Installation of radarbox
Started by Melvin2957, May 18, 2017, 07:28:58 AM
If one of the following browsers is used: IExplorer, MS EDGE, firefox or chrome and no user adjustments were made to these browsers the zip file will end up in download folder with a chance of 99.99%.
Correct then it can be unzipped into theradarbox/drivers folder
Melvin2957
Go to cortana and enter device manager, it shall be showed as desktop app in the results.
Melvin2957
It now says the best driver is already installed
OK
Go to Start/Control Panel/Hardware and Sound/Devices and Printers/and under unspecified you should see your Radarbox, confirm
In addition to Alan:
As it seems that the correct drivers may somehow be installed, you may find Radarbox listed under under connected devices (left column menu).
Melvin2957
It will always state that, you will need to continue to load in the drivers, confirm you have found your box in devices and printers please
In device manager the Radabox shall be listed under USB Controllers without a yellow exclamation mar icon symbol.
If that is the case the drivers are installed correctly.
I will now leave the discussion, it is becoming to confusing having two giving advice
Alan, it seems, that you menu structur is different from mine under Win10. Which Win version (1607, 1703 etc.) are you using.
Melvin2957
It's listed under unspecified
Melvin2957
So that means, that the correct drivers aren't installed. So we have to install them.
