Author Topic: How to feed RadarBox MLAT to VRS  (Read 22137 times)
struart
« on: September 23, 2019, 08:53:08 PM »
Hello
On what port rbfeeder(on rpi) feeds mlat data in beast so i can add this to see planes in VRS (i can do it with adsbexchange/piaware mlats by --results best,LISTEN,PORT)
abcd567
  • CYYZ - Toronto
Re: How to feed RadarBox MLAT to VRS
« Reply #1 on: September 23, 2019, 09:43:09 PM »
I am not sure, but as far as I know, RB24 does not feed back mlat calculated results to RPi feeders.
Flightaware and Adsbexchange do feed back their mlat calculation results to RPi on port 30104. The dump1090 makes these results available at port 30106 for use by VRS.
« Last Edit: September 23, 2019, 09:46:19 PM by abcd567 »
struart
« Reply #2 on: September 24, 2019, 11:00:11 AM »
Yeah i know about FlightAware and adsbexchange but i wanted to get rb24 feed because some planes from here arent detected by other mlats.
But if thats true that theres no feedback to rpi i can live without them :)
abcd567
  • CYYZ - Toronto
« Reply #3 on: February 17, 2020, 10:49:44 PM »
Yes it is possible now.
Credits: denzen
https://forum.adsb.in/f50/cervis-radarbox24-com-beta-testirovanie-1103/index22.html#post48131
Edit this line in /etc/rbfeeder.ini:
Original Line:
After Editing:
Note: Dont forget to remove # at start of the original line
For Raspbian Stretch:
mlat_cmd=/usr/bin/python3.5 /usr/bin/mlat-client --results beast,listen,30007
For Raspbian Buster:
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client --results beast,listen,30007
Code: [Select]
sudo nano /etc/rbfeeder.ini
Quote
[client]
network_mode=true
key=xxxxxxxxxxxxxxxxxxxxxxxxx
sn=EXTRPI000035
lat=43.5xxxxxx
lon=-79.6xxxxx
alt=155
sat_used=0
sat_visible=0
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
Code: [Select]
Code: [Select]
netcat 127.0.0.1 30007
111111  3▒MLAT▒▒̐5▒C▒▒▒]3▒MLAT▒▒̐5▒▒▒X▒v▒▒3▒MLAT▒▒̐5▒@▒▒   ▒-I3▒MLAT▒▒̐5▒▒
                                                              X▒▒▒$3▒MLAT▒▒̐5▒>b▒▒I▒3▒MLAT▒▒̐5▒▒X▒▒̖3▒MLAT▒▒̐5Q<▒▒▒L▒▒3▒MLAT▒▒̐5T▒▒X▒-▒▒3▒MLAT▒▒̐51<d▒"6▒3▒MLAT▒▒̐54▒▒X▒▒3▒MLAT▒▒̐5▒▒X▒K:▒3▒MLAT▒▒̐1▒8
▒▒ u3▒MLAT▒▒̐1▒_X▒▒3▒MLAT▒▒̐158▒▒l▒3▒MLAT▒▒̐1▒▒Y5▒p▒3▒MLAT▒▒̐/▒4▒▒▒▒T3▒MLAT▒▒̐/▒1Y3 ▒3▒MLAT▒▒̐/▒4>▒▒▒3▒MLAT▒▒̐/Է▒Y)26j3▒MLAT▒▒̐/▒4
▒▒Q     3▒MLAT▒▒̐/ķsY3▒WL3▒MLAT▒▒̐/A1▒▒^▒▒3▒MLAT▒▒̐/D▒/YFM▒3▒MLAT▒▒̐/1h▒<▒3▒MLAT▒▒̐/▒▒YV[▒▒3▒MLAT▒▒̐-▒0▒穳k#3▒MLAT▒▒̐-ĴYX▒▒▒3▒MLAT▒▒̐-Q.▒▒▒`▒^3▒MLAT▒▒̐-T▒YYq{1O3▒MLAT▒▒̐+▒.▒ݺ▒3▒MLAT▒▒̐+▒Y▒▒▒3▒MLAT▒▒̐+q,v▒▒t▒3▒MLAT▒▒̐+t▒▒Y▒▒▒▒3▒MLAT▒▒̐+A+T▒▒Z3▒MLAT▒▒̐+D▒▒Y▒▒w3▒MLAT▒▒̐)▒*Z▒▒Y243▒MLAT▒▒̐)ԭ▒Y▒t▒N3▒MLAT▒▒̐)▒)▒▒m▒(3▒MLAT▒▒̐)▒▒EY▒:os3▒MLAT▒▒̐'▒&▒▒g▒3▒MLAT▒▒̐'䪓Y▒-▒3▒MLAT▒▒̐'▒'▒*>a▒3▒MLAT▒▒̐'Ԫ▒Y▒~R▒11^C
« Last Edit: February 19, 2020, 01:31:21 AM by abcd567 »
nigelj65
« Reply #4 on: February 22, 2020, 04:50:24 PM »
Hi, am I missing a step if I get a an error message connection cannot be made with these settings, the target machine actively refused it. IP address and port are correct and SSH is enabled. Thanks
abcd567
  • CYYZ - Toronto
« Reply #5 on: February 22, 2020, 06:23:19 PM »
nigelj65
(1) What are outputs of following commands:
Code: [Select]
cat /etc/os-release
apt-cache policy mlat-client
apt-cache policy python3.5
apt-cache policy python3.7
(2) What is output of this command?
Wait few minutes if initially there is no output.
If there is lot of output (strange characters), stop it by pressing Ctrl and c keys simultaneously.
Code: [Select]
« Last Edit: February 22, 2020, 06:32:34 PM by abcd567 »
nigelj65
« Reply #6 on: February 22, 2020, 08:34:11 PM »
Hello abc,
attached is the output. Thanks for the help.
Just noticed on the RB24 feeder page MLAT is no longer running or even available as an option to configure through the website??
Nigel
« Last Edit: February 22, 2020, 09:16:27 PM by nigelj65 »
abcd567
  • CYYZ - Toronto
« Reply #7 on: February 22, 2020, 09:10:33 PM »
You installed software is OK:
OS = Raspbian Buster
mlat-client = ver 0.2.11
python = ver 3.7
Problem seems in settings of rbfeeder.
Please post output of following command (remove sharing key before posting):
Code: [Select]
cat /etc/rbfeeder.ini
nigelj65
« Reply #8 on: February 22, 2020, 09:26:02 PM »
rbfeeder.ini attached
MLAT seems to have stopped working all together?
abcd567
  • CYYZ - Toronto
« Reply #9 on: February 23, 2020, 12:29:46 AM »
In the line below, you have not left any space between mlat-client and --results.
Code: [Select]
mlat_cmd=/usr/bin/python3.7 /usr/bin/mlat-client--results beast,listen,30007
Add a space so it becomes like this:
Code: [Select]
Save file rbfeeder.ini
Restart rbfeeder
Code: [Select]
Now test connection in VRS.
« Last Edit: February 23, 2020, 02:48:58 AM by abcd567 »
nigelj65
« Reply #10 on: February 23, 2020, 08:15:49 AM »
Glad it was a typo! MLAT up and running, thanks for all your help.
teesvalley spotter
« Reply #11 on: February 24, 2020, 03:57:52 PM »
Hi.
Is it possible to see MLAT returns from the AirNav Micro RadarBox ADS-B Receiver locally using Virtual Radar Server? It's the dongle and antenna kit off Amazon for £14.95 - https://www.amazon.co.uk/AirNav-Micro-RadarBox-ADS-B-Receiver/dp/B01GNGZAIG
Getting adsb via VRS is easy enough to set up just wondering if it's possible with mlat aircraft too?
abcd567
  • CYYZ - Toronto
« Reply #12 on: February 24, 2020, 05:47:28 PM »
Hi.
YES, it is possible. Use same procedure as described in above post.
« Last Edit: February 24, 2020, 05:51:05 PM by abcd567 »
teesvalley spotter
« Reply #13 on: February 24, 2020, 05:50:36 PM »
Hi.
Hi. Thanks for your reply the above all seems to be aimed at a raspberry pi. Is it possible to do the same somehow for those just using a PC
abcd567
  • CYYZ - Toronto
« Reply #14 on: February 24, 2020, 05:55:41 PM »
No, I dont think it is possible to configure Windows RBfeeder for mlat feed back. In fact I never tried it. The method described in this thread is for RPi feeder.
Note: Even with RB feeder on RPi, VRS on Windows can be used, as done in howto post above.
« Last Edit: February 24, 2020, 06:02:19 PM by abcd567 »
