That EUREKA Moment
Started by golfboy, April 25, 2008, 07:28:28 PM
golfboy
After my last post "No Live Flights (EVER)",I returned my RadarBox to Primetec for them to check it out.I have just recieved it back and connected it to my PC.It was just the same,i.e. USB light flashing one time per second and the signal light as dead as a Dodo.No live flights on my screen,just a blank map,very depressing.
Then a light went off in my head and I remembered the post from Airmad "silly sma plug" which he posted after I had sent my box away.So I gave the antenna cable a push in and EUREKA, RadarBox lit up like a disco and my screen burst into life with live flights.Myflights was soon showing loads of aircraft.So this must have been my problem all along.I am sure Primetec checked out the RadarBox and found it to be OK,not sure if they checked the antenna connector?
It seems afew people have had this connector problem now,lets hope that the quality of the antenna connector will be improved in the future.
Anyway,from a very happy user,thanks AirNav support and thanks Airmad.
Golfboy
I'm glad that you are up and running :-)
There's nothing worse than getting a new "toy" and finding that it doesn't work - especially when it's cost a pretty penny!
All the best
steveb25
I am wondering if sombody can come up with a permaent solution to this problem
What exactly is loose, the antenna cable or the antenna connector on the RadarBox.
Nearly all SMA based cables with those antenna have those connections that way and actually allow a bit of give when connecting.
steveb25
When you unscrew the sma plug from the back of the box and look at it the centre pin sometimes has disappeared or is only just showing.
If you hold the sma shell and push the cable towards the plug the pin re-appears.
It has happened once to me, but seems t have happened to others as well
golfboy
Yes,it is the connector on the cable at fault and not the connector on the back of the RadarBox.The centre pin seems to have the ability to move backwards towards the cable.As Steve said ,by holding the connector body and pushing the cable towards it, the pin returns to its correct position.
