RB network
Started by wheeler, May 06, 2008, 06:58:54 PM
wheeler
When you have the RB connected to the network and you want to see whats going on in other parts of the UK is it possible to pick up the tower at various airports..
this might be a stupid question
cheers wheeler
steveb25
Depend how close the other users are to airports.
The frequency being used is very high (Radar freq believe it or not) and this means that apart from sparodic bounce the received signals will be line of site only.
What we need is some door-to-door salesmen visiting all the houses near to airports, then when those users share their data we'll have excellent coverage of all the airports :-)
steveb25
Boy wouldn't that be nice.
Do we get any commision on the sales?
#4
We really need a couple at Toulouse and Seatlle to keep an eye on the new aircraft being built and tested.
Or in the case of the Ethiad A345, tested into a wall.
steveb25
Hadn't thought of that one
JimK
Well as soon as WIMO get me the Mast Amp I'll shimmy up on to the roof. You should then get the ground traffic at Heathrow.
I could see it with the AirNAV twig hanging out of the Velux window. Or at least the eastern edge. With the 1090 on the roof and uncluttered view we should get a whole lot more.
Mast AMP wont be with me until the end of May though. :-(
Jim
Twickenham
London
steveb25
Roll on the end of May
Jim did you order direct from WIMO?
wheeler
No No No you all miss the point you can look on the net and listen to various stations fire ambulance etc the RB d/loads the picture from the net it gets the info from other people on the network i was just wondering if it was possible to pick up various ATC VIA the net as and when you are looking at other lacations
mm justa thought
wheeler
steveb25
Sorry Wheeler, you have completely lost me
Wheeler - if you mean live ATC voice transmissions, there was a thread here about various sites for this some time back, but I can't find it at the moment!
Anybody remember what it was??
wheeler
Hi Rod you got it what i am on about, i have been looking at all the posts with the search thingy and nothing so i was just pondering really if it could be done
thanks for that,look forward to a reply from you if you find the thread
cheers wheeler
I just did a quick Google for "live ATC" and there are lots of sites there where you can listen to it - just heard a bit from Oakland, california, for example, via http://www.liveatc.net/.
I guess you'll find lots of sites out there for many airports.
Hope that helps.
Airmad
Quote from: wheeler on May 06, 2008, 06:58:54 PM
cheers wheeler
Wheeler Try this site. but you will need a Vhf radio to pick them up http://www.ajpotts.fsnet.co.uk/air.html
steveb25
Wheeler if you are looking for liveATC from UK airports I don't think you will find any. Unlike the USA it is not permitted/illegal here in good old UK and therefore there are no UK airport on these sites.
Its the same way that it is illegal to listen to ATC on your scanner!
