the way i should have said i'm running ver 072
and i have been at this all day and still no joy getting the aircraft to appear on the map all down the side in my flights but nothing on the Map
Mick
#3
Mick,
Where on the computer have you installed RB.  Try re-installing.
EIME2
sounds like a plan but the disc i got with the box is sadly the worst for ware after 5 or so years or is there a Alternative download somewhere?
mick
EIME2
sorry C Drive Program files
mick
#6
The program files location might have some thing to do with it, that's why I asked.  If it was me I would uninstall the lot of the existing install including manually deleting any orphan files and re-install to somewhere like C:\Airnav, keep away from program files.  Remember to save any files you may want to keep first like mylog, photos, silhouettes, logos etc as it is the old ones from 2009 that will be installed.  Replace the ones in the new installation with your saved files.
You will get the full 5.00.72 on the support page here http://www.airnavsystems.com/download/ANRB/ANRB50072Setup.exe   Its a big 500 odd Mb download so will take a wee while.
EIME2
thanks Alan
still seems a bit strange  that after all this time and mind you nothing new downloaded to this machine it should start acting up like this im a little unsure about deleting the whole programme i have nothing saved to it its just basic use but sure if thats the fix then that's what i have to do thanks again
Mick
MrParanoia
You could maybe try system restore as a last resort before a full uninstall/re-install procedure
Radarbox 3D, GlobeS RTL1090, ModeSMixer2, UBC800XLT, UBC125XLT
EIME2
yup system restore might be the answer again running Plane Plotter +Plane base and PBlink i don't want to go messing with those setting or impact on anything else its a tough one alright
mick
EIME2
just as a side note i dont think i have seen this before under the map portion on the same line as all requests done i have .FTP Upload Status  connecting to 127.0.0.1.  is this normal cant remember seeing this before
Mick
Have not got a clue about that but if you go to Preferences/General/ Screen Shot Auto FTP Upload, the host on there is 127.0.0.1.  Have you ticked a box on there?
EIME2
just unchecked the box and the message is gone but the problem remains no plots on the map but all still showing in the my flights plane
Mick
MrParanoia
On the toolbar between the Airport selection box and the Quick List button is a Show All button - try clicking that
Does clicking on the Map View button do anything?
