Author Topic: Windows 10  (Read 20383 times)
wabews
Windows 10
« on: December 14, 2015, 01:40:29 PM »
I have upgraded to windows 10 and ever since this has been done I cannot get my Air Nav Radar Box 3D to connect,is there a known problem with Win 10
Re: Windows 10
« Reply #1 on: December 14, 2015, 01:58:04 PM »
Which drivers did you use and which version of RB.  Also did you upgrade or do a completely new install.  The advice on the Windows 8 drivers sticky usually works.
« Last Edit: December 14, 2015, 02:00:24 PM by Runway 31 »
FACTflights
  • Amateur Radio is my hobby.
Re: Windows 10
« Reply #2 on: December 15, 2015, 06:37:18 PM »
I went from Windows 8 to Windows 10 on 29 July, and did not experience any problems at all.
John
ZS1AGH
No HF antennae at the moment.
CYYZGUY
Re: Windows 10
« Reply #3 on: December 15, 2015, 07:33:06 PM »
Hi All, I upgraded from Win 7 64 Bit Ultimate to windows 10 without any issues at all.  Did not even need the 8.1 driver.
Jason
40" LED Monitor
40" LED Monitor
scampton
Re: Windows 10
« Reply #4 on: January 08, 2016, 06:01:21 PM »
I upgraded to win10. Since then I have not been able to use Radar Box. I have tried the Win8 drivers, and all the suggestions to get it to work. Still nothing. Really frustrating.
Re: Windows 10
« Reply #5 on: January 08, 2016, 06:22:09 PM »
Did you follow all the advice on the Windows 8.1 of the Windows 8 sticky
If you are using Windows 8.1, do the following:
1. From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
2. Click ‘Change PC Settings’.
3. Scroll down, and click ‘update and recovery’
4. Click ‘recovery’
5. Click under advanced start up and restart now
6. Click ‘Troubleshoot’
7. Click ‘Startup Settings’
8. Click Restart
9. When Win8 restarts type the number next to \"Disable driver signature enforcement\"
For Windows 8 drivers please download:
http://www.airnavsystems.com/download/anrb/drivers/ANRB-Win8Drivers-v2.08.30.zip
Instructions:
1- Download the file above;
2- Unzip it to a folder on your computer;
3- Disconnect your RadarBox USB cable, wait a few seconds and connect it again;
4- When Windows prompts you to find the proper RadarBox driver browse the folder where you have extracted your drivers to;
If the above Windows prompt box does not appear:
1- Go to Windows Control Panel - Device Manager- USB Controllers - RadarBox - Driver -  Update Driver
2- Point at the relevant folder and install the drivers;
scampton
Re: Windows 10
« Reply #6 on: January 09, 2016, 05:08:32 PM »
Did all the above. I get a message about a missing hash. And that the file is corrupted.
Re: Windows 10
« Reply #7 on: January 09, 2016, 05:48:35 PM »
If you are using Windows 10, do the following:
1.) Please click on Windows-10 Logo Button
2.) Click Control Panel
3.) In Control Panel select (click) System.
4.) And now in System click Advanced System Setting
5.) Windows 10 with Driver Checking disabled (Option 7)
For Windows10 drivers please download the Windows 8:
Instructions:
Any issues please follow
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
scampton
Re: Windows 10
« Reply #8 on: January 09, 2016, 07:24:03 PM »
Thanks for speedy reply. But have done that suggestion. Still a message about corrupt file and missing hash.  I understand all the procedures of disabling driver signing and win8 driver downloads. Is there anything else? I have even tried compatibility mode and administrator setting. But no luck.
Re: Windows 10
« Reply #9 on: January 09, 2016, 07:58:09 PM »
At which point are you getting stuck, there must be a certain step which you are unable to do.
scampton
Re: Windows 10
« Reply #10 on: January 10, 2016, 04:11:06 PM »
What does missing hash mean? And yes I have done the Control panel and eventually option 7. When it comes to the driver being installed that is where the problem is. I click update driver, but the message about corrupt driver is the problem that occurs.
scampton
Re: Windows 10
« Reply #11 on: January 10, 2016, 04:31:33 PM »
Also Radar box is not listed under USB controllers. It is at "Other"
scampton
Re: Windows 10
« Reply #12 on: January 10, 2016, 05:16:15 PM »
I have it working. I used the Command line trick    bcdedit -set TESTSIGNING off
It seems to have done the trick. Thank you for your help and speedy replies.
NB
Re: Windows 10
« Reply #13 on: January 18, 2016, 10:14:09 PM »
Hi there! Having the exact same problem. don't know how this bcedit Works though.....any help?
Re: Windows 10
« Reply #14 on: January 19, 2016, 07:53:33 AM »
NB did you follow the advice on the sticky.  If so contact support@airnavsystems for their help
Alanm
