Radarbox Server Alert
Started by FACTflights, September 05, 2015, 10:30:12 AM
FACTflights
I keep getting messages saying something like "Last message received on 2015/09/04 05:25:48", yet RadarBox24 shows all the aircraft that my system picks up.
I don't know what to do about this.
John
ZS1AGH
No HF antennae at the moment.
Where do you get this message John?
FACTflights
John
ZS1AGH
Do you have any email alerts set up?
FACTflights
John
ZS1AGH
I presume you have just started receiving these emails John and have made no recent changes to your settings or preferences, I have no idea why so suggest that you contact support for advice.
FACTflights
Thanks for the interest Alan,
I am now also not able to log into Radarbox24.  I get a message that says "Too many mobile devices"
I will talk to support.
No, I have not changed anything since 29 July when I got Windows 10.
John
ZS1AGH
Hi John,
is it possible, that WIN10 has somehow changed the partition of your hard disc. I know cases in which the PC appeared as different hardware after such a partition change, although the physical hardware wasn't changed. The result would be, that although you are still using the same physical PC, the Airnav account management system* thinks that you have installed the SW on another System and/or RB24 login system thinks that you are using another -additional- PC for logins.
*  or whatever it is called...
Regards Ingo
Sorry John, I didn't notice that it was RB24 that you were having the issue with, thought it was your Radarbox.  Still none the wiser though but the answer Ingo gave may very well be relevant and if the case I would presume that it should be relatively easy for Airnav to deal with as it is similar to loading onto a 3rd computer.
John,
Are you able to log in now?
John,
Did you get it sorted
FACTflights
Things got a bit confused with this topic further back.
The problem with RadarBox 24 is sorted out, I can log on.
But I still get these email messages from ANRB "Last message received on 2015/09/04 05:25:48"
I get these at least once a day.
Which I read to mean that they are not getting shared info from me.
Yet all my aircraft appear on RadarBox24,  is that not where the shared info goes ?
John
ZS1AGH
I have no idea John, they go to the network as well as RB24 but I have no idea if the message relates to that or something else.  Did support not offer any guidance, no one else appears to be receiving these emails that's why I asked if you had made any changes to your set up which could have brought them on.
FACTflights
Just got a reply from ANRB Support.  They are experiencing a problem with the alert server and are working on it.  So the problem is not a problem, thank all.
John
ZS1AGH
Thanks for the update John
