Installation of radarbox
Started by Melvin2957, May 18, 2017, 07:28:58 AM
Melvin2957
Melvin2957
Ok let's do it anyway:
right mouse click on RadarBox, select update drivers.
In the window that openes select Browse my computer for driver software (advanced)
Tell when ready
A different question have you ever heard about Teamviewer?
Melvin2957
Melvin2957
Melvin2957
Can you send it to the pic radarbox is on
There is a field named: looking at this place for drivers
In that field should be a location.
On rights hand side after the filed is a button named browse.
Use that button and navigate to the folder were you have copied the drivers to.
Tell when ready.
Melvin2957
Melvin2957
If the folder of Radarbox drivers is displayed and use subfolders is ticked too click on continue.
Melvin2957
If you would like to use teamviewer that would be fine
Melvin2957
It's come up again saying the best drivers are already installed
That' what I feared...
Teamviewer needs to be installed on your PC.
If it is not installed you can download it here: https://download.teamviewer.com/download/TeamViewer_Setup.exe
Melvin2957
