First screen shot from Rockeyes with new antenna
Started by Rockeyes, April 29, 2008, 05:15:46 PM
Rockeyes
Roadrunner
Not attempting to nock the number of contacts you have, but can you say what the timeouts are set at. The reason I ask is if they are at the preset valuse then you will find a fair proportion shown in the list of 224 have actually timed out. I only use 3 minutes for timeouts so that what is in the list is what is still being picked up.
However, that IS a very impressive total ! :-)
Rockeyes
Found that info in the end.
My settings are set as 30sec when no info received and 60 sec to hide time out flights.
Roadrunner
Thats great then......  mine initially was set for about 20 minutes and I ended up at times with a long list in MyLog but only 10-12 on the map. Looking through the list more were time-out than active. I now have mine set to 30 and 60 also.
