MyLog Flight Search
Started by RodBearden, May 14, 2008, 10:29:29 AM
Am I being daft?
I can't seem to find a way of searching for a particular flight ID - I want to search for all the different aircraft used on a particular flight.
Can it be done?
No, it can't be done from within MyLog.
It can be done using an external SQLite viewer such as SQLite Database Browser or SQL Maestro.
I'm not going mad, then - thanks, Allocator!
AirNav - can we please have this feature built in to the next version (or the one after that?)
Here is a small section of exported data from SQL Maestro - txt file attached.
It shows that all the data is there, it's just a case of getting at it :-)
[attachment deleted by admin]
It'll be easy for AirNav to do it, then!  :-)
nortonbeak
This task would be straightforward for Acars Analyser.
I suspect, unfortunately, that the format of MyLog is not suitable for export to Acars Analyser.
