Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
AirNav Systems Forum
AirNav Radar Discussion
(Moderator:
Signal Problems
« previous
next »
Print
Pages: [
1
Author
Topic: Signal Problems (Read 9143 times)
thedouth
New Member
Signal Problems
on:
August 19, 2016, 02:57:33 PM »
I have recently moved house . I have set up my radarbox on the second floor next to a window . I pick up hardly any planes unless the window is wide open . The window frames are steel . Would this affect my antenna signal . Any ideas please
Logged
Hero Member
Re: Signal Problems
Reply #1 on:
August 19, 2016, 03:34:41 PM »
A window frame made of steel alone won't be a problem. Unfortunately you might have a window which had been coated with a thin layer of metal to block out UV and IR radiation. This is done to reduce the "solar heating" of rooms during the summer and to keep the IR radiation in the room during the winter. Disadvantage: it blocks almost all VHF transmissions too.
Logged
thedouth
New Member
Re: Signal Problems
Reply #2 on:
August 19, 2016, 03:52:20 PM »
Could I put the antenna onto the outside of the frame and use the steel as a plate, that way the window wont have to stay wide open
Logged
Moderator
Hero Member
Re: Signal Problems
Reply #3 on:
August 19, 2016, 04:00:27 PM »
That should be OK as long as the antenna is vertical, give it a go and see how it goes
Logged
thedouth
New Member
Re: Signal Problems
Reply #4 on:
August 19, 2016, 04:05:40 PM »
Thanks Alan, I shall give it a go . How about being on the inside of the frame, Would that work also
Logged
Hero Member
Re: Signal Problems
Reply #5 on:
August 19, 2016, 04:20:23 PM »
I fear that putting it inside will result in no airframes received. But I would try it out anyway, just in case.
Logged
thedouth
New Member
Re: Signal Problems
Reply #6 on:
August 19, 2016, 04:40:30 PM »
Thanks for your replies Ingo. I will try inside and outside
Ben
Logged
thedouth
New Member
Re: Signal Problems
Reply #7 on:
August 20, 2016, 08:07:06 AM »
Just to confirm that it works fine with the antenna on the outside on the window frame. Thanks for your input
Ben
Logged
Moderator
Hero Member
Re: Signal Problems
Reply #8 on:
August 20, 2016, 08:18:44 AM »
Thanks for advising, just remember that the antenna is not weather resistant, it doesn't like rain
Logged
thedouth
New Member
Re: Signal Problems
Reply #9 on:
August 20, 2016, 08:38:02 AM »
Don't worry I don't leave it out there lol
Ben
Logged
Print
Pages: [
1
« previous
next »
(Moderator:
Signal Problems
