User-generated RadarBox Location Map
Started by RodBearden, November 17, 2008, 11:49:58 AM
#195
Quote from: naird on March 28, 2009, 03:44:26 PM
Don't see a pin on Kingston, Ontario, Canada - have been sharing for a while - feel free to add one - whoever does that at AirNav.
If you've got your City/Country setup in Radarbox (Preferences:Home Station Data), it should appear on the map.
Only appear to be two in Canada at the moment:
Montreal,Canada
VERDUN,CANADA
And a tip.  If you want to see if your location is getting onto the map, just view the source of http://www.airnavsystems.com/RadarBox/network.php
Interesting - I see that Chorley is defined in the source of the map (twice, with two different positions - the lower case one is wrongly situated in Hampstead), but doesn't appear in the drop-down list in Preferences.
So I'm not on the map :-(
Quote from: RodBearden on March 28, 2009, 06:04:44 PMInteresting - I see that Chorley is defined in the source of the map (twice, with two different positions - the lower case one is wrongly situated in Hampstead), but doesn't appear in the drop-down list in Preferences.
The coordinates listed in the source are the position of your ISP.
Falcon
I have read through this thread and it appears I have everything setup correctly. I have tried entering my actual town and when that didn't work, a larger city south of me, and I am not able to get plotted on the map. I am watching a person south of me in Seattle come and go on the map as he receives ADS-B returns. We don't get quite as many aircraft with ADS-B in this part of the world so it is a bit of an on and off affair at times.
I am wondering if my shared information is getting out at all. It is setup to share in the settings.
It would be nice to know if my shared information is getting out and what I can do to get plotted on the map.
Send support a mesage and tell them your login code (PG..) and they can confirm whether you are sharing on the network by checking the network stats.
carp777
not sure how to add to map but you can add mine at preston lancashire england
Hi Carp and welcome!
I'm just down the road from you in Chorley.
Just make sure you select Preston in File...Preferences...Home Station Data, and you'll be added automatically.
