Alerts
Started by pwfu, May 20, 2008, 10:56:08 AM
pwfu
Hi all,
Been using my box for a couple of weeks now, took it to the States with me last week on a work trip and was pretty useful for a few bits.
Anyway, I've set up a load of alerts, but have a couple of quick questions:
Sometimes an alert pops up on the screen, but there's no details of what it's alerting me to
Is there a way of making the color of the aircraft change on the map to indicate that it's an aircraft that I've set up an alert for?
Thanks!
Hi C510,
It does look like the first time you get an alert, the pop-up window only says "Alert" - I think that it's OK for subsequent alerts, but I haven't really tested this.
I tend to look at the list of alerts in the window at the bottom of the Alerts setting tab to see what's happened while I've been away from the computer.
There is no way to have the aircraft generating the alert change colour on the map.  This would only work for the last alert anyway, otherwise you would end up with a whole bunch of aircraft changing colour.  I look at the Alert list, then use the "Quick Filters" if I need to to find the aircraft.
