(windows 10
Started by briand, May 26, 2016, 09:00:52 AM
briand
Hi Alan
its been a while but only just received my box
I have downloaded program as per your instruction and alls well
I then altered computer settings asper instruction then downloaded the driver file and finished with
a file   ANRB-Win8Drivers-v2.08.30.zip where do I go  from here
Brian
#16
Brian,
1. From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
2. Click 'Change PC Settings'.
3. Scroll down, and click 'update and recovery'
4. Click 'recovery'
5. Click under advanced start up and restart now
6. Click 'Troubleshoot'
7. Click 'Startup Settings'
8. Click Restart
9. When Win8 restarts type the number next to \"Disable driver signature enforcement\"
For Windows 8 drivers please download:
http://www.airnavsystems.com/download/anrb/drivers/ANRB-Win8Drivers-v2.08.30.zip
Instructions:
1- Download the file above, YOU HAVE ALREADY DONE THIS
2- Unzip it to a folder on your computer;
3- Disconnect your RadarBox USB cable, wait a few seconds and connect it again;
4- When Windows prompts you to find the proper RadarBox driver browse the folder where you have extracted your drivers to;
If the above Windows prompt box does not appear:
1- Go to Windows Control Panel - Device Manager- USB Controllers - RadarBox - Driver -  Update Driver
2- Point at the relevant folder and install the drivers;
briand
Morning
how do I unzip it to a folder when I click on it I get a list of things
Brian
Create a folder and name it ANRB W8 Drivers.
Right click on the zipped folder of the W8 drivers you downloaded.  You will see on the list Extract All.
Another window will open, browse to the folder you created above the press extract and you divers will de-compress into it.
cttrondonia
I have a different form.
When I have installed the ANRB6.0 i have right click in the EXE, go to propriety and mark to execute in compatibility with windows 7.
After instaled, when I execute the program i have put again to execute in compatibility with windows 7.
For me have work. I use windows 10 and ANRB 6.0
PGANRB500002 - XRANGE2
https://www.radarbox24.com/stations/PGANRB500002
FlightStick with Airnav Radarbox Software
https://www.radarbox24.com/stations/PGANRB300418
briand
Hi Alan
still cant get nav box to work I unzip the drivers to a folder I then went into device manager clicked on
nav box a box came out saying no drivers installed clicked on update drivers  and it could not find any
when I right click on the zipped folder all I get is the driver file I downloaded shall I extract one
sorry to be a pain
Brian
You don't go to the zipped folder, go to the unzipped one.
Follow the instructions above
briand
Hi Alan
all working fine thanks for your help and sorry if I was a bit of a pain
Best regards
Brian
Just glad you got it going Brian.
