Author Topic: Unable to install RB24 on my RPi  (Read 37369 times)
Millsey
« on: May 06, 2017, 04:56:48 PM »
I tried to install RB24 to an existing RPi running Dump1090 which failed. I sent a request for help via the contact page and then to [email protected]. I got an automatic reply on May 1st, but have heard nothing since. If I try to login on the link provided all it says is that my email is already taken ?
Getting a bit confused as to why it is not possible to get an answer or login when I can here ?
John
Re: Unable to install RB24 on my RPi
« Reply #1 on: May 06, 2017, 05:39:53 PM »
I presume that you followed https://www.radarbox24.com/raspberry-pi  and https://www.radarbox24.com/blog/radarbox24-raspberry-pi-client
I will contact support and ask that they contact you as they don't look in here very often
« Last Edit: May 06, 2017, 05:43:59 PM by Runway 31 »
anorak
« Reply #2 on: May 06, 2017, 06:29:55 PM »
Could I suggest that we keep Raspberry issues to the thread that is running.
http://www.airnavsystems.com/forum/index.php?topic=8767.0
Dave.
Dave. Exmoor, North Devon.
« Reply #3 on: May 06, 2017, 09:09:02 PM »
Thats 3 or 4 running now Dave
Millsey
« Reply #4 on: May 07, 2017, 07:46:09 AM »
Thanks Alan, my ticket number is 8254 btw. Yes I followed instructions, but got this message at the end:
The following packages have unmet dependencies:
rbfeeder : Depends: libc6 (>= 2.17) but 2.13-38+rpi2+deb7u3 is to be installed
            Depends: librtlsdr0 but it is not installable
            Depends: systemd but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
bash: line 24: systemctl: command not found
bash: line 28: systemctl: command not found
My existing system is still running fine feeding a private VRS web site with data. I didn't post in the RPi3 thread as mine is a RPi2, and being new I guess I should have looked further at the forum first, sorry.
John
« Reply #5 on: May 07, 2017, 08:18:14 AM »
Sorry means nothing to me John
I have emailed support and asked them to contact you
Millsey
« Reply #6 on: May 07, 2017, 10:00:56 AM »
Me neither Alan,
John
  • CYYZ - Toronto
« Reply #7 on: May 07, 2017, 03:01:14 PM »
Try following:
Code: [Select]
sudo dpkg --configure -a
Code: [Select]
sudo apt-get install -f
Then try installation again
Code: [Select]
« Last Edit: May 07, 2017, 03:12:36 PM by abcd567 »
anorak
« Reply #8 on: May 07, 2017, 04:32:42 PM »
Hi a, my set up keeps going offline after a few minutes and I`ve no idea why. Running a NooElec dongle feeding another site that seems to be working fine, laptop getting tired so want to feed 24/7 via the Raspberry.
Cheers, Dave.
  • CYYZ - Toronto
« Reply #9 on: May 07, 2017, 05:37:19 PM »
Cheers, Dave.
1) Give this command in SSH console:
Code: [Select]
cat /etc/rbfeeder.ini
2) Post output of above command in this thread.
Note: remove you sharing key before you submit the post.
« Reply #10 on: May 07, 2017, 05:43:15 PM »
Thanks for your advice ABD567 I have no idea on this
Millsey
« Reply #11 on: May 07, 2017, 05:50:01 PM »
Try following:
Code: [Select]
Code: [Select]
Code: [Select]
Thanks for the info abcd567, I've just tried your suggestions but got this message after running the first two lines:
pi@raspberrypi ~ $ sudo dpkg --configure -a
pi@raspberrypi ~ $ sudo apt-get install -f
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 191 not upgraded.
Same message after running the install line as I posted earlier
Know you from FR24 Forum I believe ?
John
« Last Edit: May 07, 2017, 06:42:28 PM by Millsey »
  • CYYZ - Toronto
« Reply #12 on: May 07, 2017, 06:31:45 PM »
When you give cat /etc/rbfeeder.ini command, the contents of file rbfeeder.ini will be displayed. Copy that output from SSH window, and paste in your reply to this thread.
For your guidance, I am posting below the output of the cat /etc/rbfeeder.ini for my RPi. (I have replaced my actual sharing key by xxxxxxxxxxxxxxx ).
This is the setting which works ok for me, as before installing rbfeeder, I already had some version of dump1090 running for feeding other sites.
Code: [Select]
[client]
network_mode=true
key= xxxxxxxxxxxxxxxxxxxxxxxxxx
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
  • CYYZ - Toronto
« Reply #13 on: May 07, 2017, 08:21:12 PM »
I had dump1090-fa already installed before I installed RB Feeder
Millsey
« Reply #14 on: May 08, 2017, 10:47:45 AM »
Hi again abcd567, I wonder if you noticed I edited my last post with updated information after I tried your suggestion ?
John
