RB Crashes
Started by wheeler, May 08, 2008, 07:08:20 PM
wheeler
Hi its me again
can someone please tell me why RB crashes when i switch from full screen mode back to normal.iget the dreaded NOT RESPONDING message.
thanks wheeler
Rockeyes
I often cannot get the full screen after I have minimised the RB onto the toolbar and often get a 1cm wide flash across the screen when switching from full map mode to the start up page. The only cure so far is to shut down the program and restart. Not sure if they are linked.
We have heard of a few issues with some customers with high resoution screens, and then going from full screen back causing issues.
It will be fixed in the next version.
Rockeyes
Thanks AirNav.
Monsieur Wheeler. Out of interest how are you switching from full screen and back?
wheeler
Ok Monsieur Rockeyes
i use the ESC key is there another way ?
can you shed some light on it
cheers wheeler
and also a big thanks to the airnav team they always seem to be there when do you think the new version will be out ??
