Author Topic: Installation of radarbox  (Read 47790 times)
Melvin2957
Re: Installation of radarbox
« Reply #15 on: May 18, 2017, 08:49:26 PM »
Should i start again take it on my pc and start from sctrach
Melvin2957
« Reply #16 on: May 18, 2017, 08:55:20 PM »
The driver version is 2 8 30 0
« Reply #17 on: May 18, 2017, 09:01:59 PM »
I would uninstall including manually doing any orphan files left behind then install again as detailed.  Also while V6 works OK with the box it is designed for USB sticks.  I would suggest you use http://www.airnavsystems.com/download/ANRB/ANRB50072Setup.exe
Driver from support page http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip  Zipped file.  Unzip into the Radarbox/Drivers folder then install through Devices and Printers
« Last Edit: May 18, 2017, 09:04:52 PM by Runway 31 »
Melvin2957
« Reply #18 on: May 19, 2017, 07:30:29 AM »
Thank you Alan for your help is the anything on you tube a video or something step by step installation of the radarbox
« Reply #19 on: May 19, 2017, 07:39:25 AM »
I don't know.  What specific issue are you having installing it and I will see if I can talk you through it.
Melvin2957
« Reply #20 on: May 19, 2017, 07:56:36 PM »
Right sorry for delay just finished work I am now going to install radarbox soft ware
Melvin2957
« Reply #21 on: May 20, 2017, 06:38:26 AM »
Can anyone help please I have just installed software disc gone to devices right clicked USB gone into drivers and it says from the top driver provider unknown driver date not available,driver version not available digital signer not digitally signed  please help
« Reply #22 on: May 20, 2017, 06:56:38 AM »
Hello,
1st: you did this: Download http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip  Zipped file.  Unzip into the Radarbox/Drivers folder ?
2nd: Regarding your last post: You are in device manager aren't you?
If 1st and 2nd is true:
- go to update drivers
- a window opens stating something like search for drivers automatically and search on computer for driver. Please select the latter.
- the window will change and a field were you can enter the location of a folder is displayed. Enter the path to the folder Radarbox/Drivers. Please make sure, that search subfolders is ticked too. You can click through the folders by using the browse button.
- click on continue.
- the installation of the signed WIN10 drivers  for Classic Radarbox shall start now.
« Last Edit: May 20, 2017, 06:58:38 AM by neroon79 »
Melvin2957
« Reply #23 on: May 20, 2017, 07:13:43 AM »
Thank you very much all done I hope
Melvin2957
« Reply #24 on: May 20, 2017, 01:39:07 PM »
Hello again I have been out come back put radarbox on both green lights are on blank screen checked drivers seems windows is deciding what drives I use
« Reply #25 on: May 20, 2017, 01:49:37 PM »
In the radarbox/drivers folder do you have a folder ANRB-Drivers-20161222
Melvin2957
« Reply #26 on: May 20, 2017, 01:54:17 PM »
No
« Reply #27 on: May 20, 2017, 01:58:37 PM »
http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip unzip these drivers into the radarbox/drivers folder and let me know once you have done that
« Reply #28 on: May 20, 2017, 02:01:31 PM »
In addition to Alan:
After you have downloaded the zip file from the given link you have to open the zip file (zip folder). You can use CTRL+A and then CTRL+C to copy all files/folders in the zip file/folder. After that you have to got to Radarbox\Drivers folder and use CTRL+V to paste all the files from the zip file into that folder. After that you can install the drivers via device manager the way I stated earlier today. Windows is not capable to install drivers directly out of a zip file / zip folder.
That's not the shortest/smartest way to decompress a zip folder, but it may be the best way to make sure we get the drivers were they should be.
« Last Edit: May 20, 2017, 02:17:34 PM by neroon79 »
« Reply #29 on: May 20, 2017, 02:09:25 PM »
I was assuming that the file would be download onto somewhere on the computer like the desktop or the download folder and then unzipped into the radarbox/drivers folder using the unzip facility within windows to leave the decompressed folder ANRB-Drivers-221222
« Last Edit: May 20, 2017, 02:11:59 PM by Runway 31 »
