Problems exporting to CSV
Started by wheeler, May 01, 2008, 01:23:26 PM
wheeler
Hi again
Having a little problem with exporting files to exel,todays date no prob but in MYLOG when i call up yesterdays date you can see it as yesterdays file in the MYLOG but when i export it,it exports todays log not yesterdays with todays date on it as i like to look a day behind sometimes
Or am i being stupid and not doing something i should i have changed the variables to yesterdays date
please help
Quote from: wheeler on May 01, 2008, 01:23:26 PM
Hi again
please help
Wheeler,
Just to clarify, are you using MyLog | Tools | Export to CSV, or are you using MyLog | Reporter | Testerday's Entries | Generate?
Can you post a bit of your exported file to the forum here - just copy and past into the post.
wheeler
Hi thanks for the reply i have been using mylog repoerter generate then export to csv
but as i said when you look at the report in my log its there but when you export it to csv it puts todays date
Here is a bit of the log if it helps
3C656C                                     2008/04/30 06:58:10
   A2F13A                                     2008/04/30 19:36:33
* C0773A                                     2008/04/30 03:56:20
* AC3B9C                                     2008/04/30 11:10:00
* 4055FF                                     2008/04/30 11:16:00
   AE0681  58-0086 K35R                       2008/04/30 18:56:23
   AE0264  60-0355 K35R  USA - Air Force      2008/04/30 07:43:00
* AE07D5  92-3291 C17   USA - Air Force      2008/04/30 13:11:00
* AE07FC  98-0050 C17   USA - Air Force      2008/04/30 03:53:40
* 76CCCD  9V-SFM  B744  Singapore Airline... 2008/04/30 06:37:50
   06A019  A7-ACB  A332  Qatar Airways        2008/04/30 07:52:20
   06A052  A7-BAA  B77W  Qatar Airways        2008/04/30 09:33:00
   C02201  C-FMWU  B763  Air Canada           2008/04/30 05:26:10
   C05681  C-GGTS  A332  Air Transat          2008/04/30 07:47:50
   C058B0  C-GHPF  B763  Air Canada           2008/04/30 07:07:10
* C087F1  C-GZMM  B763  Zoom Airlines        2008/04/30 09:55:20
* 02007D  CN-ROR  B738  Royal Air Maroc      2008/04/30 18:36:23
   4911A4  CS-DMD  BE4X  Untitled (NetJets... 2008/04/30 15:21:30
* 4911CD  CS-DNM  H25X  Untitled (NetJets... 2008/04/30 19:38:53
   49124A  CS-DRJ  H25X  Untitled (NetJets... 2008/04/30 17:24:40
* 4950CB  CS-TFK  B752  Euro Atlantic Air... 2008/04/30 13:10:20
   495145  CS-TJE  A321  TAP Portugal         2008/04/30 18:38:13
   495147  CS-TJG  A321  TAP Portugal         2008/04/30 11:49:30
   495191  CS-TLQ  B763  Euro Atlantic Air... 2008/04/30 13:05:00
   4951B7  CS-TMW  A320  TAP Portugal         2008/04/30 16:27:40
as you can see yesterdays date buy not when exported
many thanks wheeler
wheeler
i have just looked at the export to notepad and all looks fine there but i want it to open uo in exel oo this is getting a bit beyond me all this i will confuse all in a min maybe its the header date thats confusing me
cheers wheeler
#4
Quote from: wheeler on May 01, 2008, 02:35:12 PM
cheers wheeler
The export to CSV only works with MyLog and not Reporter.  What you have posted is the report generated using Reporter - which only give options of Today and Yesterday, not the MyLog listing.
So:
- You can only generate a "Report" for Today and Yesterday.  Don't forget to click "Generate" after selecting Today or Yesterday.
- The generated report can be saved to file as a txt file and opened with Notepad
- You can only export MyLog to a csv file, although you can choose many more periods other than Today and Yesterday.  You can also use the filers to see particular aircraft
- The MyLog CSV file can be opened using Excel using File | Open
I hope that this makes things a little clearer :-)
P.S. See pages 27-29 in the RadarBox PDF Manual.
wheeler
Ok i think i understand but can you tell me what the difference between mylog and reporter
i think this is where i am getting confused
cheers for that
wheeler     oooooo there are some clever people out there but not me
Quote from: wheeler on May 01, 2008, 03:42:50 PM
cheers for that
No problem,
Reporter is a "quick and dirty" way of generating a report of all the traffic you picked up today or yesterday.  This can easily be emailed either manually or automatically using the buttons on the reporter window.
MyLog is much cleverer, as you can see traffic for any period of time, and you can use filters to see only the traffic you are interested in.
Try putting the following in the MyLog Filters
ModeS = 43C*
Then click Filter - you will see all the British Military aircraft you have detected.  Use the filters on the next line down to show All Time, Yesterday, Last Week etc
You can't print from this filtered list, but when you use Tools | Export to CSV, the filtered file will export and then you will get a pop-up which offers to open the CSV file - if you click Yes and you have Excel installed, then Excel opens and displays the file.
Now you can sort or print in Excel.  You can do all sorts of other clever stuff in Excel too - so if you exported all your contacts rather than just the 43C* aircraft, then you can filter and sort in Excel.
Just have a play, you can't break anything :-)
wheeler
Many thanks for that
why does it put two dates in the log here is a copy in notepad
i also run a program to keep check on what flights i have seen from this location thts why i export the file so i can mark it as seen or spotted i want to keep track of what is around up there.
Here is what i mean about the dates and this is done in mylog
2008/04/30 21:41:23    2008/04/23 16:54:39,Boeing 737-436,B734,CSA - Czech Airlines,49DCF8,Czech Republic,OK-WGX,         X
,2008/04/30 23:54:16,2008/04/23 17:12:16,Airbus A319-111,A319,EasyJet Airline,400CD4,United Kingdom,G-EZIU,         S
,2008/04/30 17:30:20,2008/04/23 17:16:36,Airbus A319-111,A319,EasyJet Airline,400EFC,United Kingdom,G-EZBB,
,2008/04/30 15:14:30,2008/04/23 17:22:16,Piper PA-32-300 Cherokee Six,...,Untitled,401230,United Kingdom,G-AVUZ,
,2008/04/30 22:10:23,2008/04/23 17:22:22,Boeing 737-8AS,B738,Ryanair,4CA1B3,Ireland,EI-DAD,
,2008/04/30 09:38:30,2008/04/23 17:26:56,,null,,4784A1,Norway,null,
,2008/04/30 16:49:40,2008/04/23 17:38:46,Airbus A330-343X,A333,Untitled (Iberworld Airlines),342553,Spain,F-WWKO,
,2008/04/30 14:11:00,2008/04/23 17:38:58,Boeing 737-37Q,B733,Bmibaby,40069C,United Kingdom,G-ODSK,
,2008/04/30 22:48:23,2008/04/23 17:39:46,Airbus A320-214,A320,Aer Lingus,4CA281,Ireland,EI-DEI,
,2008/04/30 08:47:10,2008/04/23 17:45:15,De Havilland DHC8-402,DH8D,Flybe Ltd,401050,United Kingdom,G-JECT,
,2008/04/30 10:24:50,2008/04/23 17:46:41,Boeing 737-8AS,B738,36570,4CA64A,Ireland,EI-DYH,
,2008/04/30 15:57:20,2008/04/23 17:48:29,Airbus A319-111,A319,EasyJet Airline,400FDA,United Kingdom,G-EZBI,
,2008/04/30 08:01:00,2008/04/23 17:51:32,Boeing 737-8AS,B738,Ryanair,4CA2A7,Ireland,EI-DHS,
,2008/04/30 21:54:43,2008/04/23 17:52:37,Boeing 737-8AS,B738,Ryanair,4CA266,Ireland,EI-DHJ,
,2008/04/30 21:57:23,2008/04/23 17:54:09,Airbus A319-111,A319,EasyJet Airline,400C43,United Kingdom,G-EZIA,
,2008/04/30 11:49:30,2008/04/23 17:59:24,Airbus A321-211,A321,TAP Portugal,495147,Portugal,CS-TJG,
,2008/04/30 18:21:33,2008/04/23 18:06:04,Boeing 757-3CQ,B753,Thomas Cook Airlines,4008E0,United Kingdom,G-JMAA,
The dates are first time/date picked up and last time/date picked up.
wheeler
Oh you are awfull but i like it
thanks for all the help
Cheers wheeler
