server
Started by wheeler, May 22, 2008, 01:33:51 PM
wheeler
Is there a prob with the server as i can't rec any flights via network,and when ever i try to do anything like tools/interface etc it all locks up and have to close the program should it keep doing this, still rec flights live but if i try to do anything it just locks uk ???
cheers wheeler
I am starting to wish that AirNav would be a bit more forthcoming about server outages - it seems that we users always have to ask what's going on.
AirNav - could you please START threads to notify us about significant outages? It would save us all being paranoid about our internet connections!
I'm assuming that we are currently experiencing one now!
This issue is being investigated.
If we are conducting maintenance on the server it usually means which the server will be down for a few mins to about 15 minutes to the max. These are minor disruptions and done at low usage times and we don't think they need to be advised (sometimes they done immediately).
Other outages as today's are issues relating to the server running and then take a vast amount of our time to find and rectify the cause. Again sometimes it may be a very quick and the server is back up within a few minutes. If its a minor fix its easy for us to fix it and saves time having to write a post about it. If its serious we are all busy running around trying to fix it :) (Catch 22 situation)
We do though hope to have a server status page in the future.
"It would save us all being paranoid about our internet connections! " :). If everything else on the net works then assume the server is down.
Fair enough - thanks for the quick reply!
The Network looks OK now.
Thanks Support :-)
wheeler
Thanks Mr AIRNAV for the quick reply but it would be nice to know if there is a problem.
Because when ever there is a problem we all think it must be our selves so we start messing getting more frustrated when it still don't work start tho think where the hammer is only to find out its not our problem
cheers wheeler
Deadcalm
For what it's worth, I think any scheduled server maintenance should be broadcast to the users as a matter of courtesy, however short the forecast duration.  It would only take seconds to post a warning of your intentions, even if the duration was so brief as to be unnoticed.  It's a good customer relations policy.
DC
wheeler,
As mentioned we hope to add a server status page in the future.
Deadcalm,
We would agree with you if its longer than 20 mins, but a lot (95%) our maintenance means a restart and its less than 2 minutes downtime. You would get bored of the posts :)
