Author Topic: Micro RadarBox  (Read 11901 times)
jacobite
Micro RadarBox
« on: October 21, 2016, 09:43:44 AM »
Hi all, has anyone on the forum used the Micro RadarBox? I am wondering if I can get a longer antenna cable as what came with the new one I have purchased is not long enough to be put out side.
Any help would be much appreciated.
Re: Micro RadarBox
« Reply #1 on: October 21, 2016, 03:55:23 PM »
Hi Ian,
if you purchase a "male MCX" to "female SMA" adapter you shall be able to connect the micro Radarbox donlge Receiver to your old/existing antenna equipment.
this one for example: https://www.amazon.com/DHT-Electronics-coaxial-adadpter-female/dp/B00CWZDCUQ/ref=sr_1_2?ie=UTF8&qid=1477065180&sr=8-2&keywords=male+MCX+to+female+SMA+adapter
I'm using one of these adapters with my dongle receiver.
Regards Ingo
« Last Edit: October 21, 2016, 04:07:57 PM by neroon79 »
Judwin45
Re: Micro RadarBox
« Reply #2 on: October 21, 2016, 04:02:27 PM »
I asked the same question back on October 4th, so I am grateful for the reply, thanks.
Keith
5 miles south of EGDY
jacobite
Re: Micro RadarBox
« Reply #3 on: October 22, 2016, 07:47:31 AM »
Hi Ian,
Regards Ingo
Thanks for the info Ingo
jacobite
Re: Micro RadarBox
« Reply #4 on: October 23, 2016, 12:11:42 PM »
Hi Ingo, At the moment I am using the Micro dongle with the antenna that came with it, it is being used indoors and I cant believe how good it is, maybe its just luck, but I do live right on the coast and I get all the flights that are going over the pond.
Judwin45
Re: Micro RadarBox
« Reply #5 on: October 23, 2016, 12:56:03 PM »
I recently took my Micro Radarbox to a high point using the supplied aerial and got a range of just under 200 miles. Brilliant.
Keith
Re: Micro RadarBox
« Reply #6 on: October 23, 2016, 06:34:54 PM »
Hi Ian, in the beginning I was quite sceptical about the use of these SDR dongles too. But after some intense tests in various situations and connected to various antenna setups I have decomissioned my "mobile" classic radarbox hardware. Only my 24/7 server used to get logfiles to investigate unknown airframes is still running with the classic hardware for reliability reasons. In all other cases I'm using SDR dongles like micro radarbox.
« Last Edit: October 23, 2016, 06:38:40 PM by neroon79 »
Judwin45
Re: Micro RadarBox
« Reply #7 on: October 24, 2016, 02:15:35 PM »
Hi Ian
For information, I looked at the link that Ingo suggested and although the basic price looked reasonable because it was shipped from the US the postage was £9 which took the total price to £12.
I subsequently found a UK supplier 'RS Components Ltd' in Corby Northamptonshire.
Their stock number is 7619951. I ordered one late on Friday and it has just arrived.
My Micro box now connects to the aerial supplied with my original RadarBox and seems to work fine.
Keith
Keith
