Author Topic: .NET Framework required?  (Read 6111 times)
N9JIG
  • ANRB, too many radios and an understanding wife!
    • CARMA, the Chicago Area Radio Monitoring Association
« on: September 26, 2015, 09:52:50 PM »
Over the last few months I have noticed that I was not seeing any planes plotted on the map. Since I had recently moved from Illinois (near ORD) to Arizona I figured that there just wasn't as many planes with the right reporting equipment in the area.
I recently updated (?) to Windows 10 and in order to get another program to work (totally unrelated to ANRB) I had to install .NET Framework 4. After I restarted I noticed that I was now seeing planes plotted on the map.
I suspect it was due to the .NET but I don't know why they suddenly stopped displaying a few months ago in the first place.
Am I correct in assuming that .NET is required?
Re: .NET Framework required?
« Reply #1 on: September 27, 2015, 04:04:04 AM »
With regards to the small start-lable I would say yes, as it states "loading Framework" there.
« Reply #2 on: September 27, 2015, 08:15:10 AM »
I would have thought that the .NET framework was an integral part of Windows so I wonder why it wasn't already there and it had to be installed separately.  Maybe some specific issue with the upgrade process meant it didn't install and load for you.
N9JIG
« Reply #3 on: September 30, 2015, 01:30:39 AM »
Weirdly though AirNav displayed flights when I lived in Chicago and when I relocated it seemed to stop. Same computer, same RB and same antenna, just a different house. 6 months later I update from Windows 7 and install .NET and the flights return to the map.
« Reply #4 on: September 30, 2015, 07:57:05 AM »
As long as it is working now that's the main thing and your resolution may help others.
