Author Topic: Real-Time Network Not connected  (Read 22719 times)
PGANRB113875
« on: December 28, 2020, 08:40:27 AM »
Hi Folks,
Could You please help or offer Me some advice.
I have just installed My Airnav Radar Box, I have registered and everything online, but I have a constant red light stating "Real-Time Network Nor Connected".......the Hard ware connsction light is Green......... I just cannot get any realtime network coverage !.
Many Thanks#
Neil.
Re: Real-Time Network Not connected
« Reply #1 on: December 28, 2020, 10:24:17 AM »
Have you ticked Get Flights from Radarbox Network, bottom left on the Network tab screen
« Last Edit: December 28, 2020, 10:30:59 AM by Runway 31 »
PGANRB113875
« Reply #2 on: December 28, 2020, 10:26:19 AM »
Yep tried all that, I registerd My box etc yesterday afternoon amd I have Business user account as I am sharing DATA, but cannot get real time data ?
« Reply #3 on: December 28, 2020, 10:33:18 AM »
Also are you sending data to the network by having Share Flight Data ticked on File/Preferences/Radarbox.  I see from your station page that you are showing yellow for no data and that may explain.  Your range is zero so if you are seeing aircraft on your MyFlights tab it looks like while you are receiving data you are not sending data
« Last Edit: December 28, 2020, 10:37:30 AM by Runway 31 »
PGANRB113875
« Reply #4 on: December 28, 2020, 10:40:19 AM »
Hi Buddy,
Yep share data box is ticked.
At the bottom of the radarbox interface it says "Your account expired or you are not Subscribed to Radarbox Network". However I have a Business account as I am sharing/Feeding DATA !!!.
« Reply #5 on: December 28, 2020, 10:49:37 AM »
I presume that you are a Business account holder for Radarbox24.  I dont know if that applies to the network though the V6 software through your Radarbox as you advise you are not subscribed to it
If you are not seeing aircraft on your MtStations page on RB24 you are not sending data, hence the yellow block on the grid
I suggest that you speak to support regarding that issue
« Last Edit: December 28, 2020, 10:51:45 AM by Runway 31 »
PGANRB113875
« Reply #6 on: December 28, 2020, 10:51:06 AM »
Many thanks for Your help Sir,
Do You have a link to "Support" please.
Neil.
« Reply #7 on: December 28, 2020, 10:54:47 AM »
Neil
If you are not seeing aircraft on your MyStations page on RB24 you are not sending data, hence the yellow block on the grid.  Are you seeing aircraft on your MyStation page
[email protected] is the email address and they should reply within 24 hours
PGANRB113875
« Reply #8 on: December 28, 2020, 10:57:51 AM »
I will contact support....... I have to point out that the radarbox hardware itself is somthing I got roughly 8- 10 years ago.......... no whether that is causing the issue because of its age ?
« Reply #9 on: December 28, 2020, 11:09:01 AM »
Are you using the V6 software or the original that came with the box.
« Last Edit: December 28, 2020, 11:11:41 AM by Runway 31 »
« Reply #10 on: December 28, 2020, 11:13:17 AM »
The V6.00.02 version can be found here as using the original software will be your problem
 https://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
I suggest that you delete the old version then go in and manually delete any Airnav folders left behind and then install to c:\Airnav not to program files
PGANRB113875
« Reply #11 on: December 28, 2020, 11:15:12 AM »
I will try that now Sir.
« Reply #12 on: December 28, 2020, 11:18:47 AM »
You will also need the driver package, note they are in zipped format http://www.airnavsystems.com/Download/ANRB/Drivers/ANRB-Drivers-20161222.zip
PGANRB113875
« Reply #13 on: December 28, 2020, 11:19:52 AM »
I assume the Drivers are loaded first before the main siftware ?
« Reply #14 on: December 28, 2020, 01:12:19 PM »
Load the main software then unzip the drivers into the Airnav Systems/Radarbox/Drivers folder
