Thank you
Started by escahute, April 25, 2008, 12:57:44 PM
escahute
Bonjour à tous,
Je vois sur certains logs des appareils militaires mais je ne reçois aucun avion de chasse, y a t-il une modification à faire dans programme ?
Concernant l'envoi automatique du log journalier à 00h00 quand j'entre l'adresse mail elle est refusée, je ne comprends pas le terme "comma separated"
Une dernière question, y'a t-il sur ce forum un Français ?
Merci et bon Week-end.
Daniel.
Hello everyone,
I see some logs on military aircraft but I do not get any fighter, is there a change to a program?
Regarding sending automatic log daily at 00:00 when I address mail it is refused, I do not understand the term "comma separated"
One last question, 'Does this forum a French?
Thank you and good weekend.
Daniel.
Hi Daniel,
A comma separated file or csv file, has lines of data with each field in that line being separated by a comma.  At the each of each data line there is a CR+LF so the next lot of data starts on a new line.  See the short example below:
14:09:19.061,2008/03/21,14:14:19.061,TOM762N,33525,,,0,0,0,3426,0,0,0,0
14:09:19.061,2008/03/21,14:14:19.061,RYR1916,36550,413,302,52.3846,-4.0594,-0,6726,0,0,0,0
14:09:19.061,2008/03/21,14:14:19.061,RYR539Z,18000,360,288,0,0,0,3254,0,0,0,0
14:09:19.061,2008/03/21,14:14:19.061,EIN159,20250,283,310,0,0,-1536,7675,0,0,0,0
14:09:19.061,2008/03/21,14:14:19.061,SWR8N,34000,428,330,0,0,0,3045,0,0,0,0
14:09:19.061,2008/03/21,14:14:19.061,BAW52,21200,456,132,52.3713,-1.6428,-28,4234,0,0,0,0
csv files can be imported easily into other programs such as spreadsheets and databases.
RadarBox can detect some fighter aircraft and they show in the aircraft list.  They will not appear on the map as it is a bad thing if other poeple can see where your air power is.  However, very few fighter type aircraft have the equipment necessary for them to show in RadarBox.
asecna
Hello Daniel
If you want some explanation in French just mail it to me
The forum is in english only otherwise we can't track whats going and who is asking what :)
escahute
I am sorry to have used the French language, I did not know.
Regarding mail address (send by email - subject - recipients - comma separated) can you tell me why this does not?
Thank you.
