Picture from Stevenage
Started by Roadrunner, July 08, 2007, 03:02:19 PM
Roadrunner
Here is a picture I just took using the supplied aerial siting on the back of the sofa in my lounge.
[attachment deleted by admin]
nice pic, I hope the monarch and ryanair didn't get too close :)
Roadrunner
The ryanair is at 5,500 ft and the Monarch at 8700 feet so should be OK
Since taken the following of UK with network switched on.
Roadrunner
Finally a screen shot from Heathrow - all the traffic is from the Network as my aerial location can't quite reach that far at present. As you can se, wuite crowded. Dont know what will ahppen when it gets busy ?
Excellent!
Almost real time, I can see BMA17 live on the SBS-1 just approaching EGBB.
Quote from: Roadrunner on July 08, 2007, 03:14:10 PMSince taken the following of UK with network switched on.
Anything further north, specifically north of Inverness?
Not yet, we do have someone close to Glasgow though picking up ground traffic as well :)
#7
Tarbat: a few in Scotland.
Note trails will be available in the next update :)
sleepylondon
one i took of heathrow, i am 15 miles away
great pics m8 thanks for posting
Roadrunner
The attached picture just taken with purely network traffic
sleepylondon
here is one of heathrow using local and network
how do i get rid of the flight trail lines? any idea?
Roadrunner
Quote from: sleepylondon on July 09, 2007, 05:47:33 PM
Hi Sleepylondon,
I think the picture you have added is identical to mine and shows no trails.
Actually I think you are referring to the leading lines and you get rid of them in File/Preferences/General and remove tick in box - draw 5 minute flight path vector
Mike
sleepylondon
many thanks, it worked!
does your hardware keep disconnecting from green to red every now and then?
regards
Roadrunner
Yes it does It did so a few moments ago just because I tried to change the map view from London to Scotland
