Invalid Floating Point operation error when resizing window
Started by N9JIG, October 06, 2016, 03:32:55 AM
N9JIG
I have ANRB 6.00.000 installed on my Windows 10 machine. I also have .net framework 4.6.1 installed.
When I resize the application window I get an error message that says "Invalid floating point operation".   Below is the first part of the error (I saved the entire error message if needed.)
This occurs anytime I resize the window. I can click on the window to reduce the size and again to make it full screen again but I cannot set it to a desired size, it is either full screen or a tiny window that is of no use at all.
Any ideas?
(PS: It reports as Windows Vista but it is really Windows 10Pro...)
EurekaLog 6.0.18
Application:
  1.1 Start Date      : Wed, 5 Oct 2016 20:26:09 -0700
  1.2 Name/Description: ANRB.exe
  1.3 Version Number  : 1.0.0.1421
  1.4 Parameters      :
  1.5 Compilation Date: Wed, 4 Nov 2015 03:05:04 -0700
  1.6 Up Time         : 37 seconds
Exception:
  2.1 Date          : Wed, 5 Oct 2016 20:26:46 -0700
  2.2 Address       : 008CA736
  2.3 Module Name   : ANRB.exe
  2.4 Module Version: 1.0.0.1421
  2.5 Type          : EInvalidOp
  2.6 Message       : Invalid floating point operation.
  2.7 ID            : 11D7
  2.8 Count         : 1
  2.9 Status        : New
  2.10 Note         :
User:
  3.1 ID        : Rich
  3.2 Name      :
  3.3 Email     :
  3.4 Company   :
  3.5 Privileges: SeShutdownPrivilege             - OFF
                  SeChangeNotifyPrivilege         - ON
                  SeUndockPrivilege               - OFF
                  SeIncreaseWorkingSetPrivilege   - OFF
                  SeTimeZonePrivilege             - OFF
Active Controls:
  4.1 Form Class   : Tmainform
  4.2 Form Text    : AirNav RadarBox - 6.00.000  - [United States.ml4]
  4.3 Control Class: TglobForm
  4.4 Control Text : United States.ml4
Computer:
  5.1 Name          : W7
  5.2 Total Memory  : 9207 Mb
  5.3 Free Memory   : 6284 Mb
  5.4 Total Disk    : 953.42 Gb
  5.5 Free Disk     : 846.3 Gb
  5.6 System Up Time: 41 minutes, 4 seconds
  5.7 Processor     : Intel(R) Core(TM) i7 CPU         920  @ 2.67GHz
  5.8 Display Mode  : 1920 x 1080, 32 bit
  5.9 Display DPI   : 96
  5.10 Video Card   : NVIDIA GeForce GTS 250 (driver 9.18.13.4195 - RAM 1024 MB)
  5.11 Printer      : Microsoft Print To PDF (driver 10.0.14393.0)
Operating System:
  6.1 Type    : Microsoft Windows Vista (64 bit)
  6.2 Build # : 9200
  6.3 Update  :
  6.4 Language: English
  6.5 Charset : 0
As far as I am aware you have never been able to resize the window from full screen although quite happy to be corrected.
N9JIG
I will submit it to Support and see what they say. I used to be able to change the size in the past but it has been a while...
Thanks Alan!
coastal air
I've been having the same issue - as soon as I try to resize the little tiny window to a more usable size I get the same message if the double ended mouse arrow goes outside the border of the program window and its also very "jerky" while stretching it.Have found that by resizing it extreemly slowly in the very corners of the window it can be done,however this has to be done every time the program is started as it will not save the new size.It seems to stretch quite happilly until I reaching the map section then becomes "jerky " as though the graphics are not loading quick enough.
