AirNav Radar => AirNav Radar Discussion => Topic started by: orkney on July 22, 2012, 07:26:17 PM
Title: Database Update Requests
Post by: orkney on July 22, 2012, 07:26:17 PM
Hello
This is a new Database Update Requests thread since the old one is now large and unwieldy so has been locked.
Thank you in advance for your requests.
Andrew
Title: Re: Database Update Requests
Post by: 54901 - Jim on July 23, 2012, 12:27:48 AM
Here's another one from today's log ...
AD0CF5 / N94Y / VTUR / Dawson Tony/Guin Arlon Questair 20 / Q V Ventures Inc / 0044
Thanks!
Post by: jim_stockwell on July 23, 2012, 09:43:52 AM
God morning Andrew
Not populating and leaving Luton, I think,  this morning was E48C2D which Gatwick AS says is E135 PT-TRM C/N 14501148
Jim
Post by: X on July 23, 2012, 11:19:06 AM
Descending into area at 0115 today and not populating
* 400151                                                              2012/07/23 01:12:00
X
Post by: Runway 31 on July 23, 2012, 11:39:54 AM
Thanks again Jim
Post by: Runway 31 on July 23, 2012, 11:44:49 AM
Thanks Jim
Post by: Runway 31 on July 23, 2012, 11:49:02 AM
God knows what is using that code X, its never been issued by CAA as far as I can see
Post by: diddyboy on July 23, 2012, 01:57:55 PM
Hi X/Alan
I had 4001E1 VT-PPA at the pit at 00:02, so could be another miscode of this one as i haven't had 400151 showing on my box at all.
Neil
Post by: diddyboy on July 23, 2012, 02:06:42 PM
Also had the following unknown's yesterday in the sandpit. Is this another code for EP-LCE
* 734064                                                              2012/07/22 10:11:57
* 734064                                                              2012/07/22 18:52:12
C05FE8  AZAZ0909                                              2012/07/22 17:07:22
Neil
Post by: Runway 31 on July 23, 2012, 02:12:08 PM
Hi Neil
Still nothing comes up for 400151.  I note you received 400E1E an hour or so before X noted 400151 descending in the pit area.
Post by: X on July 23, 2012, 02:16:47 PM
Alan/Neil
734064 is EP-PCD is an identified a/c which we believe is a neighbourly chopper on oil rig work as with 734068 EP-PCH both picked up regularly.
400151 is a miscode seen in 2011 would suggest a RAF miscode into NHD, my sighting was at 01:15 descending so does not match up with diddyboys time of 00:02.
400151   United Kingdom Mil   UNKNOWN            13/09/2011 00:44
Post by: Runway 31 on July 23, 2012, 02:18:20 PM
Neil,
734064 isnt one of the many associated with EP-LCE, so far!! and was first noted on the network 4/1/2011.  It decodes to EP-PCD which I dont have anything on, possibility I suppose but nothing confirmed.
C05FE8 decodes to C-GKIH, Bell 412EP, c/n 36570 Which left the Canadian Register in March and went to UAE and is so far unidentified.
Post by: diddyboy on July 23, 2012, 02:20:49 PM
X/Alan
Many Thanks for that
Post by: X on July 23, 2012, 02:38:14 PM
Alan/Neil
AZAZ0909 is a regular Il76 flight number into this area used by various machines in the past including 6030A0 UP-I7612, 514033 4L-FFG, 1533FA  RA-78842, 514046 4L-SKL so would suggest a serious miscode
Also while in Russia AZAZ0909 has been used by TU3 150186 RA-65926 and Yak40 1557A0  RA-87968
To complicate things more AZAZ0909 was used recently by US hex A57FCE  AZAZ0909, so I am not sure what the call sign signifies.
X
Post by: X on July 23, 2012, 02:47:40 PM
Quote from: Runway 31 on July 23, 2012, 02:18:20 PM
Alan/Neil
you replied as I was typing re AZAZ0909 but now we have to find out this choppers new reg, but I do wonder if AZAZ0909 is some sort of default code which shows up if flight number not entered by crew due to the multiple types it appears on.
PS 734064 isn't EP-LCE, normally it is low level which is why we believe it is an undentified chopper on rig duties in the Gulf
X
Post by: X on July 23, 2012, 02:57:23 PM
Over the villa just had 60104C outbound DWC, which was an all white IL-76 so possibly a box swop/reuse has occurred with An-12 EK12704?
Possibly this would explain EX-035 all white IL76 not being picked up but EK12704 being in and out!
X
Post by: Runway 31 on July 23, 2012, 03:02:53 PM
Thanks X saw your reply re EL-LCE following my post
I have noted AZAZ at various locations throughout the world and havent a clue as to its significance.
Akan
Post by: flygfantast on July 23, 2012, 05:12:42 PM
Not populating: 8880A0 (Viet Nam), no c/s, 304 msgs, altitude 4550 thru 9900.
Niklas
Post by: Runway 31 on July 23, 2012, 05:36:51 PM
Cant find anything on it Niklas
Post by: Xon on July 23, 2012, 11:39:47 PM
8006E1 VT-IEZ A320 c/n 5231
424568 VQ-BPJ A333 c/n 1328
Post by: Runway 31 on July 24, 2012, 07:21:29 AM
Thanks Xon both already in the d/b
Post by: EK01 on July 24, 2012, 08:43:25 AM
Alan,
Not sure if you already have this information due to problems I had with the last d/b update, but the following Air Nostrum aircraft are currently in storage at Valencia :
EC-GYI c/n 7249
EC-HSH c/n 7466
EC-HTZ c/n 7493
EC-HYG c/n 7529
EC-IAA c/n 7563
EC-IJS c/n 7706
EC-IZP c/n 7950
Post by: Runway 31 on July 24, 2012, 08:50:06 AM
Thanks Ian, guess their duties are being taken over by the ATR fleet
Post by: Xon on July 24, 2012, 11:19:31 AM
Quote from: Runway 31 on July 24, 2012, 07:21:29 AM
Already? It's not public d/b ? I can't see this in newest db or here in "Database Update"
Post by: Runway 31 on July 24, 2012, 11:32:56 AM
Xon,
The details of those aircraft are in the database having been added since the last update.
If you see the aircraft click on it and its details will be downloaded. Alternatively click on populate in Mylog/ Tools and the details will download into your d/b
Post by: Xon on July 24, 2012, 11:39:09 AM
Quote from: Runway 31 on July 24, 2012, 11:32:56 AM
Ok so this data will be published in next DB update? I do not use BaseStation so i can't check hexs with this method, i always checking here on forum + in newest DB.
Post by: Runway 31 on July 24, 2012, 12:01:56 PM
Yes Xon,
The data is in the database already and that being the case will be available to you in next update.  There are too many added, deleted and amended each month to post on here.  Its normally only the ones users note on their screen that come up as unknown that are posted.
Please keep on forwarding any hex codes new to you, your assistance is appreciated
Post by: lebelgepatte on July 24, 2012, 12:05:42 PM
a litlle change:
44b5ad - OO-MMM is not a civil airplane but a militairy airplane of belgium.
can it be change so we detect him as militaiy ?
Post by: Runway 31 on July 24, 2012, 12:20:10 PM
lebelgepatte
44B5AD is OO-MMM, Britten-Norman BN-2A-21 Islander, c/n 468, Royal Belgian Institue of Natural Sciences. It was formerly B-02 of the Belgian Army
Post by: 54901 - Jim on July 24, 2012, 03:35:30 PM
A couple from this morning's log for you, Alan ...
A4D96A / N411SC / BE40 / Hawker 400XP / Seneca Companies / RK-408
A89209 / N651SH / T6 / North American Medore T-6D / Flying Texans and Mustangs Unlimited LLC / 49-3305
Thanks!
Post by: Runway 31 on July 24, 2012, 03:44:02 PM
Thanks Jim, nice to get a Texan
Post by: 54901 - Jim on July 24, 2012, 03:49:18 PM
It's that time of year again, here in Oshkosh! Lots to look at!
Post by: Runway 31 on July 24, 2012, 04:08:31 PM
Enjoy it Jim
Post by: neroon79 on July 24, 2012, 05:14:05 PM
Evening, the unknowns from Yesterday:
200000 ( no allocation, flight id: PTO101, PTO: Pilot Training Network, 2nd time after May 31st 2012)
388ADB (France, no flight id, no further details)
3944FA (France, flight id: AFR1153, decoding error of 3944F2)
3C6DC0 (Germany, no flight id, nothing more)
3C6DC2 (Germany, flight id: DLH6PY, either a decoding error of 3C6DC8 or 3C6DCA)
3D1A84 (Germany, flight id: DEIHG, airframes: D-EIHG C150 Cessna 150 )
3D40FD (Germany, flight id: DEWWB, D-EWWB Boeing PT-13D Kaydet (E75) Private CN:119, Mk1EB May 2011: http://www.myaviation.net/search/photo_search.php?id=02002738 )
3D423C (Germany, flight id: DEXII, nothing more)
3DD3D3 (Germany, no flight id, ex D-HALV)
3EDE68 (Germany, flight id: DKZEM, airframes D-KZEM DG80 DG Flugzeugbau DG-800B Private 8-194B116 )
3FEF61 (Germany, flight id DMOOC, D-MOOC BREZ Aerostyle Breezer Private CN:? source: http://www.daec.de/fileadmin/user_upload/files/2012/luftsportgeraete_buero/kennblaetter/178-11.pdf )
4001A1 (UK, flight id: VPBNO, decoding error of 4001A5)
AE2235 (USA, flight id: RCH278, RCH287, RCH288, RCH: USAF Military Airlift Command unidentified MIL airframe)
MIL List:
3E939E  GAF777
3E99CE  GAF674
3EBAE0  GAF121
3F44BB  SHOCK1
3F71F3  PACK2
3F7E69  HAMMER
3F901D  GAF705
3FAB2C  GAMTVG07
3FADA9  GAF016
3FB6A3  LK01B
That's all from yesterday. Next: unknowns from Sunday
BR Ingo
Post by: 54901 - Jim on July 24, 2012, 05:34:52 PM
Another one for you ...
A3587A / N3143M / CRER / Justin Frank Rans S-7 Courier / W Scott Carpenter / 002
Thanks!
Post by: Runway 31 on July 24, 2012, 05:40:30 PM
Hi Ingo
200000 unkown miscode
388ADB F-PRPM, Jodel D-140C Mousquetaire III, c/n 400
3C6DC0 unknown to me
3D40FD decodes to D-EWWB Boeing PT-13D Kaydet, c/n 75-5659, this is now F-AZSZ
3D423C D-EXII, unknown to me
3DD3D3 D-HALV, Robinson R44 Raven I, c/n 2174, Air Lloyd Deutsche Helicopters
AE2235 decodes to 70-1276, C-130E.  This became 1504 with the Polish Air Force
Post by: neroon79 on July 24, 2012, 05:43:20 PM
Sundays unknowns:
3D1FC6 (Germany, flight id: DEKHA, D-EKHA A210 Aquila AT-01 Luftsportverein Rhein-Main e.V. CN:? http://lsv-rhein-main.de/EKHA.html )
3D2271 (Germany, flight id: DELHH, still no luck with the details)
3D3FE1 (Germany, flight id: DEWLD, nothing more)
3E5402 (Germany, no flight id, nothing more)
3E7D18 (Germany, flight id: DKMOM, noting more)
3FECE4 (Germany, flight id: DMWBS, D-MWBS still no luck with the details)
3FEE75 (Germany, no flight id, D-MKSW still no luck with the details)
3FEEE8 (Germany, flight id: DMZAI, D-MZAI HCH60 Zenair CH602XL Zodiac Private CN:? Mk1EB May 2012: http://www.flugzeugbilder.de/show.php?id=1142210 )
3FF07B (Germany, no flight id, D-MBIG nothing more)
3FF102 (Germany, flight id: DMJSA, still no luck with the details)
3FF165 (Germany, flight id: DMFHD, still no luck with the details)
400520 (UK, flight id: BAW234, decoding error of 400524)
4005E9 (UK, flight id, VIR301, decoding error of 4005ED)
484C40 (Netherlands, flight id: PHTOO, PH-TOO C206 Cessna TU206G Turbo Stationair 6 Private  U20606258 MK1EB March 2012: http://www.abpic.co.uk/photo/1340122/ )
489780 (Poland, no flight id, nothing more)
4A8030 (Sweden, no flight id, nothing more)
That's all from Sunday. Next: Saturday.
Post by: neroon79 on July 24, 2012, 05:47:33 PM
Quote from: Runway 31 on July 24, 2012, 05:40:30 PM
In that case, this page
http://www.deutsches-museum.de/flugwerft/information/aktuell/jubilaeum/fly-in-2012/fly-in-2012-teilnehmer/
indicates that D-EWWB is (now) a PT17
Post by: Runway 31 on July 24, 2012, 05:51:16 PM
Thanks Jim
Post by: Runway 31 on July 24, 2012, 05:54:36 PM
Sorry Ingo,
That link takes me to an error
Post by: neroon79 on July 24, 2012, 06:02:21 PM
Unknowns from Saturday:
3D0529 (Germany, flight id: DEAEZ, D-EAEZ RALL Morane-Saulnier MS-893A Commodore 180 Private 11630 airframes / http://www.three-greens.at/index.php?page=Thread&postID=22327 / http://www.morane.de/k_fotos/D-EAEZ.htm )
3D0973 (Germany, two times without flight id, no more details)
3D2CCD (Germany, flight id: DEPFH, still no luck with the details)
3D3FE1 (Germany, flight id: DEWLD, posted earlier)
3FF10F (Germany, no flight id, D-MJMW still no luck with the details)
4008CE (UK, flight id: MON827, decoding error of 4008CC)
400990 (UK, flight id: BAW863, decoding error of 400980)
4041A6 (UK, flight id: 0X_2FQ, airframes: G-BYLF CH60 Zenair CH-601XL Zodiac)
4BA889 (Turkey, no flight id, nothing more)
That's all from my Back-LOG. Have a nice Evening!
BR Ingo
Post by: neroon79 on July 24, 2012, 06:04:24 PM
Quote from: Runway 31 on July 24, 2012, 05:54:36 PM
Sorry Ingo,
Link altered. Seems it was to long for a simple C&P: http://www.deutsches-museum.de/flugwerft/information/aktuell/jubilaeum/fly-in-2012/fly-in-2012-teilnehmer/
Ingo
Post by: Runway 31 on July 24, 2012, 06:19:00 PM
Hi Ingo,
Sunday
3D1FC6 D-EKHA A210 Aquila AT-01 Luftsportverein Rhein-Main c/n AT01-159
3D2271 D-ELHH, Aerospool WT-9 Dynamic, c/n DY429/2012
3D3FE1 D-EWLD, unknown to me
3E5402 decodes to D-IWZY unknown to me
3E7D18 D-KMOM, unknown to me
3FECE4 D-MWBS unknown to me
3FEE75 D-MKSW unknown to me
3FF07B D-MBIG unknown to me
3FF102 D-MJSA, still unknown
3FF165 D-MFHD, Flight Design CTLS c/n unknown
484C40 PH-TOO C206 Cessna TU206G Turbo Stationair 6 Private  U20606258 , had this as W/O must have been able to be rebuilt
489780 unknown to me
4A8030 unknown to me
Post by: Runway 31 on July 24, 2012, 07:05:48 PM
Ingo
Saturday
3D0529 (Germany, flight id: DEAEZ, D-EAEZ RALL Morane-Saulnier MS-893A Commodore 180 Private 11630 I have as broken up
3D0973 decodes to D-EBVF unknown to me
3D2CCD D-EPFH, Cirrus SR22 c/n 3497
3D3FE1 D-EWLD, still unknown to me
3FF10F D-MJMW unknown to me
4041A6 decodes to G-BYLF cancelled by CAA IN 2010
4BA889 decodes to TC-JDI, B734 now TC-SKD
Post by: Runway 31 on July 24, 2012, 07:13:53 PM
Hi Ingo,
As can be seen from the attached photographs 119 is the code painted on the side of the aircraft
http://www.abpic.co.uk/search.php?q=D-EWWB&u=reg
http://www.planepictures.net/netsearch4.cgi?srch=D-EWWB&srng=2&stype=reg
http://www.airplane-pictures.net/photo/227339/d-ewwb-private-boeing-pt-13d-kaydet/
Post by: freqhopping on July 24, 2012, 09:58:38 PM
3B7FCF F-ZXXX  Eurocopter X3
Currently at KDAA on a demo tour.  Flight ID is XCUBE.
Post by: Runway 31 on July 25, 2012, 07:22:06 AM
Many thanks Freqhopping
Post by: 54901 - Jim on July 25, 2012, 01:37:12 PM
Two more for you, Alan ...
A1CBB6 / N2147L / BE95 / Beech 95-B55 / Honeywell International Inc / TC-1991
A3D0B3 / N345JK / RV12 / Vans RV-12 / Perrien Aviation LLC / 120477
FYI ... Here's a link to the Oshkosh webcams --> http://bit.ly/LNEMvN
Thanks!
Post by: Runway 31 on July 25, 2012, 01:45:08 PM
Thanks for those Jim and thanks for the link.  Hats off to ATC for getting that lot in and out safely!!
Post by: GreekSpy2001 on July 25, 2012, 02:46:19 PM
3F4A59  GAFMED1 just landed at Northolt.  Read off as C-160 50+48
graham
Post by: Runway 31 on July 25, 2012, 02:56:27 PM
Thanks Graham, added as tactical code although i am sure some will be happy to receive the serial for todays flight
Post by: neroon79 on July 25, 2012, 05:49:42 PM
Evening, the unknowns from yesterday
391D9C (France, flight id: F-JSFE, still no luck with the details)
3C4822 (Germany, no flight id, was D-ABAB a B737 but this one is no VQ-BLS)
3C7D90 (Germany, no flight id, very good chance that this again a decoding error of 3C7D94)
3D1DB8 (Germany, flight id: DEJMU, D-EJMU JUNR Bölkow BO.208C Junior Private 585 Latest Mk1EB November 2009: http://www.flugzeugbilder.de/search4.cgi?srch=D-EJMU&stype=reg&srng=2 )
3E7BD5 (Germany, flight id: DKMCB, nothing more)
3FEFE5 (Germany, flight id: DMOFA, nothing more)
3FF095 (Germany, no flight id, nothing more)
3FF10A (Germany, flight id: DMIJN, no luck with the details)
45D970 (Denmark, no flight id, nothing about a new one using this hex)
484F10 (Netherlands, flight id: TRA741, decoding error of 484F14)
4B160A (Switzerland, flight id: SWR105T, decoding error of 4B160E)
511061 (Estonia, no flight id, nothing about this one)
MIL List
3E9AAA  GAF121
3F492D
3F657F
3F8444  GAF007
3F9B41  TA64
3F9D70  BURNER2
3FB60D  HAMMER3
That's all from yesterday. Have a nice Evening!
BR Ingo
Post by: neroon79 on July 25, 2012, 06:28:09 PM
The unknowns from today:
3CCF1F (Germany, flight id: DCFST, D-CFST LJ31 Learjet 31A MHS Aviation 31-011 Source: http://www.abpic.co.uk/photo/1338049/ )
3D1DB8 (Germany, flight id DEJMU, already posted)
3E1BDC (Germany, no flight id, nothing more)
3E644F (Germany, no flight id, D-KDEL DG80 D G Flugzeugbau DG.808 private 8-396B295X57 source: http://www.lph2o.com/table/25/0.html?lang=en&resetfilters=0&limitstart25=1404220 )
3E67C0 (Germany, flight id: DKEMI, D-KEMI AS16 Schleicher ASK 16 FSV "Glück Auf" Ailertchen e.V. CN:? source: http://www.fsv-ailertchen.de/fsv_motorflugzeuge.htm )
3E7BD5 (Germany, flight id: DKMCB, already posted)
3FAC87 (Germany, no flight id, nothing more)
3FED74 (Germany, flight id: DMJBR, no luck with the details)
3FEE74 (Germany, flight id: DMCPW, D-MCPW EV97 Evektor Eurostar SLW  Ultraleichtflugschule im AirPark Riesa GmbH [www.Born-2-fly.de] CN:? source: http://www.born-2-fly.de/pages/flugzeuge.php )
3FF02D (Germany, flight id: DMOVF, still no luck with the details)
3FF0FB (Germany, flight id: DMJAZ, D-MJAZ JK05 Ekolot JK-05 Rotax 912 UL source: DULV)
3FF112 (Germany, flight id: DMFTL, D-MFTL WT9 AEROSPOOL WT-9 Dynamic private CN:? source: DULV)
MIL List:
3E8613  GAF777
3E9AAA  GAF626   EDDL-LIRF
3F5A8A  HAMMER3
3F5A8A  SHOCK2
3F733E  APEX2
3F83B3  GAF031
3F979A
3F9991  GAF910   EGLL-OMAA
3F9B41  GAF123
3F9D70  NITRO01
That's all for now.
BR Ingo
Post by: Runway 31 on July 25, 2012, 06:52:16 PM
Hi Ingo,
Yesterday
391D9C F-JSFE, unknown to me
3C4822 was D-ABAB a B737 now VQ-BLS)
3C7D90 decodes to D-AOLP unknown to me
3E7BD5 D-KMCB, Stemme S 10 c/n 10-06
3FEFE5 DMOFA, unknown to me
3FF095 decodes to D-MDMO unknown to me
3FF10A D-MIJN, unknown to me
45D970 decodes to OY-VKP A320 exported to Philipinnes
511061 unknown to me
Post by: flygfantast on July 25, 2012, 06:57:38 PM
4AE1E3 SE-XOC, Rand KR2, c/n 19-888, Bengt K Alvarsson
Niklas
Post by: Runway 31 on July 25, 2012, 07:16:58 PM
Ingo,
Today
3CCF1F decodes to D-CFSX, D-CFST LJ31 Learjet 31A MHS Aviation is in d/b under its allocated 3CCF1B
3E1BDC decodes to D-IBTC unknown to me
3E644F DG Flugzeugbau DG-808 C
3E7BD5 D-KMCB, see yesterday
3FAC87 unknown to me
3FED74 D-MJBR, Ikarus C42B, c/n C42-0074
3FF02D D-MOVF, unknown to me
Many thanks
Post by: Runway 31 on July 25, 2012, 07:18:48 PM
Thanks again Niklas
Post by: 54901 - Jim on July 25, 2012, 08:22:58 PM
Another one from today's log ...
A1FA01 / N2262Z / A4 / American Warplane Heritage Inc A4D-2N / Skyhawk Ventures LLC / 60-12377
Thanks!
Post by: Runway 31 on July 25, 2012, 08:54:41 PM
Thanks Jim, another nice one.
Post by: neroon79 on July 26, 2012, 02:26:08 AM
Morning,
3FEE62 D-MJKH is in my db with AT of ULAC, shouldn't it be JK05?
Ingo
Post by: Runway 31 on July 26, 2012, 08:12:44 AM
Thanks Ingo, amended
Post by: paul tricker on July 26, 2012, 08:47:18 AM
* 468AC5  N887EA                   SX-BVE  DH8A  Aeroland Airways     2012/07/26 09:11:28
This was registered N887EA on 13/07/12 to Intellex Group Inc
Paul
Post by: Runway 31 on July 26, 2012, 08:53:25 AM
Thanks Paul, its inbound Prestwick and is allocated AC383B and is in d/b as such.
Post by: viasa on July 26, 2012, 11:44:53 AM
Quote from: EK01 on July 24, 2012, 08:43:25 AM
Alan,
EC-GYI c/n 7249
EC-HSH c/n 7466
EC-HTZ c/n 7493
EC-HYG c/n 7529
EC-IAA c/n 7563
EC-IJS c/n 7706
EC-IZP c/n 7950
EC-IZP is still active.
Post by: Runway 31 on July 26, 2012, 11:49:58 AM
Thanks for the update viasa
Post by: 54901 - Jim on July 26, 2012, 03:07:05 PM
One for you, this morning ...
A9F1B8 / N74RR / BALL / Lindstrand 120A / Rainbow Ryders Inc / 5513
Thanks!
Post by: neroon79 on July 26, 2012, 04:29:12 PM
Evening, the unknowns from today:
3C60CA (Germany, no flight id, was D-AHFJ a tuifly B738 until 2008, but this one is now OO-JBV. I wasn't able to find a new one with this hex/reg tie-up)
3CE3C3 (Germany, no flight id, nothing more)
3D423C (Germany, again with flight id DEXII, still no luck with the details)
3FA420 (Germany MIL, no flight id, 72+32 UH1 Dornier UH-1D Iroquois (205) 8352 source: airframes)
3FEFE3 (Germany, flight id: DMDCK, nothing more)
3FF184 (Germany, flight id: DMOFL, D-MOFL C42 Comco-Ikarus C-42 Cyclone Private CN:? latest Mk1EB Tannkosh 2009: http://www.airport-data.com/aircraft/photo/350457.html )
48ADA5 (Poland, flight id: LOT2WI, no luck with the details, or if this is a decoding error)
MIL List:
3E842E  NITRO2
3EB396  PANTER2
3F513E  PACK1
3F5A8A  SMASH
3F5A8A  SMASH
3F657F  SNIPER1
3F83A8  SHOCK2
3F9B41  GAF123
That's all for now. Have a nice evening!
BR Ingo
Post by: X on July 26, 2012, 04:38:15 PM
Another new unknown descending into sandpit
* 761667                                                              2012/07/26 06:36:02
X
Post by: neroon79 on July 26, 2012, 05:07:18 PM
Some airframes to be updated:
3CE3C3 D-HVBT EC35
3E0A42 D-HVBU EC35
3E0A32 D-HVBE EC35 currently operating as MEDEVAC CHX4 (Christoph 4) in the Hanover area.
3E0A30 D-HVBC EC35
are all in the db with operator (AC) Bundesgenzschutz. Until 2005 the correct entry would have been Bundesgrenzschutz. Since the re-naming in 2005 the Bundesgrenzschutz is called Bundespolizei.  So, please amend all AC from Bundesgenzschutz to Bundespolizei.
Thanks!
Ingo
Post by: Runway 31 on July 26, 2012, 05:37:54 PM
Thanks Jim
Post by: Runway 31 on July 26, 2012, 05:44:45 PM
Evening Ingo
3C60CA agree now OO-JBV
3CE3C3 (decodes to D-CNOD unknown to me
3D423C D-EXII, still unknown to me
3FEFE3 DMDCK, unknown to me
3FF184 D-MOFL c/n 0005-6253
48ADA5 unknown to me, think its a decode error
Note the operator changes as well
Many thanks
Post by: Runway 31 on July 26, 2012, 05:49:02 PM
Cant find anything on it X
Post by: RodBearden on July 27, 2012, 12:50:20 AM
Hi Alan
Not populating:
51405F id 4LFGA
Post by: neroon79 on July 27, 2012, 01:41:04 AM
Morning, one additional MIL airframe from yesterday:
3F979A (Germany MIL, no flight id, nothing found)
about Rod's request: (and at this point mine too, as it was in my range from 1:37UTC until 2:23UTC, seems that it is on its delivery flight)
51405F (Georgia, flight id: 4LFGA, is is ex EI-EWF and will become 4L-FGA A319 Airbus A319-111 FlyGeorgia 3834 and is due to delivery on August 1st 2012. sources: http://www.planesregister.com/aircraft/a319-3834.htm http://www.airfleets.net/ficheapp/plane-a319-3834.htm http://www.flickr.com/photos/40168621@N07/7479209980/ )
BR Ingo
Post by: flygfantast on July 27, 2012, 06:00:25 AM
Morning Alan
Unknowns from yesterday:
47C2B4 (Norway)
47822E (Norway)
Niklas
Post by: Runway 31 on July 27, 2012, 07:13:42 AM
Rod/Ingo
51405F 4L-FGA, Airbus A319-111, c/n 3834, FlyGeorgia out of Dublin on delivery courtesy John Hargreaves
Post by: Runway 31 on July 27, 2012, 07:17:53 AM
Hi Niklas,
47C2B4 LN-PNB, Piper PA-31-310 Navajo, c/n 31-609, Blom Geomatics
47822E unknown to me
Post by: Flieger_NDS on July 27, 2012, 08:07:55 AM
I caught a G550, reg D-AVAR on photo this morning in Braunschweig and found nothing about her what so ever. I have no hex-code for her, but she had flight number DAVAR.
http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-Privat-Gulfstream-Aerospace-G550-D-AVAR-BWE-Braunschweig-Wolfsburg-9448.html (http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-Privat-Gulfstream-Aerospace-G550-D-AVAR-BWE-Braunschweig-Wolfsburg-9448.html)
Post by: Runway 31 on July 27, 2012, 08:13:12 AM
Hi Flieger_NDS
D-AVAR should have hex 3C0FEA but other than that I can find no details on her, must be very new.  Nice photo.
Post by: Flieger_NDS on July 27, 2012, 08:43:28 AM
Thanks for the additional info. Well, I knew that the paint was somehow familiar to me. I found it again on a Global 5000 from DC Aviation. May be this is the link we need.
http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-DC-Aviation-Bombardier-Aerospace-BD-700-1A11-Global-5000-D-AAAZ-BWE-Braunschweig-Wolfsburg-5639.html (http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-DC-Aviation-Bombardier-Aerospace-BD-700-1A11-Global-5000-D-AAAZ-BWE-Braunschweig-Wolfsburg-5639.html)
Post by: Runway 31 on July 27, 2012, 08:56:52 AM
Building together piece by piece
Post by: Runway 31 on July 27, 2012, 09:17:42 AM
Flieger_NDS
Thanks to Nigel Howarth on the mode-s forum, looks like it is c/n 5189 ex G-YAAZ de-registered to Germany last week but nothing confirmed as yet but same colour scheme thought.  http://www.plane-mad.com/aviation-photos/view/private/gulfstream-iii-iv-v/london-luton/10806.html
Post by: Flieger_NDS on July 27, 2012, 09:53:29 AM
Quiet a story developing here: G-YAAZ was the former D-AAAM (http://www.flugzeugbilder.de/show.php?id=836605). And gues what: when it still was D-AAAM, it flew for DC Aviation. So may be (or may be not) it is back with DC Aviation but just with a different reg. But this way the matching paint of the DC Aviation Global 5000 makes more sense.
Post by: Chris11 on July 27, 2012, 03:42:11 PM
ZU-FNI 00E52F   RV10   Van's Aircraft RV10   Airvest (Pty) Ltd   41163
Post by: paul tricker on July 27, 2012, 04:32:59 PM
non populators..
4B10D5 HBGJT  HB-GJT Beech 350 c/n FL-535 Breitling SA
also picked up
4CA831 & 4D0259, but unsure if these were duff signals or not!
Paul
Post by: X on July 27, 2012, 05:08:01 PM
LV-CXN B737 Aerolineas Argentinas parked at DWC 1900 on delivery no hex as yet. Next stop Barcelona tomorrow?
X
Post by: neroon79 on July 27, 2012, 05:39:16 PM
391D9C (France, flight id: FJSFE, unfortunately still no luck with the details)
3CC23D (Germany, flight id: DCAWB, back in my area, still no luck with the details)
3D0CE3 (Germany, flight id: DEDDB, D-EDDB C172 Cessna 172P Skyhawk Aero-Clubs Norden/Nordsee e.V. 17274499 airframes, operators Website: http://www.edws.de fleet: http://www.edws.de/fliegen/flugzeuge.htm )
3E1762 (Germany, flight ids: AYY103, DIABA, DIABE, decoding error of 3E1766 D-IABE PAY3, very unstable signal from this airframe)
3E6C00 (Germany, flight id: DKGHI, decoding error of 3E6C86)
3FEFE3 (Germany, flight id: DMDCK, received again, no luck with the details)
3FF095 (Germany, no flight id, D-MDMO, DULV indicates, that this is a Flight Design CTsw: http://www.dulv.de/fmi/xsl/lta/browserecord.xsl?-lay=LTA-Web-Details&-recid=8897&-find=-find )
3FF135 (Germany, flight id: DMYWT, D-MYWT according to DULV this is a WT9 AEROSPOOL WT-9 Dynamic Private CN:? source: http://www.dulv.de/fmi/xsl/lta/browserecord.xsl?-lay=LTA-Web-Details&-recid=9152&-find=-find )
3FF16A (Germany, flight id: DMLUM, D-MLUM WT9 Aerospool WT-9 Dynamic Aero-Club Butzbach e.V. CN? source: http://www.aero-club-butzbach.de/index.php?option=com_content&view=article&id=406%3Ad-mlum&catid=41&Itemid=66 )
400AA3 (UK, no flight id, no "active" airframe found)
45ACC0 (Denmark, no flight id, nothing more)
4AC8D1 (Sweden, no flight id, nothing more)
4CA1B0 (Ireland, flight id: RYR9322, decoding error of 4CA1B4)
MIL List:
3E842E  BURNER01
3E9AAA  GAF727
3F8444  GAF007
3F8B92  SNAKE1
3F9B41  GAF777
3F9B9E  GAF008
That's all from today -at least for now. Have a nice evening and a good start into weekend!
BR
Ingo
Post by: Runway 31 on July 27, 2012, 07:04:09 PM
X
LV-CXN = E0360E, picked it up earlier on the updater but cannot find anything on it yet
Post by: Runway 31 on July 27, 2012, 07:06:38 PM
Thank again Chris
Post by: Runway 31 on July 27, 2012, 07:18:06 PM
Hi Paul,
Thanks again
4CA831 decodes to EI-ELI A332 which is now VN-A376
4D0259 is unknown to me
Post by: Runway 31 on July 27, 2012, 07:33:57 PM
Evening Ingo,
3CC23D D-CAWB, Cessna 680 Citation Sovereign c/n 680-0319 operator unknown
3FEFE3 D-MDCK, unknown to me
400AA3 decodes to G-EZEK A319 now VQ-BLY
45ACC0 unknown to me
4AC8D1 unknown to me
Sitting on my varandah sipping a San Miguel while on the computer, my weekend is going the way I like it, hope your goes the same
Thanks again
Post by: 54901 - Jim on July 28, 2012, 12:39:14 AM
From today's log ...
C08136 / C-GWYF / C206 / Cessna T206H / PGS Ventures Ltd / T20608539
A05F33 / N123DS / C177 / Cessna 177B / Denton Farms LLC / 17702373
A316B4 / N2988T / M200 / Aero Commander 200D / Ross O Warner III / 361
A9D38C / N732M / C525 / Cessna 525 / Cessna Aircraft Co / 525-0685
A89D0D / N654R / RV12 / Vans RV-12 / Randal Huizenga / 120012
Thanks!
Post by: neroon79 on July 28, 2012, 05:12:59 AM
Morning, some additional unknowns from yesterday, but first:
Yesterday I posted two WT9. One has populated but the other didn't. The one that hasn't populated is this one:
All other formerly unknowns have populated.
The additional airframes:
3C489F (Germany, flight id: BER538L, actually no unknown but a decoding error of 3C4897)
3DF22F (Germany, flight id: DHLYT, D-HLYT R44 Robinson R44 Raven II Heli-Flight 2176 sorces: operators Website, Mk1EB: http://www.helionline.net/230-122700-688128/photogallery/30/185/35176///D-HLYT.html )
3E50D9 (Germany, no flight id, nothing more)
406006 (UK, no flight id, no "active" airframe found)
4B1625 (Switzerland, flight id: SWR125P, the second proofed decoding error: SWR125P was done by 4B1621)
That's all. I'll do my very best to have one the way  I like, but he best part is, that this "weekend" will last two and a half weeks. In this sense, have a nice Day!
So long! Ingo
Post by: Chris11 on July 28, 2012, 08:07:21 AM
Hi Alan
And another
00C66F ZU-SAX    RV10   Van's Aircraft RV10   ALTIUS TRADING 418 (PTY) LTD   41143
Chris
Post by: Runway 31 on July 28, 2012, 08:37:53 AM
Morning Ingo,
Dont know what happened with D-MLUM, must have forgotten to press the button fter putting in the details, its definately in now, sorry.
3E50D9 decodes to D-IVUV unknown to me
406006 decodes to G-SYGB BE20, now M-SYGB
Have a good day
Post by: Runway 31 on July 28, 2012, 08:38:39 AM
Thanks Chris
Post by: neroon79 on July 28, 2012, 08:56:46 AM
Must have been the forgotten button. It has now populated.
Many Thanks!
Ingo
Post by: X on July 28, 2012, 08:00:23 PM
reg and call sign vary...any reason?
* 4241AD  VPCCD                    VP-CET  GLF4  Jet Aviation Busi... 2012/07/28 14:01:32
X
Post by: neroon79 on July 29, 2012, 04:58:31 AM
Morning, only two decoding errors an one that may be a unknown:
4BA8F1 (Turkey, flight id: THY7PW, decoding error of 4BA8F5)
4BBC2A (Turkey, flight id: OHY965, decoding error of 4BBC2E)
8961A0 (UAE, no flight id, airframes: A6-PHE, was/is a B732)
That's all from yesterday. Have anice Day!
BR Ingo
Post by: Runway 31 on July 29, 2012, 09:48:50 AM
Hi X
I have no idea, we have the same hex for VP-CET, 4241AD as GAS, Airframes and AvDb
The same databases and Airnav give VP-CCD as 424141
Looking throught the mode-s forum archives there seems to be some disparity here as VP-CET was noted at Luton showing 4241AD and was first noted as 4241AD a GLF4 with flight ID VP-CET on 24th October 2009 but it is also noted that VP-CCD LJ60 arrived and departed Frankfurt showing the same hex during November last year.
Maybe we are all wrong and it looks like we are needing a Mk 1 eyeball sighting to sort this out.
Post by: X on July 29, 2012, 11:49:13 AM
VP-CET was eyeballed as a G450 in sandpit arriving 3 March 12 at 2117 and stayed till 7 March 12 departing 2146. Unfortunately I was in Switzerland so did not pick him up so cannot confirm which hex it used but have found 4241AD also had VP-CCD in c/s box on 10 Dec last year. Would suggest it looks like a problem with the c/s in the box and that the db is correct. Will confirm when my colleague gets back from his Blighty Olympic visit.
* 4241AD  VPCCD                    VP-CET  GLF4  Jet Aviation Busi... 2011/12/10 19:06:03
X
Post by: Runway 31 on July 29, 2012, 11:58:15 AM
Hi Jim,
Looks like I forgot to acknowledge you yesterday, many thanks again
Post by: Runway 31 on July 29, 2012, 12:11:05 PM
Hi Ingo,
Nothing on 8961A0
Post by: dotspotter2003 on July 29, 2012, 03:38:32 PM
   Does anyone have anything on the following Hex code.0123AB, I have found nothing on this or,could this be a miscode,I have has this pop up in South East London for the last few days.
MTIA
Steve
Post by: Runway 31 on July 29, 2012, 03:44:36 PM
Hi Steve,
It comes out as Egyptian but I think this will be a miscode.  Nothing on Airframes or the mode-s forum other than it was noted in Brentwood yesterday.
Post by: flygfantast on July 29, 2012, 04:46:05 PM
Hi Alan
Unknown on screen just now: 15076A RA-67434
Niklas
Post by: 54901 - Jim on July 29, 2012, 05:43:08 PM
Some additional updates for you, Alan ...
A935BB / N6929D / PA22 / Piper PA22-150 / David Sterling / 22-4857
A686D2 / N52CL / P28R / Piper PA28R-200 / Haire Aero LLC / 28R-7135042
A6CEEE / N538JA / PAR1 / Paradise P-1 SLSA LW / Jerrys Air Service LLC / 83
Thanks!
Post by: Runway 31 on July 29, 2012, 06:00:32 PM
Hi Niklas
The 15076A RA-67434 that I have details of is a Let L-410UPVP Turbolet c/n 831125 which became 9L-LBK and was last noted WFU at Conakry, Guinea in 2005
Post by: Runway 31 on July 29, 2012, 06:04:51 PM
Thanks again Jim
Post by: 54901 - Jim on July 30, 2012, 01:06:07 AM
Another one for your collection ...
AAEF9C / N80316 / BE17 / Beech G17S / Kiwi Lion LLC / B-15
Thanks!
Post by: neroon79 on July 30, 2012, 04:13:06 AM
Morning, the unknowns from Sunday:
3FEEDF (Germany, no flight id, D-MRCH GX Remos GX Private 324 Mk1EB 2010: http://jetphotos.net/viewphoto.php?id=6831972 )
3FF18B (Germany, flight id: DMCIX, D-MCIX C42 Comco-Ikarus C-42 C Private CN: ? Mk1EB JUL 2012: http://www.flickr.com/photos/wasq/7551995598/ , http://www.flickr.com/photos/wasq/7552000406/in/photostream/ )
4CA240 (Ireland, no flight id, according the time of reception in may be a decoding error  of 4CA245)
A15F28 (USA, no flight id, would match to N188HW, but nothing about this reg. Possibly a decoding error of A15F2C)
That's all from Yesterday. Have nice Day!
BR Ingo
Post by: Judwin45 on July 30, 2012, 06:09:19 AM
Morning.
I was in the vicinity of Sibson last week and picked up some sort of miscode.
A257B3, Flight N208AJ, Reg N250CC. The aircraft is the Sibson parachute aircraft a Cessna Caravan (N208AJ ?). N250CC is a PA24.
Any clues?
Post by: Runway 31 on July 30, 2012, 06:49:36 AM
Keith,
Its N208AJ miscoding, thread on mode-s forum
Post by: Skyliner on July 30, 2012, 07:25:08 AM
Quote from: flygfantast on July 29, 2012, 04:46:05 PM
Hi Alan
Niklas
New Cessna 208 of "Skol" on delivery, no serial my end, sorry
Chris
Post by: Runway 31 on July 30, 2012, 07:57:17 AM
Thanks Jim
Post by: Runway 31 on July 30, 2012, 07:59:18 AM
Hi Niklas,
15076A decodes to RA-67434 so guess the registration has been re-allocated to the Ce208
Post by: Runway 31 on July 30, 2012, 08:05:13 AM
Thanks Niklas
Nothing on 4CA240 or A15F28
Post by: paul tricker on July 30, 2012, 08:11:46 AM
non populator..
47856D  LNBAB
This is Beech King Air 350 c/n FL-590 Bergen Air Transport
Rgds
Paul
Post by: Runway 31 on July 30, 2012, 08:22:14 AM
Hi Paul,
Thanks, LN-BAB was removed from the d/b as it was transferred to the FAA registry as N943AS but that is now showing as Pending Cancel so I guess the sale fell through.
Post by: tommyg on July 30, 2012, 03:30:33 PM
Alan.
Just had Auster G-AMKU fly over and it shows on the Database as a J5s. I was going to get Rod to do a silhouette when I checked on airframes.org and it shows this acft as a J1.
Thanks Tommy
Post by: Blueboy on July 30, 2012, 04:42:01 PM
Hi Alan, picking up HEX A70473 with N551PM as flight ID - Gulfstream G550 c/n 5374 according to FAA
J.D
Post by: Runway 31 on July 30, 2012, 05:03:09 PM
Cheers JD
Post by: Runway 31 on July 30, 2012, 05:11:17 PM
Tommy,
G-INFO shows it as an Auster 5J1S with a popular name of Autocrat but my d/b has it as an Auster J/1B Aiglet and either way it should be an ICAO J1 as you state.
Many thanks
Post by: flygfantast on July 30, 2012, 05:50:17 PM
3FEC33 D-HMBG, Faeta Atec 321, c/n unkown
See http://www.dulv.de/fmi/xsl/LTA/browserecord.xsl?-lay=LTA-Web-Details&-recid=7158&-find=-find
Niklas
Post by: Runway 31 on July 30, 2012, 06:02:31 PM
Thanks again Niklas
Post by: Chris11 on July 30, 2012, 07:19:09 PM
ZS-SVL   00B1C6      PA28   Piper PA-28-161   Avic-International Flight Training   2842344
Post by: Northern Watch on July 30, 2012, 07:21:14 PM
Evening Alan
Picked this up today 43E946 with no c/s, Nothing yet in Manx register, any ideas?
regards
Keith
Post by: Runway 31 on July 30, 2012, 07:25:41 PM
Thanks Chris
Post by: Runway 31 on July 30, 2012, 07:28:28 PM
Hi Keith,
43E946 M-WATJ, type unknown as yet, went into Hawarden on delivery
Post by: Northern Watch on July 30, 2012, 07:33:21 PM
Thanks Alan
Keith
Post by: neroon79 on July 31, 2012, 03:52:07 AM
Good Morning, the unknowns from Monday:
00E028 (South Africa, flight id: CNV6521, I have this flight id in may Log-list with ADFEEE a DC93 of th US-NAVY, that's more plausible as CNV is U.S. Navy Reserve Logistic Air Forces. This two hex codes are far to different to be a decoding error. So, I don't know how this happened.)
3D2DE2 (Germany, two times with flight id DEPPY, D-EPPY PA46 Piper PA-46-500TP Meridian Private 4697227 [ex N771BL] Mk1EB June 2012: http://www.flugzeugbilder.de/show.php?id=1148829 )
451E88 (Bulgaria, flight id: BGH3001, decoding error of 451E82)
471758 (Hungary, no flight id, nothing more)
484011 (Netherlands, no flight id, nothing more)
4A8036 (Sweden, no flight id, no luck with information)
4B8E00 (Turkey, no flight id, nothing more, but I guess that this was a decoding error because double 0 ended hex are decoding errors very often.)
4CA61A (Ireland, no flight id, nothing more)
MIL List:
3E8613  GAF121
3E87DB  METAL1
3E9AAA  TA64
3EAC11  GAF016
3EB4EF
3F41E4  SNIPER1
3FAF0E  RAZOR
3FB06D  GAF120   EDDT-EDDL
3FB227
3FB99B  NOBLE
That's all from Monday. Have a nice Day and thanks for adding my two Sunday unknowns!
BR Ingo
Post by: Runway 31 on July 31, 2012, 07:42:19 AM
Morning Ingo,
00E028 will be a deliberate miscode adopted by US mil not a decoding error
471758  unknown to me
484011 unknown to me
4A8036 unknown to me)
4B8E00 unkown to me
4CA61A unknown to me
Post by: EK01 on July 31, 2012, 11:05:27 AM
Alan,
Not quite sure why, but the following Austrian Airlines aircraft have been transferred to Tyrolean Airways :
OE-LBA c/n 552
OE-LBB c/n 570
OE-LBN c/n 768
OE-LBO c/n 776
OE-LBP c/n 797
OE-LBD c/n 920
OE-LBE c/n 935
OE-LBQ c/n 1137
OE-LBR c/n 1150
OE-LBS c/n 1189
OE-LBF c/n 1458
OE-LDD c/n 2416
OE-LDE c/n 2494
OE-LDF c/n 2547
OE-LDG c/n 2652
Post by: Runway 31 on July 31, 2012, 11:15:01 AM
No doubt it will be cheaper for them
Post by: X on July 31, 2012, 07:48:16 PM
A6-FAA? B738 flyDubai which I questioned as I saw that as a C150 last month has been repainted and photographed as A6-FEA (hex 896332)
X
Post by: Runway 31 on July 31, 2012, 08:00:49 PM
Noted on the Pugetsound blog, changed from this morning A6-FAA NTU, delivered so should be over the pond within the next couple of days
Post by: BBJUK on August 01, 2012, 01:55:38 AM
Morning all.
Going back a few pages
"A9CB87 decodes to N730EZ, Beech C90GT King Air c/n LJ-1808 deregistered to A6-"
This is still flying in the UAE on a daily basis, based at Al Ain, and read off as N730EZ a couple of weeks ago. It appears on the box in the Abu Dhabi area almost daily, along with another deregistered Beech 90, ZS-SLX
Cheers BBJUK
Post by: neroon79 on August 01, 2012, 05:11:25 AM
Morning, the unknowns from Tuesday,
3CD051 (Germany, flight id: GFD30, unknown Airframe of Gesellschaft fuer Flugzieldarstellung. )
Amendment request: The GFD owns D-CGFA to D-CGFJ (hex 3CD05A to  3CD063), but they are in the db as owned by German Ministry of Defence or with typos in the name. Picture of the fleet: http://www.gfd-hohn.de/images/a1010015.jpg )
3D23E1 (Germany, no flight id, nothing more)
3D37F4 (Germany, flight id: DETLC, no luck with the details)
400946 (UK, no flight id, was G-BYYK, but this one is scrapped/broken up)
406754 (UK, flight id: EZY9001, good chance that this is G-EZWC A320 Airbus A320-214 of EasyJet 5236 delivered yesterday. details source: http://xfw-spotter.blogspot.de/search/label/G-EZWC )
44016F (Austria, no flight id, no luck with the details)
4A0091 (Romania, flight id: FAT7RG, no luck with the details. It was a Farnair Flight, but all other Farnair airframes in my log are having other flight ids. Plus if it's a decoding error two digits of the hex number must have been altered to generate the received hex. )
4CA24A (Ireland, flight id: RYR9706, decoding error of 4CA24E)
7808C0 (China, flight id: CSN123, B-6913 A321 Airbus A321-231  China Southern Airlines 5237 delivered yesterday source: http://xfw-spotter.blogspot.de/search/label/B-6913 )
AA0E0D (USA, no flight id, N747RL has already populated as FA7X)
MIL List:
3E976E  TA43
3EB396  ORCA
3F69F1  GAF169
3F69F1  GAF169
That's all from Yesterday. Have a nice Day!
BR Ingo
Post by: Runway 31 on August 01, 2012, 06:32:57 AM
Thanks BBJUK
N730EZ came off the US register in March.  I'm sure we will be advised if it ever gets an A6- registration
Post by: Runway 31 on August 01, 2012, 07:55:05 AM
Hi Ingo,
3CD051 decodes to D-CGER, unknown to me, fleet standardised on Gesellschaft fuer Flugzieldarstellung
3D23E1 decodes to D-ELVL
3D37F4 unknown to me
400946 unknown to me
406754 it is G-EZWC A320 Airbus A320-214 of EasyJet 5236 delivered yesterday and added yesterday
44016F unknown to me
4A0091 unknown to me
Many thanks again, hope you have a good one too.
Post by: Northern Watch on August 01, 2012, 01:58:47 PM
Good afternoon Alan
Just picked up and not populating was 48B9C9 c/s HAE31B believe this to be SP-OOK, PA-46-350P Malibu, c/n 4636417, owner n/k.
Keith
Post by: Runway 31 on August 01, 2012, 02:34:12 PM
Thanks Kieth,
48B9C9 decodes to SP-OOK, however the PA46 with this c/n is now SP-GPS and the owner will be R Z Trazowski
An eyeball would be handy
Post by: Northern Watch on August 01, 2012, 02:57:12 PM
Thank you Alan
There was no chance of an eyeball in this weather on the East coast of Scotland.
Keith
Post by: neroon79 on August 01, 2012, 04:29:07 PM
Afternoon, the unknowns from today:
3C4860 (Germany, flight id: BER312C, decoding error of 3C4862)
3C48D2 (Germany, flight id: BER8705, decoding error of 3C48D0)
3C492A (Germany, no flight id, was A B721 ages ago)
3C5822 (Germany, flight id: DAFAB, D-AFAB CL60 CANADAIR    CL-600 Challenger 604  Untitled CN:? source, Mk1EB June 2012: http://www.flugzeuge.de/s/Sonstige/Canadair-/Canadair-Challenger-604/10388 )
3C6448 (Germany, flight id: DLH9921, D-AIBH A319 Airbus A319-112 Lufthansa 5239 source: http://xfw-spotter.blogspot.de/2012/07/a319-112-lufthansa-d-avya-d-aibh-msn.html )
3C6507 (Germany, flight id: DLH428, decoding error of 3C650F)
3D096F (Germany, flight id: DEBVB, D-EBVB was a Beechcraft Bonanza, but this one was exported to another country)
3D0CAA (Germany, flight id: DEDAW, D-EDAW P230 Wordemann Pottier P-230S Panda Private 465 source: airframes, latest Mk1EB August 2009: http://www.flickr.com/photos/ga-bob/6668716359/ )
3D1A1C (Germany, flight id: DEIDG, D-EIDG SUBA Fuji FA-200-180AO Private FA-200-270 source airframes, confirmed here: http://www.planeboys.de/Movements/Tempelhof/2008/05/08-05.htm in 2008 )
3D1D28 (Germany, flight id: DEJHG, D-EJHG PULS Gold Aero Designs Pulsar XP Private P001 airframes, http://jetphotos.net/viewphoto.php?id=533555 last stated here in 2010: http://swag-trip-logs.blogspot.de/2010/03/270210-munich-oberschleissheim.html )
3D1E6D (Germany, no flight id, D-EJTT still no luck with the details)
3D23E1 (Germany, flight id: DELVL, still no luck with the details)
3DD3D6 (Germany, flight id: DHALY, D-HALY R44 Robinson Helicopter R44 Raven I Air Lloyd CN:? Mk1EBed May 2012: http://www.planespotters.net/Aviation_Photos/photo.show?id=284568 )
3FEBCD (Germany, no flight id, D-MKMN if someone have access, there is a picture of D-MKMN here: http://www.flugzeugforum.de/flugbetrieb-marl-loemuehle-edlm-63005-7.html )
3FEE00 (Germany, flight id: DMCOE, decoding error of 3FEE20)
49D24F (Czech Republic, flight id: OKFAL, OK-FAL B06 Agusta-Bell AB 206B Jet Ranger III may be owned by TFC Top Finance Club 3958 Mk1EB 2012 & Source: http://www.planespotters.net/Aviation_Photos/photo.show?id=270230 )
4CA265 (Ireland, no flight id, no active airframe found)
MIL List:
3EA4A3  TA70
3EB917  TA69
3F6CEB
3F98BC
3F9919  GAF910   EGLL-OMAA
3FA107  FALCON
That's all for now. Have a nice Evening!
BR Ingo
Post by: Bob SEN on August 01, 2012, 05:25:35 PM
Hi Alan
due for departure from SEN in the not too distant is  A0BD34 = N147FF (EX G-FLTA) B462 Neptune Aviation Services .
Also, I pcked up OM-BTS earlier today which is now registered EK73771 but still using the OM- hex,
see here http://bhxflightguide.blogspot.co.uk/
cheers
Bob
Post by: flygfantast on August 02, 2012, 05:55:00 AM
Not populating yesterday:
3C6448 D-AIBH, Airbus A319-112, c/n 5239, Lufthansa
Niklas
Post by: neroon79 on August 02, 2012, 06:16:12 AM
Quote from: flygfantast on August 02, 2012, 05:55:00 AM
I've already posted this one yesterday a couple of hours after the delivery flight. Maybe Alan's Internet connection has ceased function again.
Post by: Runway 31 on August 02, 2012, 07:54:37 AM
Niklas/Ingo
Was off the air yesterday afternoon from 1700, unfortunately/fortunately I have other things to do in my life :-))
D-AIBH added this morning.
Post by: Runway 31 on August 02, 2012, 07:55:32 AM
Thanks Bob, in the d/d waiting for it.
OM-BTS is in the d/b with that miscode as well as its correct code
Post by: paul tricker on August 02, 2012, 07:58:00 AM
Alan/Neroon79
this is c/n 5510 & is advertised for Sale on the Aircraft Sales Online website
Paul
Post by: flygfantast on August 02, 2012, 08:20:11 AM
Quote from: neroon79 on August 02, 2012, 06:16:12 AM
Must have been blind this morning, I checked thru the posts before I posted but missed it...
Niklas
Post by: paul tricker on August 02, 2012, 10:10:45 AM
E8031B  SKU9900
This is CC-AFZ  A319-111 c/n 2251 Sky Airline  which has just departed Southend on delivery
Paul
Post by: Runway 31 on August 02, 2012, 10:41:48 AM
Thanks Paul
Post by: Runway 31 on August 02, 2012, 11:25:48 AM
Hi Ingo,
3C492A suggest a miscode or decoding error
3C5822 D-AFAB, c/n 5510
3D096F D-EBVB Cessna 180H, c/n 18051589
3D0CAA D-EDAW P230 Wordemann Pottier P-230S Panda  first in d/b
3D1E6D D-EJTT still unknown to me
3D23E1 D-ELVL, still unknown to me
3DD3D6 D-HALY R44 c/n 2149
3FEBCD decodes to D-MKMN unknown to me
49D24F OK-FAL, I have as owned by Entera Group
4CA265 decodes to EI-DHI, now TC-SAI
Thanks again
Post by: Blueboy on August 02, 2012, 12:18:35 PM
Hi Alan, picking up HEX 3CE617 with flight ID D-COLB - A Swearingen SA227AC Metro c/n AC-754B according to GAS
J.D
Post by: 54901 - Jim on August 02, 2012, 02:24:20 PM
One update for you, Alan ...
A69C86 / N525LL / GLAS / James L Lenz Glasair III / Glasair Investors III LLC / 3263
Thanks!
Post by: Runway 31 on August 02, 2012, 03:16:40 PM
Hi JD
D-COLB is now N754TR, its been on FAA register since 28/3 so its must be miscoding its former hex
Post by: paul tricker on August 02, 2012, 04:19:26 PM
404401 is doing circuits at Redhill, HOWEVER
404401= G-FEDA EC120B w/o earlier this year. The hex is currently being mis-used by the owners new helicopter...
G-OTFL EC120B Colibri c/n 1073 J.Henshell *should* be transmitting 4046BC according to G-INFO
Paul
Post by: paul tricker on August 02, 2012, 04:23:09 PM
It looks like X's favorite engineer has a new job with Aer Lingus!!!
4CA210  EIN525        2012/08/02 15:16:59
4CA216  EIN525                   EI-DEH  A320  Aer Lingus           2012/08/02 15:19:22
4CA214  EIN525                   EI-DEE  A320  Aer Lingus           2012/08/02 15:13:29
Paul
Post by: Runway 31 on August 02, 2012, 05:13:05 PM
Thanks again Paul
Post by: X on August 02, 2012, 08:55:48 PM
As from tomorrow midnight will be in MOW, very little happening in sandpit other than delivery's to EK.
X
Post by: neroon79 on August 03, 2012, 03:21:36 AM
Morning, the unknowns from Thursday:
MIL List:
3E805B  GAF727
3EB9BB  GAF626   EDDL-LIRF
3F4E3C  ORCA1
3F5BA3  GAF014
3F7E2E  GAF710
3F7E2E  GAF710
3F80E4  LK01B
3F8221  GAF269
3FEB62 (Germany, no flight id, D-MONE Tecnam P92 SW X-RAY Flugsportzentrum Leipzig 922 sources: http://www.propellermann.de/p92_sw.html / http://www.propellermann.de/pdf_dat/XRAY_Chartervertrag_P92_DMONE_V1.PDF )
40093C (UK, flight id BAW981, decoding error of 400938)
4CAA4B (Ireland, no flight id, nothing more)
78092F (China, flight id: CSC6899, B-6899 A321 Airbus A321-231 Sichuan Airlines 5233 source: http://xfw-spotter.blogspot.de/2012/07/a321-231-sichuan-airlines-d-avzb-b-6899.html )
A30D70 (USA, no flight id, hex matches to N296TC, there are indication that this is SP-YXY [ex N296TC] still using its old hex of N296TC)
That's all from yesterday. Have a nice Day and a good start into weekend!
BR Ingo
Post by: Runway 31 on August 03, 2012, 09:04:23 AM
Hi Ingo,
4CAA4B unknown to me
A30D70 decodes to N296TC, which is now SP-YXY VELO
Thanks again and hope you have a good day
Post by: flygfantast on August 03, 2012, 05:48:03 PM
Not populating:
45C848 OY-RBH Diamond DA40D, c/n D4.312. Although it was canceled and exported to Sweden as SE-MBG, but it's still using that hex and shows OYRBH as callsign, so I guess it's miscoding.
SE-MBG is allocated 4AB447 and owned by Feringeflyg AB
Niklas
Post by: Runway 31 on August 03, 2012, 05:56:13 PM
Thanks Niklas, was in under SE-MBG and have now added the miscode.
Post by: neroon79 on August 04, 2012, 04:22:57 AM
Morning, the unknowns from Friday:
3950D4 (France, no flight id, nothing more)
3C4860 (Germany, flight id: BER986E, again a decoding error of 3C4862)
3C4B1D (Germany, no flight id, nothing more)
3C7D9C (Germany, no flight id, nothing more)
3CCF97 (Germany, no flight is, nothing more)
3D1439 (Germany, no flight id,  D-EFXH A210 Aquilla AT-01 RWL German Flight Academy CN:? Mk1EB January 2012: http://www.flugzeugbilder.de/show.php?id=1108616 )
3D4107 (Germany, flight id: DEWWL, still no luck with the details)
3E6400 (Germany, flight id: DKDCK, decoding error of 3E641A)
3EFFF5  (Germany, flight id: D8030, D-8030 GLID Rolladen-Schneider LS4a Flugsportgemeinschaft Datteln Bork e. V. CN:? Source: http://www.fsg-datteln-bork.de/flugzeugpark.html )
3FEA7A (Germany, flight id: DMSJB, D-MSJB TL20 TL Ultralight TL-96 Sting 2000 Private CN:? sources: DULV, Mk1EB 2006: http://texelairport.opvliegen.nl/register.php?vliegtuig=775 )
478380 (Norway, no flight id, nothing more)
4A0828 (Romania, no flight id, was YR-BAH until 2011, but this one is now EI-EPL)
MIL List:
3E805B  TA44
3E8176
3EB917  TA70
3EB9BB  TA42
3F4C6E  GAF774
3F57F1  KNIGHT1
3F6004
3F8221  GAF626   EDDL-LIRF
3FAF81  GHOST3
That's all from Friday. Have a nice Day!
BR Ingo
Post by: neroon79 on August 04, 2012, 07:18:49 AM
Today morning:
440633 (Austria, flight id: OEFHO, OE-FHO E50P Embraer EMB-500 Phenom 100 Private 50000185 source: http://www.laasdata.com/corpjet/corpjet-by-type.php?t=66 / http://www.airport-data.com/aircraft/photo/750407.html )
Post by: Runway 31 on August 04, 2012, 08:13:51 AM
Morning Ingo,
3950D4 decodes to F-GUGU unknown to me
3C4B1D unknown to me
3C7D9C unknown to me
3CCF97 decodes to D-CFXN
3D23E1 (Germany, flight id: DELVL, still unknown to me
3D4107 (Germany, flight id: DEWWL, still unknown to me
478380 unknown to me
4A0828 now EI-EPL, last noted in storage
Also noted new Phenom
Regards and have a good day
Post by: flygfantast on August 04, 2012, 08:33:06 AM
Morning Alan,
4AD996 SE-VLV, Dyn-Aero MCR01-ULC, c/n 380, Private owner
Niklas
Post by: Runway 31 on August 04, 2012, 09:04:37 AM
Morning Niklas, thanks again
Post by: neroon79 on August 04, 2012, 10:14:23 AM
Two to check:
While manually updating the designators I noticed, that 45AC58 OY-KBX is in the db with designator GLID and 44051A OE-9503 is in the db with designator VENT. Both airframes are in the db with AN of SCHEMPP-HIRTH DISCUS 2CT. So the designator for both should be DISC, right?
Ingo
Post by: Runway 31 on August 04, 2012, 11:05:38 AM
You are correct Ingo
Post by: paul tricker on August 04, 2012, 02:53:43 PM
43E94D  MBETY
An internet search reveals this to be a Dornier 328-300Jet  c/n 3176 cannot find anything on operator though
http://www.flickr.com/photos/il-photography/7676007458/
for a picture
Rgds
Paul
Post by: Runway 31 on August 04, 2012, 03:32:36 PM
Thanks again Paul, BTW its a 310
Post by: X on August 04, 2012, 05:41:59 PM
Now in MOW with internet at last (did not help that wife had pulled line out of the back of the router), some unknowns and one Yak-42 with current/old reg in c/s box!! Couple of odd balls too boot
* 15FE1F                                                              2012/08/04 16:59:29
* 3DF280                                                              2012/08/04 15:54:08
* 4249A5                                                              2012/08/04 13:05:13
* 5BA6C8                                                              2012/08/04 12:47:05
* 6030FE                                                              2012/08/04 13:30:54
* 683063  UP42721                                              2012/08/04 11:18:17
* 683063  UP42721                                              2012/08/04 16:32:36
X
Post by: X on August 04, 2012, 06:22:54 PM
I can answer one of my own questions 15FE1F is 14FE1F double coding at same time and altitude....so Paul was wrong my favourite engineer has moved from Iran to Moscow (possibly via Dublin)!!
X
Post by: Runway 31 on August 04, 2012, 06:39:02 PM
Hi X,
Nice to hear from you, what would we do without our dear ladies!!
15FE1F   unknown to me
3DF280  decodes to D-HMBW and will either be EC45 RA-01833 or B105 RA-02533
4249A5  unknown to me
5BA6C8  Miscode unknown to me
6030FE  Miscode unknown to me
683063  UP-42721 , Yakovlev Yak-42D, c/n   4520423310017, Kazakhstan - Air Force
14FE1F RA-65055 T134
Post by: X on August 04, 2012, 07:01:27 PM
Not sure if you got my second post, 15FE1F is 100% 14FE1F double coding like EP-LCE
X
Post by: Runway 31 on August 04, 2012, 07:02:45 PM
Yes got it X
Post by: mikek on August 05, 2012, 05:05:22 AM
Not popuulating:
898072, c/s P2RNA, PAC750. Other details unknown.
Mike
Post by: flygfantast on August 05, 2012, 06:10:36 AM
Morning Alan,
4AD916 SE-VHV, Tanarg 912, c/n T10013, Lidkoping Motorflygklubb
Niklas
Post by: X on August 05, 2012, 07:19:09 AM
Can you double check 424136 VP-CCP, looked too big to be a FA20 looked more like a CL60 in size?
X
Post by: neroon79 on August 05, 2012, 07:46:15 AM
Morning, the unknowns from Saturday (Fraport area)
3D243B (Germany, flight id DELYX, still no luck with the details)
3D37F4 (Germany, no flight id, D-ETLC still no luck with the details)
4A8AED (Sweden, flight id: SEBWM, SE-BWM FW44 Focke-Wulf Fw 44J Stieglitz Private 655 airframes, Mk1EB May 2012: http://www.flugzeugbilder.de/show.php?id=1144685 )
4C804D ( Cyprus, flight id: CYP346, 5B-DCP A321     Airbus A321-231 Cyprus Airways 2793 Leased from ILFC source: http://www.planespotters.net/Production_List/Airbus/A321/2793,5B-DCP-Cyprus-Airways.php )
That's all from Fraport Area.
BR Ingo
Post by: paul tricker on August 05, 2012, 08:02:13 AM
Quote from: paul tricker on August 04, 2012, 02:53:43 PM
43E94D  MBETY
for a picture
Rgds
Paul
Skyliner is quoting 3169 as the c/n. Unfortunately neither Bones or the official site show anything against this reg.
Paul
Post by: neroon79 on August 05, 2012, 08:14:32 AM
The unknowns from  Hannover area:
3C09F6 (Germany, no flight id, nothing more)
3C5312 (Germany, no flight id, nothing more)
3D1400 (Germany, flight id: DEFWM, D-EFWM with a decoding error of its hex 3D1424)
3D1FBD (Germany, no flight id, D-EKGR E400 Extra   EA-400 Private 28, source airframes, Mk1EB April 2010: http://www.flugzeugbilder.de/show.php?id=934832 )
3D37F4 (Germany, no flight id, D-ETLC seems, that this was coming from north and going to south)
3FEB74 (Germany, flight id: DMCOV, DULV: D-MCOV CORO Corvus CA-21 Phantom Jabiru 2200 Private CN:?)
3FEBCD (Germany, flight id: DMKMN, still no luck with the details)
3FED54 (Germany, flight id: DMHAA, D-MHAA ECHO Tecnam P-92-S Echo Luftsportgruppe Muenchberg e.V. CN:? Sources: http://www.zell-haidberg.de/flugzeug.htm, http://www.flugzeugbilder.de/show.php?id=376830 )
3FEFE9 (Germany, flight id: DMDDO, still no luck with the details)
3FF102 (Germany, flight id: DMJSA, unfortunately still no details)
501D24 (Croatia, no flight id, nothing more)
That's all from Saturday. Have a nice Sunday!
BR Ingo
Post by: Runway 31 on August 05, 2012, 08:46:27 AM
X
424136 is FA20 VP-CCP delivered February this year.  The previous VP-CCP CL604 is now LX-SPK.  May well be the old one still using its previous details
Post by: Runway 31 on August 05, 2012, 08:53:12 AM
Thanks Paul,
The photo you attached detailed it was ex UR-AER which was c/n 3176.  3169 is/was UR-DAV as per Skyliner so I guess the photographer is wrong.
Post by: Runway 31 on August 05, 2012, 09:02:44 AM
Thanks Niklas
Post by: Runway 31 on August 05, 2012, 09:05:12 AM
Thanks Mike
Post by: Runway 31 on August 05, 2012, 09:17:58 AM
Hi Ingo,
Fraport area
3D243B D-ELYX, Cirrus SR22, c/n 0595
3D37F4 D-ETLC still unknown to me
4C804D 5B-DCP A321 already in d/b since 17/7
Thanks and Hannover area next
Post by: Runway 31 on August 05, 2012, 10:17:58 AM
Hi Ingo,
Hannover area
3C09F6 decodes to D-ASUB unknown to me
3C5312 decodes to D-ADXR unknown to me
3D37F4 D-ETLC unknown to me
3FEBCD D-MKMN, still unknown to me
3FEFE9 D-MDDO, unknown to me
3FF102 D-MJSA, some day we will ID it
501D24 unknown to me
Good day being had, you have a good one too.
Regards and thanks
Post by: X on August 05, 2012, 10:45:21 AM
Ta, VP-CCP (2) is based VKO and what I saw was ex SVO so maybe there was another a/c at same time or as you say as might be VP-CCP(1) miscoding old hex. As they do not plot it is a nightmare trying to work out which is which and from what field as I can pick up all nine MOW fields from here and even Tver so 76's drive me daft.
This miscode came and went from SVO I believe
* 203547                                                              2012/08/05 10:13:30
* 203547                                                              2012/08/05 14:02:20
X
Post by: Runway 31 on August 05, 2012, 10:52:57 AM
Nothing on that miscode X
Post by: X on August 05, 2012, 01:47:44 PM
* 440644  OEIRA                                                       2012/08/05 17:00:02
* A64543        2012/08/05 15:09:21
X
Post by: X on August 05, 2012, 02:00:14 PM
Either we have a very confused pilot or we have two aircraft using the same code 23 minutes apart!
   4249FC  ABW797   UUEE-ZSPD       VQ-BQZ  A333  Aeroflot Russian ... 2012/08/05 13:47:00
   4249FC  AFL200     UUEE-ZBAA       VQ-BQZ  A333  Aeroflot Russian ... 2012/08/05 13:24:27
X
Post by: Runway 31 on August 05, 2012, 02:03:34 PM
A right couple you have presented there X,
440644 decodes to OE-IRA was a B707-138B of Montana Austria which was b/u around 1987 not aware of a reallocation
A64543 decodes to N503BW Luscombe 11E Sedan
Post by: Runway 31 on August 05, 2012, 02:06:49 PM
The correct one is the Aeroflot, I can only gues the other was a decoding error of some sort
Post by: X on August 05, 2012, 02:21:52 PM
Well you have me on that one...a Luscombe ....never heard of one
The Aeroflot A333 VQ-BQZ took off at 1324 and was seen as such, climbed to 35,000 and timed out 1348, two minutes later reappeared with changed code and destination and landed 19 minutes later at SVO (but not seen landing)as i lost him at 900 ft....weird!
X
Post by: paul tricker on August 05, 2012, 03:36:31 PM
unknowns today
503CC2 (Lithuania)  other than the fact it was climbing up to 35000 before I lost it, no other details I'm afraid.
49D2AE (Czech Rep.) no further details but something small I guess as it did not go over 3500ft
Paul
Post by: Runway 31 on August 05, 2012, 03:47:29 PM
Nothing on the Lithuania Paul
49D2AE OK-PCC, Pilatus PC-12/47E c/n 1344/ OK Business Aircraft
Post by: flygfantast on August 05, 2012, 04:23:39 PM
Unknown 15076B RA-67435. A new delivery for SKOL??
Niklas
Post by: Skyliner on August 05, 2012, 04:45:20 PM
Quote from: flygfantast on August 05, 2012, 04:23:39 PM
Niklas
[/quote
Cessna 208, so far operator given as Globeflyers Inc, a ferrying company
Post by: Runway 31 on August 05, 2012, 05:24:59 PM
Niklas/Skyliner
Thanks both
Post by: flygfantast on August 05, 2012, 07:11:12 PM
Not populating 43E94A, 419 msgs no c/s
Niklas
Post by: Runway 31 on August 05, 2012, 07:28:23 PM
Nothing on 43E94A yet Niklas
Post by: Runway 31 on August 05, 2012, 09:05:17 PM
Niklas,
43E94A was noted in Moscow earlier with a flight ID of CDR208, so getting closer to ID
Post by: neroon79 on August 06, 2012, 05:10:09 AM
Morning,the unknowns from Sunday:
06A034 (Qatar, no flight id, nothing about a new one)
3991E5 (France, no flight id, D-HEPF no luck with the details)
3C5CBC (Germany, no flight id, nothing more)
4844EC (Netherlands, no flight id, no active airframe found)
49D2AE (Czech Republic, flight ids: NTF201A and NTF201B, is in he db by now)
4B85B4 (Turkey, no flight id, nothing more)
That's  all from Sunday! Have a nice Day!
BR Ingo
Post by: neroon79 on August 06, 2012, 05:11:57 AM
By the way: In Fraport Area it was only D-ETLC.
Ingo
Post by: flygfantast on August 06, 2012, 06:00:43 AM
Quote from: Runway 31 on August 05, 2012, 09:05:17 PM
Niklas,
Could possibly be ex C-GIVW,  Bombardier CL-600-2B19  c/n 8108  export to ISLE OF MAN, export date 2012-07-31.
Niklas
Title: Re: Database Update Requests
Post by: Runway 31 on August 06, 2012, 09:26:52 AM
Morning Ingo
06A034 decodes to A7-AFO now TC-JNG A332 Turkish Airlines
3991E5 decodes to F-HEPF unknown to me
3C5CBC unknown to me
4844EC decodes to PH-CMC now OO-RMC BE33
49D2AE PK-PCC, Pilatus PC-12/47E, c/n 1344, OK Business Aircraft
4B85B4 decodes to TC-AMT unknown to me
Post by: Runway 31 on August 06, 2012, 09:28:08 AM
Possibly Niklas, shouldnt be too long before we get a positive ID on it.
Post by: flygfantast on August 06, 2012, 12:23:24 PM
Quote from: Runway 31 on August 06, 2012, 09:28:08 AM
Should be M-LILY, according to Skyliner:
Canadair CRJ  200  8108     M-LILY  TAG Aviation Asia  CL850, C-reg cx 31jul12, delivery 04-05aug12 YPQ-YYR-KEF-DME   ex C-GIVW
But need to be confirmed.
Niklas
Post by: Runway 31 on August 06, 2012, 12:39:30 PM
Hi Niklas,
Just seen it myself, looks good, thanks again
Post by: Flieger_NDS on August 08, 2012, 06:56:21 AM
Quote from: Runway 31 on August 02, 2012, 11:25:48 AM
Seems to be a private Remos GX: http://www.luftfahrtclubbraunschweig.de/picdb/Juergen-Gruettner-Privat-REMOS-Aircraft-GmbH-GX-D-EJTT-BWE-Braunschweig-Wolfsburg-9572.html (http://www.luftfahrtclubbraunschweig.de/picdb/Juergen-Gruettner-Privat-REMOS-Aircraft-GmbH-GX-D-EJTT-BWE-Braunschweig-Wolfsburg-9572.html)
Post by: Runway 31 on August 08, 2012, 08:10:39 AM
Thanks Flieger_NDS
Post by: X on August 08, 2012, 11:18:11 AM
Another unknown Russkie and a yank
* 159944                                                              2012/08/08 12:49:22
* A37690                                                              2012/08/08 14:48:25
X
Post by: Runway 31 on August 08, 2012, 11:37:30 AM
X
159944 unknown to me
A37690 decodes to N322JK, now RA-***** Piper PA-46-350P Malibu Mirage c/n 4636242
Post by: X on August 08, 2012, 12:09:56 PM
Did not get pic but saw VP-BHM H25X at VKO 1600 yesterday (did not pick up though) could this be my new Bermudan picked up a couple of days back? Reuse from old DC8 reg.
X
Post by: Runway 31 on August 08, 2012, 12:32:42 PM
Hi X
Can only find details of the DC8 with that registration and the DC8 is in the d/b with its hex of 4000BB and marked as WFU stored.  I can find no details of the H25B with that registration which if newly re-issued doesnt really surprise me.
I have looked back the past 9 days or so but cannot see the Bermudan you refer too, can you advise the hex please.
Post by: X on August 08, 2012, 12:35:43 PM
424540 I believe on 6TH
X
Post by: Runway 31 on August 08, 2012, 12:46:02 PM
X
From a few days back
440644 OE-IRA, Bombardier BD-700-1A10 Global Express XRS, c/n 9237, ART Aviation
Post by: X on August 08, 2012, 02:29:15 PM
All seen and graphed in full UTair c/s
RA-42342   D   4520421706302      UTair
RA-42362   D   4520424811431      UTair
RA-42388   D   4520424016510      UTair
x
Post by: Runway 31 on August 08, 2012, 03:25:13 PM
Lucky you X
Post by: neroon79 on August 09, 2012, 04:25:54 AM
Morning, some unknowns from FRAPORT received area on Monday:
3D1C10 (Germany, no flight id, decodes to D-EIWM, which is now N54WT last seen on August 3rd. So, must be a new one or a decoding error)
AE2C96 (USA, flight id: DEFAULT, might be a MIL airframe)
Some MILs:
3F9919  GAF121
3F9991  GAF122
3FB0D6  GAF120   EDDT-EDDL
Next: unknowns from Hannover area.
Ingo
Post by: neroon79 on August 09, 2012, 04:44:52 AM
Unknowns from Monday (Hannover)
3C6591 (Germany, no flight id, would match to D-AILQ, but details about this one)
3D2EFB (Germany, no flight id, nothing more)
3D32A3 (Germany, no flight id, D-ERKT C172 Cessna 172S Skyhawk SP Private CN:? Mk1EB July 2012: http://www.airplanes.se/?script_name=bild&bild=12950 )
4405C5 (Austria, flight id: VJS203, decoding error of 4405CD)
71BC11 (Rep. of Korea, no flight id, nothing more)
8A0268 (Indonesia, no flight id, nothing more)
ACD7FB (USA, flight id: N9268Y, N9268Y C172 Cessna 172S Skyhawk SP Private CN:? Mk1EB August 2012: http://www.flickr.com/photos/guernseyairportphotography/7716509994/ )
AE2C8D (USA MIL, flight id: AMMO01, no details found)
MIL List:
3E8443  NITRO02
3E8717  GAF727
3EA005  GAF041
3EA4A3  GAF653
3EB5FE  GAF162
3F468A  ORCA1
3F535F
3F8241  GAF910   EGLL-OMAA
That's all from Monday. Next: Tuesday.
Post by: neroon79 on August 09, 2012, 05:01:29 AM
Tuesday unknowns (From now on Hannover area only)
3D13B9 (Germany, flight id: DEFJS, D-EFJS C182 Reims-Cessna F182Q Skylane II    Aéroclub d'Alsace F18200116 last Mk1EB from July 2nd, according to ASN Airframe substantial damaged during landing caused by breaking nose-gear. Can't figure out if it was the repaired C182 or a new airframe.)
3D23E1 (Germany, D-ELVL again)
400125 (UK, flight id: VIR250, VIR: Virgin Atlantic Airways, nothing more)
406753 (UK, flight id: EZY9001, EasyJet delivery out from XFW. Therefore I presume it is in the db by now. If not the details are here: http://xfw-spotter.blogspot.de/search/label/G-EZWB )
AE048E (USA, flight id: QID65, MIL airframe, as QID is id for U.S. Air Force 100th Air Refueling Wing, RAF Mildenhall   )
That's all from Tuesday. Next: Wednesday.
MIL List
3E8717  GAF626   EDDL-LIRF
3E92B5  GAF163
3F4EDE  LK01B
3F6DC9  SPEAR1
3F7990
3F7C42  EAGLE
3F92DA  MISTY
3F9BB9  GAF711
3FB0D6  GAF120
Post by: neroon79 on August 09, 2012, 05:16:25 AM
Wednesday unknowns:
222222 (no allocation, 22222222, airframes has 12 identified miscoded airframes against this hex...)
3C6636 (Germany, no flight id, nothing more)
3CD450 (Germany, flight id: DCHSA, D-CHSA C550 Cessna 550 Citation II Private/Untitled 550-0041 according to LAAS Current Corporate Jet Register ex OE-GCI)
3FA7CC (Germany, no flight id, nothing more)
406755 (UK, flight id: EZY9002, another EasyJet delivery from XFW, details just in case: http://xfw-spotter.blogspot.de/search/label/5249 )
7608A1 (Pakistan, no flight id, nothing more)
A1EC24 (USA, flight id: N223AF, decoding error of A1EC2C)
AE129C (USA MIL, flight id: RCH1033, RCH: USAF Military Airlift Command, no luck with the details)
MIL List:
3EA005  GAF041
3EAB09  SNIPER1
3EB264  GAF322
3F6007  DASA06
3FA15B  GAF770
3FA303
That's it for the back-log. Have a nice Day!
BR Ingo
Post by: neroon79 on August 09, 2012, 06:31:56 AM
One change to be done:
3D443F D-EYCD is in the db as BU33 Bücker BÜ-133C Jungmeister.
But this Pictures from April 2012 and May 2010 (http://www.flickr.com/photos/vriesbde/5333415743/ http://www.flugzeugbilder.de/show.php?id=1139743) are proofing that D-EYCD is actually a Cirrus SR-22 gTs X turbo (CN:3615) and not longer a BU33(, although I would have preferred, that it is still the BU33).
Post by: Chris11 on August 09, 2012, 07:44:22 AM
ZS-ZOT   00C394 - new owner - Swift Flite (Pty) Ltd
Post by: Runway 31 on August 09, 2012, 08:12:02 AM
Thanks Chris
Post by: Chris11 on August 09, 2012, 08:25:40 AM
Hi Alan
A new import for SA. Cessna 172S' for 'Chinese' flight school AVIC - International Flight Training Academy in Oudtshoorn
ZS-AIF   0080E6      C172   Cessna 172S   Avic Air Asset (Pty) Ltd   172S11169
ZS-FIA   008E15      C172   Cessna 172S   Avic Air Asset (Pty) Ltd   172S11170
ZS-AIA   0080E1      C172   Cessna 172S   Avic Air Asset (Pty) Ltd   172S11171
ZS-AFI   00809B      C172   Cessna 172S   Avic Air Asset (Pty) Ltd   172S11172
ZS-AVC   008235      C172   Cessna 172S   Avic Air Asset (Pty) Ltd   172S11173
Post by: Runway 31 on August 09, 2012, 08:43:41 AM
Ingo,
Fraport Monday
3D1C10 D-EIWM, Cessna 172S Skyhawk SP, c/n 172S11104
AE2C96 US Mil Tactical
Hannover
3C6591 D-AILQ, unknown to me
3D2EFB decodes to D-EQAT unknown to me
71BC11 decodes to HL7411, B747 b/u and completely scrapped at Pinal Airpark during 2005
8A0268 unknown to me
AE2C8D US Mil Tactical
Post by: Runway 31 on August 09, 2012, 09:08:32 AM
Ingo,
Tuesday
3D13B9 D-EFSJ, Tecnam P-2002-JF Sierra, c/n 004
400125 miscode G-VOGE, allocated 400925
406753 G-EZWB, Airbus A320-214, c/n 5224, easyJet Airline
AE048E unknown to me, possibly miscode?
Thanks again
Post by: Chris11 on August 09, 2012, 09:12:11 AM
00D6AB   ZU-FLT   RV9   Van's Aircraft RV9A   PRETORIUS D J   92006
Post by: Runway 31 on August 09, 2012, 09:17:43 AM
Ingo,
Wednesday
3FA7CC unknown mil
406755 G-EZWD, Airbus A320-214 c/n 5249, easyJet Airline
7608A1 decodes to AP-BEA B412 w/o, maybe new allocation but unknown to me
AE129C 69-6575, Lockheed AC-130H Hercules, c/n 4349, US - Air Force
Thanks again, have a good day.
Post by: Runway 31 on August 09, 2012, 09:22:35 AM
Many thanks for those Chris
Post by: Runway 31 on August 09, 2012, 11:52:11 AM
Hi Chris,
Please see PM
Post by: flygfantast on August 09, 2012, 04:40:49 PM
4A82F1 60040, SB05, Saab SK60A, c/n 60040, Sweden - Air Force
Niklas
Post by: Xon on August 09, 2012, 05:09:45 PM
489323 SP-EQD DH8D c/n 4411 (C067B6 C-GNHD 05-06 aug 2012 delivery flight)
Post by: Runway 31 on August 09, 2012, 05:37:58 PM
Thanks Xon
Post by: Runway 31 on August 09, 2012, 05:38:15 PM
Thanks Niklas
Post by: BBJUK on August 09, 2012, 05:50:25 PM
A few unknowns from Dubai this week while X is on his travels:
06 Aug 51405E TZS701 into Fujairah
            388A5B F-WTAH into DXB
08 Aug  730C45 over the Gulf
             84106C which I think was JA04JJ A320 on delivery flight
09 Aug  515261 somewhere in the area
And now back to the serenity of AUH!
Cheers BBJUK
Post by: Runway 31 on August 09, 2012, 06:08:36 PM
Hi bbjuk,
51405E TZS701 unknown miscode
388A5B F-WTAH unknown to me
730C45 decodes to EP-CBE unknown to me
84106C JA04JJ Airbus A320-232, c/n 5245, Jetstar Japan
515261 EY-534, Boeing 737-247, c/n 23605/1371, East Air, already in d/b
Post by: flygfantast on August 09, 2012, 07:10:01 PM
F-WTAH is now VT-JSI.
From Skyliner:
Embraer 135    LR    145.00893        VT-JSI    Jindal Steel Power    delivery 06-07aug12 LFBF-LCA-DXB-DEL, F-reg    ex F-WTAH
Niklas
Post by: Runway 31 on August 09, 2012, 07:18:41 PM
Thanks Niklas, ex LX-LGL
Post by: neroon79 on August 10, 2012, 06:33:01 AM
3D1FB4 (Germany, flight id: DEKGI, D-EKGI S05R SIAI-Marchetti S-205-18/R Private 365 source: airframes, confirming Mk1EB September 2011: http://www.flugzeugbilder.de/show.php?id=1080174, stated here http://www.flugzeugforum.de/flugbetrieb-osnabrueck-atterheide-edwo-2012-a-68577-11.html  March 2012 to be still this Airframe)
3E66D1 (Germany, flight id: DKEDD, D-KEDD ARCP Schempp-Hirth Arcus T Private / somehow related with Segelfliegerclub HiHai e.V CN:? Source and Mk1EB June 2011: http://www.flugzeugbilder.de/show.php?id=1155260 )
3EAB09 (Germany, no flight id, nothing more)
4B16EE (Switzerland, no flight id, nothing more)
8A0269 (Indonesia, flight id: GIA88, decoding error of Garuda Indonesia A332 8A026D)
MIL List
3EB264  GAF322
3F5479
3F5479
3F71AC
3F7E85  COLT01
3F85C2  GAF674
3F9D97
3FA15B  GAF777
3FA303  SNIPER01
3FB5B4  COLT02
That's all from Thursday. Have a nice Day!
BR Ingo
Post by: neroon79 on August 10, 2012, 06:50:04 AM
From today morning:
4BD14A (Turkey, flight id: CAI508, should be TC-TJJ B738 Boeing 737-8S3/W Corendon Airlines 29247/493 sources: airframes, http://www.rzjets.net/aircraft/?reg=288504 , several Mk1EB from this year can be found by using google / Seems that someone has noticed and corrected the miscode)
3F9B9E (Germany MIL, flight id: GAF019)
Post by: paul tricker on August 10, 2012, 07:16:46 AM
Quote from: paul tricker on August 05, 2012, 08:02:13 AM
43E94D  MBETY
for a picture
Rgds
Paul
Paul
Skyliner has changed its mind! & is now quoting 3176 as per the photograph!!
Additional info is the operator...Fünfte XR Gmbh
Paul
Post by: Runway 31 on August 10, 2012, 09:14:49 AM
Thanks Paul
Post by: Runway 31 on August 10, 2012, 09:30:23 AM
Morning Ingo,
3E66D1 D-KEDD ARCP Schempp-Hirth Arcus T c/n 20 but I have as cancelled
3EAB09 unknown to me
4B16EE decodes to HB-IRU DC-3, would suggest decoding error/miscode
Note the miscode correction
Thanks again and  have a good day
Post by: chewycanes on August 10, 2012, 10:43:42 AM
Morning Alan
A97041 Callsign N707TJ Boeing A75N Breitling  (from AF & FAA)
3CE617 Callsign DCOLB SW4 OLT (from AF)
Brian
Post by: Runway 31 on August 10, 2012, 11:03:04 AM
Hi Brian,
D-COLB is now N754TR on FAA register since March
Post by: Chris11 on August 10, 2012, 12:13:56 PM
Hi Alan
Another NTCA
00E97C   ZU-JGR   JAB4   Shadow Lite Jabiru J430   JAGER TECHNOLOGIES CC   c/n 823
Chris
Post by: Runway 31 on August 10, 2012, 12:52:14 PM
Thanks again Chris
Post by: neroon79 on August 10, 2012, 02:05:16 PM
Hi Alan, when was D-KEDD cancelled?
At a competition that took place from May 12th to May 19th this year (http://www.lehmann-aviationphotos.de/HWW2012.htm) D-KEDD was still the Schempp-Hirth Arcus T, further the mentioned Aero-Club was/is at the "Niedersächsische Landesmeisterschaften 2012 in Hodenhagen" (http://www.soaringspot.com/nsm2012/pilots/?lang=de) The only Arcus T related to this Club is D-KEDD.
Another Site with matching details: http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=9E25FE8AFCD8015AC92FEF34438D5863?dsId=2616318
In my opinion D-KEDD is an Arcus T, but I'm not sure if it is the one with CN of 20.
Ingo
Post by: Kenny on August 10, 2012, 02:59:02 PM
HEX: 885043
Reg: HS-TBC
Airline: Thai Airways International   not Thai International Airways
Post by: Runway 31 on August 10, 2012, 03:23:36 PM
Cheers Kenny
Post by: Runway 31 on August 10, 2012, 03:34:00 PM
Ingo,
Its in the d/b but have left the c/n blank.  c/n 20 became D-KOZX and it has been cancelled.
Post by: flygfantast on August 10, 2012, 04:38:54 PM
460912 OH-DLI, Aerospool WT-9 Dynamic LSA, c/n DY-448/2012 LSA, Aero Club of Lappeenranta
See http://www.liy.fi/images/FM_DLI_1.pdf
Niklas
Post by: Runway 31 on August 10, 2012, 04:55:42 PM
Thanks Niklas
Post by: neroon79 on August 11, 2012, 04:04:56 AM
3C1646 (Germany, no flight id, was D-AXLH, which is now 9M-MLA, no details about a new one with reg D-AXLH)
3C662A (Germany, no flight id, decodes to D-AHQJ, but no details about this reg, so can be a decoding error)
3C6631 (Germany, no flight id, decodes to D-AIQQ, same as above)
42428E (UK, flight id: 691, has already populated)
451E9F (Bulgaria, flight id: VIM588, decoding error of 451E97)
4CA252 (Ireland, flight id: RYR5VB, it must be a decoding error, but there are at least four different hex with this flight id in the particular timespan, so now way to tell which one did this flight.)
508292 (Ukraine, flight id: UTN1122, has already populated)
739411 (Israel, flight id: 4XCWW, airframes: 4X-CWW SR22 Cirrus Design Corp SR-22 Private 1118 Mk1EB September 2011: http://www.flugzeugbilder.de/show.php?id=1127859 )
761484 (Pakistan, flight id: ABQ007, has already populated)
AABBF0 (USA, flight id: CKS207, decoding error of AABBF8)
MIL List:
3EB0CC  GAF626   EDDL-LIRF
3EB264  TA40
3F5436  GAF770
3F5479  RAVEN02
3F55AD  T419
3F7573  NOBLE01
3F85C2  TA71
3F9499  SNIPER
3F9B9E  GAF019
3FA303  RAVEN01
That's all from Friday. Have a nice Weekend!
BR Ingo
Post by: Runway 31 on August 11, 2012, 10:02:27 AM
Hi Ingo,
3C1646 D-AXLH, which is now 9M-FFB
42428E  VP-BCJ, Boeing 737-46QF, c/n 28663/2922, Aviatrans Cargo Airlines
508292 UR-UTY, Canadair CL-600-2B19 Regional Jet CRJ-200ER, c/n 7122, UTair Ukraine
761484 AP-EDD, Airbus A320-214, c/n 1467, Airblue
Thanks and have a good weekend
Post by: Kenny on August 11, 2012, 03:25:45 PM
Airport Correction
VTBD (DMK)  Don Mueang Intl  http://en.wikipedia.org/wiki/Don_Mueang_International_Airport
VTBS (BKK)  Suvarnabhumi Airport  http://en.wikipedia.org/wiki/Suvarnabhumi_Airport
LH783  DLH783  KUL FRA via BKK
Post by: Runway 31 on August 11, 2012, 03:29:33 PM
Hi Kenny,
We only update the aircraft table.  Airnav are aware that a (large) number of Airports are missing from the last update and are sorting as we speak
VTBS  Bangkok Suvarnabhumi Airport however is in the d/b
Post by: Kenny on August 11, 2012, 04:28:43 PM
On my screen VTBD shows as Bangkok Intl   which is the old name before VTBS opened.
While VTBS doesn't show any name.
Cheers,
Post by: Runway 31 on August 11, 2012, 05:18:22 PM
What version of the Navdata are you using Kenny?  In the current one from July, VTBS is in it as Bangkok Suvarnabhumi Airport.  If you open up the airport table through DB explorer you will find it as the first entry.
VTBD however isnt in the current d/b
Post by: Kenny on August 12, 2012, 12:27:14 AM
Hi Alan,
I use the standard db from 4.03 with Updater20120525 applied.  Confirm that VTBS is in the top list of airport table but it is not show in the radar.  Only VTBD with Bangkok Intl underneath
Post by: neroon79 on August 12, 2012, 05:17:34 AM
Morning, the unknowns from Saturday:
3C6620 (Germany, no flight id, nothing more)
3C674F (Germany, no flight id, decodes to D-AIZO, will be A320 cn 5441 due to delivery January 2013, so a decoding error I guess)
3D199F (Germany, flight id: DEHYL, D-EHYL DA40 Diamond Aircraft Industries DA-40D TDI Diamond Star >For Sale/Sold< D4.057 source airframes)
3E7BA6 (Germany, flight id: DKMAG, D-KMAG SF25 Scheibe SF 25 B Luftsport-Club Oeventrop e.V. 46112 source: https://www.aeroclub-nrw.org/belege/temp/tmp156201344746226288.pdf / http://www.lsc-oeventrop.de/flugzeuge )
3E7CDD (Germany, flight id: DKMMF, D-KMMF nothing more)
3FEAF0 (Germany, flight id: DMONC, according to airframes 3FEAF0 decodes to D-MJGG TL20 TL Ultralight TL-96 Sting 2000 last eyeballed 2010 / D-MONC might be an Rans aircraft, but nothing specific)
3FEE75 (Germany, flight id: DMKSW, D-MKSW still no luck with the details)
3FF02D (Germany, flight id: DMOVF, D-MOVF same as above)
3FF0C8 (Germany, flight id: DMESN, D-MESN FK9 B & F TECHNIK FK-9 ELA Private[member of LSV Wolfhagen) CN:? source: http://www.edgw.de/flugzeugpark/private-flugzeuge.html )
3FF10F (Germany, flight id: DMJMW, D-MJMW BREZ Aerostyle Breezer Private CN:? determined by picture at Flugzeugforum.de taken July 2012)
3FF199 (Germany, flight id: DMIGX, D-MGIX no details found)
40015F (UK, no flight id, nothing more)
BR Ingo
Post by: neroon79 on August 12, 2012, 07:48:43 AM
Today Morning:
3D07B5 (Germany, flight id: DEBEB, D-EBEB (AT may be FOX) Kitfox 4 Private 1828 sources: http://www.lba.de/cae/servlet/contentblob/22292/publicationFile/1918/T6_LaermLst4.pdf / http://www.kitfox.eu/germany-kitfoxes/dekf-all.html no Mk1EB)
Post by: Runway 31 on August 12, 2012, 09:58:43 AM
Kenny,
Can only state at this time, I dont know. VTBS is in the Navdata and doesnt show, VTDB not in d/b but does show.  Other airports in the area also not in the d/b but show OK.
I will speak to Airnav and try and find out
Post by: Runway 31 on August 12, 2012, 11:04:26 AM
Hi Ingo,
3C6620 unknown to me
D-KMMF unknown to me
3FEAF0 decodes to D-MJGG unknown to me D-MONC Rans S-6 Coyote II, c/n 0494609 so looks like a miscode
3FEE75 D-MKSW still unknown
3FF02D D-MOVF still unknown
3FF199 D-MIGX unknown to me
40015F decodes to VP-BMG CL604 now N698RS.
Note D-EBEB also
Thanks and have a good day
Post by: neroon79 on August 12, 2012, 12:24:37 PM
Consistency request / remark / question:
All other Denney Kitfox Mk 4/IV are in the db as Denney Kitfox Mk 4 only D-EBEB is in the db with AN of Denney Kitfox Mk IV. Is there any difference between Mk IV and Mk 4? If not we should stay with Mk 4 aren't we?
Post by: flygfantast on August 12, 2012, 12:32:51 PM
3FED1C D-MYGG, Impulse 100, c/n unknown
Niklas
Post by: Runway 31 on August 12, 2012, 12:36:25 PM
Point taken Ingo, my d/b had Mk IV and I never checked what the others were.
Post by: Runway 31 on August 12, 2012, 12:39:54 PM
Thanks Niklas
Post by: Runway 31 on August 12, 2012, 03:45:05 PM
Simon,
It would appear that the airport data we see on the maps is not contained in the Navdata but it is contained within one of the dat.files in the data folder.
Post by: Flieger_NDS on August 12, 2012, 04:33:25 PM
Quote from: Runway 31 on July 27, 2012, 07:33:57 PM
My first guess when this reg popped up now got confirmed: It is the latest jet for Aerowest from Hannover, Germany http://www.aerowest.aero/cms/front_content.php?idcat=38&idart=170 (http://www.aerowest.aero/cms/front_content.php?idcat=38&idart=170)
I wonder why neroon79 did not come up with it first, as he is living only "11.75nm ESE of EDDV" ;-)
Post by: neroon79 on August 12, 2012, 04:55:43 PM
Quote from: Flieger_NDS on August 12, 2012, 04:33:25 PM
Because the information wasn't available at the time I searched for it. Operator re-searches are performed, when I'm at the screen and an Bizjet occurs with reg for flight id. In case of D-CAWB I wasn't at the screen at each time of reception. And I have not the time to completely go through my Log-File with 5000+ records a day. The unknown's are usually providing enough do to. So, many thanks for giving the missing detail.
Post by: Runway 31 on August 12, 2012, 05:08:47 PM
Hindsight is a wonderful thing and the information required is not always there when you look for it and sometime you have to wait.
As an example neither Airframes or GAS have anything on the frame and the d/b I use doesnt have the owner either.
Post by: neroon79 on August 12, 2012, 05:11:26 PM
Quote from: Runway 31 on August 12, 2012, 05:08:47 PM
until now! ;-)
Post by: Flieger_NDS on August 12, 2012, 07:49:31 PM
There was no affront intended, but with neroon79 being so close to Hannover, I would have thought he might have guessed it as well that D-CAWB is the latest jet for Aerowest, as they are based there.
Title: Database Update Requests
Post by: Kenny on August 13, 2012, 02:23:38 AM
Quote from: Runway 31 on August 11, 2012, 03:29:33 PM
Hi Kenny,
Hi Runway 31
I'm new to ANRB (a few days)  and found that lots of DD and FD flights have no or incorrect route info.  If I add them in DB Explorer, will they be updated to only me or network as well.   Is there any better options?
Post by: neroon79 on August 13, 2012, 04:27:30 AM
06A0DF (Qatar, flight id: QTR075, decoding error of 06A0DB)
3D1C89 (Germany, flight id: DEJBD, D-EJDB D253 CENTRE EST DR-253 Regent SFG Immelmann e.V. airframes plus "fleet list" on operators website: http://www.sfg-immelmann.de/fliegen/unsere_flugzeuge.htm )
3EC931 (Germany, flight id: DKRDP, last known as to be D-KRDP DIMO Diamond HK-36TC-100 'Super Dimona' Private CN:? last Eye-balled in 2008)
3FF02D (Germany, flight id: DMOVF, still no luck with the details, but airframe is equipped with full ADS-B)
3FF123 (Germany, no flight id, airframes: D-MCCV by JetPhotos.net: FK9 Fk-Lightplanes FK-9 Mk.III Private CN:? Mk1EB May 2012: http://jetphotos.net/viewphoto.php?id=7422818&nseq=0 )
4A0923 (Romania, no flight id, no active airframe found)
That's all from Sunday. Have a nice day and a good start into the new week!
BR Ingo
Post by: neroon79 on August 13, 2012, 04:30:41 AM
Quote from: Flieger_NDS on August 12, 2012, 07:49:31 PM
How did you guessed that this one is owned/operated by Aerowest? I wasn't able to guess that. Neither by using the registration nor by using the airframes hex.
Post by: neroon79 on August 13, 2012, 07:01:49 AM
Operator Update:
D-ERMM 3D32D0 is owned by Aerowest Flugcenter (http://www.flugschule-aerowest.de/flugzeuge.html / picture on the left)
Post by: Runway 31 on August 13, 2012, 07:14:38 AM
Kenny,
For the routes my suggestion is to wait for the next Navdata update.  If adding them onto your own system make sure you time stamp them as I believe that is required. Any you add will only appear on your system.
Post by: Flieger_NDS on August 13, 2012, 07:24:13 AM
Quote from: neroon79 on August 13, 2012, 04:30:41 AM
I was very lucky, because I found the descent-profile (http://dfld.de/Link.php?URL=Mess/ShowProfilSo.php?L=G!E=D!R=31!D=19.07.2012!P=9287!F=Trck-120719So.dat) of D-CAWB into EDDV the day you noted it the first time. Then I was summing up the details: delivery flight into Hannover and the reg is extremely similar to another jet of Aerowest (D-CAWM, Citation XLS+), hence it most likely was a new jet for them. Since then I was waiting for a photo of it or official announcement by Aerowest.
Post by: Runway 31 on August 13, 2012, 07:27:56 AM
Hi Ingo,
3FF02D D-MOVF, yes seen on screen many times
4A0923 decodes to YR-BIC which is now VT-SGK with SpiceJet
Noted the operator info
Thanks again
Post by: Runway 31 on August 13, 2012, 07:28:52 AM
Flieger,
There is no room for guessing when adding to the d/b, if not confirmed it isnt included
Post by: neroon79 on August 13, 2012, 07:43:26 AM
Another recurring guest here is D-CAWU. That's a quite similar reg too, but this one isn't owned by Aerowest. This time your hunch was correct. But in many times these kind of hunches won't be correct. I learned this in the past five years. So I've decided to post guesses only with big commercial airlines based on their hex/reg fleet structures.  With all others I proceed the way you did: Waiting for official announcements ore pictures, if the aircraft is labelled. But I don't actively search for them. Usually I find this Updates by coincidence while looking for other things or during updating activities. If you have the time for recurring searching sweeps of this type: I only can say the better for us all.
Post by: neroon79 on August 13, 2012, 07:51:39 AM
Just received this one:
3FF1A5 (Germany, flight id: DMEEO, no luck with the details.)
Post by: Runway 31 on August 13, 2012, 07:54:55 AM
I cant find any details either Ingo
Post by: neroon79 on August 13, 2012, 05:55:04 PM
Evening, the unknowns from today:
38099A (France, Flight id: AIB01AT, ferry flight of Thai Airways International A388 from, LFBO to EDHI. MSN 100 Test/Temporary reg: F-WWAT, HEX/REG should be added as Airbus Test Registration Various (A380) Airframes
/ source: http://forum.flightradar24.com/threads/1852-Testflights-AIB-****-HAM-%28and-other%29-letters-A-z-fase-of-test/page38?s=607394a853e599888c9ffbd801db30fb)
391543 (France, no flight id, was F-GFKD A320 of Air France CN014 depending on source this one is scrapped/stored since 2010, could find anything about a new one with this hex/reg tie-up)
3C48E8 (Germany, no flight id, was D-ABGH A319 of Air Berlin, this one is re-reged to HB-JOY and transferred to Belair. Nothing about a new one with reg D-ABGH/3C48E8)
3D23E1 (Germany, flight id: DELVL, D-ELVL PA46 Piper PA-46-350P Malibu Mirage Private CN:? Eye-balled seven day ago at EDDV: http://www.flugzeugbilder.de/show.php?id=1161538 )
3F0472 (Germany, flight id: D9179, D-9179 ARC? Schempp-Hirth Arcus ? used by FG Oerlinghausen CN:? http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=1DA61716D1E5F18FFA8DA262D183F08B?dsId=2613165
EDIT:
3FF02D (Germany, flight id: DMOVF, two times today)
440488 (Austria, flight id: MJF702, decoding error of 44048C)
4CA296 (Ireland, no flight id, no active airframe found)
AE2CE8 ( USA MIL, flight id: DEFAULT)
AE2D14 (USA MIL, flight id: INDY02)
C61F97 (No allocation, flight ids FIN14R & FIN38R, obviously a miscoded Finnair airframe)
MIL List:
3EA71B  GAF674
3F41AE  GAF643
3F5542  GAF787   EGWU-LFBD
3F735A  GAF959
3F8300  LIFTER2
3F86E5  LIFTER1
3F8D5C  GAF626   EDDL-LIRF
3F9A43  KAZY8
3F9A43  LIETER3
3FAFE5  EIFEL
That's all for now. Have a nice evening.
Post by: Runway 31 on August 13, 2012, 06:52:26 PM
Hi Ingo,
391543 was F-GFKD A320 broken up for spare, maybe re-using the box and havent re-coded it?
3C48E8 was D-ABGH A319 of Air Berlin, now HB-JOY, miscode old hex ?
C61F97 possibly 461F97 OH-LZB miscoded
Post by: neroon79 on August 13, 2012, 07:04:41 PM
Quote from: Runway 31 on August 13, 2012, 06:52:26 PM
Negative. HB-JOY is in my list (today 3-times / 3 flights) using correct. A decoding error might be possible. But without flight id almost no chance to figure out if it was one and which airframe caused it.
About F-GFKD: Could indeed be a case of inconsequential recycling of parts or it's a good old case of a decoding error.
Post by: neroon79 on August 13, 2012, 07:10:22 PM
QuoteC61F97 possibly 461F97 OH-LZB miscoded
OH-LZB did FIN38R with correct hex at nearly the same time as the miscoded airframe did today.
Post by: Runway 31 on August 13, 2012, 07:14:46 PM
Thanks Ingo,
Looks like the Finnair is sending out 2 codes at nearly the same time
Post by: neroon79 on August 13, 2012, 07:19:22 PM
Quote from: Runway 31 on August 13, 2012, 07:14:46 PM
Thanks Ingo,
Sorry there was missing one word in my text. Brain is faster then fingers syndrome.
OH-LZB did FIN38R yesterday with correct hex at nearly the same time as the miscoded airframe did today.
Post by: Runway 31 on August 13, 2012, 07:34:38 PM
OK Ingo
Post by: neroon79 on August 13, 2012, 07:38:48 PM
Confirming required:
3D21E1 D-ELVL has populated as Piper PA-36-350P Malibu Mirage is this correct? Should be Piper PA-46-350P Malibu Mirage aren't it?
Post by: Runway 31 on August 13, 2012, 07:43:40 PM
Correct PA-46
Post by: neroon79 on August 14, 2012, 05:07:40 AM
Morning, some additional unknowns from yesterday evening:
3C493C (Germany, no flight id, second time received. Again no luck with the details)
44D233 (decoding error of 44D033)
44D233 (either a decoding error caused by 44D23A or 44D23B)
4CA76B (decoding error of 4CA76A)
Have a nice Day!
BR Ingo
Post by: GreekSpy2001 on August 14, 2012, 02:09:36 PM
noted this today
   AE1191  SPEED31                  03-0016 C560  US - Army            2012/08/14 13:26:37
however this callsign was reported as an F-15 out of LN today.  So hex probably needs to be changed to TACTICAL.
Graham
Post by: Runway 31 on August 14, 2012, 04:06:13 PM
Graham
AE1191 is the code allocated to the UC-35B.  However a look at the mode-s forum logs shows that is appears to also be in use by an F-15 as you state.
Yesterday AE1191 was noted by a box in Atlanta US no callsign noted and in Middlesex and the Netherlands using callsigns BOLAR31 and GINIS31 so looks like the F-15 is miscoding
Will amend thed/b and change the details to read in use by various aircraft
Post by: neroon79 on August 14, 2012, 04:14:52 PM
3CD055 (Germany, flight id: GFD91, decoding error of3CD05D)
3D32D6 (Germany, flight id: DERMS, no luck with the details)
3D3FA2 (Germany, flight id: DEMIS, D-EWIS RV6 Vans Aircraft RV-6 Private CN:? Mk1EB Jan 2012: http://www.luftfahrtclubbraunschweig.de/picdb/Swen-E-Johannes-Privat-Vans-Aircraft-RV-6-D-EWIS-BWE-Braunschweig-Wolfsburg-7927.html )
3FF04E (Germany, flight id: DMKKZ, still no luck with the details)
3FF0F4 (Germany, flight id: DMYPS, D-MYPS Mk1EB 2012: http://foobla.wigbels.de/wp-content/uploads/2012/05/DSC03561.jpg )
4780A6 (Norway, no flight id, nothing more)
AE2E5B (USA MIL, flight id: STICK02, various)
E09B31 (Argentina, no flight id, seems to be miscoded MIL airframe(s) )
MIL List:
3E9FD1  GAF626   EDDL-LIRF
3E9FD1  TA70
3EB870  BU23T
3F7520  GAF777
3F7520  TA68
3F8A79
3FA30C  LIFTER3
That's all for now. Have a nice evening!
BR Ingo
Post by: Runway 31 on August 14, 2012, 05:38:45 PM
Hi Ingo,
3D32D6 (unknown to me
3D3FA2 already in d/b
3FF04E D-MKKZ, Evektor EV-97 EuroStar c/n EV97-0253
3FF0F4 D-MYPS Mk1EB 2012: http://foobla.wigbels.de/wp-content/uploads/2012/05/DSC03561.jpg ) anyone able to ID aircraft type please
4780A6 unknown to me
AE2E5B (USA MIL Tactical
E09B31 Netherlands - Air Force F16 but no details known
3C493C unknown to me
Thanks again and have a good evening as well
Post by: Northern Watch on August 14, 2012, 06:19:26 PM
Quote3FF0F4 D-MYPS Mk1EB 2012: http://foobla.wigbels.de/wp-content/uploads/2012/05/DSC03561.jpg ) anyone able to ID aircraft type please
Evening Alan
Looks like a Pipistrel Sinus to me.
Keith
Post by: Runway 31 on August 14, 2012, 06:25:38 PM
Good lad Keith
Post by: neroon79 on August 15, 2012, 02:59:12 AM
Morning, some additional from yesterday:
3D3FA2  D-EWIS does not populate and do disappear from local db after manual adding and using the populate function of MyLog.
3FB1D1 (Germany, no flight id, nothing more)
3FF1B5 (Germany, no flight id, nothing more)
4784C6 (Norway, no flight id, nothing more)
89613A (UAE, no flight id, nothing more)
A9ED8A (USA, no flight id, decodes to N739LX, nothing about a new airframe using this Reg. Maybe a decoding error again.)
Have a nice Day!
Ingo
Post by: Kenny on August 15, 2012, 04:01:56 AM
Quote from: Runway 31 on August 13, 2012, 07:14:38 AM
Kenny,
Not sure when the new Navdata will be released.  Just a heads up on route.
Starting Oct 1,2012 all Thai Air Asia (AIQ) flight will operate from VTBD instead of VTBS.
http://www.airasia.com/th/en/latestnews/bangkok-move-don-mueang-airport.page
Post by: flygfantast on August 15, 2012, 05:18:57 AM
Alan,
Not populating C61F97 using c/s of Finnair, appeared for the first time this monday (FIN14R) and was using ADS-B.
Niklas
Post by: X on August 15, 2012, 05:54:24 AM
Unknown MOW regular miscode 7FF3FF uses c/s GABLESEN which is common on USN C2's so very unlikely to be in Moscow, however looking back at last two years GABLESEN was used by the following TU3 on four occasions and was seen on deck at DME on Monday.
150026  GABLESEN                 RA-65574 T134  Kosmos Aviation C... 2011/02/09 18:11:46
It could now be miscoding as I have not picked RA-65574 going in our out, but cannot give 100% verification.
X
Post by: Runway 31 on August 15, 2012, 07:25:23 AM
Hi Ingo,
3D3FA2  D-EWIS RV6 is in the d/b being added 13:28 29/05/2012, checked my d/b explorer and its their so have no idea why you dont have it in yours.
3FB1D1 unknown probable Mil tac
3FF1B5 unknown to me
4784C6 unknown to me
89613A unknown to me
A9ED8A N739LX, presumed decoding or miscode
Post by: Runway 31 on August 15, 2012, 07:27:03 AM
Kenny,
The updaters dont add routes these are generated from what  I cant gather automatically from where the sysytem sees the aircraft landing and departing and from various routings sources.
Other
Post by: Runway 31 on August 15, 2012, 07:30:35 AM
Hilas,
Suggestions elsewhere that C61F97 possibly 461F97 OH-LZB miscoded but Ingo suggests otherwise and nothing confirmed.
Post by: Runway 31 on August 15, 2012, 07:31:44 AM
Thanks X, verification would be nice.
Post by: X on August 15, 2012, 09:17:42 AM
Just to add to my thoughts it appears that 7FF3FF is in DME on M,W,F arriving approx 0930 departing 1930. Fits a scheduled service and RA-65574 was seen parked all day DME on the terminal ramp area on both Friday and Monday.
X
Post by: chewycanes on August 15, 2012, 02:37:24 PM
Hi Alan
AE127F 73-1586 EC130 USAF (from AF)
43E731 M-ERIT AW139 mercury Eng (from AF)
Brian
Post by: Runway 31 on August 15, 2012, 02:55:31 PM
Thanks Brian,
43E731 decodes to M-ERIT, however it became A6-AWP with Abu Dhabi Aviation in January 2011 unless it has reverted back to the Manx or its a re-issue of the registration.  Bones still as it as having become A6-AWP
Post by: chewycanes on August 15, 2012, 03:11:29 PM
OK Thanks Alan
Brian
Post by: flygfantast on August 15, 2012, 04:59:32 PM
4A8694 SE-ATT, Piper J3C-65, c/n 11979-588, Gunvor V Lundqvist
4A8308 60112, Saab SK60A, c/n 60112, Sweden - Air Force
4A8309 60114, Saab SK60A, c/n 60114, Sweden - Air Force
4A830A 60115, Saab SK60A, c/n 60115, Sweden - Air Force
4A8311 60129, Saab SK60A, c/n 60129, Sweden - Air Force
Niklas
Post by: Runway 31 on August 15, 2012, 05:33:39 PM
Thanks Niklas, you have been busy today.
Post by: neroon79 on August 15, 2012, 05:43:04 PM
3CD055 (Germany, flight id: GFD32, may be a decoding error)
3D2B95 (Germany, flight id: DEOTH, D-EOTH BREZ Aerostyle Breezer B600 Luftsport-Club Dümpel e. V. CN:? source: http://www.lsc-duempel.de/motorflug/flugzeugpark.html )
3D3563 (Germany, flight id: DESLV, D-ESLV A210 Aquilla AT-01 Luftfahrtverein Essen e.V. CN:? source: http://www.luftfahrtverein-essen.de/index.php?option=com_content&view=article&id=91&Itemid=117 )
3FEF72 (Germany, flight id: DMBIO, D-MBIO CH70 ZENAIR CH.701 STOL Private CN:? source: DULV and http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MBIO )
3FF088 (Germany, flight id: DMEIK, D-MEIK CH60 Zenair CH-602XL Zodiac Private CN:? sources: http://sfgmendig.jimdo.com/ search function on this page: http://www.lph2o.com/Library-||-Photo-Gallery-|-Aircraft-Database.html and dulv )
3FF121 (Germany, flight id: DMDOK, D-MDOK nothing more)
4009C1 (UK, flight id: BAW85WA, deciding error of 4009C5)
4405E2 (Austria, flight id: OEDSW, OE-DSW C182 Cessna 182T SKYLANE Union Sportfliegergruppe Ybbs CN:? source: http://www.lolg.at/htdocs/www/index.php?option=com_content&view=article&id=27%3Aoe-dsw-c182t-skylane&catid=6%3Amotorflugzeuge&Itemid=9 )
44915B (Belgium, no flight id, nothing more)
4D0366 (Luxembourg, no flight id, nothing more)
894028 (Bahrain, flight id: GFA003, decoding error of 89402C)
AE2D32 (USA MIL, flight id: HOSS01)
AE2E56 (USA MIL, flight id: HOSS02)
MIL List:
3E9C1A  AXEMAN13
3E9FD1  GAF666   EDDT-BIKF
3EB35A
3EB35A  GAF699
3F58AD
3F7520  TA47
3F7B9F  SNIPER1
3F8228  NOBLE
3F90C1
3FA15B  TA45
3FA3B5  GAF811
3FA4A5  GAMG60A
3FB5B4
BR Ingo
Post by: Runway 31 on August 15, 2012, 06:44:42 PM
Evening Ingo,
3CD055 decodesto D-CGEV unknown to me
3FF121 D-MDOK unknown to me
4405E2 OE-DSW C182 is allocated 4405E3 so miscode
44915B unknown to me
4D0366 decodes to LX-MAX, previous is preserved, unaware of reallocation
AE2D32 Tactical
AE2E56 Tactical
3FA3B5  71+53 UH1
3FA4A5  73+65 UH1
You have been busy as well,thanks again
Post by: Kenny on August 15, 2012, 09:00:15 PM
The unknown reg and A/C Type today
76CEC2   Singapore  SIA981
780586   China  CHH7960
7803E4   China  3U8810
Post by: neroon79 on August 16, 2012, 02:43:50 AM
Morning, one additional from yesterday evening:
3C1E76 (Germany, no flight id, nothing more)
Have an nice Day!
Ingo
Post by: flygfantast on August 16, 2012, 05:01:45 AM
Morning Alan,
Unknown from yesterday 4603CC
Niklas
Post by: Runway 31 on August 16, 2012, 07:45:10 AM
Hi Kenny,
76CEC2   9V-SVB, Boeing 777-212ER, 28525/353, Singapore Airlines was V8-BLD now returned
780586   B-5465 B738 Hainan Airlines, in d/b since 9/6/2010
7803E4   B-6323 A320, Sichaun Airlines in d/b since 8/6/2010
Post by: Runway 31 on August 16, 2012, 07:46:20 AM
Morning Ingo,
3C1E76 unknown to me
Post by: Runway 31 on August 16, 2012, 07:51:21 AM
Niklas,
4603CC decodes to OH-BLK which unless it has been re-allocated, was a Queen Air cancelled from the register in 2005.
Post by: Judwin45 on August 16, 2012, 11:29:23 AM
Hi Alan
Not sure if you have this one. 43C632, Sea King HAR3A, cn WA1007, ZH541.
Post by: Runway 31 on August 16, 2012, 11:50:22 AM
Hi Keith,
Thanks for that.
Post by: neroon79 on August 16, 2012, 05:27:51 PM
3C4931 (Germany, flight id: DLH2990, decoding error of 3C4935)
3C4931 (Germany, flight id: DLH6TU, decoding error of 3C4939)
3D143B (Germany, no flight id, D-EFXJ A210 Aquila AT01 RWL German Flight Academy CN:? Mk1EB: http://www.flugzeugbilder.de/show.php?id=1078333 )
3E61BA (Germany, flight id: DKCFA, Was/Is Glaser Dirks DG-808C 8-410 )
405A4C (UK, no flight id, nothing more)
4BD14F (Turkey, no flight id, nothing more)
MIL List:
3E8032  EIFEL
3E8032  GAFE01
3EA360  GAF320   EDDF-KDEN
3EB437
3F71CD  LIFTER3
3F722E  FLAME29
3F8F7C  TA48
3FAD8D  LIFTER2
Ingo
Post by: Runway 31 on August 16, 2012, 05:51:00 PM
Evening Ingo,
3E61BA decodes to D-KCFA, unknown to me c/n should be 8-***B***X*
405A4C not assigned by CAA
4BD14F decodes to TC-TJO unknown to me
Thanks again and have a good one too
Post by: flygfantast on August 16, 2012, 07:27:39 PM
Evening Alan
4A95C7 SE-ENG, MFI-9B, c/n 054-112, Lars-Erik Larsson
Niklas
Post by: X on August 17, 2012, 10:35:22 AM
Back in the sandpit and four unknowns
* 508254                                                              2012/08/17 00:36:18
* 515261                                                              2012/08/17 05:28:26
* 762043                                                              2012/08/17 11:00:43
* AE1D8A                                                              2012/08/17 03:29:15  (either P3 or Herc)
X
Post by: Runway 31 on August 17, 2012, 12:28:27 PM
Hi X
508254  UR-CJO, Airbus A320-231, c/n 354,  Khors Aircompany/Iran Air Tours
515261  unknown to me
762043  unknown to me
AE1D8A unknown to me
Post by: Xon on August 17, 2012, 01:11:13 PM
489325 SP-EQF DH8D c/n 4422
Post by: Runway 31 on August 17, 2012, 01:14:21 PM
Thanks again Xon
Post by: lebelgepatte on August 17, 2012, 01:59:22 PM
hi,
G-ISSU EC55 is changed to belgium oo-nhp
Post by: Runway 31 on August 17, 2012, 02:19:46 PM
44B910, OO-NHP, Eurocopter EC155 B1, Noordzee Helikopters
Post by: Runway 31 on August 17, 2012, 03:10:37 PM
Niklas,
Regarding 4A8694 SE-ATT, Piper J3C-65, can you confirm the hex please because I have also had a report of it being 4A8964.
Thanks for the response Niklas
Post by: flygfantast on August 17, 2012, 06:49:00 PM
Quote from: Runway 31 on August 17, 2012, 03:10:37 PM
Niklas,
Alan,
I can confirm that the hex was 4A8694.
Niklas
Post by: flygfantast on August 17, 2012, 06:49:48 PM
Not populating: 78094D (China) 1208 msgs received during 50 mins at FL190, no c/s.
Niklas
Post by: Runway 31 on August 17, 2012, 07:07:00 PM
Thanks Niklas, noted your response.
Cant add anything to 78094D other than noting it was first picked up 15th
Post by: X on August 18, 2012, 07:20:36 AM
New visitor to sandpit
800709  VT-ZST CL60 Challenger CL604 5629 Zest Aviation
X
Post by: neroon79 on August 18, 2012, 07:45:17 AM
Morning!
Some to check and amend:
3E167E D-HZSG is in the db with operator Bundespolizei. The operator shall be Bundesministerium des Innern (BMI), as this one is one of the bright orange MEDEVAC helicopters operated by the BMI. D-HZSG is currently servicing as CHX4 here in Hannover.
Please check the following too:
3E1678 D-HZSA (in database with operator Luftrettung Bundesministerium Des Innern)*
3E1679 D-HZSB (in my db with Bundesministerium des Innern)
3E167A D-HZSC (in db with entry Luftrettung, but is operated by BMI)
3E167B D-HZSD (in db with entry Luftrettung, but is operated by BMI)
3E167C D-HZSE (in my db with Bundesministerium des Innern)
3E167D D-HZSF (in my db with Bundesministerium des Innern)
3E167E D-HZSG (detailed mentioned above)
3E167F D-HZSH (The 'D' in des is upper-case, but need to be lower-case)
3E1680 D-HZSI (in db with entry Bundespolizei, but is operated by BMI)
3E1681 D-HZSJ (in db with entry Bundespolizei, but is operated by BMI)
3E1682 D-HZSK (in db with entry Bundespolizei, but is operated by BMI)
3E1683 D-HZSL (in db with entry Bundespolizei, but is operated by BMI)
3E1684 D-HZSM (in db with entry Luftrettung Bundesministerium)
3E1685 D-HZSN (in db with entry Bundespolizei, but is operated by BMI)
3E1686 D-HZSO (in my db with Bundesministerium des Innern)
3E1687 D-HZSP (in my db with Bundesministerium des Innern)
checked all listed registrations. All Helicopters are the bright orange ones operated by the BMI.
* We should fix to one common entry:
All Bundesministerium des Innern shall either be Bundesministerium des Innern or, if we decide to give the additional information "Luftrettung" in-front of the operator itself, Luftrettung Bundesministerium des Innern.
The unknowns from yesterday are following...
Post by: Runway 31 on August 18, 2012, 08:01:59 AM
Thanks X
Post by: Runway 31 on August 18, 2012, 08:06:55 AM
Thanks Ingo,
All standardised to Bundesministerium des Innern
Post by: neroon79 on August 18, 2012, 08:44:49 AM
The unknowns from Friday:
3442D4 (Spain, no flight id, nothing more)
3C630C (Germany, no flight id, decodes to D-AHXL, nothing about an active airframe using this reg. So I presume a decoding error)
3D9818 (Germany, no flight id, decodes to D-GDVS, but on airframe it is mentioned that this could also be D-GDVK repeatingly sending false hex. )
3DAFA5 (Germany, flight id: DGMTP, nothing more found)
3FCA51 (Germany, no flight id, D-OOAZ BALL Colt Balloons Ltd Cold 90  Thomas Ruchay 4928 sources: http://www.airport-data.com/aircraft/photo/555670.html & http://www.ballonfahrer-online.de/bo_datenbank/datenbank_datenblatt.php?id=780)
3FEBD9 (Germany, flight id: DMUSP, no luck with the details)
3FF009 (Germany, flight id: DMYQR, D-MYQR ULAC P&M Quick-R 912S Private CN:? last Mk1EB April 2012 posted at flugzeugforum.de)
3FF0C2 (Germany, flight id: DMKPC, D-MKPC FK9 B & F Technik Vertriebs GmbH Speyer FK 9 ELA Flugschule Klaus Pöllmann CN:? source: http://www.ul-fliegen.eu/mitte3.html )
3FF187 (Germany, flight id: DMXSE, D-MXSE WT9 Aerospool WT-9 Dynamic Private CN:? source DULV / http://mail.dulv.de/fmi/xsl/LTA/browserecord.xsl?-lay=LTA-Web-Details&-recid=9172&-find=-find )
3FF1B4 (Germany, flight id: DMKUN, D-MKUN C42 Ikarus C-42 Private CN:? Mk1EB May 2009: http://www.abpic.co.uk/photo/1176455/ )
424295 (UK, flight id: ORB9401, ORB: Orenburg Airlines, nothing more)
484F10 (Netherlands, no flight id, could be a decoding error)
484FB5 (Netherlands, no flight id, nothing more)
4891A8 (Poland. flight id: ENT734T, SP-ENI B734 Boeing B737-43Q Enter Air cn 28489 / ln 2827 source: http://www.planespotters.net/Production_List/Boeing/737/28489,SP-ENI-Enter-Air.php confirming: http://www.airfleets.net/ficheapp/plane-b737-28489.htm )
4A0091 (Romania, flight id: FAT7RG, still no luck with this one)
780900 (China, flight id: TBA5256, already populated to Database)
780955 (China, no flight id, already populated to Database)
A2B922 (USA, no flight id, would match to N275AU, nothing about a new airframe using this reg. )
MIL List:
3E8BDD  TA69
3E991D  GAF960
3F9DCC  GAF019
3F9DCC  GAF019
That's all from yesterday. Have a nice Weekend!
BR Ingo
Post by: neroon79 on August 18, 2012, 08:46:27 AM
Quote from: Runway 31 on August 18, 2012, 08:06:55 AM
Thanks Ingo,
Did the same. Thanks!
Post by: Runway 31 on August 18, 2012, 11:22:32 AM
Hi Ingo,
3442D4 unknown to me
3DAFA5 D-GMTP, unknown to me
3FEBD9 D-MUSP, unknown to me
3FF009 D-MYQR ULAC P&M Quick-R 912S c/n 8573
3FF1B4 D-MKUN C42 Ikarus C-42 c/n C42-0081
424295 VP-BEI, Boeing 737-86J, c/n 30881/1067, Orenair
484F10 unknown to me
484FB5 PH-KMF, SOCATA TB20 Trinidad GT
4A0091 as its flight ID is FAT7RG, I am going to hazard a guess it is 4B0091 HB-AFP Miscoding
Regards and have a good weekend
Post by: X on August 18, 2012, 11:36:22 AM
* 51526E  NAS502                                                      2012/08/18 15:23:03
This is EY-622 A320
HS-TXC  en route DXB on delivery, assume code is already in db
X
Post by: Runway 31 on August 18, 2012, 12:24:41 PM
Hi X
Yes 885303 HS-TXC, Airbus A320-214, c/n 5258, Thai Smile already in d/b
I have EY-622 now as E7-SKB with Sky Bosnia/Iraqi Airways since around about May this year so I guess it still using its old hex.  It went to EX-32003 after being EY-622 and is now E7-SKB.
Post by: X on August 18, 2012, 01:22:42 PM
Maybe I didn't make it clear enough. E7-SKB has changed back to EY-622 and was seen as such on take off DXB on f/n NAS502.
X
Post by: Runway 31 on August 18, 2012, 01:46:40 PM
My apologies X, as you can see from my answer that not how I picked you up.  I presume its back with East Air who have sub leased it to Nasair
Post by: EK01 on August 18, 2012, 07:09:58 PM
Alan,
Just flown over :
Mode S : 780901
Flight ID : HBH3208 = Hebei Airlines
Post by: chewycanes on August 18, 2012, 07:13:07 PM
Evening Alan
402749 G-BMXC C152 (FROM AF)
Brian
Post by: Runway 31 on August 18, 2012, 07:17:23 PM
Hi Ian
Picked it up as well, but was out with the dogs
780901 B-3208, Embraer 190-100AR, c/n 19000566, Hebei Airlines
Post by: Runway 31 on August 18, 2012, 07:23:14 PM
Evening Brian,
Thanks again
Post by: EK01 on August 18, 2012, 07:25:25 PM
Quote from: Runway 31 on August 18, 2012, 07:17:23 PM
Hi Ian
What you mean is you were sitting outside with a glass of the Scottish wine !
Cheers.
Post by: Xon on August 18, 2012, 08:24:55 PM
50829F UR-UTL AT72 c/n 1037 (UTair-Ukraine)
Post by: neroon79 on August 19, 2012, 04:41:43 AM
12E729 (Russian Federation, no flight id, nothing more)
3D2EFB (Germany, flight id: DEQAT, still no luck with the details)
3FEA03 (Germany, no flight id, D-MMFH EV97 Evektor EV-97 EuroStar Flugschule Hamburg CN:? sources: airframes and operator website: http://www.flugschule-hamburg.de/flugzeugcharter/ultraleicht )
3FEF02 (Germany, flight id: DMUHC, D-MUHC FDCT Flight Design CTsw Private CN:? source: http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MUHC confirming information: http://www.govfr.com/aircraft_D-MUHC-FDCT_-1_4899.html )
3FF06E (Germany, flight id: DMNYC, D-MNYC CDUS AutoGyro Calidus Private CN:? source/Mk1EB Sep. 2011: http://spotters.net.ua/file/?id=55400 )
3FF0A3 (Germany, flight id: DMOAF, D-MOAF  ECHO Tecnam P-92 Echo Private CN:? sources: http://www.dulv.de/fmi/xsl/LTA/browserecord.xsl?-lay=LTA-Web-Details&-recid=9277&-find=-find & http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MOAF )
3FF102 (Germany, flight id: DMJSA, still no luck with the details)
3FF144 (Germany, flight id: DMRTX, D-MRTX FK14 B & F TECHNIK FK-14 Le Mans Private 145 source: http://www.airport-data.com/aircraft/photo/762690.html )
3FF1B1 (Germany, no flight id, nothing more / receives two times, 5 hours between the two)
4009C2 (UK, no flight id, was G-GSSB, but this one is re-registered and is now N475MC of Atlas Air. Nothing about a new one with reg G-GSSB)
408000 (UK, flight id: NAX9LC, NAX: Norwegian Air Shuttle, possibly a decoding error)
800709 (India, flight id: VTZST, already populated to my db.)
That's it for Saturday. Have a nice and peaceful Sunday.
BR Ingo
Post by: paul tricker on August 19, 2012, 05:29:58 AM
424139  VPCBE                    VP-CAM  F2TH
just went OTT BUT was an A330
A330-202  1321 VP-CBE  unk
Rgds
Paul
Post by: Runway 31 on August 19, 2012, 06:59:19 AM
Hi Paul,
424139 VP-CBE, Airbus A330-343E, c/n 1321, HongKong Jet  f/f 6/6, in d/b since 25/7
Post by: Runway 31 on August 19, 2012, 07:00:22 AM
Quote from: EK01 on August 18, 2012, 07:25:25 PM
Hi Ian
Cheers.
Nah Spanish wine is cheaper!!
Post by: Runway 31 on August 19, 2012, 07:00:44 AM
Thanks Xon
Post by: paul tricker on August 19, 2012, 07:11:25 AM
Quote from: Runway 31 on August 19, 2012, 06:59:19 AM
Hi Paul,
It is NOT an A330-343, it is only a 202 series.
I guess it showed as a F2TH as I had picked that up previously.
Paul
Post by: Runway 31 on August 19, 2012, 07:45:33 AM
Thanks Paul I will ask AvDb to amend, I checked on there instead of the d/b. The d/b has it as a 202 as you state.
The A332 is in the new Navdata hopefully out today.
Post by: paul tricker on August 19, 2012, 07:57:33 AM
[/quote] I will look for it later on/tomorrow. Many thanks as always for all your hard work
Paul
Post by: 54901 - Jim on August 19, 2012, 01:21:24 PM
Hello, Alan!  Here are several items missing from the new DB ...
A80002 / N6140R / C72R / Cessna 172RG / Ricardo Alberto McCullough / 172RG0092
AB29EB / N8183X / P28B / Piper PA28-236 / Comelis De Jong / 28-8011075
A74E6A / N570AA / MD83 / McDonnell-Douglas MD83 / American Airlines / 49352
Thanks!
Post by: Runway 31 on August 19, 2012, 01:56:01 PM
Thanks Jim
I have the MD83 in storage at Roswell, good to know its back in the air
Post by: 54901 - Jim on August 19, 2012, 02:33:13 PM
More updates for you ...
AD7D7F / N9689P - Terry M Johnson
AD88A8 / N971PG - Pegasus Aviation V LLC
AC95CB / N91RB - Russell E Ginn
AC5F6A / N897AW - Audrey Enterprise LLC
AA0D70 / N747KD - Wells Fargo Bank Northwest NA Trustee
A97B39 / N71RP - Randy T Pinkston
A96EB5 / N707BN - Wilmington Trust Co
A9ADA0 / N7222H - 7222H LLC
A687AD / N52ME - Coral Aviation Group LLC
A7623C / N575NV - International Air Services Inc Trustee
A7492D / N569JM - Southern Aircraft Consultancy Inc Trustee
A68AD7 / N520VP - Turbine Air LLC
A5B39F / N467AC - Billy E Thompson
A526DA / N431AE - Bell Helicopter Textron Inc
A5D202 / N474WZ - Turbines Ltd
A39413 / N33GG - Wild Goose LLC
A393FF / N33FM - Cessna Aircraft Company
A39D81 / N332CT - Super Puma LLC
A2A936 / N27023 - Cascade Seaplane Association LLC
A197EA / N201YK - FAA Registrations LLC Trustee
A076C4 / N129SU - Marco Aldo Di Bernado
A1E4C4 / N221AM - Michel Adam De Villers
A1E1D4 / N220JL - Juliet Charlie LLC
A1683F / N190AV - 888 Aircraft
Thanks!
Post by: Runway 31 on August 19, 2012, 02:58:13 PM
Many thanks again Jim
Post by: Runway 31 on August 19, 2012, 05:27:27 PM
Hi Ingo,
Peaceful and relaxing day had by me here in Spain, hope you had the same.
12E729 unknown to me
3D2EFB DEQAT, still unknown to me
3FEA03 D-MMFH c/n EV97-0052
3FEFE9 D-MDDO, still unknown to me
3FF102 D-MJSA,still unknown
3FF1B1 unknown to me
4009C2 Can only presume a miscode/decoding error
Thanks again
Post by: flygfantast on August 19, 2012, 08:11:50 PM
45A593 OY-ILS, Vulcanair P.68 Observer 2, c/n 466-36/OB2, BioFlight A/S
See: http://bioflight.dk/images/oyils_big.jpg
Niklas
Post by: neroon79 on August 20, 2012, 02:55:21 AM
Morning, some unknowns from Sunday:
1st:
That's strongest flight id misbehaviour I've ever noticed:
* 1C7D94  H1GX                                                        2012/08/19 08:50:40
* 1C7D94  H27X0                                                       2012/08/19 08:51:33
* 1C7D94  I1OX                                                        2012/08/19 08:50:13
* 1C7D94  I27X0                                                       2012/08/19 08:51:40
* 1C7D94  I3GX0                                                       2012/08/19 08:51:53
* 1C7D94  I3GX0                                                       2012/08/19 08:52:06
* 1C7D94  J17XP                                                       2012/08/19 08:54:56
* 1C7D94  J1WX                                                        2012/08/19 08:49:34
* 1C7D94  J1WX0                                                       2012/08/19 08:48:54
* 1C7D94  J3WX                                                        2012/08/19 08:53:07
* 1C7D94  K1OX0                                                       2012/08/19 08:48:20
* 1C7D94  K1OX0                                                       2012/08/19 08:48:34
* 1C7D94  K2GX                                                        2012/08/19 08:53:40
* 1C7D94  K2GX0                                                       2012/08/19 08:48:00
* 1C7D94  K2OXP                                                       2012/08/19 08:55:23
* 1C7D94  K2WX                                                        2012/08/19 08:54:22
* 1C7D94  K2WXP                                                       2012/08/19 08:54:16
* 1C7D94  M2OXP                                                       2012/08/19 08:56:50
* 1C7D94  M3GX                                                        2012/08/19 08:56:03
* 1C7D94  M3OX                                                        2012/08/19 08:57:50
* 1C7D94  N27XP                                                       2012/08/19 08:57:03
* 1C7D94  N37X                                                        2012/08/19 08:59:45
* 1C7D94  N3GXP                                                       2012/08/19 08:57:29
* 1C7D94  N3OX                                                        2012/08/19 08:56:36
* 1C7D94  N3WX                                                        2012/08/19 08:56:30
* 1C7D94  N3WX                                                        2012/08/19 08:58:38
* 1C7D94  N3WX                                                        2012/08/19 09:02:19
* 1C7D94  N4GX                                                        2012/08/19 08:59:38
* 1C7D94  N4GX                                                        2012/08/19 09:00:12
* 1C7D94  N4OX                                                        2012/08/19 09:00:05
* 1C7D94  O3OX                                                        2012/08/19 09:00:32
* 1C7D94  O3WX                                                        2012/08/19 09:00:25
* 1C7D94  O4GX                                                        2012/08/19 08:59:32
* 1C7D94  O4OX                                                        2012/08/19 08:59:05
* 1C7D94  OLT628                                                      2012/08/19 08:47:14
* 1C7D94  OLT628                                                      2012/08/19 08:48:28
* 1C7D94  OLT628                                                      2012/08/19 08:49:01
* 1C7D94  OLT628                                                      2012/08/19 08:50:00
* 1C7D94  OLT628                                                      2012/08/19 08:50:26
* 1C7D94  OLT628                                                      2012/08/19 08:50:53
* 1C7D94  OLT628                                                      2012/08/19 08:52:00
* 1C7D94  OLT628                                                      2012/08/19 08:52:20
* 1C7D94  OLT628                                                      2012/08/19 08:53:27
* 1C7D94  OLT628                                                      2012/08/19 08:53:54
* 1C7D94  OLT628                                                      2012/08/19 08:54:29
* 1C7D94  OLT628                                                      2012/08/19 08:55:10
* 1C7D94  OLT628                                                      2012/08/19 08:56:10
* 1C7D94  OLT628                                                      2012/08/19 08:57:09
* 1C7D94  OLT628                                                      2012/08/19 08:57:57
* 1C7D94  OLT628                                                      2012/08/19 08:58:58
* 1C7D94  OLT628                                                      2012/08/19 08:59:11
* 1C7D94  OLT628                                                      2012/08/19 08:59:52
* 1C7D94  OLT628                                                      2012/08/19 09:00:59
* 1C7D94  OLT628                                                      2012/08/19 09:01:32
* 1C7D94  OLT628                                                      2012/08/19 09:01:52
* 1C7D94  OLT628                                                      2012/08/19 09:02:52
* 1C7D94  OLT629   LLBG-EHAM-LFPG                                     2012/08/19 05:48:07
* 1C7D94  P37X                                                        2012/08/19 09:00:52
* 1C7D94  P3OX                                                        2012/08/19 09:01:19
* 1C7D94  P3WX
3C5CB6 (Germany, no flight id, nothing more)
3D0D1B (Germany, no flight id, airframes: D-EDFF C172 Cessna F 172 H Skyhawk Private CN:? Mk1EB 2009: http://www.flugzeug-bild.de/name/einzelbild/number/18516/kategorie/kleinflugzeuge~sportflugzeuge~cessna-172-skyhawk.html 2011: http://www.str-spotting.de/index.php?p=result&Reg=D-EDFF )
3D2563 (Germany, no flight id, still no luck with the details)
3D2EFB (Germany, flight id DEQAT, received again)
3DAFA5 (Germany, flight id: DGMTP, received again)
3FEBD9 (Germany, flight id: DMUSP, received again)
3FEDE6 (Germany, flight id: ZZZZZZZ, still no luck with the details)
That's all for now. The rest will follow (much) later today.
BR Ingo
Post by: X on August 20, 2012, 06:05:05 AM
Something weird is up with new db, this a/c is well known for years and is A6-ERQ A343 EK and is still in service. This mornings report shows it as unknown?
   896090  UAE176   ULLI-OMDB                                           2012/08/20 00:34:03
   896090  UAE564   OMDB-VOBL                                          2012/08/20 03:55:01
The night I left to MOW  4/8/12 (and nearly everyday for four years)
   896090  UAE924   HECA-OMDB       A6-ERQ  A343  Emirates             2012/08/04 00:07:52
Strange one this.
X
Post by: X on August 20, 2012, 06:18:47 AM
Another curious one as DUB002 is normally the Big Bosses plane hex 8960AE, but today c/s turns up on 8961BC which is an old hex from A6-RZJ long gone PRM1 which became N37019!
* 8961BC  DUB002   EGSS-OMDB                                          2012/08/20 03:54:12
Normally Dubai 2 (or DUB002) is A6-MMM
    8960AE  A6-MMM   Boeing 747-422   26906   Dubai Air Wing   Uses fixed ATC callsign of Dubai 2.
Did anyone in Blighty pick this up departing EGSS (as per report?)
X
Post by: Runway 31 on August 20, 2012, 08:13:30 AM
Thanks again Niklas
Post by: Runway 31 on August 20, 2012, 08:20:36 AM
My fault I,m afraid X.  A6-ERQ is due for HiFly next month as CS-TQY and I got a wee bit ahead of myself and deleted it.  Added it back in meantime.  A6-ERR is going to them as well but not till later in the year.
Cant find anything on 9861BC after July 25 2008
Post by: Runway 31 on August 20, 2012, 08:25:16 AM
Hi Ingo,
At least the miscode in consistant.
3C5CB6 decodes to D-AGEV, now PR-GOD, dont think it will be this so miscode?
3D2563 decodes to D-EMKH unknown to me
3D2EFB D-EQAT, still unknown to me
3DAFA5 D-GMTP, still unknown to me
3FEBD9 D-MUSP, still unknown
3FEDE6 unknown to me
Post by: X on August 20, 2012, 08:46:57 AM
I was recently informed that EK were not releasing the Airbuses as originally planned due to delay in A388 deliveries.
Do you have a code yet for A6-TIA reported as A320 of RAK Airways, might be one of my unknowns?
X
Post by: RodBearden on August 20, 2012, 09:53:57 AM
X
Currrently 8961BC as DUB003 is north of me here in Lancashire at Fl360 on a transatlantic track.
Post by: John Hargreaves on August 20, 2012, 10:00:37 AM
Alan / X,
8961BC is A6-COM B747-433 c/n 25074/862 miscoding. Was using this code over the Black Sea, and again as is went over me heading for the pond. It has called at Stansted in between.
John H.
Post by: Runway 31 on August 20, 2012, 10:13:30 AM
Thanks lads 8961BC added as miscode
Post by: Runway 31 on August 20, 2012, 10:16:10 AM
X
As far as I am aware A6-TIA doesnt appear to have been delivered yet, I believe its still EI-EUL
Post by: tommyg on August 20, 2012, 10:28:22 AM
Guys.
If you are updating routes now, just had ICE542 flyover Sussex at FL360 showing route EPKK-EGKK.
Post by: X on August 20, 2012, 10:37:57 AM
Quote from: John Hargreaves on August 20, 2012, 10:00:37 AM
Alan / X,
John H.
John/Alan
Thanks for sorting that out but try this one!
There is something very definitely not quite right here out here in Sandpit at the moment!
Hex 8EF40E RA-64026 T204 Vladivostok Air was in Moscow and seen by me BUT was apparently in DWC at exactly the same time. Today 8EF40E has just gone for a swan around the Gulf, but look at FR24 at 1015 UTC today and you will see it joined up between DWC/Khabarovsk and Moscow!!! I believe we have two 8EF40E's as one claiming to be RA-64026 has been in and out of DWC since about 6th August when RA-64151 TU204SM Tupolev OAK was reported as being there but no hex was picked up!
   8EF40E                                           RA-64026 T204  Vladivostok Air (... 2012/08/13 21:34:46
   8EF40E  VLK4648                           RA-64026 T204  Vladivostok Air (... 2012/08/13 00:01:16
   8EF40E  VLK4649  UIUU-UUEE       RA-64026 T204  Vladivostok Air (... 2012/08/13 13:43:55
X
Post by: Runway 31 on August 20, 2012, 11:17:43 AM
X,  You will need to get out to the field and ID what it is
Post by: X on August 20, 2012, 11:26:43 AM
It has just gone into DWC but just too far to see type, will go out when heat haze dies down, but I believe it is going to be Tu204SM RA-64151 on desert trials for Tupolev OAK. I also think 8EF40E is most likely a Tupolev Factory test code and that is why it is still on Tu-204-300 RA-64026 (the first real Tu204-300 as the first Tu-234 was a shortened Tu204)!
X
Post by: X on August 20, 2012, 03:32:53 PM
You will not believe this, or possibly will...I went to DWC and 8EF40E took off FIVE minutes before I got there, going straight to f/l 230, flew around in a big circle. It came over me at f/l 230 just as I left the field one hour later, went around again and landed 45 minutes later as I got in the door...In all a 2 hour wild goose chase and was within four miles of it on three seperate occasions....mutter, mutter!
Its definitely on trials going out swanning around for an hour then landing again day in day out since early August!
Picked up a confused Russian on a Russian web site who also had it as being both 64026 and 64151!
X
Title: Re: Database Update Requests
Post by: Runway 31 on August 20, 2012, 03:52:57 PM
Yes X I believe it, that's what you call a wild goose chase!!
Post by: neroon79 on August 20, 2012, 04:19:17 PM
Evening, the rest from yesterday:
3FEF7F (Germany, no flight id, D-MVSW PIVI Pipistrel Virus SW100 Private CN:? Mk1EB 2011: http://www.abpic.co.uk/photo/1324076/ )
3FF137 (Germany, flight id: DMEEU, nothing more)
3FF199 (Germany, flight id: DMIGX, D-MIGX still no luck with the details)
3FF1B1 (Germany, flight id: MDRW, may be D-MDRW, but still no luck with the details)
3FF1B5 (Germany, flight id:DMPRS, still no luck with the details)
400970 (UK, no flight id, nothing more)
4021AC (UK, no flight id, nothing more)
484E9B (Netherlands, no flight id, from this file: http://antonakis.co.uk/registers/Netherlands.txt / "PH-PLK","SOCATA-GA GY-80-180","GY80","239","484E9B","","H.G. van Dorp","Ommerweg 71,7683 AW,DEN HAM OV  / http://www.youtube.com/watch?v=55Dzo58yF2g )
484F10 (Netherlands, flight id: SAS4710, SAS: Scandinavian Airlines System presume a decoding error or a miscoded airframe)
489324 (Poland, flight id: LOT357, LOT: Polish Airlines, SP-EQE DH8D  De Havilland Canada DHC-8-402Q Dash 8 Eurolot 4417 source: http://www.planespotters.net/Production_List/De-Havilland-Canada/DHC-8_Dash-8/4417,SP-EQE-Eurolot.php and http://www.flightradar24.com/data/airplanes/sp-eqe )
4BA900 (Turkey, flight id: THY3DY, decoding error of 4BA904)
508097 (Ukraine, flight id: AUI501, decoding error of 508093)
That's all from Sunday! Have a nice evening!
Ingo
Post by: neroon79 on August 20, 2012, 04:51:46 PM
The unknowns from today:
3C0A42 (Germany, flight id: SXD18N, decoding error of 3C0A46)
3C78C7 (Germany, flight id: ATV4210, decoding error of 3C78C3)
3D38D5 (Germany, flight id: DETTT, D-ETTT C172 Cessna 172R Skyhawk II Fliegergruppe Leutkirch e.V. 17280331 sources: airframes, http://www.fliegergruppe.de/cms/front_content.php?idcatart=10&start=1&view=upload%2Fbildergalerie%2Fdettt-neuer-tower.jpg http://www.flugzeugbilder.de/show.php?id=779614 )
3FF198 (Germany, flight id: DMFBW, D-MFBW FK9 Funk FK 9 Ela Flugsportvereinigung Bad Wildungen CN:? Source: http://www.hna.de/nachrichten/kreis-waldeck-frankenberg/korbach/flieger-vieles-kann-2446313.html )
MIL List:
3EAB09
3F5402  LK01A
3F6B5B  LK01A
3F6B5B  LK01B
That's all for now.
Ingo
Post by: Runway 31 on August 20, 2012, 05:28:42 PM
Hi Ingo,
3FF137 D-MEEU, unknown to me
3FF199 D-MIGX still unknown to me
3FF1B1 D-MDRW, unknown to me
3FF1B5 D-MPRS, still unknown to me
400970 decodes to G-BPND b/u for spares
4021AC G-LTRF, Sportavia Fournier RF-7, c/n 7001, Dirk Radewald
Have a good one as well
Post by: neroon79 on August 20, 2012, 05:47:58 PM
Hi Alan,
is there already a type designator for the RF-7?
Ingo
Post by: Runway 31 on August 20, 2012, 06:23:31 PM
Not as far as I am aware Ingo
Post by: shouriken on August 20, 2012, 06:58:18 PM
Does anyone have anything about 508290, callsign BA1234CB?
I have it in my logs on August the 17th (215 messages between 1131Z and 1219Z).
Liviu
Post by: Runway 31 on August 21, 2012, 06:53:50 AM
Hi Ingo,
3D38D5 D-ETTT is Cessna A185F Skywagon c/n 18504190, registered 7/3/2012  The Cessna 172R was written off 8/7/2009.  It flew underneath high tension wires (at 8,60 m) but the tail struck wires and was torn off. The Cessna crashed into a field. Both pilots were seriously injured.
Post by: neroon79 on August 21, 2012, 04:06:10 PM
Hi Alan,
Thanks for the update. Database amended.
Ingo
Post by: neroon79 on August 21, 2012, 04:27:01 PM
000017 (no allocation, no flight id, the miscoded mil airframe is back...)
3FF1A1 (Germany, no flight id, nothing more)
4001B6 (UK, no flight id, airframes VP-BCY LJ60 Learjet 60 ACASS Canada 60-215 Mk1EB 2009: http://www.aeroweb.de/show/?id=2620104 )
47876A (Norway, no flight id, nothing more)
48051B (Netherlands MIL, no flight id, no details found)
4C0728 (Yugoslavia, flight id: YUBZM, YU-BZM C56X Cessna 560XLS Citation XLS+ Air Pink 560-6037 Mk1EB April 2012: http://www.flugzeugbilder.de/show.php?id=1153762 )
MIL List:
3E8573  GAF462
3F5C2F  MUDDY
3F5CBD  GAFM58A
3F9061
3F9DCC  GAF019
Ingo#
Post by: Runway 31 on August 21, 2012, 06:48:08 PM
Hi Ingo,
3FF1A1 unknown to me
4001B6 VP-BCY LJ60 became N275HZ in July 2010
47876A decodes to LN-OSQ not currently allocated
48051B unknown to me
4C0728 is YU-BZI, Piper PA-34-200T Seneca II, c/n 34-7970286, Pelikan Airways.  YU-BZM is 4C072C
Post by: neroon79 on August 22, 2012, 02:43:18 AM
Morning, some additions to yesterdays unknowns:
344280 (Spain, no flight id, nothing more)
3C4AAD (Germany, flight id: CFG670, D-ABUM B763 Boeing 767-31BER Condor 2517/542 ex EI-CRF, delivered yesterday, source: airframes)
Have a nice Day!
Ingo
Post by: Runway 31 on August 22, 2012, 09:21:55 AM
Hi Ingo,
344280 unknown to me
3C4AAD D-ABUM, out of Manchester in Retro Condor colours
Post by: 54901 - Jim on August 22, 2012, 01:52:27 PM
One update for you ...
C040C5 / C-FYNS / A319 / Airbus A319-114 / Air Canada / 0572
Thanks!
Post by: chewycanes on August 22, 2012, 02:50:25 PM
Afternoon Alan
3D4DC0 D-FBRS Extra EA500 (from GA)
Brian
Post by: Runway 31 on August 22, 2012, 03:38:30 PM
Thanks Jim,
Post by: Runway 31 on August 22, 2012, 03:42:50 PM
Thanks Brian,
Post by: neroon79 on August 22, 2012, 05:04:31 PM
Evening, the Unknowns from today:
395008 (France, no flight id, decodes to F-GUAI, but nothing about this reg. So a decoding error I presume)
3FF192 (Germany, flight id: DMKPM, D-MKPM CLON AutoGyro Cavalon Private [currently for sale or already sold by now) V00039 Source: http://pilots24.com/pilots24/markt24/showad.php?adid=24871 )
4840E1 (Netherlands, flight id: KLM1900, so decoding error of 4840E3)
4A0091 (Romania, flight id: FAT2BU, another Farnair decoding error)
4CA735 (Ireland, no flight id, no active airframe found)
F4747F (no allocation, flight id: LYLLT, LY-LLT was/is a PIVI Pipistrel Virus Mk1EB September  2010: http://www.airliners.net/photo/Pipistrel-Virus/1790594/&sid=976ae986e5da16e7d7d36a3ceb83e20b)
MIL List
3F47F9
3F50C8
3F610D  GAF709
3F84BA  GAF757T
3F8DF9
3F988F  RAPTOR2
3FA30C  LIFTER1
BR Ingo
Post by: Runway 31 on August 22, 2012, 05:46:30 PM
Evening Ingo,
4AA0091 possibly 4B0091 HB-AFP AT72, Farnair
4CA735 decodes to EI-ECS Pipistrel Taurus now PH-4J2
Post by: neroon79 on August 23, 2012, 02:48:43 AM
Morning, one addition:
3C4927 (Germany, no flight id, nothing more)
Have a nice Day!
Ingo
Post by: paul tricker on August 23, 2012, 06:35:18 AM
A lot of e's have become a ? particularly in the F- range..
F-HBXI  E170  R?gional/Air France
Air Fly H?licopt?res Sarl
etc
Paul
Post by: Northern Watch on August 23, 2012, 07:00:59 AM
QuoteA lot of e's have become a ? particularly in the F- range..
etc
Just done a quick check and the same is happening here.
Keith
Post by: Xon on August 23, 2012, 07:28:53 AM
488049  SP-ACK A320 c/n 2645 (Bingo Airways)
Post by: Runway 31 on August 23, 2012, 07:44:59 AM
Xon, many thanks
Post by: Runway 31 on August 23, 2012, 07:46:38 AM
Keith/Paul
Its because there are accents on the French company details, diacritical bug in action I believe, hopefully sorted when we get the fix.  The font used by Airnav cannot handle accents
Post by: Runway 31 on August 23, 2012, 08:14:53 AM
Hi Ingo,
3C4927 decodes to D-ABIG unknown to me
Have a good day as well
Post by: Northern Watch on August 23, 2012, 08:18:57 AM
QuoteKeith/Paul
Thanks Alan
Never noticed it in the past - Oh for the new fix !!!!
Keith
Post by: neroon79 on August 23, 2012, 05:58:55 PM
Good Evening, the unknowns from today:
260A4B (no allocation, flight id: DUDE2, miscoded mil airframe I guess)
261581 (no allocation, no flight id, nothing more, same origin as above?)
2615C2 (no allocation, flight id: WHAWK12, another one)
26175C (no allocation, no flight id, last one of this group)
3C674E (Germany, no flight id, nothing more)
3E5C3D (Germany, no flight id, nothing more)
3E6EFA (Germany, no flight id, D-KHFM AS25 Schleicher ASH-25Mi Private 25225 sources: http://www.rcawsey.co.uk/ash25.htm http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html;jsessionid=38CB3E02DFF42F013B39EAD6CEF646ED?dsId=2088778 http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-KHFM )
3FEE88 (Germany, flight id: DMKMK, D-MKMK CH60 Zenair CH.602 Zodiak last spotted 2009: http://www.abpic.co.uk/photo/1212778/ )
3FF078 (Germany, flight id: DMCTA, still no luck with the details)
738095 (Israel, no flight id, decodes to 4X-EBT was/is a B752 that is stored since Feb 2012.)
7808EA (China, flight id: CES299, nothing more)
AE070E (USA MIL, no flight id, may be variable F15 airframes)
MIL List:
3E9B7A  GAF004
3E9DB9  GAF162
3F610D  GAF710
3F610D  GAF710
3F8A79  STONE01
3FA3CC  TA43
3FA596  GAF757T
That's all for now.
BR Ingo
Post by: Runway 31 on August 23, 2012, 06:13:29 PM
Evening Ingo,
260A4B US mil tac miscode
261581 US mil tac miscode
2615C2 US mil tac miscode
26175C US Mil tac miscode
3C674Edecodes to D-AIZN unknown to me
3E5C3D D-KACZ, Grob G 109B c/n 6112
3FF078 D-MCTA, still unknown to me
738095 4X-EBT stored for part out and scrap since Feb 2012 in Tupelo
7808EA B-6926, Airbus A321-231, c/n 5227, China Eastern Airlines
AE070E Tactical
Post by: neroon79 on August 24, 2012, 02:49:45 AM
Morning, two additions to the unknowns from yesterday:
3C7D9C (Germany, no flight id, second time of reception. Low message count, so may be a decoding error)
3E9B7A (Germany MIL, second reception with flight id GAF004)
Have a nice Day!
BR Ingo
Post by: X on August 24, 2012, 05:01:18 AM
Going into SHJ and tracking!
* 51405D  701                                                         2012/08/24 08:59:59
And at f/l 430 OTT
* AE4DE1                                                              2012/08/24 09:06:19
X
Post by: John Hargreaves on August 24, 2012, 07:14:41 AM
 X,
51405D and 51405E are the fwo former AirBridgeCargo B747-281Fs which were recently withdrawn from service. Nobody appears to know the 4L- registrations, and so if you fancy a mad dash across to SHJ then it would be much appreciated by all!
jOHN h.
Post by: John Hargreaves on August 24, 2012, 07:30:44 AM
 X,
I stand to be corrected.
4L-MRJ c/n 24576/818 and 4L-MRK c/n 25171/886 of 'Cargo Airlines' . Just need one of them to be eyeballed to match up the codes now.
John H.
Post by: X on August 24, 2012, 07:43:11 AM
Hi John
Thanks for the clarification as that's what I understood and that we just needed to identify one, I will get back if I can get which one is at SHJ at the moment.
X
Post by: John Hargreaves on August 24, 2012, 07:48:56 AM
 X,
Many thanks.
John H.
Post by: Runway 31 on August 24, 2012, 08:15:35 AM
Cheers X
Dont know your US mil code
Post by: Runway 31 on August 24, 2012, 08:38:48 AM
John,
Call received from X at Sharjah.  51405D is 4L-MRK, in full Air Bridge colours minus titles.
Post by: John Hargreaves on August 24, 2012, 08:46:25 AM
Thanks Alan,
...and now to confuse the issue. Also reported as 4L-MRK and 4L-TZS c/n's not known. Looks like another trip out in the sandpit will be required to verify what 51405E is actually wearing when it next visits.
John H.
Post by: Runway 31 on August 24, 2012, 09:18:31 AM
Hi Ingo,
3C7D9C unknown to me
3E9B7A Mil tac
Have a good day
Post by: Runway 31 on August 24, 2012, 09:23:57 AM
Nothing found on 4L-TZS.  Both AtDb and AvDb have 4L-MRJ as 24576/818
Post by: John Hargreaves on August 24, 2012, 10:02:32 AM
 Alan,
Got MRJ from the same sources. TZS comes from a reported visual sighting at FJR - also still wearing full ABC colours.
John H.
Post by: Runway 31 on August 24, 2012, 10:29:08 AM
John,
51405D just off Sharjah as TZS703
Post by: X on August 24, 2012, 10:31:27 AM
John/Alan
What date was the FJR sighting as there have been several visits there recently and I can try to check it out with local reports.
I had personally not picked up either 51405D or E before today, It was BBJUK on 6th and 9th August who reported that 51405E TZS701 went into Fujairah. I was in MOW at time.
X
Post by: X on August 24, 2012, 11:31:09 AM
John/Alan
4L-TZS and 4L-MRK were seen parked together at FJR on 19th August by two of our group, therefore sorted that one out (4L-MRJ either ntu or short lived)
X
Post by: Runway 31 on August 24, 2012, 11:48:52 AM
Good work by the lads, many thanks
Post by: X on August 24, 2012, 02:16:52 PM
I can confirm that 8EF40E is Tu-204-100SM RA-64151 Tupolev OAK, so there are two users of this hex as i thought. The other user is RA-64026 Tu-204-300 of Vladivostok Air.
X
Post by: Runway 31 on August 24, 2012, 02:36:09 PM
Thanks X,
Amended the d/b to show in use by both aircraft.
Post by: X on August 24, 2012, 03:10:55 PM
762043                                                              2012/08/23 11:28:38
This appears to be HA4T RC-21 ex A6-SHH carrying the code HBC21 and nought else (Pak Military??)
X
Post by: ACW367 on August 24, 2012, 04:07:31 PM
Quote from: X on August 24, 2012, 03:10:55 PM
X
HBC21 could just stands for Hawker Beechcraft Corp frame CN 21
Of course that doesn't help with full identity or owner.
Post by: X on August 24, 2012, 04:27:33 PM
Quote from: ACW367 on August 24, 2012, 04:07:31 PM
X
ACW367 Hi
Yes, we are aware that HBC21 is most likely using Hawker Beechcraft Corp and c/n 21 but it is flying with these markings, which is why we believe it might be a Mil or Govt code or DXB ATC would have a fit! You cannot even park outside the hangar without a reg being displayed. Maybe they think the authorities will think its a Swiss reg!
PS. Uses HBC21 as c/s as well
X
Post by: Runway 31 on August 24, 2012, 05:07:44 PM
Hi X
Nothing on 762043 but my d/b has A6-SHH as sold overseas in Dec 11 to?
Asked about it and awaiting a reply.
Post by: X on August 24, 2012, 06:11:51 PM
I only picked up A6-SHH once this year in April, prior to that late 2011 as you indicate.
89626E                           A6-SHH  HA4T  Elite Jets           2012/04/25 08:35:02
I believe it has been parked at the sandpit for most of this year and only recently started flying again (I first picked up on return from MOW 17/8). Reported came out of the hangar with 'reg' HBC21 applied and has been airborne as such a couple of times that I am aware of and also has used HBC21 as call sign.
X
Post by: neroon79 on August 25, 2012, 05:03:37 AM
Morning, the unknowns from Friday:
1C7D94 (Russia, flight ids OLT213, OLT214, airframes says that this is D-AOLT (3C7D94) with a recurring misuse of hex.
400A53 (UK, flight id: EZY276G, decoding error of 400A57)
4404D3 (Austria, no flight id, airframes: OE-FFM DA42 DA42M-NG Twin Star Diamond Airborne Sensing GmbH 42.MN003 can't find any sightings after 2010)
45AD09 (Denmark, no flight id, no active airframe found / was OY-KHI MD87 re-registered to EC-KAZ, N517PT, stored in Arizona 2010 to be scrapped)
478793 (Norway, flight id: WIF9106, WIF: Wideroes Flyveselskap [ http://www.wideroe.no/ ], couldn't find any details)
4A0091 (Romania, no flight id, again...)
4CA253 (Ireland, no flight id, was EI-DCS B738 of Ryanair now VQ-BPM, no new airframe found)
5081A4 (Ukraine, flight id: WAU6092, decoding error of 5081A0)
AE4DE1 (USA MIL, flight id: VELCRO4, no details)
MIL List:
3E8BFF  GAF711
3F8DF9  SNAKE1
3F9292  HG02
3FA3CC  TA63
3FBF36
That's all. Have a nice Weekend!
BR Ingo
Post by: X on August 25, 2012, 07:31:33 AM
An old one i forgot to report is UR-CHN MD83 Caspain Airways 49938/1785 now carries EP-CPV but still using Ukraine hex
X
Post by: Runway 31 on August 25, 2012, 11:09:49 AM
Hi Ingo,
4404D3 OE-FFM DA42 DA42M-NG Twin Star Diamond Airborne Sensing GmbH 42.MN003 can't find any sightings after 2010)  I have as WFU 7/2011
478793 LN-WSC, De Havilland Canada DHC-8-202 Dash 8, c/n 441, Wideroes Flyveselskap
4A0091 unknown to me
AE4DE1 US Mil Tactical
Thanks and have a nice weekend
Post by: Runway 31 on August 25, 2012, 11:13:32 AM
Thanks X
On a similar vein one which you may find given your location, UR-CJF is now EP-TAC with ATA Airlines.
Post by: X on August 26, 2012, 07:56:18 AM
Vietnamese unknown seemed to be departing DWC going thru f/l 180, did not pick up on arrival but informed it arrived yesterday at 1645. Non plotter.
* 888034                                                              2012/08/26 09:42:00
X
Post by: Runway 31 on August 26, 2012, 10:29:09 AM
X,
Cant find anything on 888034.  Only unidentified Vietnamese I could find is B734, VN-A190 Jetstar Pacific which Skyliner has ferried 26aug12 CAI-BUD for interim storage prior planned cargo conversion.  I dont know its routing before CAI.
Post by: X on August 26, 2012, 11:46:19 AM
Routing was DWC-CAI-BUD so would assume 888034 is VN-A190.
X
Post by: Runway 31 on August 26, 2012, 11:50:56 AM
Thanks X
Post by: flygfantast on August 26, 2012, 04:53:21 PM
Unknowns from last week:
194E97 (Russia), c/s O5Y331T, ~1700 msgs
3D7B8A (Germany), has been seen before using c/s DFTAO
A4BFE6 SE-BIL miscoding it's former hex of N405HC. SE-BIL, North American, F-51D, 44-10753, Biltema
45D96B (Denmark)
511018 (Estonia)
AE070E (US Mil)
Niklas
Post by: Runway 31 on August 26, 2012, 05:45:23 PM
Hi Niklas,
194E97 (unknown to me
3D7B8A decodes to D-FTAO unknown to me
45D96B decodes to OY-VKK unknown to me
511018 unknown to me
AE070E unknown to me
Thanks again
Post by: Xon on August 26, 2012, 09:57:12 PM
888099 VN-A335 A321 c/n 5241
Post by: Runway 31 on August 27, 2012, 07:48:09 AM
Thanks Xon
888099 VN-A335 and 88009A (note miscode) VN-A336 both departed on delivery 24/8 with 88009B (note miscode) VN-A338 departing the day previous, all out of XFW
Post by: X on August 27, 2012, 03:52:00 PM
300544 scheduled to be  I-FLYN F900 on approach
X
Post by: X on August 27, 2012, 03:58:58 PM
* A7CA1C    2281    AT8T  UAE - Air Force c/n 802-4003 (miscoding using hex of N60033)    2012/08/27 09:42:14
Previously used A00001!
X
Post by: neroon79 on August 27, 2012, 04:16:53 PM
Evening, the unknowns from Saturday:
343381 (Spain, no flight id, nothing more)
3C4829 (Germany, flight ids: BER290 & XK _ T, in case of BER290 it's a decoding error of 3C4869)
3CC192 (Germany, no flight id, nothing more)
3F467D (Germany MIL, flight id: GAF063, no details as usual)
3FF1B5 (Germany, flight id: DMPRS, D-MPRS seems that it was a EURO ALA JET FOX sources: http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MPRS / http://www.avia-info.hu/talalat.php?GTA=t1246 )
406136 (UK, flight id: EZY4643, decoding error of 406132)
4841AC (Netherlands, no flight id, nothing more)
4CA2A3 (Ireland, flight id: RYR9312, decoding error of 4CA2A7)
7807B9 (China, no flight id, nothing more)
That's all from Saturday, next: Sunday.
Post by: neroon79 on August 27, 2012, 04:27:14 PM
Unknowns from Sunday:
3FF078 (Germany, flight id: DMCTA, D-MCTA FDCT Flight Design CT Supralight Private cn:? Mk1EB July 2012: http://www.abpic.co.uk/photo/1362931/ )
4400C9 (Austria, flight id: OEVDB, airframes: OE-VDB DA42 Diamond DA-42 Diamond Aircraft Industries)
471F46 (Hungary, no flight id, nothing more)
49D2A8 (Czech Republic, flight id: OKESC, no luck with the details)
E0F300 (Argentina, no flight id, nothing more)
That's all from Sunday. Have a nice Evening!
BR Ingo
Post by: neroon79 on August 27, 2012, 05:10:19 PM
3C48C9 (Germany, flight id: BER606, decoding error of 3C48CB)
3C6DDB (Germany, no flight id, nothing more)
3D3911 (Germany, no flight id: D-ETWB C172 Cessna 172M Skyhawk Sportfluggruppe Nordholz/Cuxhaven 17264568 Mk1EB March 2012: http://www.flugzeugbilder.de/show.php?id=1127048 )
3D7B8A (Germany, flight id: DFTAO, no luck with the details)
3D7BA2 (Germany, no flight id, D-FTBM no luck with the details)
3E6012 (Germany, flight id: DKBOS, D-KBOS Schleicher ASG 29E Private CN:? Source: http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?dsId=2656013 )
3FEFFD (Germany, flight id: DMPTB, no luck with the details)
3FF1B1 (Germany, no flight id, D-MDRW still no luck with the details)
440017 (Austria, no flight id, nothing more)
45AD11 (Denmark, no flight id, decodes to OY-KHQ still no luck with the details / possibly a decoding error)
4B169A (Switzerland, no flight id, nothing more)
MIL List:
3EBE51  GAF959
3F50C8  PANTER2
3F52DB
3F64C6  GAF710
3F6BED  MONSTR
3F86E4  VADER1
3F9D45  SHOCK2
3F9E06  COBRA02
3FAECF  SHOCK3
3FAECF  VADER2
3FAED2  SHOCK1
3FB1D1  COBRA01
That's all for now.
Post by: Runway 31 on August 27, 2012, 05:35:19 PM
Hi Ingo
Todays
3D7B8A D-FTAO, unknown to me
3D7BA2 D-FTBM unknown to me
3E6012 D-KBOS Schleicher ASG 29E Private CN 29640
3FEFFD decodes to D-MPTB, unknown to me
3FF1B1 D-MDRW unknown to me
440017 unknown to me
45AD11 OY-KHQ unknown to me
4B169A decodes HB-IOO unknown to me
Post by: Runway 31 on August 27, 2012, 06:21:22 PM
Ingo,
Sunday
4400C9 OE-VDB, Diamond DA-42 c/n 42.004 I have as cancelled, checked Austrian register and not shown
471F46 unknown to me
49D2A8 unknown to me
E0F300 unknown, would suggest its a miscode
Saturday
343381 decodes to EC-KXH now EC-LAT Extra EA-300/L c/n 1285
3CC192 decodes to D-CAPM unknown to me
3F467D German Mil Tac
4841AC decodes to PJ-XLM AT43 now HR-AXN, seems unlikely
7807B9 B-3185, Embraer 190-100LR c/n 19000480, Tianjin Airlines
Post by: Runway 31 on August 27, 2012, 06:26:29 PM
Thanks X, could have sworn I-FLYN was in the d/b
Post by: neroon79 on August 28, 2012, 02:41:31 AM
Morning, one addition to the unknowns from yesterday:
3EB70F  (Germany MIL, flight id: GAF462, no details as usual)
Have a nice Day!
Ingo
Post by: mikek on August 28, 2012, 06:59:58 AM
C81ED9, c/s ZKKBU, ZK-KBU, Pacific Aerospace 750XL, c/n 183. Operated by Pacific Aerospace Limited, so probably on delivery somewhere.
Mike
Post by: Runway 31 on August 28, 2012, 08:39:49 AM
Thanks Mike
Post by: Runway 31 on August 28, 2012, 08:41:36 AM
Thanks Ingo,
Got your Tac code
Post by: paul tricker on August 28, 2012, 04:00:23 PM
Non populator today..
401F01 GBIJB = G-BIJB  PA-18-150 c/n 18-8009001 James Aero Ltd
Paul
Post by: Runway 31 on August 28, 2012, 04:20:28 PM
Cheers Paul, thanks
Post by: neroon79 on August 28, 2012, 05:20:01 PM
Good evening, the unknowns from today:
3D13C5 (Germany, flight id: DEFSV, D-EFSV C172 Cessna 172 Skyhawk SP Flugsportverein Eggenfelden e. V. CN:? [may be 172S10720, as D-EFSV seems to be ex PH-USB) Source: http://www.flugsportverein-eggenfelden.de/index.php?d-efsv )
3D7BA2 (Germany, flight id: DFTBM [three times today], still no luck with the details)
3FEC9B (Germany, flight id: DMDDM, D-MDDM G3 Remos G3-600 Aero Club Rothenburg ob der Tauber CN:? source: fleet list operator: http://www.edfr.de/index.php?id=61 )
3FF001 (Germany, no flight id, D-MBKO AT:? B.O.T. SC 07 Speed Cruiser Private CN:? Mk1EBs 2011: http://www.flugzeug-bild.de/name/einzelbild/number/34737/kategorie/flugplaetze~deutschland~leutkirch-ednl.html / http://www.abpic.co.uk/photo/1290892/ )
45D960 (Denmark, flight id: VKG421, decoding error of 45D962)
800458 (India, no flight id, nothing more)
MIL List:
3E9DB9  TA50
3F6D33  GAF011
3F9B13
3F9E8C
3F9E8C  RAVEN03
3FA3CC  TA20
3FA3CC  TA46
3FAFB4  LC41T
3FBC55
BR Ingo
Post by: Runway 31 on August 28, 2012, 07:30:38 PM
Hi Ingo,
3D7BA2 D-FTBM SOCATA TBM 700C1, c/n 258
3FF001D-MBKO AT=BISC
Thanks again
Post by: neroon79 on August 29, 2012, 02:57:04 AM
Morning, three additional unknowns from yesterday evening:
3D0F6D (Germany, flight id: DEECB, no luck with the details)
484169 (Netherlands, flight id: TRA474, decoding error of 484161)
773504 (Sri Lanka, no flight id, nothing more)
Have a nice day!
Ingo
Post by: X on August 29, 2012, 04:09:05 AM
Possibly this is 4L-ABI A300F with corrected code instead of miscode 515287 (EY-647) but we need to confirm. Miscode has been operating with this f/n since delivery.
* 514042  GST1321                                                     2012/08/29 07:55:52
X
Post by: X on August 29, 2012, 04:20:17 AM
I assume you will need our help locally to work out this non plotter, but not a chopper from climb rate.
* 89628C                                                              2012/08/29 08:16:36
X
Post by: Runway 31 on August 29, 2012, 07:30:22 AM
X
89628C is unknown to me so if you can find something out locally, that would be good.
514042 is also unknown to me so ditto
Post by: Runway 31 on August 29, 2012, 07:53:28 AM
Hi Ingo,
I dont have anything on your unknowns either.
Have a nice day even if you are at work.
Post by: X on August 29, 2012, 10:46:17 AM
8962C8 A6-DFR was in the air at exactly the same time maybe I got a crossed signal and received 89628C as no one else picked 89628C up.
We will confirm if 514042 is 4L-ABI recoded asap
X
Post by: Runway 31 on August 29, 2012, 11:51:29 AM
It wasnt picked up on the network either X
Post by: EK01 on August 29, 2012, 02:15:53 PM
Alan,
Hope your on. Falcon 900 F-HJJB c/n 035 currently flying over Alicante with full ADSB and clearly visible at FL390.
Post by: Runway 31 on August 29, 2012, 02:17:14 PM
Yes heading my way now, thanks for the heads up.  Nice to see biz all lit up
Post by: neroon79 on August 29, 2012, 05:34:37 PM
3C663F (Germany, no flight id, nothing more)
3D0F6D (Germany, flight id: DEECB, received again at 10:12 UTC)
3E2B17 (Germany, no flight id, nothing more / only 3 messages, so a decoding error is possible)
451E80 (Bulgaria, no flight id, no active airframe found)
484446 (Netherlands, no flight id, no active airframe found)
484B94 (Netherlands, flight id: KLM54W, decoding error of 484B90)
48A091 (Poland, flight id: SPIES, SP-IES SR22 Cirrus SR22-GTS Private CN:? source: http://jetphotos.net/viewphoto.php?id=7416802&nseq=0 )
AAB7C0 (USA, no flight id, would match to N79XG, but nothing on this hex. I bet this was a decoding error of AAB7C4 )
MIL List:
3EAA96  GAF022
3F4248  JUDGE01
3F47F9
3F4F12  GAF626   EDDL-LIRF
3F546A  LIFTER1
3F6A50  NUGGET
3FB203  SNIPER
BR Ingo
Post by: X on August 29, 2012, 06:22:47 PM
No longer WFU it has been parked at sandpit for afew days and departed this evening
00412D  AZW001                   Z-WPF   B762  WFU Stored (ex Ai... 2012/08/29 17:29:55
X
Post by: Runway 31 on August 29, 2012, 06:51:11 PM
Thanks X, wonder what its fate will be.
Post by: Runway 31 on August 29, 2012, 07:00:22 PM
Good evening Ingo,
3C663F unknown to me
3D0F6D D-EECB, still unknown to me, only previous I can find is now HA-SVI C172
3E2B17 decodes to D-IHNB unknown to me
451E80 decodes to LZ-BHA now JY-JAC
484446 decodes to PH-BRG which was a CH60 but dont know what it is know
Thanks again
Post by: neroon79 on August 30, 2012, 03:01:16 AM
Morning, two additions to yesterday:
3C660F (Germany, no flight id, nothing more)
45C825 (Denmark, no flight id, nothing more)
501D1C (Croatia, no flight id, nothing more)
about D-EECB: That's the same information that I was able to find.
Wish you a nice day!
Ingo
Post by: X on August 30, 2012, 06:21:33 AM
On network not populating
43E950    BBA38
AD37D8   BBA19
3FF0AA    DMCKA
7808F0    CES299
A45A0D   N38MJ
X
Post by: Runway 31 on August 30, 2012, 08:00:23 AM
Morning X
43E950    BBA38 unknown noted all day on the ground in Canada
AD37D8   BBA19 N9506G, Bombardier BD-700-1A10 Global 6000, c/n 950, Learjet Inc
3FF0AA    D-MCKA, unknown to me
7808F0    CES299, B-6427, Airbus A319-133, c/n 5267, China Eastern Airlines added to d/b 14:12
A45A0D   N38MJ, Cessna 525C CitationJet CJ4, c/n 525C-0039, Pilatus Leasing, ex N38M
Post by: Runway 31 on August 30, 2012, 08:03:22 AM
Hi Ingo,
3C660F decodes to D-AIPO unknown to me
45C825 decodes to OY-RAE unknown to me
501D1C unknown to me
Hsave a good one too
Post by: jim_stockwell on August 30, 2012, 04:35:58 PM
Hi Alan
Not populating 424240 call sign VP-BGH
Jim
Post by: X on August 30, 2012, 05:06:52 PM
Not populating but assume it is A6-EDW EK new A388 being delivered
* 8960F8  UAE7380                                                     2012/08/30 20:11:23
X
Post by: neroon79 on August 30, 2012, 05:16:18 PM
Quote from: X on August 30, 2012, 05:06:52 PM
X
According to http://xfw-spotter.blogspot.de/2012/06/a380-861-emirates-f-wwal-a6-edw-msn-103.html it is indeed A6-EDW on delivery from EDHI to OMDB. By the way, it's in my list too. Received at 10:48UTC.
Post by: flygfantast on August 30, 2012, 05:34:45 PM
3B7797 F-RAZC, Transall C-160R, c/n F-055, France - Air Force
4780AB (Norway)
Niklas
Post by: neroon79 on August 30, 2012, 05:47:25 PM
Evening, the rest of the unknowns from today:
3B7655 (France, flight id: FAF600, FAF: France Air Force, MIL airframe)
3B7797 (France, flight id: CTM2020, France Army, MIL airframe details mentioned by Niklas)
3C55A0 (Germany, no flight id, nothing more)
424240 (UK, flight id: VPBGH, if flight id shall be the registration, so it'll not match to this hex. As far as I know. )
488000 (Poland, flight id: SPAAA / two  time received with 5 hours between the two receptions, SP-AAA was this one: http://www.planepictures.net/show.php?id=950664 but now? )
8960F8 (UAE, flight id: UAE7380,  already mentioned)
AA18C9 (USA, flight id: PHKMF, some kind of delivery, transfer with using old hex would be my guess)
MIL List:
3EB857  PACK2
3F535B  GAF121
3F5D31  GAF959
3F89CB
3F89CF  PACK1
3F8A79
3F8DF9  GAFS01
3F926D  SCHOCK
3F926D  SHOCK
3F9D73
3FA4D4  PACK3
3FA750  HAMMER
That's it for now. Have a nice evening!
BR Ingo
Post by: Runway 31 on August 31, 2012, 07:32:03 AM
Hi Jim,
424240 VP-BGH, Airbus A321-232, c/n 3034, Nordwind Airlines
Post by: Runway 31 on August 31, 2012, 07:33:02 AM
X/Ingo
8960F8 A6-EDW noted and added
Post by: Runway 31 on August 31, 2012, 07:38:11 AM
Niklas,
C160 c/n 055 has serial R55 and is coded 61-ZC so presume is 3B7797?
Post by: Runway 31 on August 31, 2012, 07:52:17 AM
Hi Ingo,
3B7655 unknown to me
3B7797 Possibly R55, Aerospatiale C-160R Transall c/n 055, France - Air Force
3C55A0 unknown to me
424240 VP-BGH,Airbus A321-232, c/n 3034, Nordwind Airlines
488000 unknown to me but dont think its that one!!
AA18C9 Decodes to N75MF, became PH-KMF in June, SOCATA TB20 Trinidad GT, c/n 2097, allocated 484FB5
Post by: flygfantast on August 31, 2012, 07:57:20 AM
Quote from: Runway 31 on August 31, 2012, 07:38:11 AM
Niklas,
Correct 3B7797 should be R55. #3B7797 has been using callsign FRAZC on a previous occasion.
Niklas
Post by: Runway 31 on August 31, 2012, 08:05:23 AM
Thanks for the confirmation Niklas
Post by: X on August 31, 2012, 08:39:19 AM
Just landed if you do not know will try to find out in a couple of hours
* 484337                                                              2012/08/31 12:07:50
PS A6-EDW populated as it took off for LIRF on EK97, Ta
X
Post by: Runway 31 on August 31, 2012, 01:49:03 PM
Thanks X
484337 CH850 P4-AST c/n 8053, Comlux Kz.
Post by: X on August 31, 2012, 02:41:56 PM
one sorted, now this takes off from somewhere in the area, but no idea what type however doubtfully claims to be of Russian origin.
* 1FC9B5                                                              2012/08/31 14:54:51
X
Post by: Runway 31 on August 31, 2012, 02:46:50 PM
No idea X, first picked up on the network 29/8
Post by: X on August 31, 2012, 02:52:53 PM
Quote from: Runway 31 on August 31, 2012, 01:49:03 PM
Thanks X
Thought it was c/n 8054 you mentioned for this one, and in db as such so assume slip of the fingers!
X
Post by: Runway 31 on August 31, 2012, 03:54:50 PM
Yep, fat finger syndrome at work!! 8054 it is.
Post by: Runway 31 on August 31, 2012, 04:13:14 PM
Niklas,
Your other unknown 4780AB is LN-RDA DH8D c/n 4013, Air Solutions Luxembourg ferried today TRF-EIN for paint as per Skyliner
Post by: X on August 31, 2012, 08:34:38 PM
Look out for 1FC9B5 around 2000UTC nr BCN as I suspect it might be LV-CYN B737 Aerolineas on delivery miscoding. It left DWC at 1450L (1050UTC) Europe bound.
X
Post by: Runway 31 on August 31, 2012, 08:48:44 PM
Thanks X should be using E0364E, ex N301LF was in Shanghai hex A32409
Post by: X on August 31, 2012, 08:52:45 PM
E0364E nor A32409 were picked up by anyone in UAE today
X
Post by: Runway 31 on August 31, 2012, 09:05:56 PM
Cheers X
Post by: neroon79 on September 01, 2012, 06:12:45 AM
3C4920 (Germany, flight id: DLH7FF, so it's a decoding error of 3C4922)
3D0F6D (Germany, flight id: DEECB, still no luck with the details)
3E1ECC (Germany, no flight id, nothing more)
484F10 (Netherlands, flight id: TRA1520, so a decoding error of 484F14)
49D0A7 (Czech Republic, no flight id, was OK-YAC A310 of Czech Airlines until 2010.)
4D2028 (Malta, no flight id, was 9H-AER A320 of Air Malta until 2006.)
MIL List:
3EB8FF  GAF900
3F765F  GAFS26A
3F9C54  GAFS28
3FA30C  GAF012
3FBB3C  GAF626   EDDL-LIRF
3FBB90  TA40T
About the MILs: sometimes after I've posted the list they populate as tactical codes, sometime they don't. Is there any technical reason why it is that way?
BR Ingo
Post by: Runway 31 on September 01, 2012, 09:12:25 AM
Morning Ingo.
To answer your question I normally do your main ones first and then go back and do the Mil when I get time, I guess sometimes I forget to go back or more likely you try to populate before I have entered them.  Not really that technical!
3E1ECC decodes to D-ICWA, unknown to me
49D0A7 decodes to OK-YAC now S2-AFF
4D2028 decodes to 9H-AER now CS-TNP
Post by: flygfantast on September 01, 2012, 02:34:05 PM
4AE218 SE-XPX, Neico-Lancair 360, c/n 635-320-380-829, Rolf E Dahlstrom
Niklas
Post by: Runway 31 on September 01, 2012, 02:41:45 PM
Thanks Niklas
Post by: Xon on September 01, 2012, 06:25:10 PM
503DEA LY-HTB EC30 c/n 4219
488000 SP-AAA PA46 c/n 4697349
7808AF B-6548 A332 c/n 1335
Post by: EK01 on September 01, 2012, 07:07:01 PM
Alan,
Just come over presumably on delivery :
Mode S : 780925
Flight ID : GCR 3212
Operator : Tianjin Airlines
Post by: Runway 31 on September 01, 2012, 08:29:56 PM
Ian,
780925 B-3212, Embraer 190-100LR, c/n 19000567, Tianjin Airlines
Post by: Runway 31 on September 01, 2012, 08:35:30 PM
Thanks Xon had 4697349 as OK-DAG P46T
Post by: neroon79 on September 02, 2012, 04:30:41 AM
Morning, the unknowns from Saturday:
3C49EF (Germany, no flight id, decodes to D-ADXR, but nothing more )
3D0979 (Germany, flight id: DEBVL, D-EBVL BREZ Aerostyle Breezer 600 BVL Bremer Verein fuer Luftfahrt CN:? http://bvl.aero/motorflug/flugzeugpark )
3D0F6D (Germany, again D-EECB this time without flight id )
3F535B (Germany MIL, flight id: GAF121, as usual no luck with details)
4403F5 (Austria, flight id: OE9344ZZ, OE-9344 last known to be DIMO Diamond HK-36 Super Dimoa Private 36302 source: http://www.wildbergair.com/photos/airports/Austria/ZZZZ/ERZBERG/20081010/20081010_9344.htm )
4BA9AE (Turkey, flight id: THY5JA, decoding error of 4BA9AA)
63A9C3 (no allocation, no flight id, so decoding error or miscoded airframe)
Have a nice Sunday!
BR Ingo
Post by: Runway 31 on September 02, 2012, 09:45:54 AM
Hi Ingo,
3C49EF decodes to D-ABOO unknown to me
3F535B Mil tactical
You have a good day as well
Post by: Northern Watch on September 02, 2012, 01:41:45 PM
Afternoon Alan
I picked this up this afternoon but did not populate:
A95146 / N7QM / Piper PA-46-500TP / c/n 4697495 / Owner Caladero Aviation inc.
keith
Post by: Runway 31 on September 02, 2012, 02:01:42 PM
Thanks Keith
Post by: neroon79 on September 02, 2012, 04:38:36 PM
Good Evening,
000555 (no allocation, no flight id, seems to be a miscoded airframe)
392AF6 (France, flight id: AFR1735, decoding error of 392AF2)
3C5823 (Germany, flight id: 00000000, nothing more)
3D2480 (Germany, no flight id, airframes: D-EMBO GY80 Sud    GY-80 Horizon Private CN:? Mk1EBs: http://www.airplane-pictures.net/photo/111590/d-embo-private-gardan-gy-80-horizon/ and http://www.flugzeugbilder.de/show.php?id=804170 )
3D37F8 (Germany, flight id: DETLG, D-ETLG, still no luck with the details)
3FEE75 (Germany, no flight id, D-MKSW, still no luck with the details)
3FF102 (Germany, flight id: DMJSA, back again after a few weeks of absence, but still no luck with the details)
44C147 (Belgium, flight id: OOPJG, airframes: OO-PJG DR22 Centre Est Dauphin Private CN:? / Mk1EB of OO-PJG: http://www.planespotters.net/Aviation_Photos/photo.show?id=134805 )
AA18C9 (USA, flight id: PHKMF, second time I have this hex with this flight id. Airframe still miscoded I guess)
BR Ingo
Post by: flygfantast on September 02, 2012, 05:43:06 PM
Not populating 3B7655 c/s FAF604, SA: 17600 ft EA: 40900 ft, 170 msgs
Niklas
Post by: anorak on September 02, 2012, 05:51:46 PM
424292 with flight ID of UTABAI just passing north of Bristol at FL370/ 480 knts.
Thanks,  Dave.
Post by: Runway 31 on September 02, 2012, 05:54:53 PM
Good evening Ingo,
3C5823 D-AFAC, Canadair CL-600-2B16 Challenger 604, c/n 5416, FAI Rent-A-Jet
3D2480 D-EMBO GY80 My d/b shows as cancelled
3D37F8 D-ETLG, Cessna 172S Skyhawk SP c/n 172S8561
3FEE75 D-MKSW, unknown to me
3FF102 D-MJSA, still unknown to
You have a good one too.
Post by: Runway 31 on September 02, 2012, 05:56:44 PM
Dave,
424292 VP-BAI, Boeing 767-224ER, c/n 30437/839, UTair out of Shannon on delivery
Post by: Runway 31 on September 02, 2012, 06:21:28 PM
Nothing on 3B7655, Niklas
Post by: Xon on September 02, 2012, 11:18:18 PM
Quote from: Runway 31 on September 01, 2012, 08:35:30 PM
Yes thats correct. OK-DAG is prev reg for this plane.
Post by: X on September 03, 2012, 06:16:06 AM
Two unknowns, the first 700078 appeared to be YA-TTC double pinging 700068 and 700078 at same time (EP-LCE style!)
* 700078                                                              2012/09/03 02:18:37
* 888035                                                              2012/09/03 09:40:55
X
Post by: Runway 31 on September 03, 2012, 08:32:40 AM
Thanks X, nothing on 888035.
Post by: John Hargreaves on September 03, 2012, 08:58:26 AM
 Alan/X,
888035 sounds very much like the second Jetstar Pacific B734, VN-A191, heading for Lasham.
John H.
Post by: Runway 31 on September 03, 2012, 09:41:18 AM
Hi John,
Of course it does, forgot about the last one.
Aaln
Post by: shouriken on September 03, 2012, 04:11:45 PM
A miscode from Romania:
3FE85A - YR-5276 - FDCT - Flight Design CTLS - Private - cn unknown
Confirmed on liveatc.
Photos http://www.photoavia.eu/advsearch/photo/search?registration=yr-5276
Liviu
Post by: Runway 31 on September 03, 2012, 04:16:48 PM
Thanks Liviu, I dont have the c/n either.
Post by: neroon79 on September 03, 2012, 05:19:23 PM
385F3B (France, flight id: FPFTN, latest one I could find: F-PFTN Dyn Aero MCR-01 Sportster Private 250 Mk1EB 2007: http://www.abpic.co.uk/photo/1091249/ )
3C4B06 (Germany, no flight id, there is a good chance, that this is again a decoding error of 3C4B0E)
3C6660 (Germany, flight id: DLH8FU, decoding error of 3C6664)
440367 (Austria, no flight id, nothing more)
48CB1D (Poland, no flight id, nothing more)
4CA7FA (Ireland, no flight id, nothing more)
MIL List:
3EA492  RAZOR2
3EB0DB  TA50
3EB870  GAFE21A
3F687F  SHOCK1
3F7C3F  GAF710
3F80DC
3F84BA
3F90D5
3F98A3  TA43
3F98A3  TA52
3F99DF
3FA4FF  MONSTR
3FA5B0  RAZOR1
3FA5B0  RAZOR1   EGKK-LFLB
3FA750  SHOCK2
BR Ingo
Post by: Runway 31 on September 03, 2012, 05:25:54 PM
Good Evening Ingo,
3C4B06 decodes to D-ABXF now B/U
440367 unknown to me
48CB1D unknown to me
4CA7FA unknown to me
Post by: flygfantast on September 03, 2012, 05:39:50 PM
Good evening Alan
51109D using c/s AEG902, 433 msgs during 40 mins, FL180
Niklas
Post by: Runway 31 on September 03, 2012, 05:44:15 PM
Still dont have anything on 51109D Niklas and the callsign doesnt help either
Post by: neroon79 on September 04, 2012, 02:35:51 AM
Morning, four additions to the unknowns of yesterday:
3F8470 (Germany MIL, flight id: KNIGHT1)
3FBE16 (Germany MIL, flight id: GAF026)
42428B (UK, flight id: VPBCU, VP-BCU A320 Airbus A320-232 Yamal Airlines [leased from ACG] 1969 source: http://www.planespotters.net/Production_List/Airbus/A320/1969,VP-BCU-Yamal-Airlines.php )
460C75 (Finland, no flight id, nothing more)
Have a nice Day!
Ingo
Post by: Runway 31 on September 04, 2012, 07:34:41 AM
Thanks Ingo,
460C75 decodes to OH-ESR, unknown to me
Its a lovely morning here so its easy to have a nice day, hope its good where you are and you have a good one too.
Post by: X on September 04, 2012, 09:15:58 AM
According to www.flyfinland.fi OH-ESR is a Cirrus SR20 G2 c/n 1542
X
Post by: Runway 31 on September 04, 2012, 09:31:46 AM
Thanks X, now found some pics and videos of it
Post by: X on September 04, 2012, 09:53:10 AM
On network at 1000 FT
0900D8 D2EWZ
x
Post by: Runway 31 on September 04, 2012, 10:14:19 AM
Hi X
Nothing on it  I'm afraid.  Did you notice its whereabouts?
Post by: EK01 on September 04, 2012, 10:58:20 AM
Alan,
Austrian Airlines have now registered the following to Tyrolean Airways. At this rate they won't have any of there own registered aircraft left :
OE-LAT c/n 25273
OE-LAW c/n 26417
OE-LAX c/n 27095
OE-LNJ c/n 28177
OE-LNK c/n 28178
OE-LPA c/n 28698
OE-LPC c/n 29313
OE-LAY c/n 29867
OE-LAZ c/n 30331
OE-LAE c/n 30383
OE-LNP c/n 30420
OE-LNQ c/n 30421
OE-LNR c/n 33833
OE-LNT c/n 33834
OE-LNS c/n 34262
OE-LPD c/n 35960
Not sure if the actual aircraft have changed colour schemes and titles.
Post by: Runway 31 on September 04, 2012, 11:36:44 AM
Change of registered owner but not operator.  As far as I can see they have all changed apart from OE-LPB.
Post by: X on September 04, 2012, 12:54:59 PM
Forgot too look at its whereabouts but acted like a chopper maintaining 1010 ft for a few minutes before disappearing! Its been picked yesterday and today on FR24 but cannot get its position but it does seem to plot
X
Post by: Runway 31 on September 04, 2012, 01:23:05 PM
Thanks X, I have put an alert on for it so hopefully I will see it, thought it might be a chopper.
Post by: X on September 04, 2012, 04:01:12 PM
OTT but type not known c/s might be a giveaway...tactical code perhaps knowing the Luftwaffe
* 3F05C2  NATO52                                                      2012/09/04 19:56:11
X
Post by: Runway 31 on September 04, 2012, 04:08:08 PM
Looks Tactical to me X
Post by: neroon79 on September 04, 2012, 04:34:17 PM
This one has populated today: EI-ABI De Havilland DH-84 Dragon II wasn't able to find a designator for this type, so I presume that there isn't one. Too bad, would be great to a have a photo silhouette for this one.
3C630E (Germany, flight id: BER132, decoding error of 3C630A)
3CD00F (Germany, no flight id, nothing more)
3D06A9 (Germany, flight id: DEATT,  latest known airframe I could find: D-EATT P28R PIPER PA-28 R-200 CHEROKEE ARROW II )
3E225D (Germany, no flight id, was D-IEFD C25A of Eisele Flugdienst until 2007, is now OE-FHB)
3FF0CF (Germany, no flight id, D-MTTO no luck with the details)
3FF137 (Germany, flight id: DMEEU, still no luck with the details)
4248CF (UK, no flight id, nothing more)
484B06 (Netherlands, flight id: KLM1840, including this hex there four airframes with this flight id in the same time-frame in my list. So a decoding error of one of them.)
896131 (UAE, flight id: ETD016, decoding error of 896133)
AE2DF0 (USA MIL, no flight id, no luck with the details)
MIL List
3E828B  GAF777
3E828B  TA57
3E86CA  GAF688
3E95B6  EAGLE1
3EA19B  GAF933
3EB857  SMASH1
3EBD1D  GAF640
3EBD1D  VIKING1
3F646E  GAF011
3F666C  GAF933
Had a very nice day. Sun without any clouds, slight wind. 24 degrees Celsius plus a day off from work due to the fact, that I've got to get rid off some overtime.
BR Ingo
Post by: Runway 31 on September 04, 2012, 05:50:10 PM
Evening Ingo,
Sounds like you had a good day as well
3CD00F decodes to D-CGCD unknown to me
3E225D same info now OE-FHB
3FF0CF D-MTTO unknown to me
4248CF unknown to me
Thanks again
Post by: neroon79 on September 05, 2012, 02:52:33 AM
Morning, some additions to yesterdays list:
3C630E (Germany, flight id: BER724, again a decoding error of 3C630A)
3E9897 (Germany MIL, flight id: BOMBER1, as usual no luck with the details)
3FEE75 D-MKSW again without flight id.
44D1C6 (Belgium, flight id: TAY016G, decoding error of 44D1C2)
471EA3 (Hungary, no flight id, nothing more, may be another decoding error)
Have a nice Day!
Ingo
Post by: Runway 31 on September 05, 2012, 09:17:24 AM
Hi Ingo,
3E9897 Mil tac
471EA3 unknown to me
Having a good one, same to you
Post by: Chris11 on September 05, 2012, 10:41:10 AM
20102C = V5-TTO, ex ZS-TL
Post by: Runway 31 on September 05, 2012, 11:00:34 AM
Can you send the last letter of the ex reg of your miscode please Chris.
Post by: paul tricker on September 05, 2012, 01:42:56 PM
Quote from: X on September 04, 2012, 09:53:10 AM
0900D8 D2EWZ
x
D2-EWZ is an EC225LP c/n 2815
see
http://patrickmathieu243.perso.neuf.fr/hu/helico/ec225/2815.html
although the picture (last one) did not load for me
Paul
Post by: Runway 31 on September 05, 2012, 01:49:46 PM
Thanks Paul.
Post by: Chris11 on September 05, 2012, 04:48:51 PM
ex ZS-PTL
Apologies
Post by: neroon79 on September 05, 2012, 04:55:32 PM
3C0E39 (Germany, no flight id, nothing more)
3EA920 (Germany, flight id: DIIHS, decoding/mixing error of 3E2D30)
40057C (UK, no flight id, nothing more)
unstable transmitter:
* 44066D  HAWHX3                                                      2012/09/05 06:56:33
* 44066D  KG7H83                                                      2012/09/05 06:55:06
* 44066D  KIWIH3                                                      2012/09/05 06:54:53
* 44066D  MHGH83                                                      2012/09/05 06:54:33
* 44066D  OEIPD                                                       2012/09/05 06:50:31
* 44066D  OEIPD                                                       2012/09/05 06:54:06
* 44066D  OEIPD                                                       2012/09/05 06:55:36
* 44066D  OEIPD                                                       2012/09/05 06:56:40
* 44066D  OHOIH3                                                     2012/09/05 06:53:59
* 44066D  PH7IH3                                                      2012/09/05 06:53:39
44066D Austria reg may be OE-IPD, wasn't able to find something about OE-IPD
49D2A8 (Czech Republic, flight ids: TIE295S at two different times 10:00 / 15:00 UTC, TIE: Time Air / http://www.timeair.cz/en/aircraft-gallery.asp )
4A0091 (Romania, flight id: FAT8TW, another Farnair miscode / decoding error)
A8D3B0 (USA, no flight id, would match to N668TX, but nothing about this reg. So a decoding error I presume.)
MIL LIst:
3EA920  TA45
3EA920  TA55
3F41E1  GAF674
3F4C52  SPIKE1
3F4C52  SPIKE1
3F62E9  EAGLE
3F89CF  SHOCK1
3F926D  PACK
3F9471  GAF064
3F96B9  DIXI14
3FA4D4  SMASH
3FBCBD  HAMMER1
Wish you a nice evening!
BR Ingo
Post by: Runway 31 on September 05, 2012, 07:26:30 PM
Hi Ingo
3C0E39 decodes to D-AUKA unknown to me
3FF137 DMEEU, stillMunknown to me
40057C decodes to G-BVDL H25C now N770RG
44066D  OE-IPD unknown to me
A8D3B0 unknown to me
Have a good one
Post by: paul tricker on September 05, 2012, 10:08:26 PM
Just for info as i know it cannot be added to the d/b
Recently (30-08-12) registered A320-211 N204AR c/n 204 , WFBN, heading USA bound over the UK
Unfortunately using hex 100000 instead of the correct A1A0EF
Paul
Post by: neroon79 on September 06, 2012, 03:03:21 AM
3E1974 (Germany, no flight id, decodes to D-IAVK nothing more)
3E5921 (Germany, no flight id, nothing more)
3E97BE (Germany MIL, flight id: GAF059, as usual no luck with the details)
461F3A (Finland, no flight id, nothing more)
461F92 (Finland, no flight id, was this one: http://www.flightradar24.com/data/airplanes/oh-lyw don't know if it's still this one or just another decoding error. )
4A0091 (Romania, maybe on it's way back with flight id FAT7TW)
Have a nice day!
Ingo
Post by: mikek on September 06, 2012, 05:41:36 AM
3B9BB5, Falcon 200 Gardian, 80, French Navy, c/n 480
Mike
Post by: Runway 31 on September 06, 2012, 08:02:24 AM
Thanks Paul, noted
Post by: Runway 31 on September 06, 2012, 08:02:46 AM
Thanks Chris, frame amended
Post by: Runway 31 on September 06, 2012, 08:04:50 AM
Thanks Mike
Post by: Runway 31 on September 06, 2012, 08:09:10 AM
Morning Ingo,
3E1974 D-IAVK unknown to me
3E5921 decodes to D-IYYJ unknown to me
3E97BE mil tac
461F3A decodes to OH-LVM unknown to me
461F92 decodes to OH-LYW now UR-CBY
Tahanks
Post by: X on September 06, 2012, 02:20:11 PM
514042 was parked at SHJ today so should be 4L-ABI A300F GCS Cargo c/s as suspected.
Plus this unknown
* 898080                                                              2012/09/06 10:44:21
We believe this PNG is a Lynden Herc that has been seen at DWC lately
X
Post by: X on September 06, 2012, 02:49:12 PM
3X-GGQ IL-18 seen FJR today in pristine condition might be 0467F1 picked up cruising at 22000 before descending into FJR.
Have you a code for EY-322 An26 also pristine at FJR looking operational is likely to be one of our three current unknown Tajiks. Have you anything on this? Might be 515194 as 515261/2 are relatively new to the area.
X
Post by: Runway 31 on September 06, 2012, 03:48:53 PM
X
N407LC ex Lynden is now P2-LAE c/n 5225 with Lynden Air Cargo PNG
0467F1 was previously 3X-GGB an A320 which is now on the French register.  Unknown to me what is using it now.
Have everything but the hex for EY-322
Post by: X on September 06, 2012, 03:49:13 PM
At long last the first time EP-IEG is picked up using its correct code instead of its ex Japanese hex!
* 7324A7                           EP-IEG  A320  Iran Air             2012/09/04 19:41:00
X
Post by: Runway 31 on September 06, 2012, 04:21:16 PM
Yippee, wonder about the other box
Post by: Judwin45 on September 06, 2012, 05:29:02 PM
Hi Alan
Noted on 'My Flights' at about 1715 1E1111 Sq7000 no other details.
Post by: Runway 31 on September 06, 2012, 05:34:56 PM
Hi Keith
Airframes have this miscode as G-VIIZ, CSA SportCruiser, c/n PFA 338-14672, Skyview Systems
Post by: neroon79 on September 06, 2012, 06:18:40 PM
000017 (no allocation, no flight id, maybe a gain the miscoded mil airframe)
3C7D90 (Germany, flight id: OLT210, decoding error of 3C7D94)
3CCD49 (Germany, no flight id, nothing more)
3CD055 (Germany, no flight id, received two times 3 hours between, decodes to D-CGEV nothing more)
3D45F7 (Germany, no flight id, decodes to D-EYTB, nothing more)
3EDE2C (Germany, flight id:  DKZCE, D-KZCE Stemme S6 http://www.alfacharlie.com/de/flugzeug/eday/d-kzce/ and http://www.abpic.co.uk/search.php?q=D-KZCE&u=reg )
48D828 (Poland, flight id: PLF116, PLF: Polish Air Force. Maybe this one: http://www.flightradar24.com/data/airplanes/0219 )
ABD6C4 (USA, flight id: FDX003, decodes to N862FB, but in this case a decoding error of ABD6C6)
MIL List:
3EB2B8  GAF727
3F851D
3F8D02  GAF061
3FB1C2  PANTER1
BR Ingo
Post by: Runway 31 on September 06, 2012, 06:56:02 PM
Evening Ingo,
3CCD49 decodes to D-CFAV unknown to me
3CD055 D-CGEV unknown to me
3D45F7 D-EYTB, Piper PA-28-181 Archer III, c/n 2843680
48D828 0219 An28, c/n  AJG004-02, Poland Air Force
Post by: paul tricker on September 06, 2012, 07:53:56 PM
A couple of non populators today...
A4DA03  DASSAULT  this is N411YF Falcon2000  c/n 161  Sand Hill Management
A34A85  N31098, only N31098 I can find was a Pa34-220T Seneca exported to Spain in 2006.
It is not current on the FAA, so either a bogus code or the EC- not recoded?
Paul
Post by: Runway 31 on September 06, 2012, 08:14:24 PM
Thanks Paul
N411YF was only registered yesterday
Nothing on N31098, the PA34 is now EC-JPO and was in at Prestwick today using its old hex
Post by: GreekSpy2001 on September 07, 2012, 11:06:44 AM
German C-160 51+02 reported into BHX.  Seen climbing out over London at 11:40
3F545B  GAF012                                                      2012/09/07 09:49:54
Graham
Post by: Runway 31 on September 07, 2012, 11:15:47 AM
Thanks Graham, tactical code
Post by: X on September 07, 2012, 01:11:04 PM
This IL76 is now EY-680 still miscoding
   68305B                           EK76111 IL76  RUS Aviation (Mis... 2012/09/06 02:51:15
   68305B                           EK76111 IL76  RUS Aviation (Mis... 2012/09/06 23:27:53
x
Post by: Runway 31 on September 07, 2012, 01:30:06 PM
Thanks X
Post by: neroon79 on September 07, 2012, 05:20:36 PM
Good Evening! The unknowns from today:
received again: 260A4B (no allocation, no flight id)
3CD051 (Germany, flight ids: GFD20 and GFD75/two times, GFD Gesellschaft für Flugzieldarstellung, still no luck with the details)
3D104F (Germany, flight id: DEEKT, D-EEKT seems to be a VAN's RV 7: http://rvforum.de/SMF108/index.php?topic=633 )
3D16CD (Germany, flight id: DEGWR, D-EGWR P28A Piper PA-28-181 Archer 3 INflight GmbH 28-7816670 http://inflight-charter.de/das-flugzeug/ Eyeballed May 2012: http://www.flugzeugbilder.de/show.php?id=1142195 )
3D32D6 (Germany, flight id: DERMS / two times, D-ERMS still no luck with the details)
3D4400 (Germany, flight id: DEXZZ, so decoding error of 3D4407)
3FF0DC (Germany, flight id: DMSFA, Seems to be an ULAC source: http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-MSFA )
3FF19B (Germany, no flight id, nothing more)
45B868 (Denmark, no flight id, nothing more)
49D0B2 (Czech Republic, flight id: OKIFR, airframes: OK-IFR P28A Piper PA-28-181 Archer 2 operator may be F-Air 28-8290131 latest Mk1EB: http://www.planes.cz/en/photo/1114227/piper-28-180-ok-ifr-f-air-benesov-lkbe/ )
4CA1BD (Ireland, flight id: RYT8943, hex matches to ex EI-TAC, but in my case it was a decoding error of 4CA1B9)
The three MILs from today:
3F423A  GAF033
3F4317  TA47
3F54C2  PANTER2
Wish you a good start into the weekend and a nice evening!
BR Ingo
Post by: paul tricker on September 07, 2012, 07:37:14 PM
Two more non-populators today which the web suggests are as follows...
3D3FA3 DEWIT = D-EWIT C172S c/n 172S10803
392FFC FJTYB = F-JTYB Pipistrel Virus (no idea what one of those is though!!)
Paul
Post by: Runway 31 on September 07, 2012, 07:48:51 PM
Hi Ingo,
3CD051 decodes to D-CGER unknown to me
3D32D6 D-ERMS still unknown ro me
3FF0DC D-MSFA, B&F Funk FK-14B Polaris c/n unknown to me
3FF19B unknown to me
45B868 decodes to OY-NCH unknown to me
Have a good weekend as well
Post by: Runway 31 on September 07, 2012, 07:54:55 PM
Hi Paul,
D-EWIT c/n 172S10803 is now PH-WIT
http://www.flickr.com/photos/tibenham/7442179120/ F-JTYB
Post by: paul tricker on September 07, 2012, 08:41:54 PM
Quote from: Runway 31 on September 07, 2012, 07:54:55 PM
Hi Paul,
Alan just Found this
PH-WIT has been reserved for this Cessna, but owner (Mr. de Wit!) told me that the aircraft will remain D-EWIT. Based at Rotterdam (RTM / EHRD)
http://www.abpic.co.uk/photo/1172075/
PH-WIT was a C182K c/n 18258418 which became D-EHKD (since W/O) & Holland has a 30 year rule on re-use, so I guess PH-WIT was NTU. Cannot find any pictures of it
Paul
Post by: neroon79 on September 08, 2012, 03:27:58 AM
04CE77 (Kenya, no flight id, seems to be a decoding error)
473413 (Hungary, no flight id, same as above)
4A0091 again... with flight id: FAT1BU
4B16BF (Switzerland, no flight id, another decoding error would be my guess)
The three MILs haven't populate.
3F423A  GAF033
3F4317  TA47
3F54C2  PANTER2
Have a nice Saturday!
Ingo
Post by: Runway 31 on September 08, 2012, 12:14:08 PM
Cheers Paul, many thanks for that info.
Post by: Runway 31 on September 08, 2012, 12:22:59 PM
Hi Ingo,
04CE77 unknown to me
473413 unknown to me
4A0091 given its flight ID is FAT1BU, I would hazard guess this is 4B0091 HB-AFT AT72, also picked up by a user in Bucharest so looks miscoded.
4B16BF unknown to me
I could have sworn I did those 3 mil tac but definately have now.
Post by: flygfantast on September 08, 2012, 02:45:43 PM
Just on screen not populating: 4CA1B0 c/s TSO8765.
Niklas
Post by: Runway 31 on September 08, 2012, 03:11:54 PM
Hi Niklas
Added at 14:02 courstesy John Hargreaves, 4CA1B0 EI-CZD, Boeing 767-216ER, c/n 23623/142
Post by: X on September 08, 2012, 03:49:33 PM
Swiss hex 4B0E97 seems to have reappeared today but last year was PC-6 HB-FNR, returning to Swiss register or 2nd use?
   4B0E97                                                              2012/09/08 16:53:29
Last year was
* 4B0E97                           HB-FNR  PC6   Pilatus Flugzeugw... 2011/03/11 17:33:05
X
Post by: Runway 31 on September 08, 2012, 04:05:34 PM
X
4B0E97 HB-FNR has not been re-issued, just checked the Swiss register.  The previous holder of the registreation is now JU-1911 Pilatus PC-6/B-2-H4 Turbo Porter c.n 972, Thomas Air
Post by: X on September 08, 2012, 04:50:20 PM
Thanks, be surprised if we had a Mongolian PC-6 around the sandpit, so probably a miscode as it was also noted in April at 3200ft in and out over two hours.
X
Post by: neroon79 on September 09, 2012, 04:23:50 AM
3413C0 (Spain, flight id: IBE3588, decoding error of 3413C8)
3C49A0 (Germany, no flight id, second time - first was on June 20th this year, no luck with details. )
3D1F00 (Germany, flight id: DEKDF, decoding error of 3D1F63)
3FEE75 (Germany, flight id: DMKSW, still no luck with the details)
3FEF54 (Germany, flight id: DMMBA, still no luck with the details)
3FF042 (Germany, flight id: DMGIE, The dulv indicates that this is a PNR3 Alpi Pioneer 300 Private cn:?)
3FF174 (Germany, flight id: DMCNA, no luck with the details)
3FF19B (Germany, flight id: DMCBP, still no luck with the details)
45AA90 (Denmark, no flight id, nothing more)
484137 (Netherlands, flight id: KLM79G, decoding error of 484133)
4BA741 (Turkey, no flight id, was TC-IZA, but is now SP-ABK of Bingo Airways)
Wish you a nice Sunday!
BR Ingo
Post by: Runway 31 on September 09, 2012, 10:57:30 AM
Hi Ingo,
3C49A0 unknown to me, doesnt decode.
3FEE75 D-MKSW, still unknown to me
3FEF54 D-MMBA, unknown to me
3FF042 D-MGIE, unknown to me but thanks for the PNR3 info
3FF174 D-MCNA, still unknown to me
3FF19B still unknown
45AA90 decodes to OY-JTP unknown to me
Not much help with those unknowns.  You have a good day as well
Post by: EK01 on September 09, 2012, 02:51:00 PM
Afternoon Alan,
Another grand day. Not sure if this is in the latest d/b as I have not risked downloading due to the usual routes problems but just come on and not populating :
018079
Post by: Runway 31 on September 09, 2012, 02:56:32 PM
No problem with the routes Ian, all 187,833 of them in there
I dont have anything on your Libyan, I take it there was no flight ID showing
Post by: EK01 on September 09, 2012, 03:14:44 PM
Alan,
No flight ID just showing mode S.
I have 351,644 routes in my d/b and don't want to lose any or have them overwritten which as you know happened before so I leave the regular updates you do well alone. Shame as all the updaters teams hard work is not being appreciated at least by me.
Post by: Runway 31 on September 09, 2012, 03:17:35 PM
No worries Ian, another alternative is to send them to me and I could see if I could have them added to the d/b
Post by: X on September 09, 2012, 03:23:08 PM
Also when it comes to routes we have some daft ones that are clearly not the route operated especially on Reach Flights as the one below Illustrates. Suggest you talk to your boys and tell them to remove US mil routes as they change all the time. The one below may have KNGU as its destination but clearly did not depart Spain if OTT DXB.
AE145E  RCH150   LERT-KNGU       06-6160 C17   US - Air Force       2012/09/08 16:42:53
I know its a damn tough job and some routes are obviously not known like our daily Baghdad to DXB Iraqi flight IAW123/124, can we advise you of these and can you pass them on or is there another quicker way?
X
Post by: Runway 31 on September 09, 2012, 03:41:19 PM
The system I would expect looks at the flight ID' and departure/arrival points from previous flight and get the routes from that.  As you suggest that may be OK for airline traffic but not many military flights fly specific routes with their attending flight numbers.  I will speak to Airnav and see what they say.
Post by: X on September 09, 2012, 05:08:11 PM
back to normal topics
4067ED                                                              2012/09/09 19:21:24
X
Post by: Runway 31 on September 09, 2012, 05:11:41 PM
X
4067ED , G-GLBX, Bombardier BD-700-1A10 Global Express c/n 9120, Finesse Executive
Post by: X on September 09, 2012, 06:17:22 PM
Just been told it was in one of the sandpit hangars all week, so I missed it on departure!
X
Post by: Runway 31 on September 09, 2012, 06:35:01 PM
Registered 30/8  was previously N887WS
Post by: X on September 10, 2012, 07:10:25 AM
That explains it, so it was only a paintscrape of an old regular...phew
X
Post by: flygfantast on September 10, 2012, 01:35:07 PM
Alan,
Not populating: 424541 using c/s VQBOJ
According to Skyliner:
 Canadair CRJ    200    ?        VQ-BOJ    Ak Bars Aero    delivery 09sep12 KEF-MSQ-KZN    ex ?
Niklas
Post by: Runway 31 on September 10, 2012, 01:56:16 PM
Thanks Niklas, no update to the c/n available yet
Post by: X on September 10, 2012, 06:00:43 PM
Here we go again with another miscode for A6-RKB, that is now six by now and trying to catch EP-LCE for the miscoding record
* 89E381  RKM300   OMRK-VOCL                                          2012/09/10 21:56:40
X
Post by: Runway 31 on September 10, 2012, 06:08:34 PM
Still a fair bit off EP-LCE.  It hasnt had any new ones for a wee while
Post by: jim_stockwell on September 10, 2012, 08:23:22 PM
Hi Alan
The database still contains G-GNAA which was re-registered G-EHAA in May 2010 with all the orther details the same
Jim
Title: Re: Database Update Requests
Post by: Runway 31 on September 11, 2012, 07:40:49 AM
Many thanks Jim
Post by: GreekSpy2001 on September 11, 2012, 09:33:15 AM
Picked up the following
* 780837  DER112                   B-8250  GLF4  Deerjet              2012/09/11 08:48:26
However I've been informed it should be G550 B-8152. Looked to be inbound Luton or Stansted.  Haven't seen either reported.
Graham
Post by: Runway 31 on September 11, 2012, 10:16:36 AM
Graham,
Ongoing discussion on the mode-s forum with a couple put forward, just waiting for confirmation but its not B-8250 .  Inbound Cambridge.
Post by: Runway 31 on September 11, 2012, 07:51:05 PM
Graham,
780837 confirmed as B-8152 G550 c/n 5005 of Deer Jet courtesy Glenn Herriott on mode-s forum
Post by: paul tricker on September 12, 2012, 08:03:11 AM
Two from yesterday, unfortunately I have drawn a blank on them...
3B772E  FAF6790
4D02B5  N160RM     The FAA only gives details of the current N160RM, & not on previous holders. It was up            at  22000ft.
Paul
Post by: Runway 31 on September 12, 2012, 08:28:27 AM
Hi Paul,
3B772E decodes to 90 but dont know anything else, The only French 90 I am aware of is a Navy E121
4D02B5 decodes to LX-JFA which is now N160RM so miscoding its old hex
Post by: X on September 12, 2012, 12:34:43 PM
Seem to have a couple of neighbourly Zagros Air MD80 codes missing. EP-ZAB (c/n 49930) , EP-ZAC (c/n 49949)and EP-ZAM c/n 49490. Would assume 736822/736823/73682D are most likely. EP-ZAB in db as miscoding 400002.
X
Post by: Runway 31 on September 12, 2012, 01:12:41 PM
X
736822 is EP-ZAB
736823 is EP-ZAC
73682D is EP-ZAM
All now updated
Thanks again
Post by: X on September 12, 2012, 01:30:53 PM
Also add these Zagros MD80's
736821 EP-ZAA  49634
736824 EP-ZAD  49279
736825 EP-ZAE  53066
736826 EP-ZAF  53119
All picked up out of Kish
X
Post by: Runway 31 on September 12, 2012, 03:53:21 PM
Cheers X all added
Post by: Runway 31 on September 12, 2012, 07:10:08 PM
Inbound Mildenhall AE4DE1, 11-9355, Bombardier E-11A, c/n 9355, US - Air Force, not TACTICAL as per d/b.
Courtesy Mode-s forum, Glenn Herriott
Post by: flygfantast on September 12, 2012, 07:43:34 PM
AD1BC4 seems to be LN-FTH miscoding it's former code of N9438G.
LN-FTH, Cessna 172S, c/n 172S11200, Pilot Flyskole AS
Also 51109D is now using c/s NVD501/NVD503 (Avion Express) and seen twice a day, guessing it's a Saab 340 or JS31, I'm trying to get the identity resolved...
Niklas
Post by: Runway 31 on September 12, 2012, 07:51:55 PM
Looks like you are correct Niklas N9438G cancelled to Norway 29/8 and look forward to an update on 51109D
Thanks again
Post by: paul tricker on September 12, 2012, 08:31:23 PM
Just the one today...
4241DA  VPCAJ
According to Skyliner this is B737-505  24648/2213  European Skybus
Rgds
Paul
Post by: BBJUK on September 13, 2012, 04:45:48 AM
Morning Alan.
A couple of additions from Abu Dhabi:
A235AB is the NEW miscode being used by Boeing 757 N757SS c/n 22176, confirmed here this week.
And the last new Bell 412EP for Abu Dhabi Aviation flew today, so the final line up is
c/n hex
A6-HBN 36590 89635E
A6-HBO 36591 89635F
A6-HBP 36592 896360
A6-HBQ 36593 896361
Cheers BBJUK
Post by: Dana on September 13, 2012, 06:55:44 AM
4A1E70, YR-GSP, Bell Helicopter Textron 429, B429, Private owner.
Post by: Runway 31 on September 13, 2012, 07:36:59 AM
Thanks Dana
Post by: Runway 31 on September 13, 2012, 07:53:48 AM
Many thanks BBJUK, records updated
Post by: Runway 31 on September 13, 2012, 07:55:21 AM
Thanks again Paul
Post by: superspotter on September 13, 2012, 02:32:39 PM
Hi Guys from Lagos;
A little bit of info, Cessna 208Floats here in LAgos 5N-BIW has appeared a couple of times this week with the spurious hexcode of 584000. That's it!
regards clive.
Post by: Runway 31 on September 13, 2012, 03:14:35 PM
Thanks Clive
5N-BIW, Cessna 208 Caravan (Floats) c/n 20800403, operator unknown to me
Post by: chewycanes on September 13, 2012, 03:17:11 PM
Afternoon Alan
ACDA92 callsign N9270Q Beech G33 Sioux City Water Services (from AF)
3D3FA3 callsign D-EWIT Cessna 172  (from AF)
Brian
Post by: superspotter on September 13, 2012, 03:26:35 PM
Another one from Lagos: Hexcode 0640E0 equates to 5N-LSG Bell 412 of Caverton Helicopters, regards clive.
Post by: superspotter on September 13, 2012, 03:33:05 PM
I am beginning to think that the Nigerians dont care much for all this hexcode nonsense!! Hexcode F9BEF4 has just landed with the callsign NGR 917. It was in fact NAF-917 C-130 Hercules of the Nigerian Air Force!
regards clive.
Post by: superspotter on September 13, 2012, 03:36:47 PM
Another one that adds fuel to the fire re: Nigerias antipathy towards hexcodes, I had on an hour or so ago hexcode 0640FA which equates to 5N-FNC A320 of First Nation Airways. Oh good, I thought as I needed that one and they are grounded. But no, turns out to be NAF-030 Do228 of the Nigerian Air Force!
They are beginning to annoy me now :)
rgds clive.
Post by: Runway 31 on September 13, 2012, 03:55:38 PM
Hi Brian,
ACDA92 N9270Q, Cessna 172S Skyhawk SP, c/n 172S11214, Weaver Aero, certificate issued 11/9 and in d/b since then although I have it still with Cessna, I expect its on delivery.
3D3FA3 D-EWIT Cessna 172S Skyhawk SP, c/n 172S10803, Mr De Wit is the owner funny enough
Post by: superspotter on September 13, 2012, 04:00:36 PM
A further two Nigerian conirmations for you: Hexcode 0640D2 belongs to 5N-BMQ Allied Air Cargo 727F and hexcode 064100 belongs to 5N-BMS Jed Oil 732F. regards clive.
Post by: superspotter on September 13, 2012, 04:05:30 PM
One more confirmation for you before I head off to eat: excode 0640EE is 5N-BND Overland Airways ATR-42, regards clive.
Post by: Runway 31 on September 13, 2012, 04:06:30 PM
Many thanks for those Clive, keep them coming.  Yes miscodes are rather annoying to say the least, bain of my life!!
Enjoy your eats
Post by: EK01 on September 13, 2012, 04:38:11 PM
Alan,
Not sure if you have this but Monarch would appear to be using I-AIMR B737-430 c/n 27007 belonging to Air Italy. It's just landed at Alicante as MON7414 from East Midlands. Not been seen before operating that particular flight.
Post by: Runway 31 on September 13, 2012, 04:47:36 PM
Thanks Ian,
Will keep an eye on it to see if its just a one off cover for a defect or if its longer term
Post by: EK01 on September 13, 2012, 04:55:58 PM
Alan,
Just wondered if Monarch may have taken over some of the now deceased bmiBaby schedules and consequently they may be short of aircraft and therefore leased this one in short/long term.
Post by: Runway 31 on September 13, 2012, 05:18:28 PM
Ian,
From the Monarch website dated 31/8
As you may have seen in press articles and in our advertising, Monarch is expanding quickly this year to offer a greater range of flights for you to choose from.
While we are introducing new services, we are temporarily using aircraft operated by other airlines. One of the regulations we have to meet in these circumstances is that the aircraft are operated using these airlines' own pilots and crew – in airline industry terms this is called 'wet leasing'.
Wet leasing aircraft is common practise in the airline industry, particularly when an airline needs to obtain aircraft very quickly and on a short-term basis. Wet leases are often used to introduce new routes or supplement an existing fleet during peak season, such as we are doing at the moment.
Please be assured that safety is our Monarch's first priority and we would never compromise upon this. Monarch has carefully selected four airlines to operate this contract and the requirements routinely stipulated by the UK Civil Aviation Authority have been met.
So looks like one of them
Post by: EK01 on September 13, 2012, 07:09:11 PM
Cheers Alan. Thanks for that info.
Post by: X on September 14, 2012, 09:01:20 AM
This is confirmed as DU-SD5 of SkyDive Dubai, so miscoding French hex
3A212B  JUMP5    F-OIJL  DHC6  Air Guyane Express   2012/09/14 10:57:39
X
Post by: Runway 31 on September 14, 2012, 09:29:11 AM
Thanks X
Post by: X on September 14, 2012, 01:01:38 PM
Just noticed that this should also have operator as SkyDive Dubai
3D4952  JUMP1                    DU-SD1  C208  (Miscode hex of D... 2012/09/14 12:22:08
X
Post by: Runway 31 on September 14, 2012, 01:08:57 PM
Amended X, thanks
Post by: RodBearden on September 14, 2012, 04:46:00 PM
Hi Alan
Just spotted that 40674B is in the d/b as G-LMOA - should be G-LMAO
Post by: Runway 31 on September 14, 2012, 04:56:45 PM
Chhers Rod, sorted
Post by: Xon on September 14, 2012, 09:40:55 PM
I suppose it's already in database but i can't check:
489325 SP-EQG DH8D c/n 4423
Post by: Runway 31 on September 15, 2012, 06:46:53 AM
Yes got it Xon,many thanks for posting it anyway.  Still looking for confirmation on SP-EQH c/n 4424 which I expect to be 489327
Post by: shouriken on September 15, 2012, 11:13:33 AM
Boeing 707-3K1C, cn 20804/883 (ex YR-ABB) has left Romania on Friday as N707GF using the hexcode of YR-ABB.
Liviu
Post by: Runway 31 on September 15, 2012, 11:21:52 AM
Thanks Liviu,
Landed Shannon last night
Post by: X on September 15, 2012, 01:35:08 PM
Il-76 UP-I7625 is repainted and is operated by Air Trust eyeballed as such at DWC
X
Post by: superspotter on September 15, 2012, 03:29:19 PM
Another one from Lagos: Hexcode 06407E is 5N-RSN Augusta AW139 operated by the River State Government, regards clive.
Post by: Runway 31 on September 15, 2012, 04:07:14 PM
Thanks X
Post by: Runway 31 on September 15, 2012, 04:09:01 PM
Thanks again Clive, keep them coming.
Post by: paul tricker on September 15, 2012, 07:27:53 PM
Two unknowns today...
49D2DC  TIE611Z  All I can find is that TIE = Time Air (cz) which should make it a biz jet of some sort.
              (Google-ing TIE611Z produced "0 documents match your query"!!!)
43E942  = M-ABFM which is FA7X c/n 108
Paul
Post by: Runway 31 on September 15, 2012, 07:39:29 PM
Thanks Paul,
Dont have anything on 49D2DC.  Its been noted around over the since 27/8 but no details are known to me
Post by: superspotter on September 16, 2012, 12:00:42 PM
Another hexcode tie-up from sunny Lagos: Hexcode 064125 is 5N-CML Augusta AW139 operated by Caverton Helicopters. regards clive.
Post by: Runway 31 on September 16, 2012, 12:02:34 PM
Cheers Clive, thanks again
Post by: Runway 31 on September 17, 2012, 08:39:08 AM
Paul,
49D2DC OK-LNZ Cessna 510 Citation Mustang c/n 510-0368, Time Air, ex EC-LNZ
Post by: anorak on September 17, 2012, 05:26:41 PM
43E90E / callsign PGT901 nothing on Airframes.
Thanks,  Dave.
Post by: Runway 31 on September 17, 2012, 05:46:56 PM
Dave,
43E90E, M-ABES, Boeing 737-58E, 29122/2991
Post by: Xon on September 18, 2012, 04:57:00 AM
Quote from: Runway 31 on September 15, 2012, 06:46:53 AM
Confirmed. Yesterday was first comercial flight.
Post by: Runway 31 on September 18, 2012, 07:39:54 AM
Thanks Xon
Post by: paul tricker on September 18, 2012, 07:25:21 PM
Thanks for sorting out 49D2DC.
two non-populators today in amongst all the duff packets...
4BD242 TCTRB =TC-TRB CL604 c/n 5494 pass on the operator
A071DF N128ES  FAA has this as reserved, last use was a SR22 c/n 3840 exported to Spain, so possibly the Cirrus using its old code?
Rgds
Paul
Post by: Runway 31 on September 18, 2012, 07:47:16 PM
Thanks Paul,
Not aware ofthe operator either.
c/n 3840 now EC-LRL, possibly it you noted but without the flight ID, could be anything
Post by: paul tricker on September 18, 2012, 08:05:05 PM
Quote from: Runway 31 on September 18, 2012, 07:47:16 PM
Thanks Paul,
N128ES was in the flight id column.
Paul
Post by: Runway 31 on September 18, 2012, 08:25:31 PM
Sorry Paul, didnt see it he first time. Possibly the Spaniard but no way of knowing without an eyeball
Post by: mikek on September 19, 2012, 04:26:34 AM
3B9BB8, Falcon 20 Gardian, 65, French Navy, c/n 465.
Mike
Post by: Runway 31 on September 19, 2012, 08:25:44 AM
Thanks again Mike
Post by: EK01 on September 19, 2012, 09:27:49 AM
Alan,
Just come on 'My Flights' :
Mode S : 00E4C9
Flight ID : RANGR85
Any Ideas ?
Post by: Runway 31 on September 19, 2012, 09:43:55 AM
Hi Ian,
Going by the call sign Ian I would suggest it is a USN aircraft miscoding.  The hex doesnt decode to anything.
Post by: EK01 on September 19, 2012, 09:47:51 AM
Cheers Alan.
Post by: X on September 19, 2012, 02:33:11 PM
504E00 has just arrived somewhere but viz bad so no type
X
Post by: jim_stockwell on September 19, 2012, 02:36:18 PM
Good afternooon Alan
Not populating is 48B68C with a flight i/d of SP-NWM. I cannot find anything out about it on either the Gatwick or Airframes web pages to help you
Jim
Post by: EK01 on September 19, 2012, 03:03:46 PM
Alan,
Two RAF Eurofighter Typhoons are currently flying around. (At least I assume they are both Typhoons ) One is showing in 'My Flights' as ZK304 c/n BS055, the other is not showing on the RB. Have you any ideas. Is the other one showing on your box by any chance ?
Post by: X on September 19, 2012, 03:13:35 PM
We believe EY-609 IL76 has been recoded 515261 as it  stopped pinging old miscode hex 60005F on 3/8/12 and new hex appeared 9/8/12 and has been seen regularly at SHJ since and times for 515261 fit our sightings. We therefore guess that EY-610 is 515262 which is irregular to say the least. They also fit in the sequence of all the new EY- IL76 machines that code correctly.
X
Post by: Hawkeye on September 19, 2012, 03:22:25 PM
Hi Alan,
A couple in MyFlights earler not showing regs, but the callsigns apparently tie them up.
A72B3E showing callsign N561GG which was G-WINT until recently.
48B68C showing callsign SP-NWM
Syd
Post by: Runway 31 on September 19, 2012, 03:36:19 PM
Jim,
48B68C SP-NWM first noted 16th, no tie ups available as yet.  Logged at Glasgow 17th, Middlesborough 17th and Ondara 16th
Post by: Runway 31 on September 19, 2012, 03:38:57 PM
Hi Syd,
Orkney added the PC12 earlier and see reply above re SP-NWM
Post by: Runway 31 on September 19, 2012, 03:41:34 PM
Ian,
I only picked up the same one as yourself, ZK304, flight ID WOLF0031.  Picked it up yesterday as well.
Post by: Runway 31 on September 19, 2012, 03:47:32 PM
X,
Thanks, 515261 first picked up on the network 9/9 as you state. 515262 first noted 15/8.
I dont have anything on your Moldovan
Post by: Runway 31 on September 19, 2012, 04:11:32 PM
Jim/Syd
Reply on Mode-s forum shows 48B68C to be a PC12 which visited Dundee yesterday.  No other info available as yet.
Post by: X on September 19, 2012, 04:51:28 PM
If my theory works the true hex codes for the currently miscoding Il-76's should be as follows
515260   EY-608
515294   EY-660
515308   EY-680
515312   EY-690
X
Post by: Runway 31 on September 19, 2012, 05:12:49 PM
Will we ever know X
Post by: X on September 19, 2012, 05:19:14 PM
As you indicate they will probably get re-regged in a couple of months knowing the operators out here!
x
Post by: RodBearden on September 19, 2012, 08:49:20 PM
Hi Alan
Not populating: 7C60A5 i/d VH TDJ
Post by: Runway 31 on September 19, 2012, 09:37:31 PM
Hi Rod,
7C60A5, VH-TDJ, Van's RV-7, c/n 73538, Anthony Travers-Jones
Post by: mikek on September 20, 2012, 06:26:11 AM
Not populating:
7808D8, c/s NSJ878
Mike
Post by: Runway 31 on September 20, 2012, 08:03:19 AM
Hi Mike,
7808D8 B-8260, Gulfstream Aerospace GV-SP (G550), c/n 5373, Nanshan Jet
Post by: EK01 on September 20, 2012, 02:27:02 PM
Quote from: Runway 31 on September 19, 2012, 03:41:34 PM
Ian,
Alan,
The second Typhoon may have been ZK333 c/n BS094 as it is flying around today with the ID of WOLF0032.
Post by: Runway 31 on September 20, 2012, 02:54:55 PM
Proably will be Ian, havent picked it up myself although I have a Portuguese P3 on just now, a first for me
Post by: EK01 on September 20, 2012, 03:07:25 PM
Alan,
Picked up that one as well and it flew right over the house. Makes a change from the Air Berlin fleet !
Post by: Xon on September 20, 2012, 03:45:24 PM
Quote from: Runway 31 on September 19, 2012, 04:11:32 PM
It's SP-NWM and probably c/n 1362 Now descending near Warsaw :)
Post by: Runway 31 on September 20, 2012, 03:46:20 PM
Correct Xon, thanks.  Inbound from Dundee
Post by: X on September 20, 2012, 03:54:19 PM
This should be EP-MHJ A320(cn 857) which is reported as SCRAPPED!!!
* 73350A                                                              2012/09/20 19:44:15
I am told it is now EP-IEC for Iran Air (so miscoding as well as resurrected from the scrapheap)
X
Post by: Runway 31 on September 20, 2012, 03:58:59 PM
X
May or not be, I have it going to EP-IEC.  My d/b has it as going to Iran Air and was noted at Tehran stored in full colours
Post by: paul tricker on September 20, 2012, 07:59:42 PM
One non populator today...
06411F  5NDOW  this would make it 5N-DOW  Do328-110  c/n 3070  DANA Nigeria.
Air-test out of Bournemouth, or return maybe??
Paul
Post by: Runway 31 on September 20, 2012, 08:19:13 PM
Hi Paul,
I believe that 5N-DOW will be following others of its kind and be going to the US for Sierra Nevada Corp so expect a reg/hex change soon.
Post by: Runway 31 on September 20, 2012, 08:29:20 PM
Mikek
For info details of the first to RNZAF BE20's were added to d/b today.  See http://nzradar.com/?p=1935
Post by: Skyliner on September 21, 2012, 05:47:20 AM
Quote from: Runway 31 on September 20, 2012, 08:19:13 PM
Hi Paul,
Returned back to Nigeria via Algeria - not for Sierra Nevada Corp
Post by: Runway 31 on September 21, 2012, 07:31:53 AM
Thanks Skyliner, hope my d/b gets updated from that info. Hopefully pick it up here in Spain on the way down.
Post by: mikek on September 21, 2012, 10:27:29 AM
Thanks Alan.
Not populating for some reason:
C8196A, ZK-JTQ, B737-476, 24442, Airwork. ex QANTAS/Jetconnect but now in service with Airwork.
Mike
Post by: X on September 21, 2012, 10:39:00 AM
Caspian miscode In and out of sandpit this lunchtime
* 728E1A  CPN029     EP-CPZ MD80                       2012/09/21 12:37:35
73350A EP-IEC A320 Iran Air 857 confirmed as being in and out sandpit yesterday as per earlier message. Miscoding ex reg EP-MHJ.
X
Post by: Runway 31 on September 21, 2012, 12:37:12 PM
Thanks Mike,
Didnt populate as it wasnt in the d/b
Post by: Runway 31 on September 21, 2012, 12:53:03 PM
Cheers X, many thanks
Post by: X on September 21, 2012, 04:45:32 PM
I assume that EP-IEC should be 7324A3 and EP-CPZ should be 730E1A (not 728E1A) so someone has punched in the wrong code in the latter....my neighbourly engineer at it again!
X
Post by: flygfantast on September 21, 2012, 05:08:46 PM
Evening Alan
Not populating from yesterday:
49D2A8 OK-ESC, BE40, Beechjet 400A, c/n RK-295, Time Air
Niklas
Post by: Runway 31 on September 21, 2012, 05:14:18 PM
Thanks Niklas
Post by: Runway 31 on September 21, 2012, 05:16:01 PM
Correct on both counts X, let me know if you pick up the correct codes.  Neither have been picked up so far.
Post by: X on September 21, 2012, 05:51:50 PM
EP-IEC on approach to DXB at the moment still miscoding, will notify you if either are corrected any time in the future.
X
Post by: Runway 31 on September 21, 2012, 05:54:45 PM
Cheers X
Post by: X on September 22, 2012, 08:59:20 AM
No doubt a US miscode and most likely a P3 being used in the large Naval exercise being held in the waters around us.
* 00012E                                                              2012/09/20 12:07:20
X
Post by: X on September 22, 2012, 09:37:03 AM
F1A300 ZU MAR in South African airspace
X
Post by: Runway 31 on September 22, 2012, 10:34:16 AM
X
ZU-MAR Van's RV-10, c/n 41033.
Nothing on your other miscode.
Post by: paul tricker on September 22, 2012, 02:21:15 PM
One for today so far...
401841  GAXOJ = G-AXOJ  BEAGLE B121 SERIES 2 c/n B121-109 Pup Flying Group
although I think its altimeter might need calibrating, or can these things reach 37,000ft?!!
Paul
Post by: Runway 31 on September 22, 2012, 02:30:32 PM
Thanks Paul,
Wouldnt thinks so, either dodgy altimeter or mixed up with loose packet from some other aircraft
Post by: paul tricker on September 23, 2012, 10:53:19 AM
300521  FXR18L
All I can find is that this call sign was used by an unknown Avanti ( I-FXR?) recently. No idea if this is the same aircraft though.
Paul
Post by: BOM1 on September 23, 2012, 11:54:22 AM
Some miscodes from a brief visit to Jakarta
9A00A9 PK-CJI B732 23135 Sriwijaya Air
A2243A PK-MBZ B732 23007 Merpati
A12467 in database as N173AW UH-1 is being used by PK-MBP B733 Merpati
Steve
Post by: Runway 31 on September 23, 2012, 12:31:04 PM
Hi Steve,
Not you clarify N2243A as PK-MBZ as I find that c/n 23007 is now PK-YSA with Trigana Air Service
Thanks again
Post by: BOM1 on September 23, 2012, 01:03:58 PM
Apologies, my log does show PK-YSA not MBZ for A2243A.
Steve
Post by: Runway 31 on September 23, 2012, 01:06:16 PM
Many thanks Steve,
Post by: GreekSpy2001 on September 24, 2012, 12:06:03 PM
New German Mil hex noted just now
3F4F13                                                              2012/09/24 13:01:57
From noise its just made it is a C-160.  Shame the low cloud block its view.
Graham
Post by: Runway 31 on September 24, 2012, 12:20:44 PM
Added as tactical code Graham
Post by: flygfantast on September 24, 2012, 03:37:10 PM
4A8303 60101, Saab SK60A, c/n 60101, Sweden - Air Force
Niklas
Post by: Judwin45 on September 24, 2012, 03:47:20 PM
000400 is an AW139 flying out of Westland, identity unknown.
Post by: Runway 31 on September 24, 2012, 03:50:43 PM
Thanks Niklas
Post by: Runway 31 on September 24, 2012, 03:52:15 PM
Sorry nothing on that miscode Keith.
Post by: Judwin45 on September 24, 2012, 04:11:26 PM
Thanks Alan
Just noted that flightradar24 is showing it as a AW149, I-RAIC. If that is correct I need to brush up on my recognition!!
Post by: Runway 31 on September 24, 2012, 04:26:31 PM
Keith,
While there have been around 11 previous users of I-RAIC, I cannot find it in use at this time, could still be correct though.
Post by: Xon on September 24, 2012, 08:38:34 PM
Quote from: Runway 31 on September 24, 2012, 04:26:31 PM
Keith,
~3 weeks ago I-RAIC AW149 with 000400 was in Poland. http://www.helihub.com/2012/09/04/agustawestland-displays-aw149-at-mspo-2012/
Post by: Runway 31 on September 25, 2012, 07:17:58 AM
Thanks for the clarification Xon.  I wonder if its correct hex should be 300400.
Post by: superspotter on September 25, 2012, 11:08:42 AM
Hi Guys;
One from Napoli instead of Lagos for a change!
Hexcode 30025F belongs to I-IVIP Eurocopter EC-130, regards clive.
Post by: Judwin45 on September 25, 2012, 02:00:23 PM
Briefly showing on my flights 424569, no other details.
000400 flying again today, confirmed visually as I-RAIC.
Post by: jim_stockwell on September 25, 2012, 02:17:50 PM
Hi Alan
I also had 424569 not populating but can add a flight I/D of AFL5651. It was flying at 37000 and was picked up at Stevenage Herts
Jim
Post by: Judwin45 on September 25, 2012, 02:20:25 PM
Simple question, in the Data Base under the aircraft section, what are the conditions 'BY' and 'IN'.
Post by: Runway 31 on September 25, 2012, 04:46:59 PM
Jim/Keith/All
424569 VQ-BPK, Airbus A330-343E, c/n 1345, Aeroflot Russian Airlines out of Toulouse on delivery
Post by: Runway 31 on September 25, 2012, 04:53:03 PM
Thanks Clive, there are plenty of Italians missing in the d/b so feel free to tie up as many as you can please!
Post by: mikek on September 26, 2012, 04:37:10 AM
Not populating:
7C499B, no further details, except constant altitude at FL210.
Mike
Post by: Runway 31 on September 26, 2012, 08:09:46 AM
Hi Mike,
VH-OTP decodes to VH-OTP which isnt current on the CASA register.  2 previous holders of the registration.
1. BAe Jetstream 31 c/n 974 which is now RP-C863
2. Beech 58 Baron c/n th-274 which is now VH-FLZ
Post by: mikek on September 26, 2012, 08:44:39 AM
Ah right, I guess it's just been put back onto the VH- register as I have now found this which ties in perfectly!
http://galonghaulnews.blogspot.co.nz/2012/09/jetstream-crossing-tasman.html
But from that, I guess it won't be for long as it says it's moving onto the New Zealand register shortly...
Post by: Runway 31 on September 26, 2012, 09:02:07 AM
Thanks for that Mike, must be VH-OTP for the ferry, still not showing on the CASA register. Will watch for it becoming ZK-VAI which now that its in New Zealand wont be long.
Post by: EK01 on September 26, 2012, 09:19:31 AM
Morning Alan,
Another glorious day. On 'My Flights' and probably yours :
3B7BF6  Flight ID : TURIA 69
Any Ideas ?
Post by: Runway 31 on September 26, 2012, 09:32:02 AM
Hi Ian,
Another find day, not missing Scotland one bit!!
3B7BF6 decodes to F-ZKBC, a Eurocopter test registration.  A previous user of the registration is Eurocopter EC665 Tigre HAP which is now HA.28-03 c/n 2008 with the Spanish Army so possibly it.
Post by: EK01 on September 26, 2012, 09:38:20 AM
Alan,
Just come back on at 570ft so must have landed somewhere. Possibly San Javier. looks as if it it probably is a helicopter with the Spanish Army. Nip along the road and check it out !
Post by: Runway 31 on September 26, 2012, 11:33:59 AM
Damn it, just back from Pilar Del Horadado, pity I didnt know that before I went out!!
Post by: flygfantast on September 26, 2012, 06:14:39 PM
Not populating from todays log:
780A48 c/s BKDP
3F95B2 c/s GAFW01A, Tactical code
39BC00 F-HPAA
Niklas
Post by: Runway 31 on September 26, 2012, 09:04:25 PM
Hi Niklas,
780A48 B-KDP, Gulfstream Aerospace GV-SP (G550) went to Luton, c/n unknown yet
39BC00 F-HPAA not on DGAC register inknown to me
Post by: X on September 27, 2012, 06:22:37 AM
New miscode in the area descending from 21000 to 11600 (probably FJR/RAK)
* 288037  3403CTXC                                                    2012/09/27 07:50:31
X
Post by: flygfantast on September 27, 2012, 07:25:49 AM
Quote from: X on September 27, 2012, 06:22:37 AM
X
Passed over/around Sweden on 25/9 with c/s 3402CTXC
288037  3402CTXC   2012/09/25 12:20:13
Niklas
Post by: Runway 31 on September 27, 2012, 08:01:54 AM
Nothing on 288037.  From what  I can see it was first noted on the report from Niklas. No previous sightings
Post by: Chris11 on September 27, 2012, 03:27:58 PM
Added owner/operator
ZS-SVE   00B1BF      PA28   Piper PA28-161   43 Air School (Pty) Ltd   28-42359
Post by: Chris11 on September 27, 2012, 03:30:12 PM
and two that does not seem to be on the database
ZS-SVF   00B1C0      PA28   Piper PA28-161   43 Air School (Pty) Ltd   28-42358
ZS-SVD   00B1BE      PA28   Piper PA28-161   43 Air School (Pty) Ltd   28-42357
Post by: Chris11 on September 27, 2012, 03:35:38 PM
and another
ZS-SUW   00B1B7      PRM1   Raytheon Aircraft Company 390   Graham Family Trust   RB-66
ZS-SWN   00B1E2      E135   Embraer EMB-135 LR   S A Airlink   145453
ZS-IPP   0096C6      PC12   Pilatus PC-12/45   Arelco Resources (Pty) Ltd   195
Post by: Runway 31 on September 27, 2012, 04:28:01 PM
Many thanks for the updates Chris.
Post by: mikek on September 28, 2012, 01:11:55 AM
C82017, ZK-DHP, B200, BB-1944, Hawker Pacific. Soon to transfer to the Royal New Zealand Air Force.
Mike
Post by: neroon79 on September 28, 2012, 07:48:45 AM
Morning Alan, I'm now starting to post my two or three weeks back log. Thanks to the new MyLog editing tool it'll only be the non-populaters without the already populated ones if I had to use the LOG-Mails :-).
Here we go (first ten)
00A9DC (South Africa, no flight id, airframes: ZS-PVN B190 Beech 1900D Aircraft Africa Contracts UE-51)
200000 (no allocation, with flight id PTO101, miscoded airframe perhaps of Pilot Training Network)
222222 (no allocation, with flight id DEGCJ, obviously miscoded airframe may be D-EGCJ C150 Reims-Cessna F150L shall use 3D14BD http://www.planepictures.net/netsearch4.cgi?stype=reg&srng=1&srch=D-EGCJ )
28889E (no allocation, with flight id ESFSR, nothing more)
37793D (Spain, flight id: KNIGHT1, mil airframe perhaps a German miscoded one)
3B77E1 (France, no flight id, two times in past two weeks)
3C48C9 (Germany, no flight id, low message count, so more likely a decoding error)
3C4940 (Germany, no flight id, low message count, same as above)
3C4987 (Germany, Air Berlin flight id, a decoding error)
3C4E19 (Germany, Lufthansa flight id, a decoding error)
end of batch one...
Post by: neroon79 on September 28, 2012, 08:16:42 AM
second batch:
3C5312 (Germany, Lufthansa flight id, decoding error)
3C5E65 (Germany, no flight id, low message count, possibly a decoding error)
3C5EE0 (Germany, flight id: GWI43K, decoding error of 3C5EE4)
3C661C (Germany, flight id: DLK9EE & 607N0, DLH flight id: decoding error of 3C6618)
3CF476 (Germany, flight id: DCTWO, was a LJ31 which is now D-CFST, couldn't find anything about a new one using D-CTWO)
3D1941 (Germany, flight id: DEHUV, D-EHUV DR40 Robin DR-400/180 Regent Aero-Club Rothenburg ob der Tauber e.V. source: http://www.edfr.de/index.php?id=59 )
3D24A4 (Germany, flight id: SEEST, any chance that this is SE-EST on transfer? )
3D2563 (Germany, no flight id, decodes to D-EMKH but now news about a new airframe with this reg.)
3D2C68 (Germany, flight id: DEPBK, nothing found)
3D2DDB (Germany, flight id: DEPPR, posted June 2011: D-EPPR BE23 Beech 23 Private / http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-EPPR )
end of batch two...
Post by: neroon79 on September 28, 2012, 08:34:04 AM
batch three:
3D3A08 (Germany, no flight id, D-EUFO SR22 CIRRUS SR-22 Private CN:? Mk1EB August 2012: http://www.strforum.de/viewtopic.php?f=9&t=8623 )
3E446F (Germany, no flight id, received two times, nothing found)
3E6F47 (Germany, flight id: DKHIL, D-KHIL G109 Grob G109B Turbo Segelfliegergruppe Singen e.V. CN:? source: http://sfg-singen.de/planes/grobg109b/ )
MIL List:
3E853D GAFE21
3E8597 GAF120
3EB910 GAF727 / GAF626
3EBA16 GAF640 / GAF320
3F488C
3F4FBF GAF320
3F51AE TIGER1
End of batch three...
Post by: neroon79 on September 28, 2012, 08:37:44 AM
batch four:
MILs continued:
3F5BD6 BU15T / none
3F61B2 STRIKE2 / none / none
3F6553 GAF014
3F6594 none
3F66A7 VADER1 / PACK2 / HAMMER
3F7EBC none / KNIGHT2
3F88D0 GAF094
3F8F5C SHOCK
3F927D PACK2
3F95B2 none
end of batch four
Post by: Runway 31 on September 28, 2012, 08:55:01 AM
Thanks Mike, Alan
Post by: neroon79 on September 28, 2012, 08:59:27 AM
batch five:
MIL the 3rd:
3F96F0 PANTER1
3F9AD2 GAF021 / GAF021
3F9D32 GAF128 / GAF128
3FA083 TA30
3FA72E GAF775 / GAF775
3FA7E7 GAF096 / GAF096 / GAF096 / HUHU / GAF096
3FA8F2 NITRO1
3FAE85 GAF910
end of mil.
3FEC32 (Germany, flight id: DMHHB, D-MHHB FAET Atec 321 Faeta Private CN:? source: DULV and http://www.flugzeug-bild.de/name/einzelbild/number/22834/kategorie/flugplaetze~deutschland~tannheim-edmt.html )
3FED07 (Germany, flight id: DMNPW, D-MNPW last known to be a Atec Zephyr 2000 and was last mentioned in 2006 )
end of batch five.
Post by: neroon79 on September 28, 2012, 09:19:02 AM
batch six:
3FEE34 (Germany, flight id: DMIXA, D-MIXA PISI Pipistrel Sinus 912 Fluggemeinschaft Rennefeld e.V. CN:? source: www.segelflug.de/vereine/schmallenberg/vereinsflugzeuge.htm )
3FF175 (Germany, flight id: DMNUL, D-MNUL FK9 Fk-Lightplanes FK-9 Mk.III Private CN:? Mk1EB July 2012: http://jetphotos.net/viewphoto.php?id=7428751&nseq=7 )
4005B2 (UK, flight id: JOR233, airframes: G-BSNR)
4009FB (UK, flight id: BMA896, decoding error of 4009FF)
4067C0 (UK, flight id: EXS440, decoding error of 4067C4)
478329 (Norway, flight id: SAS601,  decoding error of 47832B)
478346 (Norway, flight id: SAS4714, decoding error of 47834E)
48411F (Netherlands, flight id: KZR1375 -two times on two different days, KZR: Air Astana, miscoded air frame I guess)
484182 (Netherlands, no flight id, quite low message count, so might be a decoding error)
end of batch six.
Post by: Runway 31 on September 28, 2012, 09:21:13 AM
Hi Ingo,
Batch 1-4
Nothing on your unknowns
3D24A4 decodes to D-EMCY P28R which is now HB-***.  SE-EST is Cessna 205 which ahs been on the Swedish register since new in 1963
Post by: Runway 31 on September 28, 2012, 09:29:42 AM
Hi Ingo,
Batch 5-6
Nothing on your unknown apart from 48411F,  P4-KCH, Embraer 190-100LR, c/n 19000547, Air Astana.
Thanks again
Post by: neroon79 on September 28, 2012, 09:29:56 AM
Batch seven:
4841A0 (Netherlands, no flight id, no active airframe found)
48D631 (Poland, flight id: JDI20B, decoding error of 48D635)
That's all for now.
Post by: Runway 31 on September 28, 2012, 09:41:37 AM
Ingo,
4841A0 decodes to PH-ZDI not assigned previous now SX-BRV F50.
Post by: mikek on September 28, 2012, 11:01:14 AM
Hi Alan,
A9E706, N737WF, Boeing 737-406(F?), 24529.
Mike
Post by: neroon79 on September 28, 2012, 12:18:56 PM
New Airframe list batch one
02A1D4 (Tunisia, flight id: TAR6510, TAR: Tunis Air)
150779 (Russian Federation, flight id: CCESC, nothing more)
3003C8 (Italy, flight id: ISS197, ISS: Meridiana nothing more)
3421D2 (Spain, flight id: SWT5AJ, SWT: Swiftair, nothing more)
38A33B (France, flight id: FPPGB, F-PPBG BALL Type:? Operator: ? CN:? Mk1EB: http://www.flickr.com/photos/hitschko/7919862840/ )
39BC00 (France, flight id: FHPAA, no luck with the details)
3B77E4 (France, flight id: FRAF, mil airframe I guess)
3C09D8 (Germany, flight id: GMI2275, GMI: Germannia, decodes to D-ASSX but nothing on this reg. So may be a decoding error)
3C09F7 (Germany, flight id: GMI1881, decodes to D-ASUC nothing on this reg, may be a decoding error too)
end of batch 1 (new ac)
Post by: neroon79 on September 28, 2012, 12:48:07 PM
batch two (new ac)
3C4839 (Germany, flight id: BER80G, was D-ABAY until 2007, nothing about a new one using this reg, so decoding error I guess)
3C48C9 (Germany, flight id: BER94E, decooding error of an Air Berlin airframe)
3C49EF (Germany, flight id: CFG827, CFG: Condor Flugdienst, decodes tp D-ABOO, no airframe with this reg found, therfore I presume a decoding error)
3C6449 (Germany, several Lufthansa flight ids, airframes: D-AIBI A319 Airbus A319-112 Lufthansa 5284 delivered September the 21st)
3C6DC2 (Germany, flight id: DLH8YL, I presume a decoding error)
3CF0BD (Germany, flight id: IFA2526, IFA: FAI rent-a-jet, new one of them or a decoding error)
3CF476 (Germany, with flight id: AAY108 & AYY108, AAY: Allegiant Air AYY: Air Alliance Express I'll bet that AYY108 is the correct flight id. / decodes to D-CTWO already posted today)
3D078C (Germany, flight id: DEBCM, D-EBCM SR22 Cirrus SR-22 Private 0581 ex N1669C Mk1EB August 2012: http://www.flugzeugbilder.de/show.php?id=1165664 )
3D1012 (Germany, flight id: DEEIK, D-EEIK may be a DR40 http://www.dave.wise.btinternet.co.uk/DWR400B.htm / http://www.aviationfanatic.com/ent_show.php?ent=5&AC_Regno=D-EEIK )
3D14FD (Germany, flight id: DEGEV, D-EGEV may be a C182 http://www.flightglobal.com/airspace/forums/gatwick-roundup-15-06-12-85245.aspx )
End of Batch 2 (new ac) to be continued later today.
Post by: Runway 31 on September 28, 2012, 12:56:39 PM
Thanks Mike,
Its ex VH-JWL
Post by: Runway 31 on September 28, 2012, 01:08:00 PM
Ingo,
Batch 1
02A1D4 unknown to me
150779 unknown to me
3003C8 unknown to me
3421D2 decodes to EC-JGU, unknown to me
38A33B F-PPBG Rolland JGB-1050 C/N 01
39BC00 F-HPAA, unknown to me
3B77E4 unknown to me
3C09D8 D-ASSX nothing known
3C09F7 D-ASUC nothing known
Post by: neroon79 on September 28, 2012, 02:04:11 PM
batch three (new AC)
3D1A05 (Germany, flight id: DIBAZ, D-IBAZ PA23 Piper PA-23-250 Aztec B Private 27-2221 Mk1EBs: http://www.flugzeugbilder.de/show.php?id=1132309 / http://www.airplanes.se/?script_name=bild&bild=12796 )
3D32D6 (Germany, flight id: DERMS, still no luck with the details)
3D32D6 (Germany, flight id: DEROG, decoding error of 3D32FE D-EROG AA5 American AA-5 Private CN:?)
3D4107 (Germany, flight id: DEWWL, D-EWWL PA46 Piper Malibu Mirage Private CN:? Noted here: http://www.flugzeugforum.de/flugbetrieb-augsburg-edma-agb-2012-a-68518-60.html )
3E271B (Germany, flight id: DOASH, D-OASH BALL Type: ? Operator: ? CN:? sources: http://ballon.eu/gasballon/dm-gas-2011/ & http://ballon-galerie.de/7.html )
3E3C5B (Germany, flight id: DIOBBB, D-IOBB no active airframes found)
3E4710 (Germany, flight id: QGA050N, QGA: Windrose Air Jetcharter )
End of Batch three, next MIL List
Post by: neroon79 on September 28, 2012, 02:23:56 PM
Batch 4 (NEW AC / MIL List)
3E8572 GAF019, GAF027, GAF626, TA40, TA40T, TA55, TA70
3E8729 F_P
3E8768 APB, GAF112, GAF766, GAFMED1, TA31, TA40, TA58T
3E89A2 GAF068, TA50,TA57, TA59T TA63
3E8E2E MONSTR2, TIGER
3E93A5 METAL1, POISON2
3EA260 GAF062, GAF128, GAF727
3EAC1F STONE
3EAFE9 MOJO2
3EB825 PANTER1, PANTER2
3EBA16 GAF011
3EBF81 VADER1
3EBF89 PACK1, VADER1
3F40B6 GAF212
3F414A GAMTC82
3F436D METAL2, ZAPATA2
3F4444 BU11, EIFEL
3F45FA ZAPATA1
3F4811 GAF639
3F488C GAF022
3F4FBF GAF102
3F513D TA43
3F51AE TIGER, TIGER1
3F59C5 DMH44, VADER, VADER1
3F6007 GNY4530
3F6301 POISON1, ZAPATA1
3F6594 BOMBER1
3F67FE ZAPATA2
3F6974 HAMMER1
3F6D4C LK01A
3F70B2 TIGER1
3F7A1B GAF767
3F7B85 GAF000, GAF320
3F8311 GAF663
3F8A41 GAF128
3F8C5B GAF012
3F8D9E SW03
3F8DD5 GAF954
3F8E01 GAF033, GAF640
3F8FEA SMOKE1
3F9014 POISON
3F95B2 GAFW01A
3F96F0 EAGLE, PANTER1
3F9D97 FOKKER
3FA083 GAF108, GAF283, TA43T
3FA19B GAF007
3FA3DB DIXI02
3FA5C0 GAF023
3FA692 PINTO2
3FAB2E GAMTC17
3FABF5 HAMMER
3FACD4 PINTO1
3FAE05 GAF914, GAF106
3FB10E DEMON01, DEMON02, OKW23
3FB7E5 SMOKE
End of MIL List Batch
Post by: Runway 31 on September 28, 2012, 03:03:18 PM
Ingo,
Batch 3
3D1A05 decodes to D-EICJ unknown to me. D-IBAZ PA23 Piper PA-23-250 Aztec B Private 27-2221 so miscoding
3D4107 D-EWWL P46T,  Piper PA-46 Malibu Mirage JetPROP DLX, c/n 4636135, Willie-AD Beteiligungs in d/b since 20/9
3E271B decodes to D-IFZV unknown to me.  D-OASH however is a Ballonbau Worner NL-1000/STU c/n 1053 so miscoding
3E3C5B D-IOBB unknown to me
3E4710 decodes to D-ISCM unknown to me
Post by: neroon79 on September 28, 2012, 03:08:22 PM
Batch 5 (new AC)
3FEA5B (Germany, flight id: DMYYM, still noluck with the details)
3FEB97 (Germany, flight id: DMCZZ, D-MCZZ C42 Ikarus C42 Private CN:? Mk1EB September 2011: http://www.abpic.co.uk/photo/1311207/ )
3FEC4B (Germany, flight id: DMVRH, D-MVRH CH60 Zenair CH601D Zodiac Private CN:? Mk1EB September 2009: http://www.flugzeugbilder.de/show.php?id=874177 )
3FECE4 (Germany, flight id: DMWBS, still no luck with the details)
3FEE00 (Germany, flight id: DMFNY, decoding error of 3FEE36 D-MFNY FK-Lightplanes FK-9 )
3FEE6E (Germany, flight id: DMWWL, D-MWWL ex D-FDCT Flight Design CT-SW source airframes)
3FF0B5 (Germany, flight id: DMILV, D-MILV BREZ Aerostyle Breezer Itzehoer Luftsportverein e.V. CN:? source: http://www.fliegen-itzehoe.de/Charter/D-MILV/d-milv.html it's a different Breezer in the picture)
3FF09C (Germany, flight id: DMSMP, D-MSMP WT9 Aerospool WT-9  Dynamic Private CN:? source: DULV)
3FF0FC (Germany, flight id: DMEHN, D-MEHN nothing more)
3FF102 (Germany, flight id: DMJSA, finally we have it: D-MJSA BREZ Aerostyle Breezer B400 Private CN:? Mk1EB September 21st 2012: http://www.luftfahrtclubbraunschweig.de/picdb/Matthias-Kloss-Privat-Breezer-Aircraft-B400-D-MJSA-BWE-Braunschweig-Wolfsburg-9692.html )
3FF11A (Germany, flight id: DMBJR, D-MBJR may be TAKE OFF MAXIMUM KARAT 13 )
3FF173 (Germany, flight id: DMAVL, D-MAVL nothing more)
3FF189 (Germany, flight id: DMZLL, D-MZLL ECHO Tecnam P-92-S Echo Private, CN:? Mk1EB: http://www.flugzeugbilder.de/show.php?id=523710 and http://www.flugzeugforum.de/coburg-brandensteinsebene-edqc-2012-a-69456.html )
3FF19B (Germany, flight id: DMCBP, already posted today)
3FF1B1 (Germany, flight id: MDRW, matches to D-MDRW still no luck with the details.)
End of the German unknowns. My apologies for this huge amount of unknowns on one day.
Kind regards
Ingo
Post by: Runway 31 on September 28, 2012, 04:13:04 PM
Ingo,
BATCH 5
3FEA5B D-MYYM, unknown to me
3FECE4 D-MWBS, unknown to me
3FF0FC D-MEHN unknown to me
3FF11A D-MBJR, unknown to me
3FF173 D-MAVL unknown to me
3FF189 D-MZLL ECHO Tecnam P-92-S Echo Private, CN 455
3FF19B D-MCBP, already posted today)
3FF1B1 D-MDRW unknown to me
Many thanks
Post by: Judwin45 on September 28, 2012, 06:20:46 PM
Just come up on My Flights, 4D022C, flight id LXUSM, Fl 430, no other details.
Post by: Runway 31 on September 28, 2012, 06:28:42 PM
Hi Keith,
Nothing on it yet, presumably biz jet on delivery, FL430 direct KOK according to mode-s forum thread
Post by: Judwin45 on September 28, 2012, 06:50:04 PM
Thanks Alan
Post by: neroon79 on September 29, 2012, 04:56:14 AM
Good Morning, the unknowns from Friday:
34245F (Spain, flight id: ANE3469, decoding error of 342459 [CRJ9])
3D1298 (Germany, flight id: DEFHG, D-EFHG HR20 ROBIN HR-200 Acrobin Flugschule Hans Grade 264 source: Operators Charter-Site: http://www.flugschule-grade.de/flugzeugcharter_2_sitzer.php )
400429 (UK, without flight id, was G-CPEL which is now N946FD after freight conversion)
473414 (Hungary, flight id: WZZ1SX, decoding error of 473410 or 47340E)
4CA7B0 (Ireland, flight id: RYR2QP, decoding error of 4CA7B4)
A05A21 (USA, flight id: UAL96, in this case decoding error of A05A25 / A05A21 decodes to N12121 REED-MADSEN DONALD TAYLOR BIRD MADSEN DONALD H CN:09 from airframes)
ACDAF7 (USA, flight id: N9273L, N9273L is according to airframes a P28A PIPER PA-28-181 with construction number 2843041 of Plane Nonsense INC. , but according to airport-data the current status is de-registered)
MILs:
3E8BE7  GAF767
3F45FA  METAL1
3F5EA3  GAF062
3F67FE  POISON1
3F8A41  GAF128   LPLA-EDDK
3F8E01
3F9014  POISON2
3F9689  GAFW02B
3FAE85  PINTO2
3FB687  TA46
That's it for Friday. Wish you a nice weekend!
Regards Ingo
Post by: neroon79 on September 29, 2012, 05:20:53 AM
Some additions from the back-log:
440421 (Austria, flight id: OEDND, OE-DND C182 Reims Aviation F182Q Skylane Flugsportverein Stockerau F18200083 source airframes, confirmed by operators Website: http://www.fsv2000.at/ -> go to Flugzeuge)
4613B9 (Finland, flight id: OHHMF, OH-HMF EC??/[EC35] Eurocopter EC[-135] FinnHEMS CN:? seen in this video: http://www.youtube.com/watch?v=v8EfNsE_PbI )
BC614E (no allocation, flight ids: BLADE01, NAF322A, NF645B, POLLY01, one or some miscoded MIL airframes)
FFFFF6 (no allocation, flight ids: NAF322 and NF645A, another MIL Airframe)
Back-Log finished. Well, except a huge list of HEX only entries...
Post by: flygfantast on September 29, 2012, 07:16:39 AM
Morning
Unknowns from yesterday:
E8C045 c/s TCR138D. Could be OB-2015T, Skyliner has the following:
Antonov 26, 67304002, OB-2015T, Amazon Sky, delivery 28-29sep12 IEV-BGO-KEF, ex UR-VAI
3F9689 c/s GAFW02B, Tactical (also in Ingo's message)
Niklas
Post by: Runway 31 on September 29, 2012, 08:23:24 AM
Hi Niklas,
Many thanks
Post by: X on September 29, 2012, 02:36:15 PM
our unknown from a couple of days ago has left but no idea of type
    288037  3404CTXC                                             2012/09/28 00:46:42
* 728000                                                              2012/09/28 21:06:25
* 7342AF                                                              2012/09/28 19:26:43
And guess what.....here we go again with an Iranian This is EP-CPX miscoding
* 6B0E18  CPN0022                                                     2012/09/29 09:12:17
X
Post by: Runway 31 on September 29, 2012, 02:47:26 PM
Hi X
Nothing on any of those apart from 7342AF which decodes to EP-PUO which is unknown to me
Post by: flygfantast on September 29, 2012, 04:46:19 PM
473230 HA-TAE, Saab 340AF, c/n 007, ABC Air Hungary
Niklas
Post by: Runway 31 on September 29, 2012, 05:09:21 PM
Many thanks Niklas
Post by: EK01 on September 29, 2012, 07:18:12 PM
Alan,
Saturday night is definately the night to get them. Another Tianjin delivery flight just come over. This time flight ID GCR 3213 with Mode S of 780962. Details required.
Cheers,
Post by: Runway 31 on September 29, 2012, 09:04:47 PM
Hi Ian,
Was out for dinner and missed it and another one
780962 B-3213 Embraer 190-100LR c/n 19000574, Tianjin Airlines
780961 B-3193 Embraer 190-100LR c/n 19000573, Tianjin Airlines
Post by: neroon79 on September 30, 2012, 03:47:17 AM
Morning, the unknowns from Saturday:
3C48E2 (Germany, no flight id, ex. D-ABGB an Air Berlin A319 which is now with TAM. Found nothing about a new one using this reg. )
3FF10E (Germany, flight id: DMBIX, D-MBIX Breezer Aerostyle Breezer AeroLight Flugschule UL98 Mk1EB, September 2012 at ILA: http://www.flugzeugbilder.de/show.php?id=1171093 mentioned at operators Website: http://www.aerolight-flugschule.de/index.php?id=280 )
440C75 (Austria, no flight id, nothing more)
5CA508 (no allocation, no flight id, nothing more)
885304 (Thailand, flight id: THA8935, HA-TXD A320 Airbus A320-232 Thai Smile 5301 found at XFW-Spotter It's already in the db I guess)
AA4A21 (USA, flight id: CMB584, decoding error of AA4A23)
Have a nice Sunday!
Ingo
Post by: Runway 31 on September 30, 2012, 01:31:26 PM
Hi Ingo,
Nothing to add other than the Thai Smile is HS-TXD.
Post by: neroon79 on September 30, 2012, 04:21:57 PM
For Information only:
3CD6E9 D-CIRP  D328 formerly with Cirrus Airlines received several times with SUS (Sun Air of Scandinavia) flight ids in the past couple of days.
Have a nice evening! BTW. The 'A' was simply to close to the 'S' again...
Ingo
Post by: X on September 30, 2012, 05:32:02 PM
Another that is back in service and hence not WFU
700002  AFG252                   YA-PIC  B734  WFU Stored (ex Pa... 2012/09/30 04:21:08
X
Post by: Blueboy on September 30, 2012, 06:01:07 PM
Hi Alan, picked up AA2E14 with c/s of N755RA which appears to be a Global 5000 c/n 9468
J.D
Post by: Runway 31 on September 30, 2012, 06:41:14 PM
Thanks JD, only registered on Thursday
Post by: Runway 31 on September 30, 2012, 06:44:35 PM
Hi X
Thanks, was with Pamir now Arian Afghan Airlines going by call sign.
Post by: Runway 31 on September 30, 2012, 06:46:47 PM
Thanks Ingo, know what you mean, its easy to do.
Post by: Chris11 on September 30, 2012, 07:24:57 PM
ZS-BEX   008334   Beech C90GTx      LJ-2051 Owner to follow in a week or so ;)
Post by: neroon79 on October 01, 2012, 04:53:47 AM
Morning, the unknowns from Sunday:
3D2C68 (Germany, received again this time without flight id, decodes to D-EPBK, still no luck)
MIL: 3F4A05 (Germany, flight id: GAF713)
3FECCC (Germany, flight id: ZZZZZZZ, nothing more)
3FF133 (Germany, flight id: DMKEK, D-MKEK nothing more)
400600 (UK, no flight id, was G-WLSH now 4X-ATN after being D-BCRN, nothing about a new one)
400A94 (UK, flight id: VIR401Y, so decoding error of 400A90)
44054B (Austria, no flight id, was OE-GAC, which is now LX-NAT, nothing about a new one)
484147 (Netherlands, no flight id, nothing more)
48A1C2 (Poland, no flight id, nothing more)
4CA890 (Ireland, no flight id, EI-EGD Ryanair B738 http://www.flightradar24.com/data/airplanes/ei-egd ) <- not sure about this one
71C201 (Korea, flight id: KAL901, decoding error of 71C209)
Have a nice Day!
Ingo
Post by: neroon79 on October 01, 2012, 05:05:02 AM
A little off-topic, but does anyone know whether the ICAO airline code STQ is re-assigned or not. I've a Triple Alpha Biz-Jet, that was/is using STQ flight ids several times since the beginning of August this year.
Post by: neroon79 on October 01, 2012, 05:52:32 AM
Errata:
3D568B D-FFAH of Fresena Flug is in the db with AC of Fresna Flug.
Post by: Runway 31 on October 01, 2012, 07:26:12 AM
Sorted Ingo, thanks
Post by: Runway 31 on October 01, 2012, 07:29:57 AM
Hi Chris, thanks again.
Post by: Runway 31 on October 01, 2012, 07:43:19 AM
Ingo,
STQ - Starwings Dortmund, call sign Startrek
3D2C68 unknown to me
3FECCC unknown to me
3FF133 D-MKEK unknown to me
44054B same info as you
484147 unknown to me
48A1C2 unknown to me
4CA890 does not decode, unknown to me
Post by: neroon79 on October 01, 2012, 08:13:04 AM
Quote from: Runway 31 on October 01, 2012, 07:43:19 AM
Ingo,
Well, then we'll need a Logo aren't we?
Post by: neroon79 on October 01, 2012, 09:33:38 AM
Operator Update for 3DD5D8 D-HBFS: Owned by Brose Fahrzeugteile GmbH & Co. KG (http://www.brose.com/ww/en/pub/company.htm) have look at the top of tail in this picture: http://www.planespotters.net/Aviation_Photos/photo.show?id=285346
Post by: Runway 31 on October 01, 2012, 01:24:19 PM
Thanks Ingo for the operator update.
Post by: X on October 01, 2012, 07:53:39 PM
Todays unknown
* 4BCB41                                                              2012/10/01 08:23:17
X
Post by: Runway 31 on October 01, 2012, 08:03:38 PM
Hi X
4BCB41 = TC-RZA, nothing further
For info, courtesy John Hargreaves, heading your way on delivery are,
8960FA  A6-EDY  A380-861  c/n 106  Emirates
8960F9  A6-EDX  A380-861  c/n 105  Emirates
Post by: X on October 01, 2012, 08:13:45 PM
A6-EDY due 0125 DXB time
A6-EGZ also en route arrival mid afternoon tomorrow
TC-RZA rptd as CL30
X
Post by: rnsavage on October 01, 2012, 08:33:38 PM
I had G-FBJH E175 of Flybe come with the wrong c/n today
Should be 17000351 not 17000355
Rick
Post by: Runway 31 on October 01, 2012, 08:39:36 PM
Sorted, thanks
Post by: X on October 01, 2012, 08:53:36 PM
A6-EAN A332 is now EI-EYO
X
Post by: neroon79 on October 02, 2012, 04:13:48 AM
Morning, the unknowns from Monday:
37793D (Spain, flight ids: GHOST1 & NITRO2, mil airframe perhaps a miscoded one)
3C6600 (Germany, flight id: DLH5KX, it's a decoding error, but due to the fact, that there are 4 known airframes in the list at the particular time, it's impossible to tell which one is the one who was generating the other four false entries)
3D2C68 (Germany, flight id: DEPBK, seems to become the new D-MJSA: In the Log on daily basis, but no Details available. )
400DAA (UK, flight id: EZY3AU, decoding error of 400DAE)
44F079 (Belgium, flight id: BAF253, BAF: Belgian Air Force)
47878F (Norway, flight id: NAX7FM, decoding error of 47878D)
4B1699 (Switzerland, no flight id, decodes to HB-ION not yet delivered A321-212 for swiss due to delivery in 2013. Therefore a decoding error I guess)
8960F9 (UAE, flight id: UAE7381, Big Bird #1 on delivery)
8960FA (UAE, flight id: UAE7380, Big Bird #2 on delivery) <- Two on one day, seems that Airbus want to get their 30 deliveries for 2012
MIL List:
3E839A  GAF121
3E839A  TLH5KY
3E8F97  SHOCK1
3EBF45  STRIKE
3F51B4  SHOCK2
3F63F3  GAF062
3F6468  PACK1
3F9640  GAFW02C
3F97C1  TA30
3F97C1  TA58T
3F9E39  GAF320
3FAF50  PACK2
Wonder when the German MIL will run out of new hex addresses...
Have a nice Day!
regards Ingo
Post by: Runway 31 on October 02, 2012, 07:27:29 AM
Thanks X, let me know when you pick up its new hex please.
Post by: Runway 31 on October 02, 2012, 07:29:02 AM
Hi Ingo,
As per reply 818
Post by: Kenny on October 02, 2012, 03:20:39 PM
Shahjalal International Airport
IATA: DAC – ICAO: VGHS
was renamed from Zia in 2010
http://en.wikipedia.org/wiki/Shahjalal_International_Airport
Post by: Runway 31 on October 02, 2012, 03:39:46 PM
Kenny,
I have amended it in the d/b.  Please note that similar to your last request it wont change the info on the map.
Post by: X on October 02, 2012, 07:17:10 PM
* 4844AC  KZR297   UAAA-OMAA                                          2012/10/02 22:14:33
Shows up as P4-NUR type not known BUT is it P4-NUR Hawker 850XP 258982 or areuse of hex/reg
X
Title: Database Update Requests
Post by: Kenny on October 02, 2012, 07:27:40 PM
Quote from: Runway 31 on October 02, 2012, 03:39:46 PM
Kenny,
Alan,
understand about the map...
thanks
Post by: X on October 02, 2012, 07:44:26 PM
Quote from: X on October 02, 2012, 07:17:10 PM
X
Believe it might be an E190 of Air Astana reusing hex
X
Post by: Runway 31 on October 02, 2012, 08:16:34 PM
I dont have anything on it X.  P4-NUR is now with the Pakstan Navy
Other than the new one delivered in September I havent heard of Air Astana getting another E190
Post by: X on October 02, 2012, 08:32:35 PM
What about P4-KCG 19000543 Embraer ERJ-190LR which is not in db?
X
Post by: X on October 02, 2012, 08:49:50 PM
I think we might have a new double coder on our hands...using same flight number/route at exactly the same time as the one claiming to be P4-NUR!
   4844A4  KZR297   UAAA-OMAA       P4-YAS  A319  Air Astana           2012/10/02 22:13:53
X
Post by: Xon on October 03, 2012, 12:25:43 AM
Two imho misstakes in DB:
MS   AR   AT   AN   AC   CN   PT   LK   PT2   LK2   CO
440137   OE-UDV   DA42   Various DA 42 NG Airframes   Diamond Test Registration   VARIOUS   ""   ""   ""   ""   ""
4401AB   OE-UDW   DA42   Various DA 42 NG Airframes   Diamond Test Registration   VARIOUS   ""   ""   ""   ""   ""
4401AD   OE-UDX   DA42   Various DA 42 NG Airframes   Diamond Test Registration   VARIOUS   ""   ""   ""   ""   ""
Today all 3 had fuel stop in Warsaw (EPWA):
OE-UDW now 44055B
OE-UDV now 44019E
OE-UDX still 4401AD
No other DA42 in range between few minutes before landing and few minutes after take off.
Post by: neroon79 on October 03, 2012, 04:25:13 AM
Morning, the unknowns from yesterday:
3C658A (Germany, flight id: DLH4EN, decoding error of 3C6588)
3C6609 (Germany, flight id: DLH3NM, decoding error of 3C6619)
3C6609 (Germany, flight id: DLH8FA, decoding error of 3C6601)
3CF476 (Germany, no flight id, decodes to D-CTWO, no new details)
3E9E2E (Germany, flight id: CB02, might be MIL airframe)
3FECDA (Germany, flight id: DMSLH, D-MSLH C42 Ikarus C-42 FB100 Private CN:? source: http://www.airport-data.com/aircraft/photo/606175.html )
43E940 (UK, flight id: MVITO, M-VITO H25B Hawker 800XP AC: ? CN:? source: http://www.homepages.mcb.net/bones/Manx_Register/ManxRegister_ModeS.htm )
44F079 (Belgium, received again without flight id)
473414 (Hungary, flight id: WZZ1QB, decoding error of 473410)
4844E5 (Netherlands, no flight id, airframes: PH-3Z1 BREZ Aerostyle Breezer C J-H- van Klinklen 057, This says it' s cancelled in 2011: http://www.antonakis.ca/registers/netherlands/20110914.txt )
4B1625 (Switzerland, flight id: SWR105L, decoding error of 4B1621)
7808A4 (China, flight id: CCA932, decoding error of 7808AC)
A528A1 (USA, flight id: UPS283, decoding error of A528A5)
MIL List:
3F4F1A  GAF062
3F63F3  TA20
3F9601  SNIPER02
3F97C1  TA43
3F97C1  TA43T
3F9E39  GAF320
A lot of decoding errors yesterday.
Have a nice Day!
Ingo
Post by: Runway 31 on October 03, 2012, 06:56:33 AM
Thanks X
GAS and Airframes dont have anything on P4-KCG.  AvDb have details but not hex yet and note it is due October, so I dont think it has been delivered yet.
I consider it is likely that it is haveing problems ith an iffy transponder double coding like you state.
Post by: Runway 31 on October 03, 2012, 07:08:24 AM
Hi Xon.
Thanks for that.
OE-UDW definately used 4401AB previously, although I am aware that 440BB8 has also been used as well.  9 previous uses of the registration by DA42 at least
OE-UDV, been used by 14 DA42 and 2 Katana so far at least
OE-UDX been used by 9 DA42 and 3 DA40 at least so far.
Post by: Runway 31 on October 03, 2012, 07:27:16 AM
Hi Ingo,
3CF476 D-CTWO, Learjet 35A, c/n 35-504, no owner details available
3E9E2E doesnt decode, probable mil as you state
43E940 M-VITO H25B Hawker 800XP
44F079 Belgian Air Force F16, unconfirmed
4844E5 decodes to PH-3Z1 BREZ Aerostyle Breezer cancelled and now an unknown on German register
Have good one
Post by: X on October 03, 2012, 04:36:01 PM
4BCB41   TC-RZA CL30 c/n 20284   2012/10/03 15:49:05
X
Post by: jim_stockwell on October 03, 2012, 04:43:24 PM
748035 reg OO-TAL a CRJ2 appears to be back in use again as it went into Luton this evening about 1720
Jim
Post by: Runway 31 on October 03, 2012, 04:53:14 PM
Cheers Jim, now with Emerald Jets
Post by: jim_stockwell on October 03, 2012, 05:42:28 PM
Hi Alan
A typo in my last message, I think, OD-TAL rather than OO-TAL. ( The eyes are not what they used to be so causing the mix up when I read it off on approach)
Jim
Post by: neroon79 on October 04, 2012, 04:21:07 AM
44061B (Austria, no flight id, nothing more)
4492E0 (Belgium, no flight id, nothing more)
451E88 (Bulgaria, flight id: LZB461, decoding error of 451E8C)
478346 (Norway, no flight id, maybe a decoding error again)
4CA76B (Ireland, no flight id, last time it was a decoding error)
896267 (UAE, flight id: FDB9750, FDB: FlyDubai, seems that A6-FDD is back after being leased to Transavia Airlines using reg PH-FDD)
E00000 (Argentina, no flight id, miscoded airframe or broken transponder)
That's it for yesterday.
Regards Ingo
Post by: Runway 31 on October 04, 2012, 07:51:14 AM
No problem Jim, I took it to be OD-TAL given the hex
Post by: paul tricker on October 04, 2012, 07:55:40 AM
No longer stored, departed Hanover this am, although who MHV are has defeated me..
3CC629  MHV331                   D-CCIR  D328  WFU Stored (ex Ci... 2012/10/04 08:36:49
Paul
Post by: Runway 31 on October 04, 2012, 07:57:02 AM
Hi Ingo,
44061B unknown to me
4492E0 unknown to me
896267 noted as back to A6-FDD
Post by: Runway 31 on October 04, 2012, 07:58:29 AM
Thanks Paul,
MHV = MHS Aviation, radio callsign Snowcap
Post by: neroon79 on October 04, 2012, 09:35:40 AM
Quote from: Runway 31 on October 04, 2012, 07:58:29 AM
Thanks Paul,
Thank's for this intel. I was about to ask this too, because I had monitored this airframe for a couple of days by now. It seems to be a permanent/daily connection between EDDK and EDDV.
Post by: X on October 04, 2012, 03:13:49 PM
7231D1 c/s IRM5040 level at FL320. hex code says is North Korean but c/s is Mahan Air.
Based on other EP miscoders 7335D1 EP-MNQ miscoding is nearest I can think off...is it bringing the triggers from North Korea, ho ho!
X
Post by: Runway 31 on October 04, 2012, 03:23:53 PM
X
I saw it and was just going to email you to see if you knew what it was a miscode of.  Will wait to get confirmation on it
Post by: Chris11 on October 04, 2012, 07:16:21 PM
ZS-SWV   00B1EA      E135   Embraer EMB-135 LR   S A Airlink   145737
Post by: Runway 31 on October 04, 2012, 09:19:51 PM
Thanks again Chris,
Post by: neroon79 on October 05, 2012, 06:23:46 AM
Morning, the unknowns from Thursday:
073408 (no allocation, no flight id, decoding error or a miscoded airframe)
3C4969 (Germany, no flight id, was D-ABKI which is now C-GBKI)
3C78C5 (Germany, no flight id, was D-ANFE which is now EI-FXI)
3E86B7 (Germany MIL, flight id: GAF183)
3F8BD6 (Germany MIL, no flight id, nothing more)
One from Austria that's good for generating the numbers for next lottery:
440651  H2GK81P                                                     2012/10/04 19:56:23
440651  K17LH1P                                                     2012/10/04 19:56:03
440651  M3WIX1P                                                     2012/10/04 19:53:20
440651  M4WJH1P                                                     2012/10/04 19:51:38
440651  O4OJH1P                                                     2012/10/04 19:51:52
440651  OEIRL                                                       2012/10/04 19:38:33
440651  OEIRL                                                       2012/10/04 19:51:45
440651  OEIRL                                                       2012/10/04 19:51:58
440651  OEIRL                                                       2012/10/04 19:52:53
440651  OEIRL                                                       2012/10/04 19:53:27
440651  OEIRL                                                       2012/10/04 19:56:09
440651  OEIRL                                                       2012/10/04 19:56:30
440651  Q4GIX1P                                                     2012/10/04 19:52:39
440651  R4OIX1P                                                     2012/10/04 19:52:46
OE-IRL F900 Dassault Falcon 900EX ART Aviation Flugbetriebs GmbH 118 sources:
http://www.laasdata.com/corpjet/corpjet-by-country.php?c=OE
http://www.amcarusa.com/various.htm
http://forum.scramble.nl/viewtopic.php?f=45&t=81015&start=30&sid=2d82dbb53a567ce6681835f46c1de24d
45C940 (Denmark, flight id: SAS1588, decoding error of 45C948)
4840DB (Netherlands, no flight id, still nothing more -might be a decoding error)
E0177A (Argentina, no flight id, nothing more)
Have a nice Day!
Ingo
Post by: Runway 31 on October 05, 2012, 08:13:24 AM
Hi Ingo,
073408 unknown miscode
The lottery number generator was added last night
4840DB I think is a miscode
E0177A also noted in Sweden by Niklas using flight ID 4686074, miscode? possible mil
Post by: X on October 05, 2012, 03:58:42 PM
Unknown since Feb 2010 this has been seen as an An-26 in what sounds like Trastaero c/s i.e. white with blue u/s
514035                                                              2012/10/05 19:53:23
X
Post by: Runway 31 on October 05, 2012, 04:09:46 PM
Hi X,
Nothing on it.  Trast Aero is banned by EU and operate from Ras Al Khaimah.  They had their AOC suspended in 2010 but I take it they are back in the air.
Post by: neroon79 on October 06, 2012, 04:20:56 AM
0A8600 (Bahamas, no flight id, nothing more)
3C4825 (Germany, no flight id, was D-ABAE B738 of air Berlin now with Jeju air)
3C665C (Germany, flight id: DLH016, decoding error of 3C6658)
3C665C (Germany, flight id: DLH5UC, decoding error of 3C6654)
3F71AC (Germany MIL, flight id: GAFM70B)
800718 (India, flight id: VT-IFC A320 Airbus A320-232 IndiGo 5291 on delivery. Therefore I expect, that this one has already added to the database)
AAB009 (USA, no flight id, would match to N788UJ, nothing on the US reg, so it's another decoding error I guess)
Have a nice Weekend!
kind regards from rainy Hannover
Title: Re: Database Update Requests
Post by: neroon79 on October 06, 2012, 05:26:51 AM
D-CWAY is in the db with operator Silverbird, who "died" in 2010 (insolvent). Planespotters.net states, that this one is now with MHS-Aviation.
Post by: EK01 on October 06, 2012, 08:50:55 AM
Morning Alan,
Just come on :
Mode S: 48D84E
Flight ID : PLF 048
Operator : Polish Air Force
Any Ideas ?
Post by: X on October 06, 2012, 10:56:40 AM
Poland 048 was a Yak-40, do not know if this is the same 048 though
X
Post by: Xon on October 06, 2012, 11:19:36 AM
Quote from: X on October 06, 2012, 10:56:40 AM
All our YK40 have been withdrawn from service  :( 048 is ready for sale and now it's in Minsk Mazowiecki (EPMM)
Quote from: EK01 on October 06, 2012, 08:50:55 AM
Mode S: 48D84E
Flight ID : PLF 048
It's our new C295 024 c/n 92 :)
Second one is: PLF 044 48D84D C295 023 c/n 89
88809D A321VN-A390 c/n 5297 Delivery for Vietnam Airlines XFW-BAK-HAN
Post by: Runway 31 on October 06, 2012, 11:46:44 AM
Thanks for those Xon, got the Vietnam Airlines earlier as well
Can you confirm the c/n of 023 as I have S.089 as AMT-255 with the Mexican Navy
Post by: X on October 06, 2012, 11:56:52 AM
Two non populators, the second GBG402 just landed SHJ plotting.
* 504DF4        2012/10/06 15:52:42
* 896368  GBG402                                                      2012/10/06 15:44:54
X
Post by: Runway 31 on October 06, 2012, 12:02:43 PM
Ian,
I replied detailing I didnt have any info but suggested it may have been a C295 on delivery.  I think my reply got lost when the network went down
Post by: Runway 31 on October 06, 2012, 12:26:13 PM
Nothing on either of those X.  GBG = Global Jet, UAE based, according to FAA.  I presume this is them  http://www.globaljet.aero/  so looks like new delivery.
Post by: paul tricker on October 06, 2012, 02:36:37 PM
If the flight ID is correct
* E48BF5  PPWAV                                                       2012/10/06 15:27:28
is a Hawker 900XP c/n HA-0199
Rgds
Paul
Post by: Runway 31 on October 06, 2012, 02:54:50 PM
Thanks Paul, thats what my d/b gives it as too.
Post by: jim_stockwell on October 06, 2012, 02:57:15 PM
Not populating E48BF5 , call sign PP-WAV
Jim
Post by: jim_stockwell on October 06, 2012, 03:02:38 PM
Partly answering my own query PP-WAV has just passed over me and is a Hawker 900xp and Gatwick AS have its c/n as HA-0199
Jim
Post by: flygfantast on October 06, 2012, 03:16:23 PM
4AD907 SE-VHG, Combo Dynamic 450, c/n 78, Private owner
See http://nykroppaflygcentrum.rular.se/P3233974
Niklas
Post by: Runway 31 on October 06, 2012, 03:36:37 PM
Thanks again Niklas
Post by: Runway 31 on October 06, 2012, 03:37:23 PM
Hi Jim,
Thanks see the reply 2 above yours.
Post by: Runway 31 on October 06, 2012, 03:40:32 PM
Thanks Ingo,
From a sunny and warm Torreveija
Post by: X on October 06, 2012, 03:41:17 PM
Quote from: Runway 31 on October 06, 2012, 12:26:13 PM
Might be the one we have been waiting for, A6-ESG B733 finally getting here or if not the A300 I could not read off, when I went to see JA805P on delivery. will see what I can find out
X
Post by: X on October 06, 2012, 04:04:14 PM
096018 TCV602 not populating
X
Post by: Runway 31 on October 06, 2012, 04:08:00 PM
Thanks X, noted it earlier and asked on mode-s forum, nothing known.
Post by: 54901 - Jim on October 06, 2012, 04:15:38 PM
Some updates for you, Alan ...
AC04BE / N8736P - Fly Comanche LLC
AB095D / N810AA - CSC Trust Co of Delaware Trustee
AB69AA / N83403 - Alaskan Adventures Restoration thru Renovation LLC
A9D325 / N732GX - SW Air LLC
A9DF75 / N735UW - Mark A Lawler
AA3B92 / N759BA - Boeing Aircraft Holding Co
A63140 / N4988 - Miguel A Marin
A4A80B / N4BC - CANCELLED / NOT ASSIGNED
A56BCD / N4488H - LeBeouf Bros Towing LLC
A27C59 / N25976 - Robert B Huntung
A2D963 / N283CS - Wells Fargo Bank Northwest NA Trustee
A1FB1C / N227BA - Grumman N227BA LLC
A01BA6 / N106GT - Andros Marketing LLC
A0CD44 / N1505P - CJ3SP LLC
A920D7 / N6879M / C182 / Cessna 182P / Tim Welter / 18263884
A7082A / N552PM / GLF5 / Gulfstream GV-SP (G550) / Gulfstream Aerospace Corp / 5382
780A50 / B-HHI - Serial Number 5377
A125A3 / N173PM / GX / Remos GX / McAire LLC / 269
A01524 / N104SD - CANCELLED / NOT ASSIGNED
A4A82F / N4CP / GLF5 / Gulfstream GV-SP (G550) / Charlie Papa Operations LLC / 5005
Thanks!
Post by: Runway 31 on October 06, 2012, 04:43:09 PM
Hi Jim,
Nice to hear from you again.  Many thanks.
N4CP although still showing on the FAA listing became B-8192 in January but for some reason hasnt been deleted yet.  I come across a number of these in a week, bad admin I suppose.
Post by: Runway 31 on October 06, 2012, 04:50:30 PM
Hi X
096018 TCV602 D4-CBY, Boeing 737-83N, 30675/898, TACV Cabo Verde Airlines.  N734MA re-registered
Thanks to John Hargreaves
Post by: EK01 on October 06, 2012, 06:37:03 PM
Thanks guys for all the info on PLF 048. I guess delivery is imminent from here in Spain.
Post by: Runway 31 on October 06, 2012, 06:40:36 PM
That was its delivery flight Ian along with 023.
Post by: EK01 on October 06, 2012, 06:49:35 PM
Cheers Alan.
Any Tianjin deliveries due tonight ?
Post by: Runway 31 on October 06, 2012, 07:48:02 PM
Not that I am aware of Ian
Post by: EK01 on October 06, 2012, 08:23:04 PM
Alan,
Just come over and miscoding :
CN-NMF A320-214 c/n 4539 Air Arabia
He is transmitting a Mode S of 02007B which belongs to CN-TPH a Beech 200 c/n BB-1006. He should be using 0200F9.
Post by: neroon79 on October 07, 2012, 05:11:32 AM
Morning, the unknowns from Saturday,
3C4843 (Germany, flight id: BER638M, decoding error of 3C484B)
3C48EC (Germany, no flight id, was D-ABGL A319 Airbus A319-112 Air Berlin 3586 but is now V5-ANK source Planespotters.net, so it seems to be another decoding error)
3F8B00 (Germany, no flight id, another decoding error would be my guess)
424540 (UK, no flight id, received on two boxes, no more information found)
473400 (Hungary, flight id: WZZ374, a decoding error caused by 473404 or 473405)
4CA267 (Ireland, flight id: RYR4551, seems to be a decoding error of 4CA27B)
8361AC (India, no flight id, another decoding error I guess)
88809D (Viet Nam, flight id: HVN8390, already posted by Xon)
Have a nice Sunday!
Ingo
Post by: paul tricker on October 07, 2012, 06:23:40 AM
No longer stored, but I do not know who is operating it
3C5962  SWR39B                   D-AFKB  F100  WFU Stored (ex Co... 2012/10/06 07:05:30
3C5962  SWR58Y                   D-AFKB  F100  WFU Stored (ex Co... 2012/10/06 09:20:26
Paul
Post by: neroon79 on October 07, 2012, 06:59:30 AM
Quote from: paul tricker on October 07, 2012, 06:23:40 AM
Paul
I had this one with several BER flight id's since mid September 2012 and last time on September 30th.
Post by: flygfantast on October 07, 2012, 07:14:30 AM
Morning Alan,
Unknown from yesterday: 4CC4A7 (Iceland) no c/s, 629 msgs in 2hrs at FL232 -> FL221
Niklas
Post by: flygfantast on October 07, 2012, 07:20:32 AM
Quote from: neroon79 on October 07, 2012, 06:59:30 AM
Paul
It's supposed to be operated by OLT Express Germany (which is nowadays owned by Panta Holdings, that also bought Contact Air, where this aircraft was before).
Niklas
Post by: Blueboy on October 07, 2012, 08:41:57 AM
Hi Alan, just out of Prestwick is HEX C07239 which decodes as C-GRGQ but is actually 5Y-BXI  DHC-8-102 c/n 376 (from Skyliner)
JD
Post by: Runway 31 on October 07, 2012, 08:44:27 AM
Hi JD,
Yes heading back home where it will probably take up its ex ID.
Post by: cemichael on October 07, 2012, 08:46:41 AM
Hi Alan
Few unknown from Siberia region:
682115 Mongolian F-50
682169 Mongolina F-50
440207 OE-UDP
142F0D Russia
78094D China
A09440 RA-67707
507C26 Uzbekistan
780040 B-2557
140AFB RA-02811
Post by: Runway 31 on October 07, 2012, 08:47:03 AM
Ian,
02007B is in the d/b as VARIOUS in use by the two aircraft you mention.  CN-NMF has been miscoding for a couple of months.
Post by: Runway 31 on October 07, 2012, 08:57:11 AM
Hi Ingo,
3F8B00 probable mil tac
424540 unknown to me
Have a good one too.
Post by: Runway 31 on October 07, 2012, 09:13:57 AM
Hi Cemichael,
Nice to hear from you.
682115 Mongolian F-50, unknown to me
682169 Mongolina F-50, unknown to me.
440207 decodes to OE-UDP, a Dimaond DA 42 Twin Star test registration. Used 9 times at least, 3 now in Russia, 1 in St Petersburg and 2 in use by Ulyanovsk Aviation FlightSchool
142F0D decodes to RA-12045 unknown to me
780945 unknown to me
A09440 decodes to N1363D, Cessna 208B Grand Caravan c/n 208B1273 now RA-******
507C26 unknown to me
780040 B-2557 was a 767-3J6 c/n 25875/429, reported as broken up
140AFB RA-02811 was/is an An-2T c/n 1G238-05.
Post by: Runway 31 on October 07, 2012, 09:17:45 AM
Niklas/Ingo,
3C5962 is now in the colours of OLT Express  http://www.planespotters.net/Aviation_Photos/photo.show?id=301610
I presume with a SWR flight ID it was sub chartered.
Post by: flygfantast on October 07, 2012, 09:18:49 AM
Quote from: Runway 31 on October 07, 2012, 09:13:57 AM
It's now RA-67707
Niklas
Post by: Runway 31 on October 07, 2012, 09:30:18 AM
Hi Niklas,
4CC4A7, no info on it yet and thanks for the C208 registration
Post by: Northern Watch on October 07, 2012, 09:42:37 AM
Morning Alan
These two picked up on Friday and both believed to be German Tac codes for Tornados.
3F988C / c/s DRAGO16
3F4FE6 / c/s DRAGO15
keith
Post by: Runway 31 on October 07, 2012, 10:16:37 AM
Thanks Keith
Post by: Flieger_NDS on October 07, 2012, 12:25:43 PM
I am not sure whether this has been covered: DLR (German Aerospace Center) research aircraft "ATRA" Airbus A320 had its reg changed from temporary Airbus reg F-WWDB to its final reg D-ATRA, yet hex 3C0C4B remained the same. It made flights on 5th and 6th October with LFO callsign.
Old temporary reg (note it is a sticker  (http://www.luftfahrtclubbraunschweig.de/picdb/Joerg-Graupner-DLR-Flugbetriebe-Airbus-A320-200-Forschungsflugzeug-ATRA-D-ATRA-BWE-Braunschweig-Wolfsburg-4218.html)next to painted German flag): click (http://jetphotos.net/viewphoto.php?id=6839610&nseq=16)
New final reg from last night: click (http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-DLR-Flugbetriebe-Airbus-A320-200-Forschungsflugzeug-ATRA-D-ATRA-BWE-Braunschweig-Wolfsburg-9741.html)
Post by: Runway 31 on October 07, 2012, 12:34:30 PM
Thanks Flieger_NDS, 3C0C4B D-ATRA in d/b since 16/8.
Post by: Xon on October 07, 2012, 06:45:21 PM
Quote from: Runway 31 on October 06, 2012, 11:46:44 AM
http://www.sp.mil.pl/images/stories/2012/10-PAZDZIERNIK/Casa/004.jpg
Post by: Runway 31 on October 07, 2012, 06:47:30 PM
Many thanks Xon.  Will advise my d/b also
Post by: neroon79 on October 08, 2012, 02:08:28 AM
3D2400 (Germany, flight id: DEMCL, decoding error of 3D2497)
3FF19B (Germany, flight id: DMCBP, still no luck with the details.)
3FF1AC (Germany, flight id: DMPMO, no luck with the details)
400559 (UK, flight id: BAW257, decoding error of 400551)
Have a nice Day!
Ingo
Post by: Runway 31 on October 08, 2012, 08:24:28 AM
Hi Ingo,
I still dont have anything on those.
Post by: GreekSpy2001 on October 08, 2012, 11:01:10 AM
 * 3B7737  FAF6794  LFOA-EGXW       075     A342  France - Air Force   2012/10/08 11:17:53
But its also been reported as a XINGU 075/YC 'FAF6794' into Waddington.  Notice PP had it as this Xingu. Nothing on Airframes.org.  One to check up I guess.
graham
Post by: Runway 31 on October 08, 2012, 11:53:59 AM
Thanks Graham, its the Xingu
Post by: Northern Watch on October 08, 2012, 05:50:12 PM
Evening Alan
This picked up today and another German Tac code.
3EBBDA / c/s GHOST62
keith
Post by: Runway 31 on October 08, 2012, 06:25:46 PM
Thanks again Keith
Post by: X on October 09, 2012, 07:05:32 AM
Three Indaian AF An32's arrived Doha, reg tie up not known as yet plus more use of AZAZ0909!
80033A  AZAZ0909
800338  AZAZ0909
80033C  IFC2912
X
Post by: Runway 31 on October 09, 2012, 07:26:29 AM
Nothing on those X.  They were picked up over Cyprus at the weekend so they will be going back home from Kiev and have probably had their boxes re-coded.
Post by: X on October 09, 2012, 07:39:49 AM
just read off on departure DOH
80033A  AZAZ0909 K2687
80033C  IFC2912    K2682
X
Post by: Runway 31 on October 09, 2012, 07:57:06 AM
Cheers X, awaiting the other one when it goes off
Post by: Northern Watch on October 09, 2012, 01:21:53 PM
Good Afternoon Alan
These picked up today even more German Tac codes being used as part of exercise in North Scotland.
3F7733 / c/s DRAG25
3F6037 / c/s DRAGON16
3FB70C / c/s DRAGO15
keith
Post by: Runway 31 on October 09, 2012, 02:31:31 PM
Thanks Keith, going by the emails from PAMG and Scotavnet there appears to be quite a bit of activity all over.
Post by: Chris11 on October 09, 2012, 03:56:16 PM
Owner Alero Air Partnership
Quote from: Chris11 on September 30, 2012, 07:24:57 PM
Post by: Runway 31 on October 09, 2012, 04:18:27 PM
Cheers Chris
Post by: neroon79 on October 09, 2012, 04:29:34 PM
Evening, the unknowns from Monday:
3C661C (Germany, DLH3NF, decoding error of 3C6618)
3D7B8A (Germany, flight id: DFTAO, D-FTAO P750 Pacific Aerospace 750XL AC:? CN:? Mk1EB: http://www.berlin-aviation-forum.com/t5319-gransee-08092012 )
3FF18D (Germany, flight id: DMMKK, found this source: http://govfr.com/aircraft_Ikarus-C42B-D-MMKK_-1_5902.html )
3FF1AC (Germany, flight id: DMPMO, again)
44C0E3 (Belgium, flight id: AAB625, decoding error of 44C0E7)
44F079 (Belgium MIL, no flight id)
46085D (Finland, flight id: AUA11TU, decoding error of 460859)
473415 (Hungary, no flight id, nothing  more)
47838C (Norway, flight id: SAS1686, decoding error of 478388)
MIL List:
3E646A  GAF163
3F40F7  TA45
3F5048  AXEMAN1
3F63FC  VADER2
3F7E79  TA47
3F81D3  TA12T
3F81D3  TA60
3F823F  SW54
3F91DB  GAF674
3F9750  GAF023
3F9C30  GAF032
3FA99B  GAF120
3FAC6A  BURNER
Ingo
Post by: Chris11 on October 09, 2012, 05:00:54 PM
ZS-TMR   00B386   Beech B300   Tensmar Aviation Services (Pty) Ltd   FL-803
Post by: Runway 31 on October 09, 2012, 05:18:48 PM
Hi Ingo,
Thanks again, nothin on your unknowns
Post by: X on October 09, 2012, 07:05:16 PM
DWC departure most likely a IL76 at 290
* 504DF4  ATG231                                                      2012/10/09 18:05:41
X
Post by: Runway 31 on October 09, 2012, 07:54:54 PM
Hi X
Unknown to me ATG = AeroTransCargo, I think they only have one aircraft IL76T, ER-IAF, c/n 0003423699
Post by: neroon79 on October 10, 2012, 03:02:16 AM
Morning, unknowns from Tuesday:
0D00F0 (Mexico, no flight id, was XA-SHK of Click Mexicana, who has ceased operation in 2010)
3B77E1 (France, no flight id, still no details, received two time yesterday: 15:00UTC and 20:00UTC)
3C5CAA (Germany, no flight id, decodes D-AGEJ, nothing about a new one with this reg/hex)
3C6591 (Germany, with flight ids: DLH2PF, DLH6LX, DLH9HP, DLH9PK / decoding errors of 3C6595 and 3C6491)
3CBC49 (Germany, flight id: DBOBI, no 100% solid details found. May be a Cirrus)
MIL LIst:
3EABF9  BURNER
3F4AB7  TA47
3F4AB7  TA47
3F5E3F  GAF710
3F7006  GAF905
3F7E79  TA67
3F81D3  TA45
3F81D3  TA47
3F823F  SW54
3F823F  SW54
3F8DF9  RAVEN01
3F91DB  GAF674
3F9822  LANCE01
3F9C53  EAGLE
3FA99B  GAF120
3FAAC1  PACK1
3FAC6A  NITRO
End of 1st Batch, rest today evening.
Have a nice Day!
Ingo
Post by: X on October 10, 2012, 05:27:24 AM
The three An32's tied up at DOH
800338  K2668
80033A  K2687
80033C  K2682
X
Post by: Chris11 on October 10, 2012, 05:37:00 AM
A9C160 VP-BOT  Flight IKIL7538
424115 VP-BHA  Flight IKIL7526
4CA50D EI-DTX Flight ID TSO147
were all on the box this morning - no longer WFU?
Chris
You get the ZS-TMR above?
Post by: X on October 10, 2012, 05:48:11 AM
731A23, EP-FQC, F50, Qeshm Air
X
Post by: X on October 10, 2012, 05:54:06 AM
Another Moldovan has appeared
* 504E00                                                              2012/10/10 04:59:18
X
Post by: Runway 31 on October 10, 2012, 07:21:50 AM
Hi Chris, none of them are marked as WFU.  Sorry got ZS-TMR, forgot to advise.
Post by: Runway 31 on October 10, 2012, 07:24:01 AM
Thanks X, nothing on your Moldovan
Post by: X on October 10, 2012, 01:08:48 PM
On delivery via the sandpit
* 7C6B0D  JST7992  YBCG-YMML      VH-VFJ  JetStar        2012/10/10 17:02:15
X
Post by: Runway 31 on October 10, 2012, 01:10:07 PM
Thanks, added Sunday.
Post by: X on October 10, 2012, 01:17:43 PM
* 710249                                                              2012/10/10 16:38:31
Moving slowly at 7100 before descending locally, we think it might be a Diamond
X
Post by: Runway 31 on October 10, 2012, 01:57:51 PM
Nothing on it X but you might be right.
Post by: Northern Watch on October 10, 2012, 07:29:49 PM
Evening Alan
You were right, even more German Tac codes today, this time no c/s.
3F6372
3EAB42
keith
Post by: paul tricker on October 10, 2012, 08:04:52 PM
* 505D61  N956MK                                                      2012/10/10 15:08:33
This would appear to be N956MK PA34-220T  c/n 3433160  Southern Aircraft Consultancy Inc Trustee, still using its hex from its days as OM-UKA
Paul
PS Thanks to all for the operator of D-AFKB a few pages back
Post by: Runway 31 on October 10, 2012, 08:10:15 PM
Thanks Paul
Post by: Kenny on October 11, 2012, 12:16:49 AM
Airport name correction
IATA: DMK  ICAO: VTBD
Don Mueang International Airport   (they just add E in Mueang recently)
http://en.wikipedia.org/wiki/Don_Mueang_International_Airport#Name_change
IATA: KBV  ICAO: VTSG
Krabi Airport
http://en.wikipedia.org/wiki/Krabi_Airport
Post by: neroon79 on October 11, 2012, 02:00:45 AM
Morning, the rest of tuesdays unknowns:
3FF19B (Germany, flight id: DMCBP, received again)
49D2CF (Czech republic, with flight ids: CSA2MZ, CSA544, CSA545, seems to be a new one for Czech Airlines, but no luck with the details.)
4CA309 (Ireland, flight id: RYR3658, decoding error of 4CA301)
That's all from Tuesday.
Post by: neroon79 on October 11, 2012, 03:02:24 AM
Unkowns from Wednesday:
391548 (France, no flight id, was F-GFKI B/U last year)
3C0D4B (Germany, flight id: AIB308A, Airbus Test Reg D-AUBA therfore several A320 airframes will be N512VL A320-233 of Volaris 5308 source: http://xfw-spotter.blogspot.de/2012/10/a320-233-volaris-d-auba-n512vl-msn-5308.html )
3E39AA (Germany, no flight id, nothing more)
49D2CF (Czech Republic, flight ids: CSA544 & CSA545, second day in a row)
4CA287 (Ireland, flight id: ABR2MA, decoding error of 4CA285)
4CA287 (Ireland, flight id: EIN33K, decoding error of 4CA217)
MIL List:
3F4AB7  GAF727
3F4AB7  TA45
3F4AB7  TA67
3F5E3F  GAF710
3F7006  GAF905
3F7CA6  GAF066
3F7CA6  GAF066
3F8A79  SPARK
3F8B00  GAF012
3F9C53  SHARK
That's all from yesterday!
Wish you a nice Day!
Regards Ingo
Post by: X on October 11, 2012, 05:23:22 AM
Return of a June Ugandan unkown, picked up at 9000ft and departed two hours later and lost at 40000!
06805D                                                              2012/10/11 04:39:45
X
Post by: Runway 31 on October 11, 2012, 08:57:28 AM
Kenny,
Airport names amended, thanks
Post by: Runway 31 on October 11, 2012, 09:07:38 AM
Still unknown to me  X
Post by: X on October 11, 2012, 12:13:45 PM
Think this miscode needs to go as VARIOUS as at 1500 ft for 20 minutes this time it was a chopper!
* 800000                           EK26818 AN26  South Airlines (M... 2012/10/11 07:33:29
X
Post by: Runway 31 on October 11, 2012, 12:20:30 PM
Agreed X, done
Post by: Runway 31 on October 11, 2012, 12:26:21 PM
Hi Ingo,
Tuesday
3FF19B still unknown
49D2CF OK-GFQ, Aerospatiale ATR 72-212A,c/n 641, CSA Czech Airlines
Wednesday
3C0D4B D-AUAW now in d/b as VARIOUS
3E39AA decodes to D-INAO unknown to me
Thanks again and have a nice day as well.
Post by: flygfantast on October 11, 2012, 03:31:15 PM
Alan,
51104C ES-PWB, AgustaWestland AW139, c/n 31144, Estonia - Border Guard
Niklas
Post by: Runway 31 on October 11, 2012, 03:34:20 PM
Thanks again Niklas, now if we could only get that other unknown Estonian!
Post by: flygfantast on October 11, 2012, 04:17:09 PM
Quote from: Runway 31 on October 11, 2012, 03:34:20 PM
Yes, see it twice a day mon-fri!
Niklas
Post by: X on October 11, 2012, 05:26:00 PM
Has it been reregistered asN555GL is common and been stored for a while?
* A5129F  N555GL                                                      2012/10/11 21:20:00
X
Post by: Runway 31 on October 11, 2012, 06:01:56 PM
X
A5129F decodes to N426HG and is not assigned by FAA.
N555GL is A7129F so looks like a miscode and is a GLF3 c/n 403
Post by: X on October 11, 2012, 06:29:52 PM
Agreed looks like a miscode rather than rereg
X
Post by: paul tricker on October 11, 2012, 06:33:25 PM
These four all routed thru my area today....
c/n in brackets from the FAA site
* ACDBC0  N9279B   (C172S-11219)                                                   2012/10/11 07:53:22
* ACDE60  N9281C  (C172S-11221)                                                   2012/10/11 07:49:38
* ACDE78  N92812  (C172S-11222)                                                   2012/10/11 08:13:31
* ACDE89  N9282J   (C172S-11223)                                                   2012/10/11 08:06:16
All on the FAA site as owned by Weaver Aero International Inc, deliveries I assume
Paul
Post by: Northern Watch on October 11, 2012, 07:14:14 PM
Evening Alan
No German Tac codes today only this USAF Tac Code believed to be a F15:
AE0743 / c/s GREMLN51.
keith
Post by: Runway 31 on October 12, 2012, 07:50:28 AM
Thanks Keith
Post by: Runway 31 on October 12, 2012, 07:51:09 AM
Yes Paul, all on delivery, wont remain on the FAA register long.
Post by: anorak on October 12, 2012, 10:39:59 AM
43C471 any idea please?
Dave.
Post by: Runway 31 on October 12, 2012, 11:23:24 AM
Dave,
It should be ZR342 EH10, c/n 52047 and is for the Indian Air Force.
Post by: Judwin45 on October 12, 2012, 11:25:18 AM
Hi Alan
I-RAIC, still code 000400 is apparently an AW-189. (A189) We know this is right (this time) because it is written on the nose. also carries the code P4. Others are in Italy and US.
Post by: Runway 31 on October 12, 2012, 11:54:54 AM
Thanks for the update Keith.  According to the ICAO website, no allocation given yet.
Post by: John Hargreaves on October 12, 2012, 12:03:58 PM
One for X,
Global Jet UAE GBG402 using hexcode 896368 out of Iranian airspace. Not plotting very accurately and has landed at either Dubai or Sharjah! The plots disappear marginally closer to the latter.
John H.
Post by: chewycanes on October 12, 2012, 12:29:09 PM
Hi Alan
I got these four all at the same time and i thought there were corruptions but each had the separate callsigns.
ACDE78 callsign N92812 Cessna 185
ACDE60 callsign N9281C Cessna 180
ACDE89 callsign N9282J Piper Pa46
ACDBC0 callsign N9279B Cessna 175
Brian
Post by: Runway 31 on October 12, 2012, 12:30:05 PM
I dont have any details on 896368
Post by: Runway 31 on October 12, 2012, 12:35:39 PM
Hi Brian
All as per earlier reply from Paul Tricker.
All on the FAA site as owned by Weaver Aero International Inc so on delivery somewhere
Post by: John Hargreaves on October 12, 2012, 01:41:22 PM
GBG402 is up again and is out of Sharjah. Looks to be heading towards Fujairah
Post by: John Hargreaves on October 12, 2012, 01:45:08 PM
Spoke too soon! Ras Al-Khaimah now.
John H.
Post by: diddyboy on October 12, 2012, 02:23:06 PM
Hi Alan
Some more Ground Equipment codes from the sandpit for yesterday and today.
* 896EAE  ELC3                                                        2012/10/11 17:06:48
* 896EB0        2012/10/11 08:02:39
* 896EB5  WKS3                                                      2012/10/11 16:37:41
896EAE        2012/10/12 07:21:39
Diddyboy
Post by: X on October 12, 2012, 02:26:48 PM
John/Alan
It initially went to SHJ but we think it may be A6-ESG finally delivered but cannot confirm it. it has been around all week operating GBG402 which is usually a Boeing 737.
PS EI-EYO A332 all white has been reregistered back to A6-EAN!!!!!
S2-ADX DHC8 GMG Airlines has just arrived Dubai...on its way back to Europe/Canada?
X
Post by: EK01 on October 12, 2012, 02:52:44 PM
Alan,
Just had this one come on (you probably had it as well) :
Mode S : 3C406A
FL 210
Flight ID : UUZTJA3               (Very strange!)
Post by: Runway 31 on October 12, 2012, 03:21:06 PM
Hi Ian,
Sorry didnt get it as I was on the phone to a wee lassie in India trying to get my BT email working again, still not working Grrrrrrrrrrrrrr!!!!
Nothing on 3C406A as it doesnt decode to anything
Post by: Runway 31 on October 12, 2012, 03:22:59 PM
Thanks again Neil
Post by: Runway 31 on October 12, 2012, 03:23:33 PM
Thanks for the info X
Post by: X on October 12, 2012, 09:26:46 PM
8880A9 VNA688 VN-A688 Airbus A320-214 VietJet c/n 2712 on approach to sandpit at 0130L
X
Post by: X on October 13, 2012, 07:13:04 AM
A6-EDZ A388 Emirates c/n 107 arrived sandpit 0315L (NB A6-EDX/Y are in as A380 all others are A388)
* 8960FB  UAE7380                                                     2012/10/13 03:15:04
X
Post by: Runway 31 on October 13, 2012, 08:20:07 AM
Thanks X, both now added.  I must have noted the A380 myself and changed them as they are both A388 in the d/b since 1/10.
BTW, My email is now back on line thank goodness
Many thanks
Post by: X on October 13, 2012, 08:32:28 AM
Departed for Europe this am
* 702027  GMG061                   S2-ADX  DH8C  GMG Airlines         2012/10/13 09:16:17  (0516UTC)
X
Post by: X on October 13, 2012, 10:00:32 AM
This unknown, picked up three times this year, always appears at same time as 4B0E91 which is DU-333 PC6 of SkyDubai miscoding old hex. Would assume we have an intermittent double coder!
  4B0E97                                                              2012/10/13 13:32:12
X
Post by: Runway 31 on October 13, 2012, 11:05:33 AM
It must be double coding X as 4b0E97 decodes to HB-FNR and that PC-6 is now JU1911.
The DH8C must be going back to Canada at the end of its lease, wonder if it will drop into Prestwick.  Its in the d/b anyway so Airnav will know what it is when they pick it up.
Post by: X on October 13, 2012, 11:27:28 AM
Aah yes,  I remember when you replied earlier saying 4B0E97 was HB-FNR now JU1911, as I stated I doubted a Mongolian would be in the sandpit area. Must be double coding as it is seen when 4B0E91 DU-333 is up in the air.
X
Post by: X on October 13, 2012, 05:26:13 PM
This Brunei took off from somewhere about 20 minutes ago, probably SHJ/RAK/FJR not DXB
* 89501B                                                              2012/10/13 21:03:42
X
Post by: Runway 31 on October 13, 2012, 07:01:53 PM
nothing on it X
Post by: Kenny on October 14, 2012, 05:25:46 AM
Airline addition
MEGA Maldives
IATA: 5M  ICAO: MEG
Fleet of 3 and fly to 7 destinations between VRMG,VR!M and China
http://en.wikipedia.org/wiki/Mega_Maldives
http://megamaldivesair.com
Post by: Runway 31 on October 14, 2012, 09:27:58 AM
Hi Kenny,
I have been doing some work on the airlines table adding, deleting and amending entries and Mega is one of the ones included.
Next Navdata will contain these changes.
Their aircraft are already in the d/b
Many thanks
Post by: Chris11 on October 14, 2012, 01:57:04 PM
00B1E6 ZS-SWR - Owner = Paxton Group CC
Post by: Runway 31 on October 14, 2012, 01:58:48 PM
Thanks Chris,
Post by: diddyboy on October 14, 2012, 02:30:49 PM
Hi Alan
A few more Ground Transmitter codes from the sandpit.
* 896E86  SIG3                                                        2012/10/14 11:07:17
* 896E9A  COM2                                                      2012/10/14 10:12:15
   896EBD  SIG6                                                        2012/10/14 08:22:37
Neil
Post by: Runway 31 on October 14, 2012, 02:41:07 PM
Cheers Neil, thanks.
Post by: BBJUK on October 14, 2012, 05:37:26 PM
Hi Alan
An update on B757-236 c/n 22176 which lives down this part of the world
Double coding for the last few days as both AA35A9 and the old A235AB
Brgrds Darryl
Post by: Runway 31 on October 14, 2012, 06:08:07 PM
Thanks Darryl.  Its allocated AA35AB and AA35A9 belongs  to a C82R
Post by: GreekSpy2001 on October 15, 2012, 12:26:47 PM
Another new German mil code
3F5ECF  GAF027                                                      2012/10/15 13:22:57
Graham
Post by: Runway 31 on October 15, 2012, 12:31:52 PM
Thanks Graham
Post by: GreekSpy2001 on October 15, 2012, 01:17:50 PM
I know that they are tactical codes but from the sound it made it was a C160 Transall
Graham
Post by: Runway 31 on October 15, 2012, 01:51:19 PM
Thanks Graham, you never know what will use it the next time as it is only relevent to the flight flown
Post by: X on October 15, 2012, 04:55:33 PM
No longer WFU possible Haj flight
* 885184  THA8809                  HS-TLD  A345  WFU Stored (ex Th... 2012/10/15 18:01:52
X
Post by: Runway 31 on October 15, 2012, 05:17:46 PM
Cheers X
Post by: flygfantast on October 15, 2012, 06:48:47 PM
Some estonian miscoding:
28889E using callsign ESFSR
Seen twice today at FL120 -> FL180 and around 1200 msgs
Niklas
Post by: Runway 31 on October 15, 2012, 07:03:27 PM
Nothing on ES-FSR Niklas
Post by: X on October 16, 2012, 04:55:01 AM
Operating the Kabul flight for Ariana so not WFU
700002  AFG402   OMDB-OAKB       YA-PIC  B734  WFU Stored (ex Pa... 2012/10/16 02:37:14
X
Post by: Runway 31 on October 16, 2012, 07:22:36 AM
X,
The WFU was deleted 30/9.
Post by: X on October 16, 2012, 02:52:09 PM
This was N522CM a locally based Kodiak but has reappeared today as unknown
A6909A                                                              2012/10/16 18:46:36
X
Post by: Runway 31 on October 16, 2012, 03:14:34 PM
Hi X
N522CM cancelled from the FAA list as certificate expired 12/09/12.  Dont know what it is now
Post by: 54901 - Jim on October 16, 2012, 03:14:57 PM
One add for you today, Alan ...
AB2A66 / N8187E / DC3 / Douglas DC3C / Basler Turbo Conversions LLC / 25285
Thanks!
Post by: Runway 31 on October 16, 2012, 04:11:54 PM
Thanks Jim, looks like it is now a Basler BT-67 Turbo 67 following conversion as it is showing as a turboprop on FAA.
Post by: 54901 - Jim on October 16, 2012, 04:18:41 PM
Got it ... thanks, Alan!
Post by: Kenny on October 16, 2012, 04:25:13 PM
Quote from: X on October 15, 2012, 04:55:33 PM
X
TLD is now mostly use for Prime Minister foreign trip.
Post by: Runway 31 on October 16, 2012, 04:29:51 PM
Nice work if you can get it!!
Post by: flygfantast on October 16, 2012, 05:20:49 PM
SE-IIB is miscoding using 4AA622 on one of it's boxes.
It's been using both 4AA522 (972 msgs received) and 4AA622 (416 msgs received) today.
SE-IIB, Beech C90 King Air, c/n LJ-723, CW Lundberg Industri AB
Niklas
Post by: Runway 31 on October 16, 2012, 05:39:15 PM
Thanks Niklas
Post by: X on October 16, 2012, 08:31:20 PM
896303 A6-ENA B773 Emirates due sandpit tomorrow
X
Post by: Runway 31 on October 17, 2012, 07:50:47 AM
Yes X noted on Pugetsound blog.  Its been is the d/b since first flight 15/9
Post by: flygfantast on October 17, 2012, 05:54:19 PM
478F5C using c/s SAS909 and using ADS-B. New one for SAS?
Niklas
Post by: Runway 31 on October 17, 2012, 06:08:37 PM
Have not got anything on that one Niklas
Post by: John Hargreaves on October 17, 2012, 06:46:32 PM
 X
896368 is a B733 using A6-ESR. Its just arrived at Riyadh as ESJ052 from Antalya where its been since Sunday. Any of you guys out there able to say whether its in full Eastern Skyjets colours?
John H.
Post by: flygfantast on October 17, 2012, 07:05:55 PM
Quote from: Runway 31 on October 17, 2012, 06:08:37 PM
Alan,
It's LN-RKM an Airbus A330-330X, c/n 496, re-regd yesterday! It's ex OY-KBN.
See http://www.planespotters.net/Production_List/search.php?manufacturer=Airbus&subtype=A330-300&fleet=4252&fleetStatus=1
Niklas
Post by: Runway 31 on October 17, 2012, 07:23:07 PM
Thanks Niklas, well spotted.
Post by: X on October 18, 2012, 07:01:34 AM
This one has got me going as ELITE is normally a K35R/B703 call sign in this part of the world and all but one operational machine 63-7976 are known . Could of course be a miscode.
* AE0CE8  ELITE50                                                     2012/10/18 08:28:57
X
Post by: X on October 18, 2012, 07:05:22 AM
Quote from: John Hargreaves on October 17, 2012, 06:46:32 PM
X
John H.
Thanks for that, I will check with others but so far I have only seen it as a set of Boeing Osrams. We all missed it at SHJ last Friday.
   896368                                                              2012/10/18 00:58:49
   896368                                                              2012/10/14 20:01:37
   896368                                                              2012/10/12 15:50:19
X
Post by: Runway 31 on October 18, 2012, 08:00:03 AM
I cant find anything on AE0CE8 X
Post by: Runway 31 on October 18, 2012, 08:33:57 AM
Cheers X, fingers crossed.
Post by: X on October 18, 2012, 10:32:30 AM
AE0CE8 was first reported departing Qatar this am but NOT arriving and has since returned...so a miscode is most likely. We will try to find out which it is but I believe it is most likely 60-0356 which is AE04E8 and is in the area but now miscoding.
X
Post by: X on October 18, 2012, 12:09:08 PM
This C2A has just droned over to BAH had a dark with yellow tail followed immediately by another using 000001 also as RG01! I trust it confuses our neighbours as much as us.
* 000005  RG01        2012/10/18 15:57:16
   000001  RG01                     VARIOUS N/A   Broken or Miscode... 2012/10/18 16:04:48
X
Post by: Runway 31 on October 18, 2012, 12:28:54 PM
They like to try and hide who they really are
Post by: X on October 18, 2012, 02:31:11 PM
Noted HZ-A9 H125 that came into today had no operator, I believe it is Al Ajwa Aviation
X
Post by: Runway 31 on October 18, 2012, 02:38:09 PM
Thanks X, Alpha Stars Aviation Service
Post by: X on October 18, 2012, 03:02:20 PM
I note that some are Al Ajwa Aviation / Alpha Stars in db and some just Al Ajwa Aviation. Was not far off.
X
Post by: Runway 31 on October 18, 2012, 03:11:17 PM
It will probably be amended if and when further info becomes available
Post by: X on October 18, 2012, 03:48:10 PM
This new Tajik hex should decode to EY-619 but type not known as yet (Il-76??) departing either RKT/FJR? climbing between 8000 and 16000.
* 51526B                                                              2012/10/18 19:06:58
X
Post by: Runway 31 on October 18, 2012, 03:55:18 PM
Hve nothing on it X
Post by: paul tricker on October 19, 2012, 07:26:31 AM
two non-populators yesterday....
3CC008  DCAAI                                                       2012/10/18 15:41:14
according to the net this is a Do328-120 c/n 3040 see
http://www.flickr.com/photos/leeweston/8100180248/
4844B1                                                              2012/10/18 12:01:29
This showed as Aruba P4_SNS, but I cannot find a current P4-SNS
Paul
Post by: GreekSpy2001 on October 19, 2012, 08:39:47 AM
New LAN  Airbus on delivery.  just to cross SE England
E80204  LAN9901                                                     2012/10/19 09:34:04
PP has it as CC-BFD
Graham
Post by: superspotter on October 19, 2012, 08:56:05 AM
Hi Guys;
Back down in Lagos for a 15 day stint :( I'm sure I have mentioned this one before but I will do so again just in case...
Hexcode 113A15 is a Hawker 900XP and the reg is confirmed as N638MA, the ATC here very kindly requires all aircraft to state persons on board and their reg upon landing. My Db does have this aircraft as due to take up a 5N- reg at some point. regards clive.
Post by: Runway 31 on October 19, 2012, 09:19:36 AM
Graham,
E80204 CC-BFD,Airbus A320-214, c/n 5324, LAN Airlines
Also on delivery A72C78, N561AW, Airbus A321-231, c/n 5317, US Airways but its already in the d/b
Post by: Runway 31 on October 19, 2012, 09:23:06 AM
Hi Paul,
Skyliner shows D-CAAI went into Bournemouth and is heading for Sierra Nevada Corp in the US.
4844B1 P4-BFL,  Gulfstream Aerospace GIV-X (G450) c/n 4066
Post by: Runway 31 on October 19, 2012, 09:26:26 AM
Thanks Clive,
My d/b gives the same info, wonder if its the same one.  Looking forwards to some further Nigerian miscodes!!
Post by: BBJUK on October 19, 2012, 12:47:54 PM
Hi Alan
A couple of visitors into Abu Dhabi Bateen today:
A7-HYA C172S 172S-10321 still using hex A5575E
A7-KAL Cessna LC41-550FG now finally using Qatar hex 06A18E, instead of A31C79
Cheers Darryl
Post by: X on October 19, 2012, 01:24:14 PM
This has to be IL76 5A-DKS or 5A-DNO, a trip to FJR to identify which has left will need to be undertaken! Both have been there since 018064 landed back in May.
  018064                                                              2012/10/19 06:16:25
X
Post by: John Hargreaves on October 19, 2012, 01:29:08 PM
Darryl,
Is the King of Swaziland's MD87 currently in Al Matar?  If so, would be appreciated if you could advise if its still wearing 3DC-SWZ.
Thanks,
John H.
Post by: Runway 31 on October 19, 2012, 01:54:39 PM
Thanks Darryl
Post by: Runway 31 on October 19, 2012, 01:56:00 PM
Look forward to an update X
Post by: superspotter on October 19, 2012, 04:16:12 PM
Another one from Lagos. Hexcode 0640D7 is 5N-LAG Bell 412 operated by Caverton Helicopters, just flew past my hotel window, regards clive.
Post by: superspotter on October 19, 2012, 04:27:34 PM
Another hex not coming up with a reg in airnav is: Hexcode 064109 = 5N-MPB Be350 operated by Mobil Oil Nigeria, regards clive.
Post by: Runway 31 on October 19, 2012, 04:37:40 PM
Thanks for those Clive
Post by: superspotter on October 19, 2012, 05:02:37 PM
Another from Lagos, well, almost!
Hexcode 0640CE belongs to either 5N-BMQ or 5N-RKY Allied Air Cargo 727F's. I can rule out JNR as that is in full DHL colours. This hexcode has been bugging me all this year, trying to tie it down to the particular aircraft so for the next two weeks whilst I am down here, I will make a note of each 727 on the ground whilst I am on the apron then try to tie this down to the correct frame. regards clive.
Post by: Runway 31 on October 19, 2012, 05:31:13 PM
Clive,
0640D2 = 5N-BMQ so a confimation that its 5N-RKY would be nice.
Post by: superspotter on October 19, 2012, 05:49:38 PM
It has to be RKY then because they only have the three now after BJN went off the runway in Accra and JNR is in full DHL colours, rgds clive.
Post by: superspotter on October 19, 2012, 05:51:16 PM
Question. As I have access to the flightdecks of the Allied Air Cago 727's, is there any physical way of checking the hexcode?
regards clive.
Post by: Runway 31 on October 19, 2012, 06:08:14 PM
I havent a clue on that one but I wouldnt think so
Post by: X on October 19, 2012, 06:40:04 PM
5A-DKS Il76 still present FJR late this morning so 5A-DNO is the IL76 that departed FJR early morning today as 018064 (having arrived in May). Both were seen last week.
X
Post by: Runway 31 on October 19, 2012, 06:44:44 PM
Cheers X, many thanks
Post by: superspotter on October 19, 2012, 07:52:20 PM
Hmm. When I am on the DHL 767 tomorrow, I will ask the captain if he knows if it is possible, regards clive.
Post by: ACW367 on October 19, 2012, 08:47:31 PM
Quote from: superspotter on October 19, 2012, 05:51:16 PM
regards clive.
On some transponders it is hard wired pins on the back of the transponder that can only be accessed by pulling the transponder from its mounting
Page 85 http://www.neboservice.ru/docs/0216544001186664708.pdf
The aircraft Mode S address is a 24-bit binary code set at the
time of installation. The code is implemented in the aircraft
by strapping certain pins on the transponder interconnect.
Any MST 67A transponder installed in the aircraft after these
pins are strapped will adopt this address. This 24-bit address
is included in all Mode S transmissions as well as all
TCASII Mode S transmissions.
For others it can be reviewed on the transponder screen with power on and looking at certain MX pages on the transponder.
Look at page 11 onwards of this transponder manual
http://www.funkwerk-avionics.com/cms/upload/Downloads/Transponder/TRT600-200-12e-150_Install.pdf
Conclusion
It is unlikely you will be able to get the code by nosing around the cockpits without a qualified MX engineer
Post by: superspotter on October 20, 2012, 03:42:37 PM
OK, thanks for that. I had a chat with a DHL MX today and he iterated the same. However, I went onboard 5N-BMQ today and had a chat with one of their head MX guys and he disappeared and returned with a folder and inside showed the hexcodes for the aircraft. So I can confirm that 0640CE is 5N-RKY. rgds clive.
Post by: superspotter on October 20, 2012, 03:43:51 PM
Another update from Lagos. Hexcode 39CDCF is F-HTOB Regourd Aviation EMB135 ex Luxair. regards clive.
Post by: Runway 31 on October 20, 2012, 04:02:49 PM
Many thanks Clive, your effort is appreciated.
Post by: X on October 21, 2012, 05:22:07 AM
Alan/John
Something is fishy here. A6-ESG B733 was reported delivered at around the same time 896368 appeared, John stated last week on forum it was reported as being A6-ESR B733 in Turkey before going to OERK. Change of reg or wrong sighting perhaps?
A6-ESG  Boeing 737-33A  Eastern SkyJets 27-09-2012  Leased from AWAS was ferried SOF-RKT 03 / 04-10-2012 on delivery. Seen BOH as G-STRJ in full Eastern Skyjet c/s
X
Post by: Runway 31 on October 21, 2012, 10:33:00 AM
I will let John work out that one.
Post by: X on October 21, 2012, 10:48:50 AM
* 800743  VTRSP  VT-RSP  CL30  Bombardier CL-300  20356  reg 24.09.12 Manipal Health Systems PVT Ltd . Departed sandpit 2012/10/21 14:07:18
X
Post by: X on October 21, 2012, 10:52:51 AM
* 780956  CBJ131                                         2012/10/21 12:34:00
* AE4A7E  RCH1020                                      2012/10/21 11:11:44  9mins at 10000 possibly a C12?
X
Post by: Runway 31 on October 21, 2012, 11:04:51 AM
Hi X
780956 B-8258, Gulfstream Aerospace GV-SP (G550), c/n 5360
Nothing on your Reach
Many thanks
Post by: superspotter on October 21, 2012, 12:59:09 PM
Hello again from Lagos. One hexcode that has been appearing here all year is 3DD518 which according to my Db is a MBB-BO-105 D-HAYI. I have yet to see this , the hexcode appears quite regularly but no sign of the helicopter. My crew bus driver did tell me that there was a company that has a helicopter based at their premises some miles further up the road from the hotel so it may be this. regards clive.
Post by: Runway 31 on October 21, 2012, 01:52:17 PM
Hi Clive,
3DD518 D-HAYI, MBB BO 105 CBS-4, c/n S-368.  My d/b shows it is based at Lagos Murtala Muhammed.
Post by: superspotter on October 21, 2012, 02:00:14 PM
OK, but the reg does not yet appear in Airnav. I assume you will now enter it? regards clive.
Post by: X on October 21, 2012, 02:42:09 PM
Do not know what is going on with the ex Emirates A332 A6-EAN but it is now back to EI-EYO yet again
X
Post by: Runway 31 on October 21, 2012, 03:06:43 PM
Yes Clivem it is done when you forward it to me.  Should update next time you pick it up if you click on it and are connected to the net.
Post by: Runway 31 on October 21, 2012, 03:08:18 PM
Must be due to go shortly X, its owned by BBAM-Fly leasing
Post by: X on October 21, 2012, 04:38:06 PM
I am told my unknown Reach might be a MV22 Osprey, might explain the constant 10000ft as C12 are usually higher and do not usually use Reach.
X
Post by: Runway 31 on October 21, 2012, 04:49:47 PM
I dont think we will ever find out!!
Post by: X on October 22, 2012, 05:44:43 AM
Quote from: X on October 21, 2012, 10:52:51 AM
* 780956  CBJ131   B-8258, Gulfstream Aerospace GV-SP (G550), c/n 5360       2012/10/21 12:34:00
This Chinese refuses to populate
PS VP-CJM GLF5 c/n 5181 seen sandpit yesterday not in db (maybe added after 30/9)
X
Post by: X on October 22, 2012, 06:01:18 AM
A6-EKZ A332 all white (ex Emirates) may have flown the coup 17/10/12 as UAE999 . Not been in service since 8/9/12.
X
Post by: Runway 31 on October 22, 2012, 09:18:31 AM
X
B-8258 should be OK now, my fault again.
VP-CJM now in d/b hex 424186
Post by: Kenny on October 22, 2012, 02:00:03 PM
Got this unpopulated
885CA8   with several callsign:  HSWEH, HSXXX, N588GV
Post by: Runway 31 on October 22, 2012, 02:30:09 PM
Hi Kenny,
Its a Gulfstream Aerospace GV c/n 588 ex N588GA and I will go with HS-WEH at this time as my d/b doesnt shows its new registration
Post by: superspotter on October 22, 2012, 07:04:45 PM
A further update from Lagos. Hexcode 064138 is 5N-BPR Aerocontractors B734 c/n 29202. c/n 29201 is to follow into service shortly. regards clive.
Post by: Runway 31 on October 22, 2012, 07:12:35 PM
Great Clive, thanks again
Post by: superspotter on October 23, 2012, 07:10:01 AM
Morning from Lagos, I couldnt sleep! Hexcode 064119 is 5N-BOJ Caverton Helicopters Augusta AW139, regards clive.
Post by: superspotter on October 23, 2012, 09:20:09 AM
....and another Caverton Helicopters Augusta AW139, Hexcode 06411B is 5N-BOX, regards clive.
Post by: Runway 31 on October 23, 2012, 11:23:35 AM
Thanks for those Clive,
I had 064119 as 5N-BOI and 06411A as 5N-BOJ but will change them round now.
Thanks again
Post by: flygfantast on October 23, 2012, 03:37:45 PM
Unknown from today:
43E95A using c/s DA50EX at FL410
According to mode-s group this is M-VGIN, Dassault Falcon 50EX, c/n 320, Charter Air
Niklas
Post by: Runway 31 on October 23, 2012, 03:51:05 PM
Thanks Niklas, to be operated for Richard Branson prior delivery of a GLF5
Post by: superspotter on October 23, 2012, 04:39:09 PM
Another from Lagos. Hexcode 064068 is 5N-FLY Be350 Julius Berger Nigeria PLC, regards clive.
Post by: Runway 31 on October 23, 2012, 04:47:00 PM
Thanks again Clive.
Post by: superspotter on October 23, 2012, 05:02:29 PM
...and it's sister ship 5N-FLS Be350 Julius Berger Nigeria PLC is Hexcode 064076, this one just arrived as the other departed Lagos, regards clive.
Post by: Runway 31 on October 23, 2012, 05:34:06 PM
Thanks again Clive.
Post by: X on October 23, 2012, 06:07:19 PM
On approach at this moment not populating is 4241D9 but would appear to be VP-CBR Challenger
X
Post by: X on October 24, 2012, 12:41:39 AM
Quote from: X on October 03, 2012, 04:36:01 PM
X
Reappeared and did not populate
   4BCB41  TCRZA                                                       2012/10/24 03:58:45
X
Post by: Runway 31 on October 24, 2012, 06:52:27 AM
Hi X
Must have missed TC-RZA on 3rd but in d/b now.
Regarding 4241D9, unless they have re-issued the hex/registration combine VP-CBR became A6-MBH which is a CL604.  Can you advise further please.
Post by: X on October 24, 2012, 07:15:39 AM
It was read off taxiing at DXB after landing...will look into whether A6-MBH has been reregistered back to its old reg or if this is a different frame. A6-MBH last picked up by me 15/6/12.
A6-MBH is no longer on MIDRMA site updated 8/10/12 (though that can mean little)
X
Post by: Runway 31 on October 24, 2012, 07:32:11 AM
My d/b has it as stored so may have been sold and reverted to old hex reg combination, confirmation one way or the other would be nice.
Post by: superspotter on October 24, 2012, 08:50:42 AM
Morning from Lagos;
Not a hexcode update but 0640D3 5N-DOX Do328, the Db has this as WFU. It has just arrived in Lagos using callsign Dana 487 so I would assume no longer WFU, regards clive.
Post by: Runway 31 on October 24, 2012, 09:41:31 AM
Thanks Clive, amended
Post by: X on October 24, 2012, 01:05:14 PM
My colleague who sighted VP-CBR is pretty convinced it is ex A6-MBH, would explain it disappearing of MIDRMA.
X
Post by: Runway 31 on October 24, 2012, 01:28:09 PM
Cheers X will update
Post by: Xon on October 24, 2012, 07:29:22 PM
Quote from: flygfantast on October 23, 2012, 03:37:45 PM
Unknown from today:
Comfirmed, just departed from EPWA.
Post by: Runway 31 on October 25, 2012, 08:38:24 AM
Cheers Xon
Post by: 54901 - Jim on October 25, 2012, 12:56:19 PM
One update for you, Alan ...
C05200 / C-GFBJ / C152 / Cessna 152 / Avionnerie Amos ltée / 15284179
Thanks!
Post by: Runway 31 on October 25, 2012, 01:23:40 PM
Thanks again Jim
Post by: Kenny on October 25, 2012, 02:28:50 PM
Unknown of today
881E81  no callsign but fly almost every other day
Post by: Runway 31 on October 25, 2012, 02:49:31 PM
Hi Kenny,
881E81 HS-GTA, Boeing  747-4Y0, c/n 24688/1876, City Airways.
Thanks again
Post by: paul tricker on October 25, 2012, 07:19:37 PM
Today's non-populator...
* A57823  N451ZS                                                      2012/10/25 10:57:08
Makes this N451ZS   Dc3C  c/n 4363  Southern Aircraft Consultancy Inc Trustee
Paul
Post by: Runway 31 on October 25, 2012, 08:09:50 PM
Cheers Paul, d/b shows it as WFU but it must be back in the air.
Post by: Kenny on October 26, 2012, 12:33:08 AM
Quote from: Runway 31 on October 25, 2012, 02:49:31 PM
Hi Kenny,
Thanks again
I must confess that I never heard of this airline.  BTW I think it is 737-4Y0 with a long owner history (http://www.planespotters.net/Production_List/Boeing/737/24688,HS-GTA-City-Airways-%28Thailand%29.php)
Post by: typist on October 26, 2012, 10:55:29 AM
VMMC (MACAO Airport) is listed as Macao, Portugal....should be China (since 1999, actually :)
Post by: Runway 31 on October 26, 2012, 11:06:46 AM
I have changed it typist but it wont make the Navdata due out today.  Will be in next one.
Post by: X on October 26, 2012, 01:28:52 PM
Is there a hex for VP-CFL F9EX c/n 177 as I have seen a report for this being at DXB and all I have is 400047 VP-CDA landing and I think that was what was seen yesterday.
X
Post by: Runway 31 on October 26, 2012, 02:07:03 PM
X
VP-CFL F900 became VP-CDA in Septmeber 2010 hex used is 400047
Post by: X on October 26, 2012, 03:37:21 PM
Thanks it was as I thought the guy must have an out of date database
Gavin
Post by: flygfantast on October 26, 2012, 06:35:17 PM
Another Estonian not populating:
5110A1 c/s ESPJB then switching to AIA2053. Probably a new aircraft to be used in Sweden by Avies.
Niklas
Post by: Runway 31 on October 26, 2012, 06:43:00 PM
Nothing on the registration or hex Niklas
Post by: flygfantast on October 27, 2012, 07:21:45 AM
Quote from: Runway 31 on October 26, 2012, 06:43:00 PM
ES-PJB is a British Aerospace Jetstream 31, flying for Avies on routes inside Sweden and to Tallin, Estonian
Niklas
Post by: X on October 27, 2012, 07:34:10 AM
This Azerbaijan looked like a 757/321
* 60080C  AHY011                                                      2012/10/27 11:23:31
X
Post by: John Hargreaves on October 27, 2012, 07:37:40 AM
X,
We need a visual on this one if possible. Believed to be 4K-AZ12 a B752, possibly ex VP-BBS.
Thanks,
John H.
Post by: Runway 31 on October 27, 2012, 08:28:21 AM
Hi X
Its been driving John and Myself nuts for a couple of weeks.
My d/b now gives it as: 60080C, 4K-AZ12, Boeing 757-22L c/n 29305/894, Azerbaijan Airlines ex VP-BBR.
VP-BBS is to become 4K-AZ13.  I belive this will confirm the hunch you had John
Post by: John Hargreaves on October 27, 2012, 09:28:15 AM
Alan,
VP-BBR has been parked up at IST since circa 16 Sept according to a reliable source . Thats why VP-BBS is now in the equation :-)
John H.
Post by: Runway 31 on October 27, 2012, 09:37:16 AM
Eyeball time John, then we shall know.
Post by: flygfantast on October 27, 2012, 09:44:20 AM
I have now got confirmation that ES-PJB is ex G-LOVB.
So 5110A1 ES-PJB, British Aerospace Jetstream 3102, c/n 622, Avies
Niklas
Post by: Runway 31 on October 27, 2012, 10:23:00 AM
Thanks Niklas, Forgot that I deleted G-LOVB on Wednesday or Thursday as exported to Estonia
Post by: X on October 27, 2012, 11:47:09 AM
Alan/John
It was read off as 4K-AZ12 on landing
X
Post by: Kenny on October 27, 2012, 12:49:50 PM
The unknown for today
704945  of Myanmar using callsign  XYAGO
First time ever on my radar
And I got several of this  3E47B2 using callsign DISIS hopping between 100-9100ft.
Post by: Runway 31 on October 27, 2012, 12:52:30 PM
Brill X, 60080C, 4K-AZ12, just need to confirm the frame now
Post by: Runway 31 on October 27, 2012, 01:03:33 PM
Hi Kenny,
They have only had it for a little over a week
704945, XY-AGO, Airbus A320-214, c/n 973, Myanmar International Airways
3E47B2 decodes to D-ISIS but is actually HS-SAB, Dornier 228-200, c/n 8007, Solar Aviation Company still miscoding its old ID
Post by: John Hargreaves on October 27, 2012, 01:45:03 PM
X,
Many thanks for the Azerbaijani. Assume it was a B752?
John H.
Post by: X on October 27, 2012, 01:50:21 PM
Yes It was a B752, I saw it at 9nm but my colleague was at the airport and saw it land
X
Post by: X on October 27, 2012, 01:57:16 PM
This was a USN C2A today so would suggest another Various!
* 000003  RG01                     149903  EH10  Canada - Armed Fo... 2012/10/27 11:05:59
Plus a new UK/Bermuda machine in the area
* 42491A                                                              2012/10/27 17:03:36
X
Post by: Runway 31 on October 27, 2012, 03:47:40 PM
Hi X,
42491A decodes to VQ-BZB which became TC-CLH CL605 unless it has been re-allocated
Post by: Chris11 on October 27, 2012, 07:18:51 PM
00B545 HAWK   Hawk Mk-120 Lead In Fighter Trainer (LIFT)   South African Air Force Tail no 270
Post by: Chris11 on October 27, 2012, 07:21:07 PM
00B273 ZS-TCC - Owner L & P Partnership
Post by: Runway 31 on October 28, 2012, 10:20:29 AM
Many thanks Chris.
Hawk c/n SA21
Post by: superspotter on October 28, 2012, 01:06:14 PM
Hello again from Lagos;
Two bits of info: Hexcode 064121 is 5N-BOQ Ce560 operated by Bristows Nigeria. and D-CIRJ Do328 with hexcode 3CD6E3, the Airnav Db has this as WFU however it has just arrived with callsign BML 328 and my Db has this as Abuja based and operated by Prime Air Services. regards clive.
Post by: X on October 28, 2012, 01:06:37 PM
Quote from: Runway 31 on October 27, 2012, 03:47:40 PM
Hi X,
Hi Alan
On checking what landed at that time with someone on the ground I believe 42491A was actually 42493A VQ-BDP Nordstar B738 which I have heights either side of the time I saw it, so probably a crossed code as nothing else landed that fitted the bill and no one else picked up 42491A.
X
Post by: Chris11 on October 28, 2012, 01:19:41 PM
Do you have the cn of the other Hawks?
Quote from: Runway 31 on October 28, 2012, 10:20:29 AM
Many thanks Chris.
Hawk c/n SA21
Post by: Runway 31 on October 28, 2012, 01:20:30 PM
Thanks again Clive,  looks like we are both using the same d/b.  D-CIRJ was previously WFU stored ex Cirrus but is now operated as you state.
Post by: Runway 31 on October 28, 2012, 01:21:24 PM
OK X
Post by: Runway 31 on October 28, 2012, 01:25:58 PM
Chris,
Looks like the are in sequence order from 250 SA01 upwards, 251 SA02 etc
Post by: superspotter on October 28, 2012, 01:35:13 PM
Another from Lagos: Hexcode 064000 is 5N-MPB Be350 Mobil Oil Nigeria, regards clive.
Post by: Runway 31 on October 28, 2012, 02:30:00 PM
Thanks again Clive.
Post by: superspotter on October 28, 2012, 02:51:58 PM
A miscode going on here with Ethiopian Airlines and Asky airlines, not for the first time I have noticed. Just had hexcode 04002B appear as ET-ANI which is a DHC-8 but landing was a 737. I suspect it is ET-ANH as the other two, ANG and AOK regularly appear. regards clive.
Post by: Runway 31 on October 28, 2012, 03:21:49 PM
Hi Clive,
04002B is def ET-ANI DH8D
I have just checked the d/b and dont have a hex of ET-ANH, checked GAS, Airframes AvDb and they dont have its hex either.  Going by the registration sequence I would have expected ET-ANH to be 04002A but nothing on that hex
I am certain that I have seen something previously on the mode-s forum but the search facility is crap and dont get anything.  Will keep trying but may need to mark the hex as being used by various aircraft.
Post by: superspotter on October 28, 2012, 03:30:13 PM
OK. I have noticed this in the past with Ethiopian/Asky but didnt note which aircraft it was at the time. But I flagged this one up to watch a couple of days ago because I need ANI so when it appeared today I made sure I saw it on approach and it was definitely a 737 in full Asky colours. ANG appeared a few minutes later enroute ACC-ADD and I have seen AOK a few days ago. regards clive.
Post by: Runway 31 on October 28, 2012, 05:50:20 PM
Will mark as being used by more than one aircraft
Thanks Clive
Post by: Xon on October 28, 2012, 06:33:50 PM
4D2076 9H-SRT GLEX c/n 9274 Hyperion Aviation Ltd
Post by: X on October 28, 2012, 06:59:07 PM
At 16000 moving slowly like a C2 but modes S does not fit the batch...another V22 would make it three this week!
* AE498D  00000000                                                    2012/10/28 22:45:44
X
Post by: Runway 31 on October 28, 2012, 07:02:27 PM
Thanks Xon ex G-EXRS
Post by: Runway 31 on October 28, 2012, 07:05:39 PM
X
AE498D   08-0039, Boeing CV-22B Osprey, c/n D1020, US - Air Force
Post by: X on October 28, 2012, 08:07:40 PM
Seems we have a lot of V22's arriving...time for the tin hat! PS one is yet another 000005
* AE498B  00000000                 08-0037 V22   US - Air Force       2012/10/28 22:05:48
* AE498D  00000000                 08-0039 V22   US - Air Force       2012/10/28 22:45:44
    000005  00000000        2012/10/28 22:30:31
X
Post by: Runway 31 on October 28, 2012, 08:21:19 PM
You think they know something we dont!!
Post by: X on October 28, 2012, 08:26:58 PM
Last election pitch!!!
X
Post by: Runway 31 on October 28, 2012, 08:57:12 PM
Dont know if the Americans can stomach another prolonged campaign but if they just fire a few missiles, well!!
Post by: diddyboy on October 29, 2012, 06:44:30 AM
Hi All
An unknown Congolese (possible ATR) overflew the house in France at 18000ft yesterday evening
0360DA
Other Unknowns for yesterday
342394
3B9BAA FNY50F3
Diddyboy
Post by: John Hargreaves on October 29, 2012, 08:30:28 AM
 X,
The help of yourself and the guys in the sandpit is needed yet again with regard to 4K-AZ12. Its inbound DXB again as AHY011. Verification required that its in full colours and if its named ' Nakchivan'. Thats the name allocated to VP-BBS. It went into CDG yesterday and we were unable to positively identify it.
Thanks,
John H.
Post by: Runway 31 on October 29, 2012, 08:48:05 AM
Hi Neil,
Cant find anything on 0360DA, nothing on Skyliner regarding Congolose movement
342394 decodes to EC-JPL A320 which is now EC-LAA with Vueling some presumably using its old hex
3B9BAA FNY50F3  87, Embraer EMB 121A Xingu, c/n 121-087, France - Navy
Post by: John Hargreaves on October 29, 2012, 09:25:44 AM
 X,
Photographic evidence of 4K-AZ12 now exists! Taken at CDG yesterday, but the name under the cockpit window cannot be read off..
John H.
Post by: Judwin45 on October 29, 2012, 09:50:08 AM
Morning Alan
Just showing on my flights 400EF5, FL50, no other details.
Post by: Runway 31 on October 29, 2012, 10:48:40 AM
Keith,
400EF5, G-BYVY, Grob G 115E Tutor T1. c/n 82134/E, Babcock Aerospace
Post by: EK01 on October 29, 2012, 02:28:37 PM
Alan,
Not sure if this is in the latest d/b as I don't update, but the following came into Alicante on the 28th Oct operating a flight for Transaero :
EI-DOH B737-31S c/n 29056
Showing in my d/b as wfu/stored and was operating for Air Italy.
Post by: Runway 31 on October 29, 2012, 04:26:38 PM
hI ian,
Yes in the d/b but no longer WFU.
Post by: Kenny on October 29, 2012, 10:37:45 PM
Got this unknown
708022  using callsign LAO643 and LAO633
881C66  using callgsign HSGCF
A04B9C  using callsign N118TH
Post by: ACW367 on October 30, 2012, 01:15:26 AM
Quote from: superspotter on October 28, 2012, 01:06:14 PM
The same operator has also acquired M-BETY
http://nigerianaviation.wordpress.com/2012/10/29/second-do328-for-prime-air-services/
Post by: X on October 30, 2012, 04:28:27 AM
The  ex EK airbus has finally departed (To Lourdes?)
* 4CAA90  EIEYO                                                       2012/10/30 08:20:26
* 76094F                                                               2012/10/30 02:40:27
X
Post by: X on October 30, 2012, 05:03:55 AM
Another one that shuld be marked as miscode Various as this is a C2 operating in the area not a Lynx.
* 000002                           XZ182   LYNX  UK - Marines (Mis... 2012/10/29 11:09:43
* 000002  RG01                     XZ182   LYNX  UK - Marines (Mis... 2012/10/29 15:02:44
X
Post by: neroon79 on October 30, 2012, 05:44:43 AM
Morning, finally I'm able to get back to this job: Here are the unknowns from yesterday:
3DD371 (Germany, with flight id: DHAIB, according to helionline.de: D-HAIB R44 Robinson R44 Raven II Aeroheli International GmbH & Co KG 12060 Mk1EB September 14th 2012: http://www.helionline.net/198-263583-789666/photogallery/30/132/36402///D-HAIB+12060.html )
4008E8 (UK, flight id: TCX368P, decoding error of 4008E0)
45B9F1 (Denmark, flight id: LPVP, no luck with the details)
4A819B (Sweden, flight id: SVF635, so decoding error of 4A8199)
MIL List:
3F5728
3F9CFC  GAF007
3FADAC  HAMMER2
3FB0CC  GAF022
that's all from yesterday. I'll go through my back-log the next couple of days. Be prepared for some additional work.
Post by: neroon79 on October 30, 2012, 05:58:56 AM
Sunday 28th of October
3D2C68 (Germany, flight id: DEPBK, still no luck with the details)
3FEB95 (Germany, flight id: DMRZA, same as above)
3FEE75 (Germany, flight id: DMKSW, ...and the third)
3FF11A (Germany, flight id: DMBJR, again no luck with details)
3FF14F (Germany, flight id: DMEGE, finally a new one, but no luck with the details)
4785E6 (Norway, flight id: NAX1KH, decoding error of 4785E4)
Post by: neroon79 on October 30, 2012, 06:09:11 AM
Saturday, October 27th:
3D15F5 (Germany, flight id: DEGOJ, D-EGOJ C152 Reims-Cessna F152 Private F15201647 Mk1EB February 2012: http://www.flugzeugbilder.de/show.php?id=1127310 )
3F599C (Germany MIL, flight id: GAF016)
473400 (Hungary, flight id: WZZ349, decoding error of 473404, 473406 or 47340E)
7808EF (already in the db with all details)
80074D (already in the db with all details)
Title: Re: Database Update Requests
Post by: superspotter on October 30, 2012, 07:14:09 AM
Morning from Lagos;
We have a miscode, dont know if this one is my fault?!
Hexcode 064125 is 5N-CML Caverton Helicopters Augusta AW139 and not 5N-BPA, regards clive.
Post by: neroon79 on October 30, 2012, 07:40:56 AM
Friday, October 26th:
3C4E17 (Germany, flight id: DLH6AR, so decoding error of 3C4E13)
3C5865 (Germany, no flight id, nothing more)
3D323F (Germany, flight id: DERGX, D-ERGX GX Remos GX Private 390 source: http://coptercrazy.brinkster.net/search/d-e_index.asp?Search=D-ER )
3FF19B (Germany, flight id: DMCBP, still no luck with the details)
3FF1DB (Germany, flight id: DMLEU, D-MLEU CDUS AutoGyro Calidus Private CN:? Mk1EB August 2012: http://www.luftfahrtclubbraunschweig.de/picdb/Juergen-Gruettner-Privat-AutoGyro-GmbH-Calidus-D-MLEU-BWE-Braunschweig-Wolfsburg-9567.html )
45ACC0 (Denmark, flight id: SAS662, decoding error of 45ACC2)
45ACCD (Denmark, flight id: SAS1629, decoding error of 45ACCC, has also generated following false entries: 45AC4C and 45ACC8 / a CRJ9 again)
45ACCD (Denmark, flight id: SAS2683, decoding error of 45ACC5 / CRJ9)
4841D3 (Netherlands, flight id: TRA5292, decoding error of: 4841D5, 4841DB or 4841D7)
58AD04 (no allocation, no flight id, whether a miscode or a decoding error)
A4CE17 (already populated with full details)
E80201 (already populated with full details)
MIL List:
3E8BAE  LK01B
3E98E7
3EA780  LK01A
3F454D  GAF051
3F476E  ROCKET
3F4858  APEX
3F838D  NOBLE
3F864E  TA48
3FA110  NITRO
3FB6E1  HAMMER2
Post by: Skyliner on October 30, 2012, 07:51:28 AM
That was TN-AIJ E120 Equaflight into Perpignan
Quote from: diddyboy on October 29, 2012, 06:44:30 AM
0360DA
Post by: neroon79 on October 30, 2012, 07:57:21 AM
Thursday, October 25th:
26156C (no allocation, no flight id, mentioned to be a mil airframe)
3448DA (Spain, flight ids: 5JV H A, BER8394, BER8394 is decoding error of 3C48DA)
3C49C0 (Germany, flight id: BER736, decoding error of 3C49C2 or 3C4CC2)
400521 (UK, no flight id, no active airframe found)
48440B (flight id: KLM451, decoding error of 48440F)
4B009A (flight id: FAT7TW, decoding error of 4B0098)
4B160A (flight id: SWR105D, decoding of 4B160E also caused false entry with hex 4B161E)
780936 (already populated with full details)
A2E25A (flight id: UPS9, decoding error of A2E25E)
AE19FD (USA MIL, flight id: DEVIL01, airframes: 82-0646 A10 Fairchild Republic A-10A Thunderbolt II USAF 694)
MIL List:
3E98E7  SNIPER01
3F45D0  GAF710
3F46A1  LION
3F8117  GAF320   ESSA-LFPG
3F82CB  RAGE1
3F864E  GAF674
3F8D3F  SNIPER02
3F9822  RAMBO02
3FB6E1  SMASH2
3FB7CD  GAF269
3FB7EE  PANTER1
3FB9E4  GAF042
3FB9E4  GAF042
3FB9FA  TIGER1
Post by: neroon79 on October 30, 2012, 08:04:49 AM
Wednesday 24th of October:
000017 (no allocation, no flight id, some mil airframe  I bet)
3C6300 (flight id: BER796, decoding error of 3C6321, 3C6301 or 3C6305)
3C6300 (flight id: BER970, decoding error of 3C6300 also caused 3C6104, 3C6305)
4240B2 (flight id: ABW166, decoding error of 4240B6)
4D00CF (Luxembourg, no flight id, nothing more)
MIL List:
3EB664  LK01A
3F45D0  GAF710
3F5ACF  PSYCHO
3F6AD7
3FADFF  GAF017
3FB27A  LK01B
3FB6E1  HAMMER2
3FB9E4  GAF634
3FB9E4  GAF727
3FBEEB  HAMMER1
Post by: neroon79 on October 30, 2012, 08:13:53 AM
Tuesday, October 23rd: no LOG received
Monday, October 22nd:
3FF19B (Germany, flight id: DMCBP, already posted today)
406731 (flight id: EXS152, decoding error of 406735)
451E95 (Bulgaria, no flight id, was LZ-WZC of WizzAir until 2011, no new airframe found, may be a decoding error)
4CA261 (flight id: RYR1935, decoding error of 4CA263)
76CCC3 (Singapore, no flight id, received again, still no details)
ACDE59 (already populated to my database)
MIL List:
3E9BFB  SNAPPER
3F501B  GAF011
3F7567  GAF626
3F872E  TA47
3F8DF9  SNIPER1
3F94A4  GAF120
3FB6DE  GAF021
Post by: neroon79 on October 30, 2012, 08:38:22 AM
Sunday, October the 21st:
200000 (no allocation, flight ids: ADR498, PTO102, PTO103, ADR498 also in list with hex 506C04, PTO102 & PTO103: again the miscoded airframe of Pilot Training Network)
3C667C (Germany, no flight id, several possible airframes in the list that could be the origin of this potential decoding error)
3D1689 (Germany, no flight id, airframes: D-EGUB / in 2002: DV20 Hoffmann Katana DV-20 Private 20157 sources: http://govfr.com/aircraft_Katana-DV-20-D-EGUB_-1_2120.html / http://katanaflyer.de/katana-productionlists/dv20-20081-20160/ / http://wap.airliners.net/photo/Hoffman-DV-20-Katana/0219832/&sid=85e4091b08da6b573ee953386c6aa9cc )
3FEC3F (Germany, flight id: DMVLO, no luck with the details)
3FEE00 (flight id: DMFNY, decoding error of 3FEE36)
3FEE75 (Germany, flight id: DMKSW, already posted today)
3FF199 (Germany, flight id: DMIGX, D-MIGX MRC1 Dyn'Aero MCR-01 Private CN:? Sources (2007): http://www.flugzeug-bild.de/name/einzelbild/number/679/kategorie/flughaefen~deutschland~berlin-tempelhof-thf.html and  http://www.asa-be.com/Files/Traffic2007/ANR200704.pdf )
4CA89C (Ireland, no flight id, nothing more)
Post by: neroon79 on October 30, 2012, 09:03:03 AM
Saturday, October 20th:
000408 (no allocation, no flight id, miscode or a fatal decoding error)
04C0DB (Kenya, flight id: KQA116, decoding error of 04C0D3)
3FEBCD (Germany, flight id: DMKMN, D-MKMN ULAC TL Ultralight TL96 Sting Private CN:? source: Picture from October 1st at Flugzeugforum.de )
400872 (UK, no flight id, G-BZAZ last known status: stored)
4009DC (flight id: BAW856, decoding error of 4009D8)
4009DC (flight id: TOM66Y, decoding error of 4009DE)
4840E1 (flight id: KLM1353, decoding error of 4840E5 also caused entry 4840C5)
489520 (flight id: LOT279, decoding error of 489522)
49C045 (Czech Republic, flight id: OKOUU55, OK-OUU 55 WT9 Aerospool WT-9 Dynamic Private DY340/2010 MK1EB July 2012: http://www.abpic.co.uk/photo/1363285/ )
4BB427 (Turkey, flight id: DEEKU, airframes: TC-MAG DA40, seems to now owned by GAviators with registration D-EEKU unfortunately still using the old hex. Sources: http://www.gaviators.com/Aktuelles/d-eekudiezweiteda40tdiistam18102012inedazangekommen and http://www.gaviators.com/d-eeku )
Going for a break now...
Post by: paul tricker on October 30, 2012, 09:23:00 AM
* A7814D  LXJFE                                                       2012/10/30 08:38:54
A7814D is N583CP /TBM700 /208 / Andrew J Douglas,      registered 29/10/12, it was LX-JFE before
Paul
Post by: Runway 31 on October 30, 2012, 09:32:11 AM
Thanks for the update Paul
Post by: John Hargreaves on October 30, 2012, 10:16:14 AM
X,
76094F  AP-BJO  B737-4H6  c/n 27166/2410  Shaheen Air International
60080C 4K-AZ12 Azerbaijan Airlines is confirmed as being the former VP-BBS. Photographic evidence from CDG and it wears the name Nakhchivan.
John H.
Post by: neroon79 on October 30, 2012, 10:34:46 AM
Operator Update:
3DD7B8 D-HBYE EC35  Eurocopter EC-135 P2 Bavarian Police 0075 is with LifeFlight since early 2011. Received with flight id HCR1
http://www.flugzeug-bild.de/name/einzelbild/number/30773/kategorie/Hubschrauber~Eurocopter~EC+135.html
http://www.lifeflight.de/de/Startseite (Maybe we need a logo for this one) HCR is ICAO Code for this operator / ICAO Callsign: Helicraft
Post by: Runway 31 on October 30, 2012, 11:03:42 AM
Thanks for the operator update Ingo
Post by: Runway 31 on October 30, 2012, 11:07:24 AM
Thanks Clive
Post by: Runway 31 on October 30, 2012, 11:10:43 AM
Hi Kenny
I,m not able to assist much with those unknowns
708022  unknown to me
881C66  decodes to HS-GCF but unknown to me
A04B9C  decodes to N118TH SR22T now HS-***
Post by: Runway 31 on October 30, 2012, 11:11:05 AM
Thanks John
Post by: X on October 30, 2012, 11:33:37 AM
Thanks for that
Any further news on A6-ESR (or A6-ESG) yet, it's not around here much at the moment
X
Post by: Runway 31 on October 30, 2012, 11:50:48 AM
Ingo,
Saturday, thanks for those
Sunday
3FEC3F D-MVLO unknown to me
3FEE75 unknown to me
4CA89C unknown to me
Nothing to add for yesterday.
Post by: John Hargreaves on October 30, 2012, 11:58:07 AM
 Alan / X,
896368 has gone all quiet again.
708022 is an ATR 72-500 of Lao Airlines, but they have four to choose from..........
John H.
Post by: Runway 31 on October 30, 2012, 12:04:02 PM
I dont have a hex for any of them John
Post by: Kenny on October 30, 2012, 03:53:05 PM
Quote from: John Hargreaves on October 30, 2012, 11:58:07 AM
Alan / X,
John H.
John,
That 708022  could it be new ATR72-600 c/n 1049  which was delivered mid of this month..   It is the only ATR that has ADS-B around here.
Post by: Runway 31 on October 30, 2012, 04:49:22 PM
Kenny,
RDPL-34222 was delivered 16/10, 708022 was first picked up 28/10 so highly likely as AT76 are ADSB equipped and it is their sole one.
Post by: X on October 30, 2012, 06:54:31 PM
Pauls DC3 has been over here but do not know where it went at a constant 9000ft
* A57823  N451ZS                   N451ZS  DC3   Association Airsc... 2012/10/30 16:25:05
X
Post by: ACW367 on October 30, 2012, 07:23:33 PM
Quote from: X on October 30, 2012, 06:54:31 PM
X
According to the schedule Kuwait-Muscat-Karachi
http://www.dc3-antipodes.com/?page_id=7
Post by: Runway 31 on October 30, 2012, 07:31:00 PM
Cheers X
Post by: neroon79 on October 31, 2012, 04:28:10 AM
Morning, the unknowns from Tuesday, October 30th:
3EA46B (Germany, no flight id, nothing more)
3F4B42 (Germany, no flight id, nothing more)
46427F (Finland, no flight id, nothing more)
780937 (flight id: CCA931, mix-up/decoding error with/of  78082E)
780937 (China, flight id: CES299, B-6429 A319 Airbus A319-115 China Eastern Airlines 5338 delivered yesterday out of EDHI / http://xfw-spotter.blogspot.de/search/label/5338 )
That's all from yesterday, proceeding with back-log.
MIL List:
3F7534  GAF787   EGWU-LFBD
3F83A4  TA47
3F864E  GAF032
3F864E  GAF032
3FBEEB  VADER1
Post by: neroon79 on October 31, 2012, 05:15:32 AM
Friday, October 19th:
03001F (Botswana, flight id: A2ABH, A2-ABH of Air Botswana- Is Already in db)
3AC421 (France, no flight id, nothing more)
3B77E4 (France MIL, CTM1280, CTM: Armee de l'Air Francaise )
3C6649  DLH016 caused by 3C664F
3C6649  DLH46C caused by 3C6643 also caused 3C6642 and 3C6653
3C6649  DLH6NX also in list with hex 3C664B, 3C6653 and 3C674B
3C6649  DLH6TY also in list with hex 3C664D, 3C6669
3C6649  DLH804   EDDT-EDDK also in list with with hex 3C664D and 3C6669
3C6649  DLH8WC   EBBR-LHBP also in list with hex 3C664D and 3C664F
3C6649  DLH9CM   EDDT-EDDK also in list with hex 3C6646 and 3C664B
3C6649  SHS63    EDDT-EDDK no further occurrences, SHS: Shura Air Transport Services (Etopia)
3D32D6 (Germany, flight id: DERMS, D-ERMS SR22 Cirrus SR22 GTS Private CN:? source and MK1EB: http://www.flugzeugforum.de/flugplatz-schoenhagen-edaz-54970-94.html )
3E5E47 (Germany, flight id: DKAXB, D-KAXB DIMO Diamond HK-36 100TC Super Dimona AERO-CLUB Mülheim an der Ruhr e.V. CN:? http://www.aeroclub-muelheim.de/pages/unsere-flugzeuge/motorsegler.php )
3FEB95 (Germany, no flight id, D-MRZA but still no luck with the details)
400563 (UK, no flight id, nothing more bet it was one of the decoding errors)
4B0072 (Switzerland, no flight id, was HB-AEK which has cancelled from register. Could not find a new airframe with this hex. So, decoding error would be my guess)
780934 (China, no flight id, China Eastern Airlines A320, already in the db)
A247DC (USA, flight id: RA0217G, would match to N246SC / RA-0217G is a PA46 Piper PA-46-350P Malibu Mirage http://www.flickr.com/photos/33104187@N04/4357220850/ )
plus two further commercial airliners who are already in the db now.
MIL List:
3EA6FD  BONES01
3F42A4  GATOR
3F501B  GAF004
3F6005  GNY4531
3F6123  GAF626
3F6368  GAF014
3F6368  GAF014
3F872E  TA65
3FA1F5  TA48
Post by: neroon79 on October 31, 2012, 05:48:40 AM
Thursday Ooctober 18th:
33FFAA (Italy, no flight id, MIL airframe)
3C4843 (Germany, no flight id, was D-ABBC which is now VP-BEZ, no new airframe with this reg found)
3C48E8 (Germany, flight id: DLH9EP, also in list with hex: 3C48A8 and 3C48EA)
3C49E0 (Germany, no flight id, nothing more)
3D19F8 (Germany, flight id: DEIBW, airframes: D-EIBW P28T Piper PA-28RT-201T Turbo Arrow 4 Private  28R-8131162 latest Mk1EB is from 2009: http://www.airport-data.com/aircraft/photo/373745.html )
424971 (flight id: ABW466, decoding error of 424975)
4B169F (flight id: BER821Y, decoding error of 4B169B)
4BB427 (Turkey, flight id: DEEKU, D-EEKU has already populated, but without a statement, that this is a miscode / Turkish hex, but German reg)
4BBC42 (flight id: FHY3577, decoding error of 4BBC4A)
51006D (Belarus, no flight id, in this case a decoding error of 51006C but 51006D will be or already is EW-341PO E170 Embraer ERJ170-200LR Belavia 170.00352 sources: http://www.flightradar24.com/data/airplanes/ew-341po / http://www.planespotters.net/Production_List/Embraer/ERJ-170/17000352,EW-341PO-Belavia.php  )
A247DC (already posted today)
ACBDCC (USA, flight id: N92WC, decoding error of ACBDC8 )
MIL List:
3F5FC0  GAF762
3F6123  TA45
3F6123  TA45
3F872E  TA47
3F94A4  GAF634
3F94A4  TA46
3FA1F5  GAF041
3FADFD  GAF003
Post by: neroon79 on October 31, 2012, 05:56:04 AM
Wednesday October 17th:
3B77E4 (flight id: CTM1280, already posted today)
3CCE50 (flight id: FCK311, decoding error of 3CCE70)
400DB7 (flight id: EZY4707, also in list with hex 400DB3 and 400DAE)
449152 (flight id: BEL74T, decoding error of 449150)
4EA1C9 (no allocation, no flight id, nothing more)
plus one, which is already in the db now)
MIL List:
3EA6FD
3EA6FD  BONES01
3F4914  GAF757T
3F6123  GAF727
3F6123  TA65T
3F6480  GAF767
3F6AD7
3F6AD7
3F872E  TA44
3F872E  TA47
3FAE28
Post by: neroon79 on October 31, 2012, 06:07:11 AM
Tuesday, October 16th:
288037 (no allocation, flight id: 3401CTXC, nothing more)
3D0F6D (Germany, flight id: DEECB, D-EECB PA46 Piper PA-46R-350T Malibu Matrix Private CN:? Mk1EB August 2012: http://www.planespotters.net/Aviation_Photos/photo.show?id=307874 )
40068D (flight id: BAW124, decoding error of 400685)
44D8B0 (flight id: BEL4RR, decoding error of 44D8B4)
461F93 (flight id: FIN879Q, decoding error of 461F9B)
7803BA (China, no flight id, nothing more, maybe a decoding error)
82C094 (India, no flight id, nothing more)
MIL List:
3F6123  TA52
3F6123  TA52
3F6AD7  PANTER02
3F6AD7  THOR2
3F7DC5  GAF685
3F82CB  EAGLE1
3F8552  GAF732
3F8A48  GAF120
3F9F9F  STRIKE2
3FA066  GAF910
3FAE28  GATOR
Post by: Runway 31 on October 31, 2012, 06:27:10 AM
Hi Ingo,
3AC421 unknown to me
3B77E4 unknown to me
D-ERMS SR22T c/n 0346
3EA46B probable mil tac
3F4B42 probable mil tac
46427F decodes to OH-ZET unknown to me
N246SC was PA34 and is now N288DA
3FEB95 D-MRZA still unknown
Thanks again
Post by: Runway 31 on October 31, 2012, 06:40:19 AM
Ingo,
18th
33FFAA unknown to me
3C49E0 unknown to me
51006D in d/b as EW-341PO on delivery 27/10
16th
7803BA unknown would suggest a decoding error
82C094 unknown to me
Post by: neroon79 on October 31, 2012, 07:25:17 AM
One that has disappeared from the db with the last update:
3CE8DC D-CPMI C25B Cessna 525B CitationJet CJ3 Private (Papier-Mettler) 525B0286 last eye-balled August 28th 2012 ( http://www.flugzeugforum.de/flugbetrieb-nuernberg-eddn-nue-2012-a-68513-190.html )
Post by: neroon79 on October 31, 2012, 07:36:14 AM
Monday, October 15th: no LOG received
Sunday, October 14th:
3C4A20 (Germany, no flight id, nothing more - a decoding error would be my guess)
471EA0 (Hungary, no flight id, nothing more)
484446 (Netherlands, flight id: KLM54W, was PH-BRG a CH60 until 2011. I doubt that this was this airframe reborn... )
4CA1FB (Ireland, flight id: RYR1943, no further occurrences, maybe a decoding error of unknown origin)
Post by: neroon79 on October 31, 2012, 07:46:17 AM
Saturday, October 13th:
3C6673 (Germany, no flight id, decodes to D-AISS, but no info about this reg. So another decoding error would be my guess)
3D4556 (Germany, flight id: DEYMW, no details found)
3E5D38 (Germany, flight id: DKAMQ, D-KAMP SF25 Scheibe SF-25 C "Rotax Falke" LSV Kamen/Dortmund e.V. cn:? source: http://www.lsf-kamen.de/index.php?option=com_content&view=article&id=75&Itemid=82 )
3F6480 (Germany MIL, flight id: GAF710)
4CA1B6 (Ireland, no flight id, was EI-CTB now VQ-BJJ, nothing about a new one)
5081C9 (flight id: AUI102, decoding error of 5081E9)
5081C9 (flight id: WAU6091, decoding error of 5081CD)
Post by: Runway 31 on October 31, 2012, 08:00:24 AM
Ingo,
3CE8DC D-CPMI C25B is now N286VP hence the disappearance
3CE8DC D-CPMI is now Cessna 560XL Citation XLS+ c/n 560-6121
Post by: neroon79 on October 31, 2012, 08:53:42 AM
Thanks for intel about D-CPMI. Question is now: Is new D-CPMI still owned by Papier-Mettler.
Friday, October 12th
3C452E (Germany, no flight id, nothing more)
3C486F (Germany, no flight id, nothing more)
3CC2BB (Germany, no flight id, nothing more)
3D0973 (Germany, no flight id, nothing new about this one)
3EB0AA (Germany MIL, no flight id)
3F8AA4 (Germany MIL, flight id: GAF183)
4AB4EE (Sweden, flight id: JEA920, already in the db)
75028D (Malaysia, flight id: MAS2, decoding error of 75028F)
780311 (already in the db)
88809E (already in the db)
8960FB (already in the db)
896363 (already in the db)
Post by: neroon79 on October 31, 2012, 09:19:51 AM
New D-CPMI has now populated. Thanks!
Thursday, October 11th:
0066D1 (Mozambique, no flight id, nothing more)
3C4944 (Germany, no flight id, was D-ABJD B735, no information about a new airframe using this hex)
3D323F (Germany, flight id: DERGX, posted yesterday)
3E446F (Germany, no flight id, D-IRCP BE9L Beech C90GTi "King Air" Private CN:? Source and Mk1EB: http://www.flugzeugbilder.de/show.php?id=1176480 / http://www.flugzeugforum.de/flugbetrieb-nuernberg-eddn-nue-2012-a-68513-191.html )
3E4908 (Germany, no flight id, nothing more)
400A16 (UK, no flight id, no active airframe found)
440006 (Austria, flight id: SAS1626, no airframe found)
44D2A1 (flight id: JAF403, decoding error of 44D2A3)
ACDE60 (already in the db)
ACDE78 (already in the db)
ACDE89 (already in the db)
DE0000 (no allocation, flight id: AZZZZZZZ, miscoded airframe)
MIL List
3E948F  PUMA                                                        2012/10/11 07:57:55
3F476E  ROCKET                                                      2012/10/11 07:41:51
3F4AB7  TA47                                                        2012/10/11 07:07:38
3F4AB7  TA67                                                        2012/10/11 11:31:43
3F65BE  GAF263                                                      2012/10/11 07:23:42
3F7D4D  COLT                                                        2012/10/11 07:48:24
3F8AA4  GAF183                                                      2012/10/11 14:52:40
3F8DF9  RAVEN01                                                     2012/10/11 05:54:23
3F8DF9  RAVEN1                                                      2012/10/11 13:45:14
EDIT: Back-Log finished
Post by: Runway 31 on October 31, 2012, 10:30:15 AM
Ingo,
Friday 12th
I would imaging that the new D-CPMI will be the same owner.
3C452E decodes to D-AAIN unknown to me
3C486F decodes to D-ABCO unknown to me
3CC2BB decodes to D-CBAX unknown to me
3D0973 decodes to D-EBVF unknown to me
13th
3D4556 DEYMW, Cessna T182T Skylane, c/n T18208692
3FF19B D-MCBP, still unknown
4CA1B6 as stated
14th
3C4A20 doesnt decode
471EA0 unknown to me
Post by: Runway 31 on October 31, 2012, 10:47:37 AM
Ingo,
28/10
3D2C68 D-EPBK, Piper PA-28RT-201T Turbo Arrow IV, c/n 28R-8031164
3FF14F DMEGE, Aerospool WT-9 Dynamic c/n DY440/2012
26/10
3C5865 decodes to D-ACFE unknown to me
3FF19 D-MCBP, still unknown
24th
4D00CF uknown to me
22nd
76CCC3 decodes to 9V-SFC which is now B-2409 B747
Hopefully all done
Post by: Runway 31 on October 31, 2012, 10:50:25 AM
Skyliner
Thanks for the info re 0360DA, TN-AIJ
Post by: neroon79 on October 31, 2012, 11:08:09 AM
Quote from: Runway 31 on October 31, 2012, 10:47:37 AM
Hopefully all done
Don't worry time will tell.
Ingo
Post by: John Hargreaves on October 31, 2012, 12:46:14 PM
 X,
896368, the elusive Eastern Skyjets, is active again today. At 1100z picked up on ESJ011 in your neck of the woods.
John H.
Post by: neroon79 on October 31, 2012, 01:12:29 PM
From today:
3E7BBE (Germany, flight id: DKMBE, D-KMBE VENT Schempp-Hirth Ventus-2cM/18m Private Serial No.:116 Build No.:248 sources: http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?dsId=2219415 / http://www.rcawsey.co.uk/Ven2cm.htm )
3D433F (Germany, flight id: DEXSH, nothing more / ADS-B equipped)
3D3F32 (Germany, flight id: DEWEK, D-EWEK PA22 PA-22-108 Colt Private 22-9654 source: http://www.abpic.co.uk/photo/1258853/ )
3D0708 (Germany, flight id: DEAXK, D-EAXK E300 Extra Aircraft EA 330 LT Eichhorn Airadventures CN:? http://www.t6-team.de/ea330lt.html )
Post by: Runway 31 on October 31, 2012, 01:38:18 PM
Hi Ingo,
My d/b gives D-EWEK PA22 as cancelled so it may be the same one or it may be a re-issue
3D433F D-EXSH unknown to me
Thanks again
Post by: X on October 31, 2012, 01:42:14 PM
You are right it is back somewhere near here, would suggest RAK and has possibly been there for 10 days as it landed 20th and no other movements noted (however I could have missed it as RAK is difficult if they head North). Still not eyeballed by anyone I know.
896368                           A6-ESR  B733  Eastern Skyjets      2012/10/31 14:48:40
X
Post by: neroon79 on October 31, 2012, 02:06:13 PM
Hi Alan,
do you know in which year D-EWEK was cancelled from register? Maybe we can exclude the PA22 I mentioned, because as far as I was able to find out it was last eye-balled in 2010.
Just receiving D-EAXK again.
Thanks in return!
Ingo
Post by: Runway 31 on October 31, 2012, 02:38:54 PM
Hi Ingo,
Dont have a date
Post by: Judwin45 on October 31, 2012, 04:28:57 PM
Hi Alan
Anything on 43C6BB, no other details.
Post by: Judwin45 on October 31, 2012, 04:38:16 PM
I think it might be a AW159 Wildcat
Post by: Runway 31 on October 31, 2012, 05:05:34 PM
I dont have anything on it Keith must be very new
Post by: Bob SEN on October 31, 2012, 07:53:21 PM
Hi Alan
I got 484360 showing & P4-KCG an E190 (19000543) of Air Astana has just touched down at SEN on a delivery flight...?
cheers
Bob
Post by: paul tricker on October 31, 2012, 08:57:58 PM
04006A                                                              2012/10/31 14:43:02
picked this up climbing 2 mins after ET-AQC departed Stansted, not seen anything to confirm 100% that it is the DHC-8 for Ethiopian/Askay Airlines however, if so it is c/n 4421
A0AAAB  N142FR                                                      2012/10/31 14:09:40
This is SR22 c/n 3878 Cirrus Design Corp, but as on delivery to the French AF, might not be worth adding to the DB!
Paul
Post by: Xon on November 01, 2012, 12:52:43 AM
899047 A320 B-16201 c/n 5354 Eva Air Delivery flight EVA321 XFW-DWC-TPE
Post by: neroon79 on November 01, 2012, 05:07:46 AM
Morning, the unknowns from Wednesday October 31st:
42429A (UK, flight id: AFL5651, already populated)
440199 (Austria, flight id: ISK300B, decoding error of 44019B / But there may also still exist 440199 OE-DCA C172  Cessna 172 S Skyhawk operator was flight training JA 172S9951 last spotted October 2009)
4843D1 (flight id: TRA5494, decoding error of 4843D9)
484FCE (Netherlands, flight id: FOP449, already populated)
899047 (Taiwan, flight id: EVA321, B-16201 A320 Airbus A320-211 EVA AIR 5354 on delivery out EDHI: http://xfw-spotter.blogspot.de/2012/10/a320-211-eva-air-d-avzd-b-16201-msn-5354.html / already posted by Xon)
MIL List:
3E8301  MONSTR2
3E8394  GAF120
3E9C4E  NITRO54
3EAE92  STRIKE
3EB3F1  NITRO52
3F4858  NITRO53
3F57AB  BURNER
3F59EB  NITRO51
3F9185  GAF128   LPLA-EDDK
3F9A93  GAF254   BIKF-ETNH
3FB7CD  GAF024
3FB7CD  GAF024
3FB9E4  TA54
3FB9E4  TA57T
3FBCC4  GAF905
That's it. Have a nice Day!
Ingo
Post by: Runway 31 on November 01, 2012, 08:56:39 AM
Thanks Bob, P4-KCG it is
Post by: Runway 31 on November 01, 2012, 09:18:55 AM
Thanks Xon
Post by: Runway 31 on November 01, 2012, 09:20:04 AM
Thanks Paul,
I dont intend to add the FAF SR22's as they shouldn't be seen using the hex again.
Post by: Runway 31 on November 01, 2012, 09:22:39 AM
Hi Ingo,
440199 OE-DCA not allocated at present.  The C172 is now HA-DCA
Thanks again
Post by: X on November 01, 2012, 12:31:21 PM
Did not populate and obviously back home!
89635A   A6-140   Agusta-Westland AW.139   31073   Dubai Air Wing
X
Post by: X on November 01, 2012, 12:59:07 PM
Quote from: Xon on November 01, 2012, 12:52:43 AM
Xon
Thanks B-16201 sat at DWC at the moment. B-LPH A320 Hong Kong Airlines sat at AUH
X
Post by: Runway 31 on November 01, 2012, 01:49:26 PM
Sorry X, looks like I deleted the wrong one, its back in now
Post by: X on November 01, 2012, 02:19:52 PM
New Afghan OTT sandpit
* 700014  ZFW6241                                                     2012/11/01 17:50:14
X
Post by: Runway 31 on November 01, 2012, 02:22:38 PM
Nothing on it X, its up to the locals!!
Post by: X on November 01, 2012, 02:39:32 PM
It is the Safi that has been parked at AUH last month and seen by me today and departed 1740, but could not get reg. It was first reported as an A320 but it looked larger amongst a whole group of A300's..767 perhaps.
X
Post by: X on November 01, 2012, 03:29:57 PM
This was reported landing AUH 8/10/12 and has not been seen departing and Safi now report having a B752...could this be our 70014?? Can you see if you have anything as it would explain our thinking it was possibly a B763 in amongst A300's and first being thought to be a A320.
26330   B752      EI-EXX   ILFC Ireland
At first I thought the f/n being 6241 could this be short for 26241 EC-ISY B752 once used by Safi But I believe that is in service today in Europe so not at all likely and f/n maybe reuse covering EC-ISY.
X
Post by: Runway 31 on November 01, 2012, 04:20:43 PM
All I have for EI-EXX is that is is parked at Abu Dhabi in basic Air Finland colours.
Post by: X on November 01, 2012, 04:26:42 PM
I have it reported departing Perpignan in an all white c/s for a new ME customer. The scheme I saw today was basically white body and tail with sky blue S in a sky blue lozenge with black Safi immediately underneath the Lozenge.
Time will tell as its bound to be in DXB soon
X
Post by: Runway 31 on November 01, 2012, 04:51:55 PM
It was stored at PGF from 26/7 but dont know when it departed.
As  you state it wont be long until you get a visit
Post by: X on November 01, 2012, 05:22:43 PM
Departed Perpignan to AUH 8/10/12 and was picked up as such on arrival AUH.
Quote from European Airline Scene 'Air Finland B752 OH-AFI (26330), now registered to ILFC as EI-EXX, was ferried all white from Perpignan to Abu Dhabi on 8/10 prior to delivery to a new operator.'
X
Post by: neroon79 on November 01, 2012, 07:16:04 PM
From today:
3EFE52 (Germany, flight id: D7611, D-7611 GLID DG Flugzeugbau DG 200/17 Private  2-87/1705 source: http://www.onlinecontest.org/olc-2.0/gliding/flightinfo.html?dsId=2432849 / http://www.dg200.co.uk/dg200regs.htm )
3E3C5B (Germany, flight id: DIOBB, still no luck with the details)
AB1725 (USA, flight id: MDN9681, MDN: Mudan Airlines [Somalia] /  N8132F B350 BEECH 300 (B300) Super King Air 350 source: http://www.dfld.de/Link.php?URL=Mess/ShowAircraft.php?L=E!E=D!A=B350!I=!C=MDN9681 )
Post by: flygfantast on November 01, 2012, 08:24:46 PM
The mystery Estonian, 51109D, is finally solved!
It's ES-LSA ex LY-NSA, ferried VNO-TLL-OSL 3 september and operated by Airest (AEG) for Avion Express (NVD).
51109D ES-LSA, Saab 340AF, c/n 340A-055, Airest
See http://www.flickr.com/photos/andymarks/7928575344/
Niklas
Post by: Xon on November 01, 2012, 09:42:04 PM
Correction, it's A321
Post by: neroon79 on November 02, 2012, 05:25:10 AM
Quote from: Xon on November 01, 2012, 09:42:04 PM
The correct Data was added to db. Airframe has populated to my db as you state as an A321-211.
Post by: neroon79 on November 02, 2012, 05:36:08 AM
Unknowns from yesterday:
3C7D8E (Germany, no flight id, nothing more)
45ACC0 (SAS1689, also in list with 45ACC2 and 45AC42)
MIL List:
3E9093  TA64
3F5BA5  TA47
3F5BA5  TA47
3F7E36  TA67
3F83DF  TA48
3F83DF  TA68
3F8434  GAF905
3F9213  TA56
3F94BC  GAF162
3F9C6D  TA24
3FA259  GAF109
Have a nice Day!
Ingo
Post by: Runway 31 on November 02, 2012, 10:21:44 AM
Ingo/Xon
899047 B-16201 is in the d/b as A321-231
Post by: Runway 31 on November 02, 2012, 10:24:05 AM
Many thanks Niklas, anther finally put to bed
Post by: Flieger_NDS on November 02, 2012, 12:31:00 PM
Quote from: neroon79 on November 01, 2012, 07:16:04 PM
In this case MDN is Meridian+ from Russia: http://www.agpmeridian.com/ (http://www.agpmeridian.com/). The aircraft should have a Russian reg by now, but I cannot prove it (yet). I guess it will undergo special mission conversion at Aerodata in Braunschweig.
Post by: Runway 31 on November 02, 2012, 01:34:22 PM
Ingo,
3C7D8E decodes to D-AOLN unknown to me
N8132F is no longer on FAA register, i have it as RA-*****
Post by: flygfantast on November 02, 2012, 05:00:51 PM
4D2077 9H-OKI, Bombardier BD-700-1A10 Global Express XRS, c/n 9336, Hyperion Aviation (ex G-OKKI)
Niklas
Post by: Runway 31 on November 02, 2012, 06:06:17 PM
Thanks again Niklas
Post by: Kenny on November 03, 2012, 01:36:08 AM
Saw this 881C4A and 881C48 flies everyday with callsign SNxx.  Sure that they are not commercial airline but some private own or government.
Post by: neroon79 on November 03, 2012, 05:34:12 AM
Morning, the unknowns from Friday:
3EC42A (Germany, flight id: DKPGC, D-KPGC DUOD Schempp-Hirth DUO DICUS T Aero Club Kalkar Wissel e.V. 26/2001 source: http://duenenflieger.de/?page_id=138 )
501DE5 (Croatia, no flight id, nothing more)
503C04 (Lithuania, flight id: LYVJB, no luck with the details)
MIL List
3F844A  GAF775
3F89BE  TA43
3F8A3E  GAF674
rest are decoding errors or have already populated.
Post by: Chris11 on November 03, 2012, 06:24:41 AM
00E3E4 ZU-LUX Owner R Greyling
Post by: neroon79 on November 03, 2012, 06:31:13 AM
Errata of my own posting (noticed during Logo production):
Posted Registration is false shall be D-KAMQ
Post by: anorak on November 03, 2012, 09:41:55 AM
3CC009 / D-CAAJ nothing on Airframes.
Dave.
Post by: neroon79 on November 03, 2012, 09:43:37 AM
Operator Update:
D-FDHR PC12 (N184TH) was owned by Air Independence, but was sold: http://www.airindependence.com/die-flotte/aircraft-sales/ and http://www.flugzeugbilder.de/search4.cgi?srch=D-FDHR&stype=reg&srng=2 )
Post by: neroon79 on November 03, 2012, 09:47:34 AM
Quote from: anorak on November 03, 2012, 09:41:55 AM
Dave.
3CC009 D-CAAJ D328 Dornier 328-110 Untitled/Unknown 3060 (ex OO-ELI of Air Service Liege (ASL))
http://www.flickr.com/photos/28132040@N07/8144863805/
Post by: Runway 31 on November 03, 2012, 09:52:30 AM
Thanks Ingo,
D-FDHR deleted from d/b
D-KAMQ c/n 44621
Thanks for D-CAAJ info
501DE5 unknown to me
503C04 LY-VJB unknown to me
Have a good weekend
Post by: neroon79 on November 03, 2012, 09:59:13 AM
D-FDHR should not be completely deleted from the db, only  the operator should be deleted. D-FDHR is still flying around in my area, but is no longer owned by Air Independence.
Post by: Runway 31 on November 03, 2012, 10:05:00 AM
Thanks Ingo, operator now blank
Post by: anorak on November 03, 2012, 10:11:27 AM
Thanks Ingo,  Dave.
Post by: neroon79 on November 03, 2012, 10:26:04 AM
Errata:
3E1DDA D-ICMS C25A of Brose Fahrzeugteile is in the db as Brose Fahzeugteile. --> missing "r"
Related Info:
A Christine Volkmann is part of Brose Fahrzeugteile, so D-ISCV and D-IAAH may also be connected with this Company.
Post by: neroon79 on November 03, 2012, 10:38:43 AM
Operator Change:
3CD04E D-CGEO formerly owned by Cirrus Aviation is still in the db with this Operator, but is now using MHV flight ids. So it seems to be with MHS Aviation now -along with many other Cirrus Airframes.
Post by: neroon79 on November 03, 2012, 11:24:16 AM
Re-branding:
3CF77C D-CVAI operator: EFS European Flight Service was incorrect. Should have been EFS Euro-Flight Service but they have now re-branded to eu flight service. Was also formerly known as Travel Air, owning 3CD8B7 D-CJJJ.
Post by: Runway 31 on November 03, 2012, 11:30:29 AM
Thanks Ingo,
Only other Cirrus Aviation in the d/b is D-AAOK but I think it will have reverted back to DC Aviation
D-CVAI amended to eu Flight
Post by: Blueboy on November 03, 2012, 07:42:32 PM
Hi Alan, picking up HEX 06E008 with flight ID 9XRWI - no other info
J.D
Post by: Runway 31 on November 03, 2012, 07:49:46 PM
JD
06E008 9XR-WI should a  Canadair CL-600-2D24 Regional Jet CRJ-900,Rwandair on delivery.
Many thanks
Post by: John Hargreaves on November 04, 2012, 12:20:51 AM
 X,
896368 is just out of KWI and looks to be heading your way.
John H.
Post by: neroon79 on November 04, 2012, 04:54:24 AM
Morning, just one MIL airframe to be add:
3F911F  GAF021
Have a nice Sunday!
Ingo
Post by: Runway 31 on November 04, 2012, 09:34:58 AM
Thanks Ingo,
You have a good one too
Post by: flygfantast on November 04, 2012, 10:02:37 AM
SE-LLU is miscoding 4AB1B5 (hex of SE-LMU) instead of it's assigned 4AB195.
Niklas
Post by: Runway 31 on November 04, 2012, 11:26:07 AM
Thanks Niklas, now marked as VARIOUS and being used by both aircraft
Post by: X on November 04, 2012, 09:41:41 PM
896368                           A6-ESR  B733  Eastern Skyjets      2012/11/04 23:49:59
It turned up finally but too late for anyone to confirm it
X
Post by: mikek on November 05, 2012, 02:34:02 AM
Not populating:
89808A, c/s P2KNA, P2-KNA (ex ZK-XLE), PAC750, c/n 151, Niugini Aviation
Mike
Post by: neroon79 on November 05, 2012, 03:58:56 AM
Morning, the unknowns from Sunday:
43E956 (UK, flight id: MMDMH000, M-MDHM E55P Embraer EMB505 Phenom 300 AC:? CN:? source: Manx Aircraft Register. )
AA8BBE (USA, no flight id, was N779PC http://live-mode-s.info/phpBB3/viewtopic.php?p=2248&sid=d5dc3009021f4468fe4d281558a03225 )
Have a nice Day!
Ingo
Post by: X on November 05, 2012, 09:37:24 AM
This departed SHJ but did not populate
* 76096C  SAI2150D    AP-BKL A330 Shaheen   2012/11/05 12:56:15
X
Post by: John Hargreaves on November 05, 2012, 09:42:08 AM
 X,
896368 is active again today. On ESJ445 Jeddah - Almaty - Seoul! Went through Almaty about five hours late according to their A + D boards.
John H.
Post by: X on November 05, 2012, 09:56:48 AM
He must have gone through RKT as I had him descending at 2349 last night. Must be doing Haj Flights for Muslim Koreans.
Seoul!! no wonder it's difficult to get and out of RKT northward and eastward I do not pick them up.
X
Post by: Runway 31 on November 05, 2012, 10:14:10 AM
X
AP-BKL now in d/b it wasnt known until John Hargreaves advised details at 00:30 by which time I was in the land of nod.
Post by: John Hargreaves on November 05, 2012, 01:29:00 PM
 X,
896368 has now been amended on the Almaty departures as a 1230L departure to Kimhai (can't find it!) still as ESJ445. The original pick up was at 0542z at N43.20 E076.37 at 8475ft heading 097 and descending into Almaty.
John H.
Post by: Runway 31 on November 05, 2012, 02:12:18 PM
Mikek, many thanks
Post by: X on November 05, 2012, 02:18:56 PM
Unfortunately do not know any spotters at ALA (been many times on business), we will just have to wait till 896368 lands in the sandpit where we can nail it!
X
Post by: anorak on November 05, 2012, 03:07:19 PM
G-BZAX on approach to Exeter, (from Kemble?)  any clue as to why?
Dave.
Post by: Kenny on November 05, 2012, 03:10:47 PM
Quote from: ACW367 on October 30, 2012, 07:23:33 PM
X
It was around Myanmar and central Thailand around 7 UTC today but no exact route.
Kenny
Post by: Runway 31 on November 05, 2012, 03:53:13 PM
Still some way to go yet
Post by: neroon79 on November 05, 2012, 06:22:40 PM
Evening, the unknowns from today:
3CC644 (Germany, flight id: DCCJS, D-CCJS C25C Cessna 525C CitationJet Cj4 private/unknown 525C0106 sources: airframes and http://www.laasdata.com/corpjet/corpjet-by-type.php?t=63 )
3E4605 (flight id QGA483P, so decoding error of 3E4601)
4BD180 (flight id: TWI352, decoding error 4BD182)
7C2E69 (Australia, flight id: VHJGB, may be VH-JGB E135 Embraer E135 of Jetgo on delivery)
A0B5EC (N145GS, so decoding error of A0B5EA)
A28E08 (USA, flight id: N264C, hex matches to N264BX, N264C would be hex A28E0B, maybe its a decoding error)
AA8BBE (USA MIL, this time with flight id: TROJN01)
AE0353 (USA MIL, no flight id)
AE2D67 (USA MIL, flight id: SPARTA02)
MIL List:
3E8821
3E98E7
3E98E7  JUDGE02
3E9CF2  TA43
3EA46B  JUDGE01
3EB2FB  GAF071
3F4979  GAFMED1
3F5AAF  JUGE04
3F6FB1  GAF017
3F6FB1  GAF017
3F8658  JUDGE03
3F8CA3  GAE626   KTPA-KBRY
3F8CA3  TA67
3F8CA3  TA67
3F9077  SMASH
3F9D9C  GAF018
3FABA4  GAF036
3FB10A  DEMON01
3FB4F4  GAF120
Have a nice Evening!
Ingo
Post by: Runway 31 on November 05, 2012, 07:05:52 PM
Dave,
I have G-BZAX as being prepared for Asian Express Airlines and will become EY-***
aLAN
Post by: Runway 31 on November 05, 2012, 07:24:33 PM
Hi Ingo,
Yesterday
3E3C5B D-IOBB unknown to me
43E956 M-MDHM, I have as M-MDMH, Embraer EMB 505 Phenom 300, c/n 50500116, Herrenknecht Aviation
AA8BBE was N779PC is now 07-0779 PC12
Today
7C2E69 probably but not yet on CASA register
AA8BBE suspect mil tac
AE0353 suspect mil tac
AE2D67 suspect mil tac
Thanks again
Post by: X on November 05, 2012, 07:46:17 PM
We think this miscoder is a UAEAFDF  Avanti and we will try to find out which one
* 444444  YASAT05                                                     2012/11/05 19:02:28
X
Post by: anorak on November 05, 2012, 08:32:39 PM
Well done Alan. Thanks  Dave.
Post by: Runway 31 on November 05, 2012, 08:36:25 PM
Thanks X
Post by: Skyliner on November 06, 2012, 07:32:58 AM
B-8310 P180 Freesky Aviation on delivery today GOA-HER-SSH - no serial my end
Chris
Post by: Flieger_NDS on November 06, 2012, 10:00:16 AM
Quote from: neroon79 on November 05, 2012, 06:22:40 PM
Belongs to Star Wings from Dortmund: http://www.ecacnav.com/Content.asp?PageID=128&OpNum=12246&Operator=STARWINGS+GMBH (http://www.ecacnav.com/Content.asp?PageID=128&OpNum=12246&Operator=STARWINGS+GMBH)
Never heard of them, though some regs sound familiar.
Post by: Runway 31 on November 06, 2012, 10:26:59 AM
Thanks Flieger
Post by: Runway 31 on November 06, 2012, 10:31:06 AM
Thanks Skyliner, just noted an ID request for 780930 with a flight ID of B-8310 noted over Italy
Post by: paul tricker on November 06, 2012, 11:40:11 AM
* AA8BBE  TROJN01                                                     2012/11/06 11:30:40
This code belongs to N779PC a PC12 c/n 779 operated by USAF Special Ops
Paul
Post by: Runway 31 on November 06, 2012, 12:57:40 PM
Hi Paul,
I think I gave it yesterday as now 07-0779
Post by: paul tricker on November 06, 2012, 01:07:02 PM
Ah, OK, I did look thru past posts but did not see anything & it did not populate so I thought it was new
Paul
Post by: X on November 06, 2012, 01:41:50 PM
a UK unknown and not populating climbing from 13000 to 17000
* 43C026                                                              2012/11/06 16:45:13
X
Post by: BBJUK on November 06, 2012, 01:47:24 PM
Afternoon all.
GAF A310 10+25 just landing Al Dhafra AB is using a double hex, 3F8519 and 3FB93B
Brgrds
Post by: Runway 31 on November 06, 2012, 03:26:52 PM
X
43C026 used to be ZE342 Tornado F3 which is/was WFU in 2011
Post by: Runway 31 on November 06, 2012, 03:28:40 PM
Thanks BBJUK, 2 tactical codes for the price of one.
Post by: ACW367 on November 06, 2012, 04:18:53 PM
Quote from: Runway 31 on November 06, 2012, 03:26:52 PM
X
You have RAF Typhoons exercising in the UAE at the moment for the UAE ATLC Advanced Tactical Leadership Course at Al Dhafra.
Post by: flygfantast on November 06, 2012, 05:38:32 PM
Not populating:
881C47 (Thailand), 1415 msgs received during 50mins at FL250.
Niklas
Post by: Runway 31 on November 06, 2012, 05:40:41 PM
Nothing on it Niklas, unfortunately
Post by: flygfantast on November 06, 2012, 05:47:25 PM
Quote from: Runway 31 on November 06, 2012, 05:40:41 PM
Could be HS-GBG, info from Skyliner:
 Saab 340B, c/n 457, HS-GBG, Nok Mini Airlines, N-reg canx 31oct12, delivery 05-06nov12 BGR-KEF-TBS    ex N453XJ
Niklas
Post by: neroon79 on November 06, 2012, 06:00:36 PM
3C661D (DLH9M, several airframes with this flight id, so a decoding error of the worst case)
3D070B (Germany, flight id: DEAXN, D-EAXN E300  Extra 330 LT Eichhorn Airadventures CN:? sister airframe of D-EAXK http://www.t6-team.de/ea330lt.html )
45ACF9 (Denmark, no flight id, was/is OY-KGY MD82 McDonnell Douglas MD-82 SAS [SK] SAS 49420/1254)
478018 (Norway, no flight id, nothing more)
484FE6 (Netherlands, flight id PHKLQ, PH-KLQ A210 Aquila AT01 Privte/unknown AT01-251, source: http://www.hdekker.info/registermap/MK.htm )
50342D (no allocation, no flight id, nothing more)
A569DE (USA, flight id: N448RT, N448RT C680 Cessna 680 Citation Sovereign AC:? 680-0017 latest Mk1EB: http://www.flickr.com/photos/28132040@N07/8023638465/lightbox/ )
MIL LIst:
3E8AD3  TA56
3E8AD3  TA59
3EA780  LK01A
3F7979  SW54
3F8394  GAF011
3FB27A  LK01B
Have a nice evening!
Ingo
Post by: John Hargreaves on November 06, 2012, 07:15:40 PM
 Niklas,
You are quite correct. 881C47 is HS-GBG.
John H.
Post by: neroon79 on November 07, 2012, 03:57:45 AM
Morning, some additions to yesterdays unknowns:
3C7266 (Germany, flight id: BER278A, decoding error of 3C7262)
3F7D5A (Germany MIL, flight id: SW02)
3FAEC5 (Germany MIL, flight id: SW81)
40017D (UK, no flight id, no active airframe found)
71C266 (Rep. of Korea, flight id: AAR266D, HL8266 A321 Airbus A321-231 Asiana Airlines 5350 source: http://xfw-spotter.blogspot.de/2012/10/a321-231-asiana-d-avzc-hl8266-msn-5350.html )
Have a nice Day!
Ingo
Post by: paul tricker on November 07, 2012, 09:12:20 AM
440641  OEGUN                                                       2012/11/06 13:47:14
OE-GUN is a C560XL c/n 560-5061 operator unknown to me
Paul
Post by: Runway 31 on November 07, 2012, 11:02:44 AM
Thanks Paul.  Operator unknown to me as well
Post by: Runway 31 on November 07, 2012, 11:05:37 AM
Niklas/John
Thanks re HS-GBG
Post by: Runway 31 on November 07, 2012, 12:03:04 PM
Hi Ingo,
45ACF9 was OY-KGY MD82 now with Allegiant Air for spares?, last noted engineless
478018 unknown to me
50342D unknown to me
A569DE decodes to N448RT however cancelled from the FAA register 15/10
Post by: Northern Watch on November 07, 2012, 01:57:38 PM
Good afternoon Alan
Not populating today:
A7C568 / N60FE / DHC8-311 / c/n 332 / Fayard Enterprises LLC.
Keith
Post by: BBJUK on November 07, 2012, 02:18:33 PM
Hi Alan
Ref 444444, the UAE Avantis have both been flying frequently the last few days and have used their correct codes. 444444 seems to constantly be at FL160, between Al Ain and Abu Dhabi, very slow, possibly one of the DA42's used by the Mil down here?
So no further forward on that one
Cheers BBJUK
Post by: X on November 07, 2012, 02:51:34 PM
re 700014, looks like my calculation was correct that the Safi B752 seen AUH 1/11/12  is ex Air Finland B752 OH-AFI (26330), which became EI-EXX after the carrier's demise, as it was reported as ferried from Abu Dhabi to Kabul on 1/11 for Safi A/W
Now we just need to get its new reg!
X
Post by: Runway 31 on November 07, 2012, 03:08:08 PM
Thanks Keith, ex TR-LFJ
Post by: Runway 31 on November 07, 2012, 03:08:43 PM
No problem BBJUK
Post by: Runway 31 on November 07, 2012, 03:09:02 PM
I am sure it will visit soon X
Post by: Flieger_NDS on November 07, 2012, 04:05:09 PM
Quote from: Flieger_NDS on November 02, 2012, 12:31:00 PM
I would like to come back to that one: ex N8132F, FL-772 has become RA-02800. Here's finally a not so good looking proof, weather and distance were not helping for a good shot: http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-Unbekannt-Beechcraft-B300-King-Air-350i-RA-02800-BWE-Braunschweig-Wolfsburg-9867.html (http://www.luftfahrtclubbraunschweig.de/picdb/Andreas-Unbekannt-Beechcraft-B300-King-Air-350i-RA-02800-BWE-Braunschweig-Wolfsburg-9867.html)
Post by: Runway 31 on November 07, 2012, 04:56:51 PM
Thanks Flieger, pity we dont have its hex code.  Picture good considering the weather
Post by: neroon79 on November 07, 2012, 06:06:55 PM
3C09F7 (flight id: GMI1881, decoding error of  3C09F3)
3C7265 (Germany, no flight id, nothing more)
3D9B00 (Germany, flight id: DGFGH, decoding error of 3D9BCF)
400871 (UK, no flight id, no active airframe found)
440116 (flight id: AUA375A, decoding error of 44011E)
48449A (flight id: KZR903, decoding error of 484492)
MIL List:
3EAFD8  LK01B
3F7866  TA56
3F815D  TA46
3F815D  TA48T
3F876D  GAF910
3FBC77  GAF320
QuoteThanks Flieger, pity we dont have its hex code.  Picture good considering the weather
May be the next time if it is visiting EDVE again.
Ingo
Post by: John Hargreaves on November 07, 2012, 07:29:45 PM
 X,
The Safi B752 is on SFW8026 and just gone westbound over Kish Island.
John H.
Post by: John Hargreaves on November 07, 2012, 07:33:08 PM
 Alan/all,
We have a new Ural Airlines A320 believed to be A320-214 c/n 3099 (ex JA205A) as SVR3901 hex 42429E. It originated in Shanghai, is presently refuelling in Khabarovsk, and is due out for Ekaterinburg in the next fifteen minutes. Anybody able to offer a registration please?
John H.
Post by: X on November 07, 2012, 07:34:53 PM
this did not populate but according to Airframes is the following
* A569DE   N448RT C680      680-0017                                                     2012/11/07 09:33:42
X
Post by: X on November 07, 2012, 07:45:04 PM
It looks OTT at 38000 BAH/DAM and I have already sent a request for the reg.
X
Post by: Runway 31 on November 07, 2012, 07:50:53 PM
X
N448RT was cancelled from the FAA register 15/10 hence it was deleted from the d/b.  Unknown what it is now.
aLAN
Post by: X on November 07, 2012, 08:00:40 PM
It was at 41000 so assume is miscoding old hex and on delivery somewhere
X
Post by: John Hargreaves on November 07, 2012, 08:33:26 PM
 X,
The Safi has gone OTT Riyadh at FL380 - looks like its inbound Jeddah.
John H.
Post by: X on November 08, 2012, 02:55:19 AM
John/Alan
YA-AQT  B752  Safi Airways returning Jeddah Kabul as SFW 8027 is 700014.
X
Post by: neroon79 on November 08, 2012, 03:50:26 AM
Two additional MIL Airframe to be add to yesterdays unknowns:
3F81A2 (Germany MIL, no flight id)
3F8934 (Germany MIL, flight id: SW81)
Have a nice day!
Ingo
Post by: neroon79 on November 08, 2012, 04:04:03 AM
One from today early morning:
4242A5 (UK,  flight id: DNV9803, DNV: Aeroflot-Don, VP-BIS A319 Airbus A319-112 Donavia Airlines CN:? source: http://notam-ireland.blogspot.de/ http://www.flugzeugbilder.de/show.php?id=1174747 ex OH-OVF)
Post by: X on November 08, 2012, 04:13:03 AM
Quote from: John Hargreaves on November 07, 2012, 07:33:08 PM
Alan/all,
John H.
Thanks for heads up, It will likely visit the sandpit as we get up to three Urals a day at this time of year so have got all eyes on the lookout from this Friday.
X
Post by: X on November 08, 2012, 05:12:18 AM
Another new US Mil in the area
* AE1D7B                                                              2012/11/07 17:02:03
X
Post by: John Hargreaves on November 08, 2012, 05:57:30 AM
 X,
Thanks for the Safi B752 . The new Ural landed Ekaterinburg at 0230z and the new Donavia went over the house at 0300z.
John H.
Post by: Runway 31 on November 08, 2012, 06:44:28 AM
Thanks to all for the hard work put in to identifying the Safi
Post by: Runway 31 on November 08, 2012, 06:52:19 AM
Thanks Ingo, VP-BIS c/n 1808
Post by: Runway 31 on November 08, 2012, 06:55:32 AM
X
AE1D7B 162998, Lockheed P-3C-III Orion, c/n 5805, US - Navy
Thanks again
Post by: X on November 08, 2012, 01:39:31 PM
An Egyptian unknown on a Shaheen Flight according to this hex, or a miscode?
* 010177  SAI767   OMDB-OPLA                                          2012/11/08 16:40:08
X
Post by: Runway 31 on November 08, 2012, 02:06:13 PM
Its unknown to me X
Post by: John Hargreaves on November 08, 2012, 02:07:30 PM
 The new Ural A320 using 42429E is already in service. Inbound Domodedovo as SVR266 at the moment. Anybody  have contacts in Moscow?
John H.
Post by: X on November 08, 2012, 02:21:55 PM
78003A  SXA974  B-218L Y8  Yun 8  c/n 371802  holding overhead AIN at 8,000' at the moment awaiting clearance
780039 as SXA975 B-217L Y8 is following it in.
They are being allowed to land and are night-stopping.
Nasty
X
Post by: Runway 31 on November 08, 2012, 04:06:32 PM
Thanks X, they are Chinese built AN12's Shaanxi Y-8  ICAO AN12
Post by: X on November 08, 2012, 04:16:24 PM
I think that is why there was an issue with their landing clearance as AN12's are barred and if it showed up on their radar with the ICAO type they would refuse to let them land! I was informed they had no idea what a Y8 was!
X
Post by: X on November 08, 2012, 05:33:55 PM
Pretty sure now that this is 60-0356 K35R miscoding as we know its in the area should be AE04E8.
   AE0CE8  ELITE38                                                     2012/11/08 11:04:00
   AE0CE8  ELITE38                                                     2012/11/08 14:22:41
And 8hrs later guess what
  AE04E8  ELITE62                  60-0356 K35R  US - Air Force       2012/11/08 22:11:22
Someone listening in to me?
X
Post by: neroon79 on November 08, 2012, 06:46:41 PM
000017 (no allocation, no flight id, miscoded airframe)
261567 (no allocation, no flight id, miscoded airframe or a decoding error )
38B25B (France, flight id: SYU021, SYU: Sky Unlimited (Netherlands) )
3C4E1B (flight id: DLH9LT, decoding error of 3C4E13)
3C6740 (Germany, no flight id, possible a decoding error)
48ADA4 (flight id LOT286, decoding error of 48ADA0)
4C01AC (flight id: JAT282, decoding error of 4C01AA)
MIL List
3E83DF  TA59
3F4BDC  TIGER
3F5E32  BU23T
3F770B  GAF775   EDDV-EDDF
3F7A41  GAF012
3F815D  TA24
3FBC77  GAF320
Ingo
Post by: flygfantast on November 08, 2012, 07:51:41 PM
OH-AKW (allocated 46011A) is miscoding it's former hex 3D95EC (D-GDAI).
OH-AKW, Diamond DA-42NG, c/n 42.N013, Global NG Oy
See http://www.flyfinland.fi/view/6665/
Niklas
Post by: neroon79 on November 09, 2012, 02:56:38 AM
Some additions to yesterdays unknowns:
3F791F (Germany MIL, flight id:  SHARK1 )
43E786 (UK, no flight id, no airframe with this hex at Manx Aircraft Register)
471EA0 (flight id: WZZ5EK, also in list with hex: 471EA4 and 471EA6)
4AC965 (Sweden, no flight id, nothing more)
800383 (India, no flight id, no active airframe found)
Have a nice day!
Ingo
Post by: flygfantast on November 09, 2012, 06:52:26 AM
Quote from: neroon79 on November 09, 2012, 02:56:38 AM
Decodes into SE-RKE, which is not assigned.
Niklas
Post by: X on November 09, 2012, 07:02:00 AM
Quote from: X on November 08, 2012, 01:39:31 PM
X
This was SU-MWF miscoding!
X
Post by: Runway 31 on November 09, 2012, 12:22:26 PM
Thanks X
Post by: Runway 31 on November 09, 2012, 12:26:58 PM
Hi Ingo,
38B25B doesnt decode
3C6740 doesn't decode
3E3C5B D-IOBB, still unknown
43E786 doesnt decode
4AC965 see answer from Niklas previously
800383 decodes to VT-JED now HS-TKS
Post by: Runway 31 on November 09, 2012, 12:27:12 PM
Thanks Niklas
Post by: X on November 09, 2012, 01:17:31 PM
On network AD0037 N937FR not populating and John. H's 42429E once again going to DME and not one of the four that came here today!
Also AC6B63 N9KH
X
Post by: paul tricker on November 09, 2012, 01:53:33 PM
400B53  GCCTB                                                       2012/11/09 11:44:36
This is  G-CCTB    RJ100  c/n E3234  Trident Jet Leasing (Ireland) Ltd
Paul
Post by: Runway 31 on November 09, 2012, 03:22:45 PM
Thanks Paul
Post by: Northern Watch on November 09, 2012, 04:01:51 PM
Afternoon Alan
Not populating today was:
AE0740 / F15 / Tac Code.  One site has this as 00-3003 but as you know these codes are usually used by numerous aircraft.
Keith
Post by: Runway 31 on November 09, 2012, 05:27:55 PM
Thanks for the tac code Keith.  Yes the cade changes each flight and what was identified as using it today will use another code its next flight.
The F15's have even been noted changing their code in flight and I even saw reference to 3 separate aircraft using the same code at the one time within the last couple of weeks.
They occasionally have been noted using Russian codes among others, naughty!!
Post by: Runway 31 on November 09, 2012, 05:34:59 PM
Hi X,
N937FR is an ex Frontier A319 on a flight test out of Shannon on a post maintenance shake down flight prior delivery to Brussels Airlines
AC6B63, N9KH, Bell 407GX, c/n 54341, J R Kilpatrick Aviation
Post by: Xon on November 09, 2012, 06:44:14 PM
896181 A6-EEB A388 Emirates Airlines c/n 109 [Delivery XFW-DXB UAE7380]
Post by: Runway 31 on November 09, 2012, 06:54:15 PM
Thanks Xon
Post by: flygfantast on November 09, 2012, 07:15:39 PM
Not populating:
47942D c/s RTG1016, 919 msgs
AAA714 c/s N786CT, Airbus A319-112 c/n 1786, CIT Leasing
Niklas
Post by: Kenny on November 09, 2012, 07:35:33 PM
Quote from: flygfantast on November 06, 2012, 05:47:25 PM
Niklas
Hi Niklas,
Searching for N453XJ and not sure about the c/n 457.  Found on A.net as 453 while c/n 457 is N457XJ
Post by: Runway 31 on November 09, 2012, 07:59:20 PM
Hi Niklas,
47942D, LN-RTG, Dassault Falcon 2000 c/n154, Rely AS
Post by: Runway 31 on November 09, 2012, 08:04:52 PM
N453XJ c/n 453 cancelled to Thailand 31/10.  N457XJ c/n 457 still on FAA list
HS-BGB is c/n 453
Post by: X on November 09, 2012, 08:08:28 PM
I assume no longer stored and en route for a new identity, just gone OTT at 16000 climbing out of AUH.
* A6EA91                           N545AT  AT75  WFU Stored (ex Ex... 2012/11/09 23:29:21
X
Post by: X on November 09, 2012, 09:45:53 PM
760950 Pakistan unknown descending into area
X
Post by: Runway 31 on November 09, 2012, 10:12:42 PM
X
A6EA91 N545AT to be XY-AJD for Air Kanbawza was stored in Eindhoven.  Skyliner shows it on delivery 09-11nov12 BLL-TZX-AAN-NAG-RGN, N-reg
760950 decodes to AP-BJP but nothing on it yet
Post by: neroon79 on November 10, 2012, 06:17:30 AM
150779 (Russian Federation, flight id: RA67433, RA-67433 is hex 150769, so a decoding error)
261575 (no allocation, no flight id, whether a decoding error or a miscoded airframe)
3D4169 (Germany, flight id: DEXAF, D-EXAF E300 Extra E330LC Private 1313 sources/Mk1EBs: http://www.skrzydla.org/showphoto.php?photo_id=99980&cd=5398f61e583eee75659425f7b3c7e775  and http://www.airplane-pictures.net/photo/223417/d-exaf-private-extra-330lc/ )
3F8D3F (Germany MIL, flight id:  NOBLE01)
3FF1AD (Germany, no flight id, only two messages received)
42414B (UK, flight id: VPCDE, VP-CDE no details about the new one)
46A066 (flight id: QTR078, decoding error, several hex with this flight id in the list)
471EA2 (Hungary, no flight id, nothing more)
471F41 (flight id: WZZ9LG, decoding error of 471F49)
8961AA (UAE, no flight id, was A6-RJH LJ35 until 2009)
Have a nice weekend!
Ingo
Post by: Northern Watch on November 10, 2012, 05:45:31 PM
Evening Alan
On the move today EBBR - BIKF was Ex-Brussels Airlines / B734 / OO-VES / 44D8B3 which has stored/WFU in the details.
This I take it is on its way to the USA to become A61B40 / N493AC / Aircastle.
Keith
Post by: Runway 31 on November 10, 2012, 05:52:58 PM
Yes Keith, correct
Post by: Runway 31 on November 10, 2012, 06:18:43 PM
Hi Ingo,
3FF1AD unknown to me
42414B VP-CDE, nothing known yet
8961AA was A6-RJH LJ35 now unknown Greek
Have a good weekend
Post by: RodBearden on November 11, 2012, 01:28:03 AM
Hi Alan
Seen on the network over Bangkok:
70801A reg RDPL-34189 i/d LCA065
So not WFU any more
Post by: RodBearden on November 11, 2012, 01:46:43 AM
Not populating over Spain:
39E00D i/d BIE1985
Post by: neroon79 on November 11, 2012, 05:48:58 AM
Morning Alan, the unknowns from Saturday:
342607 (Spain, flight id: FTL3151, already added and populated)
3C486F (flight id: BER2664, decoding error of 3C496D)
3D5095 (Germany, flight id: DFCTP, D-FCTP PA46 Piper PA-46-500TP Meridian Private 4697070 ex D-ECTP/D-ESSS/D-FOXI source: http://www.laasdata.com/turbos/turbo-by-country.php?c=D , Mk1EB: http://www.flickr.com/photos/denis60/7233394590/ and http://jetphotos.net/viewphoto.php?id=7471783&nseq=73)
42414B (UK, flight id: VPCDE, received again)
4401FA (flight id: VJS644, decoding error of 4401FE)
445566 (Austria, no flight id, no luck with details)
471F5C (Hungary, no flight id, nothing more)
484167 (flight id: KLM1972, decoding error of 484163)
8A0374 (Indonesia, flight ids: 13:50 with 001, 14:05 with PLGLK, 14:06 with PKGLK / already added and populated. Seems, that the id was added while the bird was already airborne)
Wish you a nice Sunday!
Ingo
Post by: flygfantast on November 11, 2012, 08:41:51 AM
Not populating 8A0388.
8A0388 PK-GRE, Bombardier CRJ-1000, c/n 19029, Garuda Indonesia (courtesy of paul @ mode-s group)
Niklas
Post by: X on November 11, 2012, 09:18:42 AM
Quote from: X on November 09, 2012, 09:45:53 PM
X
760950 AP-BJP should be Shaheen International B734-4H6 c/n 27167
X
Post by: Runway 31 on November 11, 2012, 11:06:58 AM
Thanks X, its ex N109PR cancelled from FAA 24/10
Post by: Runway 31 on November 11, 2012, 11:13:52 AM
Rod,
39E00D decodes to F-HYAN, not allocated so would appear to be one of the BIE fleet miscoding
Post by: Runway 31 on November 11, 2012, 11:19:12 AM
Thanks Niklas, the report is being queried re hex but it def used 8A0388.
Post by: Runway 31 on November 11, 2012, 11:57:16 AM
Hi Ingo,
445566 unknown to me
42414B VP-CDE, Raytheon Hawker 800XP, c/n 258755, received my weekly d/b update over night
Most Airbus deliveries are added on departure of their delivery flight and Boeing shortly after their first flight
Post by: John Hargreaves on November 12, 2012, 12:18:41 AM
 Rod/Alan,
39E00D is F-GYAN A321-211 c/n 535 of Air Mediterranee miscoding. Should be sending 39600D.
Cheers,
John H.
Post by: neroon79 on November 12, 2012, 04:01:04 AM
Morning, unknowns from Sunday
3FEB95 (Germany, flight id: DMRZA, still no luck with the details)
3FEFE9 (Germany, flight id: DMDDO, still no luck with the details)
40047C (UK, no flight id, nothing more)
44067E (Austria, with flight id: BER289K, BER382V and BER476V, must be a new one or one out of storage or one that changed the owner or...)
45AA91 (Denmark, no flight id, nothing more, maybe a decoding error )
A4CB6B (USA, no flight id, would match to N408LZ, but nothing about this reg. So must be a miscode or more likely another decoding error.)
Have a nice day and a good start into the new week!
Ingo
Post by: Runway 31 on November 12, 2012, 08:05:27 AM
Cheers John
Post by: Runway 31 on November 12, 2012, 08:32:23 AM
Hi Ingo,
3FEB95 D-MRZA, still unknown to me
3FEFE9 D-MDDO, still unknown to me
40047C decodes to G-OBML now PK-MDQ
44067E OE-LOB, Airbus A319-112, c/n 3447, Niki
45AA91 decodes to OY-JTQ unknown to me
A4CB6B (N408LZ, not assigned and nothing previous
Have a good one
Post by: diddyboy on November 12, 2012, 01:54:20 PM
Hi Alan
1 x Unknown Saudi Hex Code here in Darfur.
* 711500                                                              2012/11/12 11:48:51
* 711500                                                              2012/11/12 14:55:00
and 1 x amendment
51404E   ST-MRA Boeing 737-5C9 c/n 26439 ex 4L-AJA Marsland Aviation.
Neil
Post by: X on November 12, 2012, 02:18:02 PM
This Diamond is around again using his Austrian reg as f/n
440206  OEUDO                                                       2012/11/12 16:52:30
X
Post by: Runway 31 on November 12, 2012, 03:39:55 PM
X
OE-UDO is a Diamond test/delivery reg and there have been around a dozen DA42's using it so far.
My bet would be c/n 42.M014 an unknown UAE - Air Force example
Post by: Runway 31 on November 12, 2012, 03:44:35 PM
Hi Neil,
711500 unknown to me and amendment made for ST-MRA
Post by: neroon79 on November 12, 2012, 06:39:30 PM
3004BF (Italy, no flight id, nothing more)
38B23B (France, flight id: SYU022, SYU: Sky Unlimited, nothing more)
3C630E (flight id: BER515, decoding error of 3C630A)
4B16BF (flight id: SWR1211, several other hex addresses with this flight id, so another decoding error)
MIL List:
3E9A9C  NITRO4
3EADC5  MISTY
3EBC77  POISON1
3F530D  GAF710
3F7866  GAF041
3F7D72  NITRO3
3F8FE5  GAF066
3FADF7  GAF911
Ingo
Post by: Runway 31 on November 12, 2012, 06:44:32 PM
Hi Ingo,
3004BF unknown to me
38B23B does not decode
Thanks again
Post by: neroon79 on November 13, 2012, 03:51:25 AM
Morning, two additions:
3C6125 (Germany, no flight id, was D-AHIE a B737 of HHI Hamburg International until 2008, nothing about a new one)
3EBF90 (Germany MIL, no flight id)
Have a nice day!
Ingo
Post by: X on November 13, 2012, 06:30:32 AM
At constant 1500 for six minutes (Chopper?). N264BX has nothing for it on the FAA website.
* A28E08                                                              2012/11/13 10:20:45
X
Post by: X on November 13, 2012, 06:36:38 AM
This decodes to RA-76489 IL76 at one time with Airline 400, Russian Sky, has Air Bridge c/s.
* 152AC9  ABG9360                                                     2012/11/13 10:32:14
X
Post by: X on November 13, 2012, 01:34:49 PM
60083C                           UR-CGX  AN12  Shovkoviy Shlyah ... 2012/11/13 17:23:55
This is NOT UR-CGX An12, just gone over my villa at 10000, it is a white Il76 with grey belly and engines and a logo on the tail. Not close enough to read off but from logo we think it is Silk Way 4K-AZ60 IL76 00934 99982.
4K-AZ60(1) An12 became UR-CGX, 4K-AZ60(2) is an IL76. So reuse of hex and reg.
X
Title: Re: Database Update Requests
Post by: Chris11 on November 13, 2012, 03:19:29 PM
00817D ZS-AOA H25B British Aerospce BAe-125-800A   Netcare 911 (Pty) Ltd   258160
Post by: Runway 31 on November 13, 2012, 04:12:27 PM
X
60083C, 4K-AZ60, Ilyushin IL-76TD, c/n 0093499982, Silk Way Airlines
152AC9, RA-76489, Ilyushin Il-76TD, c/n 0083485554, I have with Russian Sky
Nothin on your chopper
Post by: Runway 31 on November 13, 2012, 04:15:36 PM
Thanks Chris
Post by: Runway 31 on November 13, 2012, 05:48:58 PM
Thanks Ingo
Post by: neroon79 on November 13, 2012, 06:07:23 PM
0000CA (no allocation, no flight id, miscoded mil airframe would be my first guess)
3C5425 (Germany, flight id: DAEAE, another frighter of EAT: D-AEAE Airbus A306 A300B4-622R(F) EAT Lepizig 753 source: http://www.flightradar24.com/data/airplanes/d-aeae )
3C661C (Germany, no flight id, nothing more -last time it was a decoding error. Good chance, that it is one again)
3FF19B (Germany, flight id: DMCBP, still no luck with the details)
3FF1C9 (Germany, flight id: DMKKY, no luck with the details)
440684 (Austria, flight id: OEKAP, OE-KAP PA46  Piper PA-46-350P Malibu Mirage Private  4636003, surce & Mk1EB: http://www.flugzeugbilder.de/show.php?id=1125373 )
48415B (Netherlands, no flight id, decodes PH-DMK, but nothing about an active airframe with this reg)
A651AD (flight id N506QS, decoding error of A651A9)
AE2D46 (USA, flight id: DEVIL02, so MIL airframe)
E203CA (Argentina, flight id: GDT212, GDT: as far as i know not assigned )
MIL List:
3E84D6  GAF120
3E877E
3EB04C  APEX1
3EBB95
3EBC71
3F4B42
3FAAFC  GAF767
Ingo
Post by: paul tricker on November 13, 2012, 07:07:26 PM
Picked up over the sandpit....
* 8880AF                                                              2012/11/13 22:46:50
A320-214     4190          VN-A689     VietJet     delivery 13-14nov12 ATH-BOM-HAN
info from Skyliner
Paul
Post by: John Hargreaves on November 13, 2012, 07:15:52 PM
 Alan / X,
We have two aircraft sending out 60083C. An12 UR-CGX visited EMA on 19 Oct as SWW2109, and departed the next day as SWW2110. Miscoded hex 60083C was used on both occasions.
John H.
Post by: X on November 13, 2012, 07:38:46 PM
John/Alan
Thanks that would explain it being in the db as UR-CGX AN12.
We were scratching our heads over this aircraft out here in the sandpit as AN12's are banned out here and when both SBS and Airnav users were showing it as a AN12 at first we thought it must be on Mil flights ex NHD, However today when we had a Silk Way Il76 going over we realised there was an issue.
Alan, I think you have an unusual problem on how to handle this one as UR-CGX is obviously miscoding its old hex of 4K-AZ60(1) to the UK. With UR-CGX obviously still flying 100 of UK spotters will be chasing you stating you are wrong if an IL76 is reported and an An12 turns up, and with Various you will be hounded as well asking what it is or being told it is an AN12......can you put Various and either UR-CGX or 4K-AZ60(2) in the operator box?
Just like yesterday VP-CCD LJ took off today still pretending to be VP-CET 4241AD!
X
Post by: Runway 31 on November 13, 2012, 09:51:30 PM
Hi Ingo,
0000CA would agree probable mil
3C5425 D-AEAE Airbus A306 A300B4-622R(F) EAT Lepizig 753
3C661C doesnt decode
3FF19B D-MCBP, unknown to me
3FF1C9 D-MKKY, unknown to me
48415B PH-DMK, unknown to me
E203CA unknown to me
Post by: Runway 31 on November 13, 2012, 09:52:44 PM
X/John
No bother will put 60083C as being used by more than one aircraft with the registrations in the CO field as is usual in this case.
Post by: neroon79 on November 14, 2012, 03:27:29 AM
Morning, some additions to yestwerdays unknowns:
3C4B1E (Germany, no flight id, nothing more, maybe another decoding error)
46427F (Finland, flight id: OHZET, decodes to OH-ZET, so there is an airframe with this reg/hex. But unfortunately no luck with the details.)
Have a nice day!
Ingo
Post by: X on November 14, 2012, 05:50:49 AM
My miscoder A28E08 (N264BX) from yesterday was eyeballed and appears to be N264C F900 departing going to 29,000 using N264C in f/n box. Obviously miscoding as it should be A28E0B.
A28E08  N264C                                                       2012/11/14 08:11:56
X
Post by: M on November 14, 2012, 05:53:32 AM
Quote from: neroon79 on November 14, 2012, 03:27:29 AM
OH-ZET PRM1 RB-120 Airfix Aviation (ex D-IBBN)
Post by: Runway 31 on November 14, 2012, 11:39:54 AM
Ingo/M
Thanks for info on OH-ZET
3C4B1E doesnt decode
Post by: Runway 31 on November 14, 2012, 11:42:15 AM
Thanks X
Post by: X on November 14, 2012, 04:13:00 PM
   780024                           B-2818  B752  China Southern Ai... 2012/11/14 12:32:45
This is now UP-B5703 B752 SCAT Airlines miscoding old Chinese hex
X
Post by: X on November 14, 2012, 04:24:39 PM
* 8A037A                           PK-CLR  B738  Indonesia Air Asia   2012/11/14 17:15:42
Populated as Indonesia AirAsia should be Sriwijaya Air, the Indonesia AirAsia is PK-AXY an A320 due SHJ at 2200
X
Post by: X on November 14, 2012, 04:29:55 PM
This was a biz of some description landing at sandpit...possibly may be UP-EM010 ERJ delivered last week for Comlux but needs confirming.
* 6831E0                                                              2012/11/14 17:04:28
X
Post by: Bob SEN on November 14, 2012, 04:37:35 PM
Evening Alan
Just touched down at SEN is C-FRNC Beech 1900 UE-316  North Cariboo Air, using its old hex 00A96E (ZS-PRH)
cheers
Bob
Post by: paul tricker on November 14, 2012, 04:38:44 PM
A few more ground stations at DXB...
  896E87
  896E9B  ATC1
  896EB6  SWP4
Paul
Post by: Runway 31 on November 14, 2012, 04:47:09 PM
Correct Paul, PK-CLR amended
Post by: X on November 14, 2012, 04:55:44 PM
50FF5F unknown was picked up today probably en route FJR from descent pattern
X
Post by: Runway 31 on November 14, 2012, 05:18:52 PM
Cheers Bob, its already in the d/b under its correct hex, might have known it woulduse its old hex on delivery.
Post by: Runway 31 on November 14, 2012, 05:20:40 PM
Dont know that miscode X
Cant find anything on 6831E0
Post by: Runway 31 on November 14, 2012, 05:27:35 PM
Thanks for the ground transmitters Paul
Post by: X on November 14, 2012, 05:39:17 PM
Is this the miscode you refer to, Boeing 757 serial 25259 / 392 registration UP-B5703 (ex B-2818 ) delivered Almaty late September with photos or is it unknown 50FF5F.
X
Post by: Runway 31 on November 14, 2012, 06:12:32 PM
Sorry X, 50FF5F is the unknown miscode I was referring too
Post by: neroon79 on November 14, 2012, 06:15:06 PM
200000 (no allocation, flight id: PTO110, the PTO Pilot Training Network again...)
39155C (France, no flight id, no luck with the details)
3C4B1E (flight id: DLH7HP, decoding error of 3C4B1A)
3CC12B (Germany, no flight id, nothing more)
3D2CAC (Germany, flight id: DEPEA, D-EPEA SR22 Cirrus SR-22 G2 Private CN:? Source & MK1EB: http://www.flugzeugforum.de/flugbetrieb-osnabrueck-atterheide-edwo-2012-a-68577-26.html )
3FF1C9 (Germany, flight id: DMKKY, received again)
4CA240 (flight id: RYR2285, decoding error of 4CA244)
4CA772 (flight id: EIN665, decoding error of 4CA770)
506E5B (Slovenia, no flight id, nothing more)
MIL List:
3E9E16
3EA24B  SMOKE1
3F4333  TA68
3F8330  COBRA1
3F9ECE  GAF018
3F9ECE  GAF018
3F9FD4  COBRA2
Ingo
Post by: paul tricker on November 14, 2012, 07:33:44 PM
* 80072B  JAI9032                  VT-JFE  B738  Jet Airways          2012/11/14 23:23:20
just came up on my box, but on X's it says VT-JFD!!
Which is correct? We thought we were running the same d/b update
Paul
Sorted! Looks like an initial error in Seattle. T'was VT-JFD that went over
Paul
Post by: Runway 31 on November 14, 2012, 08:37:41 PM
Paul,
It was considered to be D until it got to Brussels on its dwelivery flight when it was found to be E.  D/b updated earlier when details posted on mode-s.
Post by: Runway 31 on November 14, 2012, 08:44:20 PM
Hi Ingo,
200000 unknown miscode
3CC12B decodes to D-CALN unknown to me
3D2CAC D-EPEA SR22 Cirrus SR-22 G2 c/n 1025
3FF1C9 D-MKKY, still unknown
506E5B unknown to me
Thanks again
Post by: neroon79 on November 15, 2012, 03:40:59 AM
Morning, one addition to yesterdays list:
ADF54C (USA, no flight id, would match to N999NP, nothing about an active airframe using this reg.)
Have a nice Day
Ingo
Post by: Runway 31 on November 15, 2012, 07:27:39 AM
Hi Ingo,
Agreed ADF54C decodes to N999NP, not assigned and only previous I can find is now N868AC
Post by: Flieger_NDS on November 15, 2012, 08:27:21 AM
Yesterday I picked up 3C83D3, flight-ID DBFTN, on ground at MUC. Does anybody have any info on that?
Post by: John Hargreaves on November 15, 2012, 08:38:06 AM
Alan,
JAI9032 80072B is VT-JFD. We have photographic evidence of it at BRU!
John H.
Post by: Runway 31 on November 15, 2012, 09:51:11 AM
Thanks John,
Doh!!  I meant to say above it was thought to be E until it got to Brussels and then was found to be D.
At least I made the correct change to the d/b and X picked it up as VT-JFD in Dubai
Doing too many things at the same time.
Post by: Runway 31 on November 15, 2012, 09:54:42 AM
Nothing available on 3C83D3 D-BFTN.
Post by: Hawkeye on November 15, 2012, 02:41:26 PM
Afternoon Alan,
AC1E28 on the box with no details. Would appear to be N880DH which is currently on 133.80
Syd
Post by: Runway 31 on November 15, 2012, 02:55:21 PM
Hi Syd,
AC1E28 N880DH, De Havilland Canada DHC-8-102 Dash 8, c/n 206, Fayard Enterprises, en-route Gabon-USA
Post by: X on November 15, 2012, 07:00:57 PM
50FF5F is most likely to be ER-IBA white IL76 with grey u/s and HUGE black registration seen at SHJ and was noted later departing
Miscode 288037 landed at same time (0840L) as EW-343TH IL76 basic white at SHJ and was seen departing as 288037 IL76
600BBF  4K-AZ11 Azerbaijan Airlines was at DXB ex VP-BBR on first visit and named Garabagh (as discussed on push back)
JA07JJ A320 Jetstar Japan arrived 2048, thanks for the tip off
X
Post by: Runway 31 on November 15, 2012, 07:18:03 PM
Cheers X
Post by: paul tricker on November 15, 2012, 08:22:33 PM
One more ground transmitter out here in Dubai...
896E98  SIG4
Paul
Post by: Runway 31 on November 15, 2012, 09:33:57 PM
Cheers Paul
Post by: X on November 15, 2012, 09:48:12 PM
HZ-AK16 B773 Saudi populated in db without me picking it up....the new system coming into play or possibly on network which I rarely use due internet connection issues?
X
Post by: Runway 31 on November 15, 2012, 10:14:02 PM
X
It will be on the network.  I added it to the d/b yesterday after its first flight on Tuesday or Wednesday.
Post by: Runway 31 on November 15, 2012, 10:15:57 PM
I will be leaving Spain to go back to Scotland first thing tomorrow morning so other than the odd occasion when I will get internet access I will be off line until Monday morning
Post by: X on November 16, 2012, 03:29:10 AM
EW-343TH is ex 4L-SKY (0053464934), info thanks to Soviet Transports.
X
Post by: ACW367 on November 16, 2012, 04:25:25 AM
Thank you X
Post by: paul tricker on November 17, 2012, 08:00:13 AM
Alan/Alan's Deputy
* 4CAA39  N353AS                                                      2012/11/17 02:21:10
N353AS was B737-484  25313/2109  stored BBU, but I guess it is now EI-??? with a new operator.
Any ideas???
Paul
Post by: orkney on November 17, 2012, 12:02:08 PM
Hello Paul
I am sorry but I can't find anything yet about his new Irish identity.
Thank you
Andrew
Post by: X on November 17, 2012, 12:16:38 PM
Alan/Andrew
8002DD thought to be K2901 IL76 of Indian Air Force has just gone OTT sandpit
Seen Muscat 1994 pre box days!!
X
Post by: orkney on November 17, 2012, 01:45:21 PM
Hello X
Many thanks for that one. It is in now.
Andrew
Post by: X on November 17, 2012, 01:51:01 PM
 Alan/Andrew
This is ex D-COMO Lear Jet reregistered in sandpit and departing
* 4241DB  VPCOO                                                       2012/11/17 17:46:33
X
Post by: ACW367 on November 17, 2012, 02:20:35 PM
4241DB  VPCOO
Thank you X
Post by: Flieger_NDS on November 17, 2012, 02:41:45 PM
Quote from: neroon79 on October 10, 2012, 03:02:16 AM
3CBC49 (Germany, flight id: DBOBI, no 100% solid details found. May be a Cirrus)
Solved: Falcon 2000LX, cn 246 from BASF (they also have D-BAMM and D-BEKY in their fleet)
Post by: Runway 31 on November 17, 2012, 05:07:20 PM
Thanks Flieger
Post by: X on November 17, 2012, 05:43:25 PM
Today this miscoder was a lumps and bumps Beech 300 N512DC belonging to that 'L3' mob (Men in B****)
  053977  ALLIED 1                 VARIOUS N/A   Miscoded Transpon... 2012/11/17 11:35:00
X
Post by: John Hargreaves on November 17, 2012, 07:09:36 PM
 Paul,
N353AS is technically a miscode. N353AS is still current with FAA. The hecode 4CAA39 relates to a lease dating back to Spring which fell through. It was supposedly ferrying to Muscat but has now turned up in Bangkok!
Cheers,
John H.
Post by: paul tricker on November 17, 2012, 07:59:00 PM
John H
"N353AS is technically a miscode. N353AS is still current with FAA. The hecode 4CAA39 relates to a lease dating back to Spring which fell through. It was supposedly ferrying to Muscat but has now turned up in Bangkok!"
Many thanks for the up-date
Paul
Post by: ACW367 on November 17, 2012, 08:24:47 PM
Thanks John
Post by: mikek on November 17, 2012, 09:11:28 PM
C82030, ZK-PGA, Cessna 525C, 525C-0112, Pacific Jets Limited.
Mike
Post by: X on November 18, 2012, 09:01:26 AM
ET-APM is entered twice in db, one spelt Airnines and also as 04005E, with same c/n but different line no. This is what it came in as yesterday (only delivered about three days ago).
* 04005D  ETH603   OMDB-HAAB       ET-APM  B738  Ethiopian Airnines   2012/11/17 19:04:34
I believe 04005E should be ET-APO delivered 2/11/12 c/n 40963/4231 and picked up and seen 7/11/12 and that ET-APM should be 40962/4250.
X
Post by: EK01 on November 18, 2012, 12:51:29 PM
Alan,
Once you're up and running again, Iberia Express would appear to now be operating EC-JFH/G c/ns 2104 and 2143 both ex Vueling Airlines.
Post by: orkney on November 18, 2012, 01:22:04 PM
Hello Mike,X and Ian
Many thanks for them, The have all now been attended to.
Thank you
Andrew
Post by: Blueboy on November 18, 2012, 03:11:11 PM
Hi Alan, picking up HEX 4D00D0 with flight ID LGL1 - I'm taking it its Luxair Dash-8 LX-LGM on delivery.
J.D
Post by: Runway 31 on November 18, 2012, 06:30:57 PM
JD
You are correct
Post by: Runway 31 on November 18, 2012, 06:41:39 PM
Thanks X, 053977 passed through Prestwick 3 or 4 days ago and was added to be then
Post by: X on November 19, 2012, 04:19:44 PM
A request from mate in Far East on 880964 B767
X
Post by: Runway 31 on November 19, 2012, 04:47:39 PM
X
880964 HS-BKD, Boeing 767-346, c/n 23962/193, Orient Thai Airlines
Post by: Chris11 on November 19, 2012, 05:37:07 PM
00B210 ZS-SYH BD700 Global 6000   Anglo American cn9470  (EX C-GSDU) (EX C-FHYL)
Post by: Runway 31 on November 19, 2012, 06:07:10 PM
Thanks again Chris
Post by: Blueboy on November 19, 2012, 07:02:34 PM
Hi Alan, picking up HEX C04D44 - which decodes as C-GDGT - B738  ex.D-AXLE on lease to Canjet
J.D
Post by: Runway 31 on November 19, 2012, 07:24:13 PM
Thanks JD
Post by: Chris11 on November 20, 2012, 08:53:54 AM
ZS-CCL   008598 new owner = B2FMS Partnership
Post by: X on November 20, 2012, 12:01:00 PM
Started at f/l 340 descending to f/l 132 730548 decodes to EP-AJH A320-233 Meraj Airlines c/n 1300
X
Post by: Runway 31 on November 20, 2012, 12:30:55 PM
Thanks Chris
Post by: Runway 31 on November 20, 2012, 12:33:03 PM
Thanks X
Post by: Northern Watch on November 20, 2012, 02:31:48 PM
Good Afternoon Alan
484FDD at f/l 260 with a message count of 94. no other information I am afraid.
Keith
Post by: Runway 31 on November 20, 2012, 02:49:56 PM
Hi Keith,
484FDD PH-ZDE, Fokker 50, c/n 20193, Aircraft Financing and Trading
Thanks again
Post by: Kenny on November 20, 2012, 02:59:14 PM
I've got 773645  of Sri Lanka using callsign MLR322 right now.
Post by: hugh on November 20, 2012, 03:47:04 PM
Route update EZY8616 EGNT-LEAL not LEMG-EGKK
Hugh
Post by: Runway 31 on November 20, 2012, 04:30:54 PM
Hi Kenny,
I cannot find anything on 773645, JohnHargreaves has queried in mode-s
Post by: Runway 31 on November 20, 2012, 04:35:06 PM
Thanks Hugh, guess this is a change for the winter season, all the usual sites have it LEMG-EGKK
Post by: John Hargreaves on November 20, 2012, 07:40:28 PM
 Alan,
773645 is expected to be a new Mihin Lanka on its delivery flight with the registration 4R-MRE. A likely candidate is A321-232 c/n 2933 ex Kingfisher which has been in storage at Subang.
John H.
Post by: X on November 20, 2012, 09:22:48 PM
Alan/John
My friends were at Subang today and trust he can confirm 773645 as John states...if not we will get it in sandpit very soon.
X
Post by: Runway 31 on November 20, 2012, 10:30:57 PM
Thanks for the info John and X hope your friend is able to confirm
Post by: mikek on November 21, 2012, 05:29:36 AM
Route correction:
UAE 434: OMDB-YBBN-NZAA
UAE 435: NZAA-YBBN-OMDB
Both currently aren't displaying via Brisbane.
Let me know if any of these become too painful and I'll stop!
Mike
Post by: mikek on November 21, 2012, 06:22:04 AM
Another route:
CAL051: RCTP-YSSY-NZAA
CAL052: NZAA-YSSY-RCTP
Flight now extends to Auckland instead of terminating in Sydney.
Mike
Post by: mikek on November 21, 2012, 08:04:21 AM
And another..
JST278: NZWN-NZAA
JST279: NZAA-NZWN
Both had NZQN listed instead of NZWN.
Post by: X on November 21, 2012, 08:06:41 AM
A6-111 AW139 is on route to sandpit for Dubai Air Wing (from Italy via LGKR). Possibly it will go DU-111 when it gets here. Will notify you what hex/reg is once it is flying.
X
Post by: X on November 21, 2012, 08:29:02 AM
This Argentinian was picked up at 2900, could this be another ex Aussie pig going to LV land via DWC?
* E0364F                                                              2012/11/21 11:06:26
And a new Tajik, but type unknown as yet. Might decode to EY-590.
* 51524E                                                              2012/11/21 12:14:10
X
Post by: Runway 31 on November 21, 2012, 09:33:27 AM
I am unable to find anything on those X.  Every possibility that its an ex Aussie 737 and the Tajik doesnt decode
Post by: Northern Watch on November 21, 2012, 09:56:36 AM
Morning Alan
Two noted leaving Hamburg this morning on delivery:
A66E7A / A320-233 / c/n 5322 / N513VL / operator Volaris
0D072F / A320 for Interjet ?
Keith
Post by: Runway 31 on November 21, 2012, 11:40:37 AM
Hi Keith
0D072F XA-BAV, Airbus A320-214, c/n 5372, InterJet
Also on delivery
A6C6CB N536AV, Airbus A320-214, c/n 5360, Avianca
Post by: Runway 31 on November 21, 2012, 11:52:57 AM
X
E0364F LV-CYO, Boeing 737-7Q8, c/n 30633/1220, Aerolineas Argentinas ex N381LF
Thanks to Pual on mode-s
Post by: anorak on November 21, 2012, 01:45:09 PM
4E2417 / speed52 tactical code?
No other info,   Dave.
Post by: Runway 31 on November 21, 2012, 02:25:57 PM
Looks like a tactical code Dave, no country code
Post by: mikek on November 21, 2012, 06:11:42 PM
Route Update:
VOZ187: NZAA-YBBN
Mike
Post by: Runway 31 on November 21, 2012, 06:21:42 PM
Cheers Mike
Post by: mikek on November 21, 2012, 06:22:17 PM
And another:
JST299: NZAA-NZQN (not NZDN)
Post by: Runway 31 on November 21, 2012, 06:29:55 PM
Thanks again Mike
Post by: X on November 21, 2012, 06:58:34 PM
Our unknown Tajik left 8hrs later on a Nasair f/n
* 51524E  KNE502                                                 2012/11/21 20:29:17
Two possibilities, first it is a new aircraft or second it is 51526E EY-622 A320 miscoding which has operated this flight regularly this month.
X
Post by: Runway 31 on November 21, 2012, 07:23:11 PM
X
51526E is EY-622 not far off 51524E so a miscode is possible
Post by: Xon on November 22, 2012, 01:40:15 PM
489D0C SP-HIM EC35 c/n 0753 (new hex, previous 3DDD78)
6831DC UP-P1003 PRM1 c/n RB-287
Post by: Runway 31 on November 22, 2012, 02:04:44 PM
Thanks for those Xon
Post by: paul tricker on November 22, 2012, 03:38:26 PM
A few more ground transmitters from Abu Dhabi
    896E12  TTS2                                                        2012/11/22 15:48:18
* 896E13  TTS1                                                        2012/11/22 15:34:05
* 896E14  TTA3                                                        2012/11/22 15:36:27
* 896E14  TTS2                                                        2012/11/22 15:50:42
Paul
Post by: paul tricker on November 22, 2012, 03:47:55 PM
more ground transmitters...
896E2B                                                              2012/11/22 15:43:39
896E2E                                                              2012/11/22 15:37:32
896E2F                                                              2012/11/22 15:41:45
finally, two German Tactical codes (I assume)
* 3F54EA                                                              2012/11/22 14:25:37
* 3F8D99  GAFK32                                                2012/11/22 14:25:38
Paul
Post by: Runway 31 on November 22, 2012, 04:58:52 PM
Many thanks for those Paul
Post by: flygfantast on November 22, 2012, 04:59:40 PM
4AC8B8 SE-REX, Boeing 737-76N, c/n 33418/1226, Scandinavian Airlines (ex N286CS)
Niklas
Post by: Runway 31 on November 22, 2012, 05:06:24 PM
Thanks Niklas
Post by: X on November 23, 2012, 05:54:07 AM
I'd better check this one out, rereg or pilot having a bit of fun with the c/s!
   43E88C  MACHO                    M-HNOY  CL60  Merhav Aviation      2012/11/22 14:55:24
   43E88C  MACHO                    M-HNOY  CL60  Merhav Aviation      2012/11/22 22:31:39
X
Post by: mikek on November 23, 2012, 06:17:01 AM
route update:
UAE407: NZAA-YMML-OMDB
Has been correct with the whole route up until now, but today seems to have dropped the OMDB part.
The inbound to NZ leg (UAE 406) was good.
Mike
Post by: mikek on November 23, 2012, 07:23:52 AM
JST281 NZAA-NZWN (Not NZAA-NZQN)
Mike
Post by: Runway 31 on November 23, 2012, 09:11:45 AM
Thanks Mike, both now corrected in the d/b.  UAE407 was showing NZAA-YMML as you stated.  These will be added to the server later tonight.
Post by: jim_stockwell on November 23, 2012, 01:55:45 PM
Good afternoon Alan
Not populating 3B772A
Jim
Post by: Runway 31 on November 23, 2012, 03:18:08 PM
Hi Jim
3B772A 096 Embraer EMB 121A Xingu c/n 096, France - Air Force
Post by: jim_stockwell on November 23, 2012, 03:27:59 PM
Hi Alan
Another not populating is C0590F
Jim
Post by: Runway 31 on November 23, 2012, 04:06:47 PM
Hi Jim,
C0590F C-GHSW, Bombardier BD-700-1A10 Global Express XRS, c/n 9220, Skyservice Business Aviation ex P4-CBA possibly on delivery
Post by: paul tricker on November 23, 2012, 04:25:47 PM
Yet more ground transmitters in Dubai...
* 896E9E  ATC1                                                        2012/11/23 16:20:26
* 896EBA  ELC5                                                        2012/11/23 10:39:14
who knows, I might have some aircraft to report one day!!
Paul
Post by: Runway 31 on November 23, 2012, 04:35:46 PM
Cheers Paul, you never know!!
Post by: flygfantast on November 23, 2012, 05:44:07 PM
Not populating:
04005E ET-APO, Boeing 737-860/W, c/n 40963/4231, Ethiopian Airlines
4CC48D (Iceland)
3D687B D-FLUX, Socata TBM850, c/n 569
Route update:
ETH714  ADD-CAI-ARN
ETH715  ARN-CAI-ADD
Niklas
Post by: Runway 31 on November 23, 2012, 07:08:15 PM
Hi Niklas,
Many thanks or those.  I dont however have anything on 4CC48D
Post by: Kenny on November 23, 2012, 07:52:52 PM
Update
440204 HS-MPP ex OE-UDR DA42 c/n 42.MN021 Asian Aerospace Services Ltd
4401AD HS-TCB ex OE-UDX DA42 c/n 42.197 Civil Aviation Training Center
440379 HS-TPQ ex OE-UDH DA42 c/n 42.407 Civil Aviation Training Center
44019F HS-TPL ex OE-VPW, OE-UHK  c/n 42.311 Civil Aviation Training Center
440371 HS-TPU ex OE-VDS DA40 c/n D4.366 Civil Aviation Training Center
4400A7 HS-TPN DA40 c/n D4.327 Civil Aviation Training Center
A12420 HS-BAP ex N1728W, HS-CMD Cessna 172S c/n 172S10619    AC Aviation Co. Ltd
Post by: Hawkeye on November 23, 2012, 09:58:45 PM
Hi Alan,
Thought I'd do a bit towards updating the routes database today and all below which were not populating are correct. I had installed the 20121121 update prior to running the box by the way.
Here we go:-
EZY97T              EGGW - EGPH
EZY3CM             EGGD -  EGAA
EZY250W          EGPE -   EGGW
EZY610N           EGCC -  LGAV
EZY736M           LEMG  - EGNT
EZY927G           EGAA  - LFPG
EZY37YZ            EGCC - LCPH
EZY368F            EGCC - EDDH
EZY629N            EGAA - EGSS
EZY886R            LEBL -  EGNT
EZY140J             EGGD - EGAA
EZY959A            EGPF -  EGGW
EZY421L            EGSS -  EGPH
EZY799L            LSGG - EGPH
EZY142M           EGGD - EGNT
EZY496R            EKCH - EGCC
EZY825P            EGAA - EGGW
EZY908G            EDDH -  EGCC
EZY32K              EGCC -  EGAA
EZY936V            EGAA - EGGW
EZY98TW           EGPD -  EGGW
EZY388F            EGSS -   EGPF
EZY142V            EGGD -  EGPH
EZY76C              EGGW - EGPF
RYR8559            EDDB - EIDW
RYR3VY              EINN  - EPWR
RYR1643            EPKK - EIDW
EIN6G8              EIDW - EHAM
BEE3435            EGPF -  LFPG
BEE 265             EGPH - EGNX
SHT2939            EGPH - EGKK
BEL1SA              EBBR - EGPH
VIR43Y               EGKK - KLAS
EXS272M           LEAL - EGNM
EIN33R              EDDB - EGPH
TOM31G            GCTS - EGNM
AWC11J            EGSS - EGPH
Post by: Chris11 on November 24, 2012, 05:10:20 AM
ZS-AIA   0080E1      C172   Cessna 172S   Avic Air Asset (Pty) Ltd   172S11171
Post by: Chris11 on November 24, 2012, 05:17:51 AM
030011 A2-CDC    Hawker Beechcraft Corp C90GTI LJ-1947 was registered as N64347
Post by: mikek on November 24, 2012, 07:57:16 AM
Some route updates (some missing/some corrections)
MAS133   WMKK-NZAA
ANZ119   NZAA-YSSY
ANZ722   YMML-NZAA
UAE406   OMDB-YMML-NZAA
ANZ934   YBCG-NZAA
VOZ164   YMML-NZAA
ANZ725   NZAA-YMML
ANZ823   NZRO-YSSY
CSN305   ZGGG-NZAA
CAL051   RCTP-YSSY-NZAA
CAL052   NZAA-YSSY-RCTP
You can probably also delete all routes with callsign PBN. Pacific Blue has been replaced with VOZ along with the rest of the Virgin Australia group.
Mike
Post by: Runway 31 on November 24, 2012, 09:45:33 AM
Hi Syd,
Many thanks for those, they go a long way to filling up the holes left in particular to the easyJet flights
One correction EIN33R is EGLL-EGAC.
Many thanks
Post by: Runway 31 on November 24, 2012, 09:50:44 AM
Hi Chris,
Many thanks, A2-CDC operated by NAC Fixed Wing Charter
Post by: Runway 31 on November 24, 2012, 10:15:08 AM
Thanks again Mike
Post by: Blueboy on November 24, 2012, 04:01:49 PM
Hi Alan, picked-up HEX 4CAA0D with flight ID of EIEWS - this is different HEX from EI-EWS already in database?
J.D
Post by: Runway 31 on November 24, 2012, 04:20:12 PM
Hi JD, miscode on one box, 4CAA0D decodes to EI-ETZ, miscode adde to d/b
Post by: EK01 on November 24, 2012, 04:53:38 PM
Quote from: hugh on November 20, 2012, 03:47:04 PM
Hugh
Alan,
Flighradar24 would appear to be hedging their bets on this one. I've just keyed in EZY8616 and it is giving 2 possibilities :
EZY8616 Malaga to Gatwick
EZY6417 with alternative flight ID of EZY8616 Newcastle to Alicante.
Very curious,
Post by: X on November 24, 2012, 05:44:00 PM
This decodes to EP-FQD. Another Qeshm Air Fokker 50?
* 731A24                                                              2012/11/24 19:55:08
X
Post by: Runway 31 on November 24, 2012, 06:02:00 PM
As Hugh is in the Newcastle area and was looking at Radarbox for Newcastle arrivals/departures I am happy it is the Newcastle-Alicante flight.  If it was the Malaga-Gatwick flight it would have been no where near Newcastle.  Looks like another summer/winter change over.
Post by: Runway 31 on November 24, 2012, 06:04:47 PM
 X,
Certainly decodes to EP-FQD but cant find anything on it
aLAN
Post by: Kenny on November 24, 2012, 09:30:59 PM
880E01 HS-CPA BE30 Beech King Air B-300 c/n FL-590 ex N590EU, LN-BAB, N943AS  Siam Land Flying Co
8866A9 HS-YUI Socata TBM 700 c/n 624 ex N850AK
1109FF HS-IOO Cessna 510 Citation Mustang c/n 510-0100 ex N6202W Bangkok Aviation Center (miscode?)
unpopulated
A1AFC0 with callsign N208AE
Post by: Hawkeye on November 24, 2012, 09:46:30 PM
Re reply #1516
Hi again Alan,
Having stated that the routes I posted were correct, I've had to slap my own wrist.
Actually, we're both wrong with EIN33R
I'd verified all of them before writing 'em down during the day and I did have EIN33R logged correctly as EDDB to EIDW. Don't know how I came to substitute EGPH for EIDW when I typed them out.  Incorrect data is worse than none at all so I'll have to crosscheck typing to jottings in future before posting.
Finding missing routes is reasonably easy for many flights showing on the box.
The difficulty is in rooting out incorrect ones and I'm sure there are hundreds of them that need removing.  I do think though that if members notified the team of any flights in their MyLog which are very obviously incorrect, we may be surprised how many and how quickly a large amount could be eliminated without much effort.
By the way, EZY6417 is down as NCL to ALC  tomorrow.
Syd
Post by: Kenny on November 24, 2012, 10:28:35 PM
Route Correction
AHK831  VHHH-VTBS-WMKP
Missing route
DRK128 VQPR VTBS
DRK129 VTBS VQPR
DRK130 VQPR VTBS via VEBD
DRK131 VTBS VQPR via VEBD
DRK126 VQPR VTBS via VGZR
DRK127 VTBS VQPR via VGZR
DRK140 VQPR VTBS via VEGT
DRK141 VTBS VQPR via VEGT
however pilots always enter flight number using IATA code (KB)
LAO441 VLVT VTBS
LAO442 VTBS VLVT
Post by: X on November 25, 2012, 06:20:14 AM
Two UAE unknowns cropped up....no idea at this stage what types they are
* 896358       Descended from 140 thru 110           2012/11/24 11:48:42
* 89636D      Chopper                                           2012/11/24 06:43:25
Looks below like one of his Majesty's choppers may be swopping hexes/regs again (going out of the country again?)
    8967D1                                                              2012/11/24 11:17:57
    8967D1                                                              2012/11/24 15:13:29
8967D1 was A6/DU-140 A139 earlier in November
X
Post by: mikek on November 25, 2012, 08:40:50 AM
A few more routes:
JST204   WSSS-NZAA-YSSY (The WSSS-NZAA leg is an A330 while the NZAA-YSSY leg is an A320)
TMN93   NZAA-YMML
ANZ38   EGLL-VHHH-NZAA
CPA197   VHHH-NZAA
ACI410A   NWWW-NZAA
ANZ705   NZAA-YSSY
TMN94   YMML-NZAA
Mike
Post by: Runway 31 on November 25, 2012, 10:44:07 AM
Hi Syd,
Many thanks for the route correction, Libhomeradar and plane finder agree
Post by: Runway 31 on November 25, 2012, 10:44:32 AM
Hi Kenny,
Many thanks again.
HS-CPA is a B350
HS-IOO is now owned by Surap Puranitee
A1AFC0 is now HS-SKR, Cessna 208B Grand Caravan, c/n 208B1241, Siam General Aviation
Post by: Runway 31 on November 25, 2012, 10:46:43 AM
Thanks X
I have nothing on your new ones
Post by: Runway 31 on November 25, 2012, 11:10:54 AM
Thanks again Mike
Post by: EK01 on November 25, 2012, 12:05:45 PM
Alan,
Can conclusively confirm that the Easyjet flight from Newcastle to Alicante is appearing on the AN map as EZY8616 (it's approaching Alicante now) but appears on the Arrivals board at Alicante airport as EZY6417 ie it's alternative flight ID.
Post by: Runway 31 on November 25, 2012, 12:16:21 PM
Hi Ian,
Thanks for the confirmation.
Title: DAC - VGHS or VGZR?
Post by: Kenny on November 25, 2012, 02:38:26 PM
A bit confuse about Shahjalal International Airport (DAC), while ANRB database seem to use VGHS but wiki is VGZR.  Several route in ANRB also use VGZR.
Which one is correct?
Post by: RodBearden on November 25, 2012, 02:55:38 PM
Wikipedia says that VGHS is correct, and VGZR redirects to it, but doesn't say why. Skyvector also says it's VGHS.
Can only assume that VGZR wan an old code while it was called Zia International.
Post by: Kenny on November 25, 2012, 03:22:29 PM
Thanks Rod.  So all the routes with VGZR has to replace with VGHS then..
Thanks,
Quote from: RodBearden on November 25, 2012, 02:55:38 PM
Post by: Runway 31 on November 25, 2012, 03:31:58 PM
Kenny,
All routes corrected now, as Rod stated VGZR was the old code for Zia International Dacca, now Hazrat Shahjalal International Airport and recoded VGHS.  Unfortunately the website I have been using to go from IATA to IACO still has the old code as has FR24 and others sites
VGHS is already in the airports d/b.
Post by: X on November 25, 2012, 03:32:40 PM
Quote from: X on November 25, 2012, 06:20:14 AM
X
F/n was MJE007 on this unknown, possibly to RKT
X
Post by: Runway 31 on November 25, 2012, 03:36:10 PM
X
MJE is as you will be aware, Empire Aviation so looks like you have a new one in your locale
Post by: Kenny on November 25, 2012, 06:26:29 PM
Thanks Alan,
And will the corrected route will be updated to local database once these flight fly within the radar range again?
Post by: Runway 31 on November 25, 2012, 06:31:31 PM
No Kenny, they will be on the server from later tonight and show on network flights.  Unless you add them to your d/b yourself you will require to wait until the next Navdata release in around 10 days.
Post by: X on November 25, 2012, 07:26:45 PM
From departure info possibly a new 76 ex DWC but will have to confirm when sighted
* 504E06                                                              2012/11/25 20:06:01
X
Post by: Runway 31 on November 25, 2012, 07:53:19 PM
I dont have anything on it at my end X
Post by: X on November 26, 2012, 10:30:00 AM
A friend also picked up unknown 504DF2 in Al Ain area (well out of my range), I wonder if the 76's are going through their seemingly annual change of reg's or it could one of the ER- An26's transitting from/to FJR over AAN.
X
Post by: X on November 26, 2012, 11:24:57 AM
Quote from: X on November 08, 2012, 05:33:55 PM
X
AE0CE8 has been confirmed as 60-0356 miscoding at Mildenhall 20/21 Nov.
X
Title: Database Update Requests
Post by: Kenny on November 26, 2012, 11:39:16 AM
Quote from: Runway 31 on November 25, 2012, 06:31:31 PM
Umm  new Navdata in 10 days....  That's mean something.
Post by: Runway 31 on November 26, 2012, 11:40:50 AM
It means that the new Navdata will be released in around 10 days, simple as that.
Post by: Runway 31 on November 26, 2012, 11:59:26 AM
X
There was some discussion on the mode-s forum last night and it is considered that AE0CE8 is indeed a one box miscode of 60-0356 and as such have added it to the d/b.
However nothing confirmed 100% at this time and the mode-s discussion gives the following info which somewhat contradicts your statement that AE0CE8 has been confirmed as 60-0356 miscoding at Mildenhall 20/21 Nov.  It may well have bben the case that it used the other box later in the day on 21st.
" AE04E8 was last reported in the USA on 21.11 but 60-0356 could easily have flown back to the Middle East in the last few days via northern or southern latitudes, thereby avoiding detection.
Where did you get your Mildenhall info from?
Post by: X on November 26, 2012, 12:21:23 PM
Paul got Mildenhall from Mode S Forum, but neither AE04E8 or AE0CE8 have been picked up since 16/11/12 and there have been several 'new' C135's just arrived so we assume it has been replaced and would be returning to US as is the US norm out here of swopping around six per month late in each month.
I understood it had been confirmed but from your email I assume it was not. I am still howevcer convinced that it is the same aircraft as there was never a cross over in the four months the two codes were noted and all other C135's out here are known and code correctly.
X
Post by: Hawkeye on November 26, 2012, 03:30:48 PM
Another rake of routes from yesterday, mostly easyJet again, and all verified – crosschecked this time :-)
EZY497F            EPKK      EGAA
EZY189A            BIKF       EGGW
EZY17X              EGPF      EGGW
EZY271Y            LFSB       EGPH
EZY943M           LEMG      EGPH
EZY711E            EGNT      LEBL
EZY678K            EGGW    EGPD
EZY778X            EGAA      EGSS
EZY829E            EGCC     EHAM
EZY157C            EGGD     EGPH
EZY337G            EGKK      EGPH
EZY235G            EGGW    EGAA
EZY890P            EGGP      EGAA
EZY62GH            EGPD      EGGW
EZY263W           EGSS      EGAA
EZY956U            EGSS      EGPF
EIN03C             EGAC     EGLL
EIN03X             EGLL      EGAC
TCX3217           DTNZ     EGPF
EXS897             EGCC     LHBP
CLX750             ELLX      KIAH
CLX838             ELLX      KATL
DAL107            EDDF     KJFK
Also three obviously incorrect:-
RCH425         KSUU/KRIV
EXS041A        EGAA/EGPH    Was over Lincs heading SE
EZY453P        EGGP/EGGW   Was abeam DCS heading SE
Syd
Post by: X on November 26, 2012, 03:54:37 PM
this should be B-3098 E135 on delivery via sandpit
* 780394                                                              2012/11/26 19:43:03
X
Post by: Runway 31 on November 26, 2012, 04:06:32 PM
Nice one X
Post by: X on November 26, 2012, 05:19:36 PM
60-0356 populated as BKC3 due to the usual AirNav type glitch so needs you to manually change it at your endand B-3098 has a 4 missing in the c/n ie 145XXXXXX not 15XXXXX
Post by: Runway 31 on November 26, 2012, 05:46:17 PM
Hi Syd,
Many thanks again
EZY453P is EGPF-EGGD
From what I can find EXS041A is a positioning flight ID
Post by: Runway 31 on November 26, 2012, 05:58:21 PM
X
Its your end that needs the manual update.  Its the software on your computer that has the problem.
Added the 4
Post by: X on November 27, 2012, 09:31:59 AM
Non populators on network
5082B2  URCLM
4844B7  KZR1382
X
Post by: Runway 31 on November 27, 2012, 11:00:31 AM
Nothing on wither of those yet X
Post by: Runway 31 on November 27, 2012, 12:28:00 PM
X, now on mode-s 4844B7  P4-KDA, Airbus A321-231, c/n 5357, Air Astana
The other was queried yesterday but no info given yet.
Post by: anorak on November 27, 2012, 04:42:28 PM
Indonesian PK-GLL as flight ID.
Dave.
Post by: Runway 31 on November 27, 2012, 05:03:48 PM
Dave,
8A0375, PK-GLL Airbus A320-214, c/n Garuda Citilink
Post by: Hawkeye on November 27, 2012, 05:05:41 PM
Quote from: Runway 31 on November 26, 2012, 05:46:17 PM
Hi Syd,
Many thanks again
Afternoon Alan,
I always used to think all callsigns with a P suffix were positioning flights but easyJet use it for at least six of their scheduled ones.
I'm told that they use EZY then four figures for positioning and delivery flights but haven't come across any myself.
Just in case you've nowt to do :-), here's some more for you:-
EZY247F       EGGD       EGPF
EZY667E      EHAM       EGGP
EZY648H      LFPG        EGPF
EZY263W     EGSS       EGAA
EZY707A      EGAA        EGGD
EZY184E      EGSS        EGPH
EZY186L      LEMD        EGPH
EZY760E      EGCC       EKCH
EZY292Y      LEAL         EGPH
TOM2XH      LEAL          EGNV
And a few wrong 'uns showing in MyLog:-
RYR4044  Showing as  EGPK/EGSS       Should be EPMO/EGGP
DLH6PH         "        "   EDDH/EDDL      Obviously wrong but can't find correct one.
EZY959A        "        "  EGPG/EGGW      EGPF/EGGW    I think EGPG could be a typo from my submission #1512
Syd
Post by: X on November 27, 2012, 06:23:38 PM
Ugandan unknown seems to have just left somewhere nearby
06805D                                                              2012/11/27 22:21:16
X
Post by: viasa on November 27, 2012, 06:47:19 PM
Quote from: Runway 31 on November 27, 2012, 05:03:48 PM
Citilink has now it's own AOC, so the name is only Citilink and not more Garuda Citilink.
Post by: Runway 31 on November 27, 2012, 06:58:17 PM
Hi Syd,
EZY training flight use EZY9*** as the fight ID
The route shown for DLH6PH was valid for the summer schedule.  I believe it is now a Manchester flight but as yet I am unable to find out from where.
Many thanks again.
Post by: Runway 31 on November 27, 2012, 06:59:37 PM
Thanks for the correction viasa
Post by: Runway 31 on November 27, 2012, 07:00:27 PM
Nothing on your Ugandan available to me  X
Post by: Northern Watch on November 27, 2012, 08:43:04 PM
Good evening Alan
Bluebird Cargo flights that did not populated today:
BBD2540      BIKF - EGMH
BDD229        EGMH - BIKF
Keith
Post by: Runway 31 on November 27, 2012, 09:08:56 PM
Cheers Keith
Post by: Northern Watch on November 27, 2012, 09:49:00 PM
Finger trouble on the bottom one, should read BBD229.
Keith
Post by: Runway 31 on November 27, 2012, 10:00:06 PM
Worked it out Keith
Post by: X on November 28, 2012, 04:34:43 AM
Looks like a Global Hawk pinging according to its c/s and an unknown Monaco a/c at 39000.
* 4D4021                                                              2012/11/28 03:31:57
* AE17EC  166509                                                      2012/11/28 02:59:57
PK-GLL A320 Citilink went OTT and RP-C8620 A320 did a splash and go both at silly o'clock. The Bangkok Air 884205 A320 ex TAM (according to John H on Mode S forum) also went in somewhere local last night. Unfortunately all were missed due to heavy ZZZ's
X
Post by: mikek on November 28, 2012, 07:29:02 AM
Missing Routes:
ANZ718: YSSY-NZAA
ANZ719: NZAA-YSSY
Mike
Post by: Xon on November 28, 2012, 08:45:14 AM
Quote from: X on November 27, 2012, 09:31:59 AM
5082B2  URCLM
5082B2 could be UR-CLM B407
Post by: Runway 31 on November 28, 2012, 09:03:57 AM
Hi X
4D4021 3A-MGC Dassault Falcon 900EX, c/n 159 HRH Prince Albert of Monaco ex 3C-MGA
AE17EC 166509   Northrop RQ-4A Global Hawk, c/n USN01, US - Navy
5082B2 UR-CLM Bell 407GX no c/n available yet
Post by: Runway 31 on November 28, 2012, 09:06:24 AM
Thanks Mike
Post by: Northern Watch on November 28, 2012, 10:24:50 AM
Good morning Alan
Just out of Hamburg heading across the North Sea is :
A675E8 / N515VL / A320-233 / c/n 5391 / Volaris
Keith
Post by: Runway 31 on November 28, 2012, 10:43:35 AM
Cheers Keith, its in the d/b so should populate if clicked on
Post by: Northern Watch on November 28, 2012, 10:51:54 AM
Hi Alan
Unfortunately did not get the Volaris in range to pick it up on the RB saw it on FR24 and then checked db.
Another heading across the North of Scotland and this time it flew straight over the house but did not populate:
C04170 / C-FYUH / Boeing 737-8K5 / c/n 34689/1935 / Sunwing Airlines ex- D-ATUH
Keith
Post by: Runway 31 on November 28, 2012, 11:22:29 AM
Hi Keith,
Thanks again, heading across he pond on winter lease
Post by: X on November 28, 2012, 01:17:18 PM
Alan/ John
I eyeballed A6-ESR B733 Eastern Skyjet finally at RKT this afternoon. Must be ex G-STRJ as exactly same c/s and will be 896368 seen OTT several weeks ago and noted as per John's post as being seen in Turkey en route Jeddah.
PS the Bangkok Air A320 was sat at SHJ at 1030 this morning
X
Post by: Runway 31 on November 28, 2012, 02:43:28 PM
Doesnt really help X, G-STRJ is A6-ESG but 896368 decodes to A6-ESR
Post by: EK01 on November 28, 2012, 04:30:15 PM
Alan,
DLH2PH is Manchester to Stuttgart. Take a look at this. They are all for Winter 2012. It should keep you busy :
http://xon.panic.pl/LH.xls
Post by: Runway 31 on November 28, 2012, 05:34:22 PM
Cheers Ian, may thanks, having a look thorough
Post by: Northern Watch on November 28, 2012, 07:45:11 PM
Evening Alan
Two Lossiemouth Tornados miscoding at present:
03C059 / Various Lossiemouth c/s.
43C14B / Various Lossiemouth c/s. This is in the db as C30J ZH868 but confirmed being used by a Tornado for a least a week looking back.
Keith
Post by: Xon on November 28, 2012, 08:22:08 PM
48ADA4 SP-LNE E190 (Delivery flight LOT9002)
Post by: Runway 31 on November 28, 2012, 08:36:21 PM
Hi Keith,
43C14B has been used by C30J ZH868 for years.
However Trubb on mode-s forum notes that "43C14B was reported using Tornado flight ID "TESTID02" from Blandford & Brentwood on 03.03.11 and significantly it is known that ZG707 left QinetiQ at Boscombe Down on delivery to41(R) Sqn at Coningsby on that date. Further to that Military Aviation Review states that Tornado ZG707 left the CMU at Marham on the 02.11 bound for the Lossiemouth wing"
He then goes on to state " All things considered it seems to me that there is little doubt that for several years now 43C14B has been used by both ZH868 & ZG707 and it should be considered as pertinent to both machines until someone at the RAF/MoD rectifies this apparent anomaly"
I will update gthe d/b accordingly.
I have no info on your other hex is unknown to me
Post by: Runway 31 on November 28, 2012, 08:39:45 PM
Thanks Xon, c/n 19000583
Post by: X on November 28, 2012, 10:13:27 PM
As far as I am aware A6-ESG has never been seen or photographed as such, only reported as G-STRJ being 'assigned' A6-ESG (by whom I do not know), and due to it being a B733 not a B734 I was under the impression that it was finally painted as A6-ESR (to be in sequence with A6-ESS the other ex Astreus B733 G-STRI). The B734's are A6-ESE and A6-ESF.
UAE codes can't be decoded as with US and Russia etc but I agree 896368 is A6-ESR (as per John H's report from Turkey) but convinced it is ex G-STRJ from what I saw today. A6-ESR has not yet been to the sandpit but once it is we will try to sort it out once and for all.
X
Post by: chewycanes on November 29, 2012, 08:21:27 AM
Morning Alan
A delivery of SR20's i believe on the 27th.
A0CABC Callsign N150FR
A0C0F5 Callsign N148FR
A0D22A Callsign N152FR
A0B5D0 Callsign N145FR
Brian
Post by: X on November 29, 2012, 09:02:59 AM
Jordan 561   IL76MF   FJR 28/11/12   Royal Jordanian Air Force  c/s ex JY-JID
Only carries number 561, no JY reg visible on aircraft but using same hex code
X
Post by: Runway 31 on November 29, 2012, 09:45:08 AM
X
Hopefully we will get it sorted soon as nobody seems to know
http://www.airfleets.net/ficheapp/plane-b737-25119.htm
What hex was the IL76 using, its correct one or the miscode 076C94 ?
Post by: Runway 31 on November 29, 2012, 09:46:45 AM
Thanks Brian,
They were on delivery to Frances so will be de-registered very soon if  they havent already been.
Many thanks
Post by: X on November 29, 2012, 09:50:31 AM
Quote from: Runway 31 on November 29, 2012, 09:45:08 AM
X
I think everbody is wrong on A6-ESG, I believe it should read A6-ESR!
561 was using miscode 076C94
X
Post by: Runway 31 on November 29, 2012, 09:53:14 AM
Cheers X sorted
Post by: Kenny on November 29, 2012, 02:32:45 PM
HEX: 8852A2
Reg: HS-TUB
Type: A388
Make: Airbus A380-841
Op: Thai Airways (THA)
CN:093
On Delivery to BKK as THA8940.  Over Black Sea now
Post by: Runway 31 on November 29, 2012, 02:54:17 PM
Thanks again Kenny, in d/b so should populate if clicked on
Post by: John Hargreaves on November 29, 2012, 03:01:18 PM
 X,
Cogratulations on finally seeing A6-ESR! We are in good company - both ch-aviation and ATDB.sero are now going with A6-ESR being ex G-STRJ. We'll see what the next UAE MIDRMA comes up with.........
John H.
Post by: Runway 31 on November 29, 2012, 03:14:20 PM
Happy to go with 896368 being A6-ESR and ex G-STRJ
Post by: paul tricker on November 29, 2012, 03:52:36 PM
84BAEC                                                              2012/11/29 18:45:18
is JA221J E170STD  170-00353 J-Air, just arrived in the sandpit
Paul
Post by: Runway 31 on November 29, 2012, 03:54:24 PM
Magic Paul, saw from Skyliner it was on delivery so hpoed someone would see it
Post by: Northern Watch on November 30, 2012, 09:08:16 AM
Good morning Alan
A7379D / N564UW / A321-231 / c/n 5374 / US Airways
I know you are usually on the ball with these deliveries but unable to check as picked this up on FR24 and it does not seem to be heading near enough to me for my RB, sad !!!!!
Keith
Post by: Runway 31 on November 30, 2012, 09:26:01 AM
Thanks again Keith, it wasnt on the d/b
Post by: Hawkeye on November 30, 2012, 04:32:40 PM
Hi Alan,
Another batch of routes.
I feel I shouldn't be loading you with so many really
with all the time you and the team already spend on aircraft data.
EZY33BT    EGPF/EGGD
EZY142V    EGGD/EGPF
EZY73AU    EDDT/EGPF
EZY630L    LFLL/EGPH
EZY630L    EDDM/EGPH
EZY378C    EDDM/EGPH
EZY174C    LFMN/EGNM
EZY452T    LFPG/EGAA
EZY957E    EGSS/EGPH
EZY19B      EGGW/EGPH
EZY419U    EGPH/EGGW
EZY754R    EHAM/EGPO
EZY921D    EGSS/EGAA
EZY184B    EGGD/EGNT
EZY38BT    EGPF/EGGD
EZY76C      EGGW/EGPF
EZY478E    EGAA/EGGD
EZY974H    EHAM/EGPH
GEC8170   EDDF/KATL
DLH428     EDDM/KCLT
DLH410     EDDM/KJFK
MPH1187   EHAM/KMIA
BAW1489  EFPF/EGLL
ABQ220     OPRN/EGCC
RYR6DC     EPKK/EGNM
AFR025R    LFPG/EGNT
RYR6GQ     EPBY/EIDW
EXS898     LHBP/EGCC
BAW835    EIDW/EGLL
EXS174C   LFMN/EGNM
DAL29       LFPG/KATL
RYR1FL      EGNX/EPKK
SHT8Q       EGLL/EGPH
WZZ2JC    EGGP/EPMO
RYR38P     EPGD/EIDW
Some incorrect ones:-
RCH81            KWRI/KPOB      Obviously wrong
EZY623Y         EGGP/LFMN      Should be EGGP/EGAA
BER242X        EDDR/ EDDM    Wrong. On box E of MAN, Hd W
TOM9289       EGGW/EINN     Wrong. Departed  EGSH but destination unknown.
FDX36            KIND/LFPG        Should be KIND/EGSS
EZY718B        EGGD/EGGW     Should be EGGP/EDDB
NJE9AD          KTEB/KSAV       Was EGLF/KSJC on 28th -  Netjets callsigns are allocated to the plane, – in this case CS-DKH, - not the route.
See:-  http://www.ciaviation.com/newpage25.html
Better if all NJE c/sns are removed from database?
Syd
Post by: Runway 31 on November 30, 2012, 05:57:49 PM
Thanks Syd,
your help is very much appreciated.
Some queries
FR24,gives EZY142V as EGGD-EGPH
You give EZY174C LFMN/EGNM. According to the easyjet website their only route from Leeds is to Geneva
BAW1489 is EGPF-EGLL and uses SHT7P as its alternative callsign
I am happy to be proved wrong but I think RYR38P is a positioning flight as I cannot find it on the net.
Agree re business flight and advised Airnav to delete all thier callsigns from Routes d/b a few days ago.
Similar with RCH etc flights, these have stopped being added to d/b but still a couple of hundred in d/b and Airnav have been requested to delete them all
Thanks again
Post by: paul tricker on November 30, 2012, 07:24:39 PM
non-populator..
75829E  RPC3271  = RP-C3271  A320-214  5381  Cebu Pacific Air
just gone OTT the sandpit ABOVE the clouds : -(
Paul
Post by: Runway 31 on November 30, 2012, 07:44:15 PM
Hi Paul,
Its in the d/b since departure so should have populated
Post by: Hawkeye on November 30, 2012, 09:59:00 PM
Evening Alan,
Regarding your queries.
EZY142V is indeed EGGD/EGPH. Had it correct on a list I sent previously!
SHT7P was showing on R/B as SHT1489  (not even BAW1489) which it has done before. Don't know the answer re cross ref in database for such cases. I hit 'F' (which lives next door to 'G' on keyboard) in departure airport code. No excuse. Doh.
RYR38P.  Don't think this one is a typo on my part as I'm pretty sure it was showing that c/s on screen. Research shows though it was RYR3BP.  Route correct as submitted.
EZY174C. Sorry Alan, can't explain this one even though I generally double check  'track lines' on other VR sites and expected arrivals details at airports.
Beginning to think 'advanced years' is getting the better of me. Perhaps I should retire from the scene gracefully :-)
Syd
Post by: BBJUK on December 01, 2012, 08:19:13 AM
Morning Alan.
UP-T3409 TU134B-3 arrived AUH overnight, hex is 683066.
Nice way to start the month.
Cheers BBJUK
Post by: Runway 31 on December 01, 2012, 09:54:41 AM
Many thanks BBJUK, nice start indeed, send it over here please when you are finished with it
Post by: Runway 31 on December 01, 2012, 09:56:22 AM
Hey Syd, no worries keep on sending them in.
I will put the shuttles in using both their original and alternative so as we get them whatever they use.
Many thanks and keep on sending them in, I get fat finger syndrome more than anyone!!
Post by: flygfantast on December 01, 2012, 12:10:59 PM
Hi Alan,
On screen just now again (seen November 5th) is 150779. Seems to be RA-67433, allocated 150769, miscoding on one of it's boxes.
RA-67433, Cessa 525 CitationJet 1, c/n 525-0484
Niklas
Post by: Xon on December 01, 2012, 03:04:47 PM
48D84F 025 C295 (PLF033 delivery flight)
Post by: Runway 31 on December 01, 2012, 03:37:31 PM
Thanks Xon
Post by: Runway 31 on December 01, 2012, 03:40:01 PM
Thanks Niklas
Post by: Blueboy on December 01, 2012, 03:47:47 PM
Hi Alan, picking up HEX A5F1FC with Flight ID of 50482 - Possibly PC-12 / U-28A  05-0482, which I think is inbound Prestwick
J.D
Post by: Runway 31 on December 01, 2012, 04:15:09 PM
Hi JD
If thats the case its a miscode, A5F1FC decodes to N482WA although it appears to be the norm for them ansd quite apt given it is c/n 482
Many thanks
Post by: X on December 01, 2012, 05:43:08 PM
Looks like we have another little Fokker, should be EP-FQA
* 731A21                                                              2012/12/01 11:05:29
Post by: Runway 31 on December 01, 2012, 05:54:05 PM
Thanks X, you may also get 731A24 EP-FQD
Post by: X on December 01, 2012, 06:06:43 PM
Thought I had already sent that one
X
Post by: Runway 31 on December 01, 2012, 06:16:03 PM
Maybe you did, I know you sent B & C
Post by: Xon on December 01, 2012, 07:01:39 PM
140B29 RA-02857 E135 c/n 145549
Post by: Runway 31 on December 01, 2012, 07:11:08 PM
Thanks again Xon
Post by: X on December 02, 2012, 07:50:48 AM
Descending into sandpit at 0330 was unknown 434C76
X
Post by: Runway 31 on December 02, 2012, 08:27:54 AM
Nothing on it X, I would sugest its a miscode
Post by: X on December 02, 2012, 08:36:24 AM
VP-CAS Challenger is sitting on the ground...could it be a new one as nothing in db against that reg
X
Post by: X on December 02, 2012, 08:52:12 AM
7335E5 EP-MOE B146 just departed sandpit
* 7335E5                                                              2012/12/02 12:47:22
X
Post by: Runway 31 on December 02, 2012, 09:39:38 AM
Must be a new on X, cant find anything on a Challenger VP-CAS, there have been half a dozen aircraft with the reg, the last being an A319 with hex 4241C5
7335E5 EP-MOE British Aerospace BAe 146-300, c/n E3129, Mahan Air
Post by: Northern Watch on December 02, 2012, 10:53:25 AM
Good morning Alan,
A batch of routes from yesterday just to keep you busy but I do appreciate the hard work the team put in to ensuring accurate information:
NAX77N      ENVA - GCLP
SAS7401     ENHD - GCLP
SAS7417     ENCH - GCLP
NAX4YM      ENRY - LEMG
NAX2RN      ENRY - LEAL
VKG6542     GCLP - ENTC
NAX5MR      ESSA - GCTS
NAX8CK      EFHK - GCLP
NAX4FQ      ENGM - GCTS
NAX62B      ENHD - GCLP
NAX9GR      EFHK - GCTS
NAX2WB     EFHK - LEAL
NAX34J       ENZV - LEAL
NAX2BL       EKCH - LEMG
NAX8KB      ENBR - LEAL
NAX5VA      GCLP - ENGM
NAX2FR      ENGM - GCLP
NAX81BZ    LEMG - EKYT
NAX71N      GCLP - ENVA
In the db but need amending:
NAX96J      ENAL - LPFR should read ENAL - GCLP
NAX42H     ESSA - LEAL should read ENTO - LEAL
Some more to come once I have checked them out.
Keith
Post by: jim_stockwell on December 02, 2012, 11:16:05 AM
Not populating is 04006B somewhere near Stevenage at 8000ft reduecing to 6500ft as I type this at 1115
Post by: Runway 31 on December 02, 2012, 03:33:33 PM
Hi Jim
04006B ET-AQD, De Havilland Canada DHC-8-Q402 Dash 8, c/n 4427, Ethiopian Airlines in Asky Airlines colours.  Landed Stansted for a fuel stop on delivery flight.
Post by: Runway 31 on December 02, 2012, 03:35:57 PM
Hi Keith,
Many thanks, I will get them on the server tonight
One typo, SAS7417 is ENCN - GCLP
Post by: Northern Watch on December 02, 2012, 08:01:16 PM
Hi Alan,
Sorry about the typo, another batch of routes from yesterday:
NAX9651     GCLP - ENAL
NAX6KA      GTCS - ESSA
NAX1CS      GCLP - EFHK
NAX5NM     GTCS - ENGM
NAX1ZB      GTCS - EFHK
NAX4PC      GCLP - ESGG
NAX74H      GCLP - ESSA
NAX3RY      GCLP - ENGM
NAX69G      GMMX - ENGM
NAX243K     LEAL - ENTO
NAX8QX      LEMG - ESGG
NAX83G      GCLP - ENHD
NAX49N      EKBI - GCLP
NAX6FA      LPFR - ESSA
NAX3MU     LEAL - EFHK
NAX33W     LEAL - ENAL
keith
Post by: Runway 31 on December 02, 2012, 08:19:43 PM
Thanks again Keith
Post by: Runway 31 on December 02, 2012, 08:47:31 PM
Thanks again Keith
Post by: X on December 03, 2012, 10:48:05 AM
Quote from: X on December 02, 2012, 07:50:48 AM
X
434C76 does appear to be VP-CAS CL60 and is suspected might be c/n 5500 but this is NOT confirmed
X
Post by: Runway 31 on December 03, 2012, 12:22:24 PM
My d/b has 5500 going to VP-C**.  Will mark it in as the miscode
Post by: Northern Watch on December 03, 2012, 02:04:18 PM
Good afternoon Alan,
Another small batch of routes from yesterday:
NAX3UC      EIDW - ENGM
NAX36C      ENGM - EGKK
BOS8001    LFPO - KEWR
In the db but needs amending:
NAX62H     LEAL - LSGG should read ENGM - LSGG
Keith
Post by: Judwin45 on December 03, 2012, 02:19:59 PM
Noted out of Exeter at 1400  4692C6, RJ100, coding GCGNU.
Post by: Runway 31 on December 03, 2012, 02:50:05 PM
Hi Keith,
4692C6 formerly SX-DVF now G-CGNU using its old hex.  Skyliner shows it is on delivery 03dec12 EXT-PDV-BAK-DYU to become EY-***
Post by: Runway 31 on December 03, 2012, 02:53:43 PM
Thanks again Keith(NW)
Post by: Hawkeye on December 03, 2012, 03:10:47 PM
Afternoon Alan,
Only these this time:-
EXS272M    LEAL/EGNM
EZY742X    EGNT/EGGD
RYR4UB    LEMG/EGPK
FCM97L     EFHK/EGCC
Needs updating:-
EZY667E  EGAA/LEBL Should be EHAM/EGGP
Syd
Post by: Runway 31 on December 04, 2012, 10:16:18 AM
Thanks again Syd
Post by: X on December 04, 2012, 02:34:01 PM
800786 as JAI9039 is on approach BAH this is being reported as VT-JCX ATR72-600 Jet Airways. Not in db but you may have added since last update
X
Post by: X on December 04, 2012, 03:30:26 PM
735043  EP-TBC just east of Kish climbing thru 21000
X
Post by: Runway 31 on December 04, 2012, 03:37:44 PM
Hi X
800786 VT-JCX added yesterday on departure from Toulouse
735043  EP-TBC, no further details known
Post by: X on December 04, 2012, 04:03:51 PM
Iranian website states EP-TBC is an MD-88 most likely Taban Air
ورودپنجمین MD-88 به ناوگان تابان ایر - EP-TBC // اختصاصی //
X
Post by: Northern Watch on December 04, 2012, 04:04:32 PM
Two from yesterday:
NAX4417     ENTC - ENGM
NAX756       ENGM - ENVA
Keith
Post by: Runway 31 on December 04, 2012, 04:08:53 PM
X
Presume its Taban Air as EP-TBB is an MD-88 of theirs
Post by: Runway 31 on December 04, 2012, 04:10:50 PM
Thanks again Keith
Post by: X on December 04, 2012, 04:36:47 PM
Quote from: X on December 04, 2012, 04:03:51 PM
X
تابان ایر is Taban Air in Iranian (Farsi) and is in the text above so 100% Taban Air
X
Post by: Runway 31 on December 04, 2012, 05:32:49 PM
Just got to find out the frame now, I presume it will be one of the UR- ones reregistered
Post by: X on December 04, 2012, 05:57:04 PM
If not found out beforehand, once it comes to sandpit we will hopefully get it tied up.
X
Post by: viasa on December 04, 2012, 07:09:44 PM
Taban now operate all  former Onur Air MD-88s - on is EP-TBB (53549) while the four other have ukrainian registrations. So one must be EP-TBC.
Post by: Runway 31 on December 04, 2012, 07:27:32 PM
Correct Viasa but which one, no info available as yet
Post by: X on December 04, 2012, 07:47:02 PM
Taban Air MD-88 pick ups
UR-CJK last noted 29/11
UR-CJL Last noted 19/11
UR-CIX last noted 29/11
UR-CIY not been picked up in last month
UR-CIZ last noted 13/11 now EP-TBB
Not much help but possibly UR-CIY is a starting point??
X
Post by: Xon on December 04, 2012, 08:20:36 PM
3D1505 D-EGFD is now SP-GMC C152 c/n F15201630 (using old hex)
Post by: Runway 31 on December 04, 2012, 08:40:13 PM
Thanks Xon
Post by: Runway 31 on December 04, 2012, 08:40:28 PM
Its a start X
