Author Topic: (windows 10  (Read 22214 times)
briand
(windows 10
« on: May 26, 2016, 09:00:52 AM »
Help
I have a new navbox and windows 10 how do I set it all up to start it running I would think the CD is out of date
sorry for being a bit thick
Brian
Re: (windows 10
« Reply #1 on: May 26, 2016, 09:38:05 AM »
Hi Brian,
Version 6 is the latest software from here http://www.airnavsystems.com/download/ANRB/ANRB60000Setup.exe download and install it.  Avoid the program files location and instil to somewhere like c:\Airnav
Once installed you will need the Windows 8 drivers from here
http://www.airnavsystems.com/download/anrb/drivers/ANRB-Win8Drivers-v2.08.30.zip
To load them in you will need to follow
. From the Metro Start Screen, open Settings (move your mouse to the bottom-right-corner of the screen and wait for the pop-out bar to appear, then click the Gear icon).
2. Click ‘Change PC Settings’.
3. Scroll down, and click ‘update and recovery’
4. Click ‘recovery’
5. Click under advanced start up and restart now
6. Click ‘Troubleshoot’
7. Click ‘Startup Settings’
8. Click Restart
9. When Win8 restarts type the number next to \"Disable driver signature enforcement\"
Instructions:
1- Download the file above;
2- Unzip it to a folder on your computer;
3- Disconnect your RadarBox USB cable, wait a few seconds and connect it again;
4- When Windows prompts you to find the proper RadarBox driver browse the folder where you have extracted your drivers to;
If the above Windows prompt box does not appear:
1- Go to Windows Control Panel - Device Manager- USB Controllers - RadarBox - Driver -  Update Driver
2- Point at the relevant folder and install the drivers;
You should then be good to go and start up the software.
briand
Re: (windows 10
« Reply #2 on: May 26, 2016, 10:07:10 AM »
Thanks your your a star
Brian
Re: (windows 10
« Reply #3 on: May 26, 2016, 10:08:00 AM »
Wait till we see if you get up and running first!!
briand
Re: (windows 10
« Reply #4 on: May 26, 2016, 10:26:52 AM »
good point but you sound like you now what your doing
Brian
briand
Re: (windows 10
« Reply #5 on: May 26, 2016, 06:11:45 PM »
just read your answer again and ive noticed its for windows 8 will it work with windows 10 or would it be better
to go back to 8
Brian
Re: (windows 10
« Reply #6 on: May 26, 2016, 07:24:55 PM »
No, the same drivers will do OK for W10
briand
Re: (windows 10
« Reply #7 on: May 26, 2016, 07:34:34 PM »
I promise this is the last question when I download the software should the usb cable be unplugged from the navbox
Thanks Alan
Re: (windows 10
« Reply #8 on: May 26, 2016, 08:54:36 PM »
Yes leave it unplugged until you have installed the software and the driver
briand
Re: (windows 10
« Reply #9 on: May 26, 2016, 09:00:46 PM »
Re: (windows 10
« Reply #10 on: May 27, 2016, 07:28:10 AM »
Brian,
As peer the driver instructions in the first post
Instructions:
briand
Re: (windows 10
« Reply #11 on: May 27, 2016, 08:16:26 AM »
Thanks again Alan
N9JIG
  • ANRB, too many radios and an understanding wife!
    • CARMA, the Chicago Area Radio Monitoring Association
Re: (windows 10
« Reply #12 on: June 06, 2016, 12:41:47 PM »
Alan:
Do you know when/if Windows 10 certified drivers will be released? In order to get it to load on Windows 10 I had to turn off Driver Signature Enforcement.
Re: (windows 10
« Reply #13 on: June 06, 2016, 03:22:03 PM »
No idea if they will get them certified.
N9JIG
Re: (windows 10
« Reply #14 on: June 08, 2016, 06:56:31 PM »
I contacted Support and they said they are working on them. They should be available soon.
