Nasty Network Flights problem
Started by RodBearden, May 15, 2008, 03:57:43 PM
Hi - Just turned on the computer and got a problem with network flights - closed down RB and restarted, problem persists.
Many Flight ID's are showing ine the ModeS column, Altitudes are showing in the Flight ID column.
Screenshot attached
HELP!
[attachment deleted by admin]
Rod,
We've seen this before when the AirNav server had a bit of an off day - I've had RB running for an hour since I got home and the Network flights look OK now.  How's it looking at your end?
Maybe AirNav are looking at the photo downlad issue?
Forget what I said, the problem still exists.
AirNav Support - Help!
It's still happening to me too - I wonder if a radarbox somewhere is sending duff info to the server.
I do hope it isn't going to corrupt any databases - I don't expect it will, as it's only showing on network flights, but the relationships between databases seem to be a bit unclear to us (at least, to me), so fingers crossed!
AirNav - anything to report??
It's all gone very quiet round here - any news, AirNav? I've still got the problem.
I guess that they are taking an in-depth look :-)
Server is fine but its being sent wrong data from one our test builds of RadarBox. We will rectify it, please bear with us.
It should only affect a certain amount of flights in that RadarBoxes range that its sharing.
Blimey - I guessed right!
Perhaps you could just stop it sharing data until you fix it, AirNav :-)
Then again, - just a thought - perhaps a validation routine on the server might help.
Problem gone away - thanks guys!
