airnav team
Started by Airmad, April 30, 2008, 10:44:24 PM
Airmad
Just out of interest why are some aircraft landing off line to centre of runway as this busy moment at (egnx) shows. Also can you please put my mind at rest by answering me on (Airmad time format). Just to make a good product a Great one. This is not a complaint
but let's get things right. Tony
[attachment deleted by admin]
Hi Tony
This has been discussed on other threads  - it's down to inaccuracies in the indivual aircraft's equipment - it's consistent per aircraft, and it's not a RadarBox problem.
If you watch the same aircraft at other airports, you will probably see the same deviation. Other aircraft landing at the same airport will normally be seen to be landing on the centreline.
Hope that answers the question :-)
Airmad
#2
Thank you very much (Rod) for info on centre line. just waiting for answer on time format
Time format can you explain?
Sorry we do try and read all the posts but this is not a direct support forum.
Airmad
Quote from: AirNav Support on May 01, 2008, 07:29:32 AM
(look at mylog) set as Today Reads from date/time 12:00:00  todate 11:59:00. That to me is Midday should it not read 00:00;00 to 23:59:00 if time is GMT/UTC Hope you now understand. Tony
Ok no proble, we will put it forward as a suggestion. Can't remember off the top of my head whether the database values are in 24hour format and its just displayed in 12 hour format.
steveb25
Database  can handle 24hr and obviously 12hr format
Airmad
Quote from: AirNav Support on May 01, 2008, 09:49:56 AM
Thank you. It will be less confusing, i think.
