Not plotting on map ?
Started by Rural Outpost, January 13, 2016, 06:31:53 PM
Rural Outpost
I couldn't sort the driver issue out so took the PC to a shop who fixed it. All working except the aircraft are not showing on the map. I have aircraft in my list with details of distance from my home ,but they are not showing. Can someone tell me which button I haven't clicked or pressed? Thanks
Hows about Show All on quick filter above the grid
Also check that the map is at your location and is not zoomed in to far
Rural Outpost
Hi Alan
Thanks for your replies but aircraft still not showing ?
Does clicking Map View, top right do anything?
Advanced 2nd row, at top left of Map, things ticked?
Try ticking and unticking Process Hardware Flights
Try double-clicking on one of the aircraft in the list to position the map on it.
Rural Outpost
Guys,
Am back on the case but frustratingly still not showing on map. Am using RB1. At bottom of screen states filtered 0. have clicked and unclicked and clicked again process hardware flights. Have also clicked advanced show airline flights and biz, have also clicked repeatedly show all in list and at top next to quick list. I , but still nothing. also double clicked on a flight showing on my list 38 miles away. Frustrating but I am obviously not doing something ? Grateful for any other thoughts?
What version of RB are you using and to where on your computer is it installed?
Rural Outpost
I have version 5.00.072 and is installed in C drive programme files X86. Because I have been clicking every box trying to identify anything I haven't ticked I now have another problem with an 'Error occurred box 'appearing. It states 'Lisi index out of bounds (359) .I have clicked restart applications a few times now but everytime I restart it the box keeps appearing. Any ideas how to clear?
#11
You should completely uninstall your ANRB Software, including a manual deleting of all remainIng files and folders. Use search to find them all. After the uninstallIng procedure restart your PC and install ANRB software to a folder like C:\AirNav. Never install ANRB software to Program files, as doing so is known to cause problems and misbehaviour of ANRB software.
Rural Outpost
Neroon,
I think that is what I will have to do. thanks
Thanks all for your assistance
Thanks Ingo, I thought that's where it would be installed to.
Rural Outpost
Back up and running after deleting all and downloading to C drive and not programmes. Thanks
