Author Topic: 164 in my flights but only one on the map  (Read 15505 times)
2E0BTX
« on: March 28, 2017, 08:49:35 PM »
Hi ALL
As above my flights are showing 164 flights but their are only 2 aircraft in my map window ,
ple3ase in easy to read terms whats wrong ? is my box duff ?
ive tried all versions of the software its the same on all
pete
Re: 164 in my flights but only one on the map
« Reply #1 on: March 29, 2017, 04:30:05 AM »
As you have tried all software versions I guess you are using the classic hardware.
Is your box ( classic hardware) duff: not necessarily
The aircraft on the map, what is their distance to your station? If they more than 100nm by 150nm away,  it would be very uncommon for a deaf box. Also the quite high count of received airframes indicates, that the box is ok.
If you have had many aircraft on the map on day 1 and only 2 on day two and the maximum reception range has reduced to a few nautical miles. Further the total count of received airframes has reduced significantly reduced. Than the possibilty,  that box went deaf is very high.
If this isn't the case, here are some other possibilties:
You have two airframes on the map. How many aircraft have a small globe on left side next to the status column? The count should be more or less equal to the number of aircraft on the map. If there is a huge difference there might be an issue with the software interface for grafic content. If that is the case I've no idea how to fix it.
Not all aircraft are equipped with ADS-B. But only ADS-B equipped airframes will show up on the map. Usually all new commercial airframes ( Boeing,  Airbus, in less count Bombardier, Embraer) are equipped with ADS-B transmitters.
My station for example:
Late evening, early morning: 90% ADS-B aircraft
Daytima average work day: 70% ADS-B aircraft
Holidays/weekend an great weather: 50% and less ADS-B aircraft due to many small aircraft only equipped with mode s transponders
If able,  please attach a screenshot of your myflights list.
Regards Ingo
« Reply #2 on: March 29, 2017, 07:51:14 AM »
Pete
As Ingo states with 164 aircraft in your myflights I wouldn't think your box is duff, quite the opposite.  Have you by chance zoomed right in and have not noted it, try using the - button on the second top line a few times to zoom out to see if you can see more aircraft
« Reply #3 on: March 30, 2017, 05:48:22 PM »
You sorted or still having problems Pete
FACTflights
  • Amateur Radio is my hobby.
« Reply #4 on: April 01, 2017, 02:43:28 PM »
Are you switched to "My Flights" and "Show All" ?
John
ZS1AGH
No HF antennae at the moment.
john262
« Reply #5 on: June 23, 2017, 10:13:46 AM »
hi I have got the same problem just installed on a win 10 machine  running great then all the icons vanished the funny thing is that if I highlight the a/c in my flights I get the to/from track and a circle for the postion
« Reply #6 on: June 23, 2017, 11:54:26 AM »
I presume that you used the latest W10 drivers in your install
Also where on the computer did you install too, did you use programme files location or c:\Airnav
john262
« Reply #7 on: June 23, 2017, 01:18:36 PM »
All fixed now thanks I just did a reboot and they all turned there stealth off
« Reply #8 on: June 23, 2017, 02:16:30 PM »
Wonderful things computers
