UAT978 connected no data transmitted
Started by Rotex43, March 13, 2022, 05:51:50 PM
Rotex43
UAT978 installed on pi os bullseye, rbfeeder status shows connected with Dump978-rb disabled. When Dump978-rb is enabled, status shows unable to access 978. 978 dongle is only device connected, no 1090 device connected. The 978UAT has been configured with serial 00000401 to match Dump978-rb. RadarBox shows connected but no data received.
I find no Dump1090 installed on computer, even though when trying various settings the status show Dump1090 enabled.
#1
Have a read at this thread Rotex https://forum.radarbox24.com/index.php?topic=105891.0
Could you post your ini file with your details redacted
abcd567
#2
Quote from: Rotex43 on March 13, 2022, 05:51:50 PM
Please post output of following command:
cat /etc/rbfeeder.ini
This is the dump1090 capsuled inside rbfeeder, and is not visible as an stand-alone application.
If you want to stop the capsuled dump1090, do following:
In file /etc/rbfeeder.ini make setting like below:
[client]
network_mode=true
Also remove # at start of following setting
[dump978]
#dump978_enabled=true
So it becomes:
[dump978]
After making changes, Save file /etc/rbfeeder.ini
Do not forget to restart rbfeeder
Rotex43
Runway31 / abcd456
As requested, see attached
#4
I note that you had it working initially with only 20 miles range, did you change anything?
I also not that you have sent back 1,650 UAT packets
#5
abcd
Just to clarify for me, I thought that making network_mode=true would start it and network_mode=false would stop it, is that not the case
abcd567
#6
Quote from: Runway 31 on March 14, 2022, 10:31:54 AM
abcd
Making network_mode=true will STOP the rbfeeder's capsuled dump1090. The rbfeeder will then connect to feed from another source such as dump1090-fa or dump1090-mutability.
Making network_mode=false will START the rbfeeder's capsuled dump1090, and rbfeeder will use feed from it. The rbfeeder will NOT connect to feed from another source such as dump1090-fa or dump1090-mutability.
The dump978-rb does not get controlled by network_mode=true/false. It works if dump978_enabled=true, and stops working if dump978_enabled=false
Many thanks abcd.  I understood the 978 part
Rotex43
Quote from: Runway 31 on March 14, 2022, 10:14:59 AM
The 978 worked for about 2hrs after installing rbfeeder using default config, the data feed stopped and resumed for a short time then quit. This occurred without any changes. As I recall the rbfeeder.ini that was created the 978 was not enabled.
Maybe abcd can come up with something for you as I am not up on Pi's
Rotex43
Looking at the dump978-rb config file line 2 "This is sourced by /usr/share/dump978-rb/start-dump978-rb as a shellscript fragment",
The /usr/share/ folder does not show dump978=rb folder. Am I missing something?
abcd567
what are outputs of following commands?
apt-cache policy dump978-rb
sudo systemctl status dump978-rb
abcd567
#12
pi@raspberrypi:~ $ sudo nano /etc/default/dump978-rb
# dump978-rb configuration
# This is sourced by /usr/share/dump978-rb/start-dump978-rb as a
# shellscript fragment.
# dump978-rb won't automatically start unless ENABLED=yes
ENABLED=yes
RECEIVER_OPTIONS="--sdr driver=rtlsdr,serial=00000401 --sdr-auto-gain --format CS8"
DECODER_OPTIONS=""
NET_OPTIONS="--raw-port 30978 --json-port 28380"
pi@raspberrypi:~ $ sudo nano /usr/share/dump978-rb/start-dump978-rb
#!/bin/sh
# Helper script that reads /etc/default/dump978-rb
# and either starts dump1090-fa with the configured
# arguments, or exits with status 64 to tell systemd
# not to auto-restart the service.
if [ -f /etc/default/dump978-rb ]
then
    . /etc/default/dump978-rb
fi
if [ "x$ENABLED" != "xyes" ]
then
    echo "dump978-rb not enabled in /etc/default/dump978-rb" >&2
    exit 64
fi
exec /usr/bin/dump978-rb \
     $RECEIVER_OPTIONS $DECODER_OPTIONS $NET_OPTIONS \
# exec failed, do not restart
exit 64
pi@raspberrypi:~ $ sudo systemctl status rbfeeder
     Active: active (running) since Tue 2022-03-15 03:42:17 GMT; 39min ago
lines 1-3...skipping...
    Process: 429 ExecStartPre=/bin/mkdir /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 481 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/run/rbfeeder (code=exited, status=0/SUCCESS)
    Process: 488 ExecStartPre=/bin/touch /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 503 ExecStartPre=/bin/chown rbfeeder:rbfeeder /var/log/rbfeeder.log (code=exited, status=0/SUCCESS)
    Process: 509 ExecStartPre=/bin/chown rbfeeder:rbfeeder /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
    Process: 516 ExecStartPre=/bin/setfacl -m u:www-data:rwx /etc/rbfeeder.ini (code=exited, status=0/SUCCESS)
   Main PID: 520 (rbfeeder)
      Tasks: 13 (limit: 4915)
        CPU: 9min 32.860s
             ├─520 /usr/bin/rbfeeder
             ├─28656 /usr/bin/python3.9 /usr/bin/mlat-client --input-type dump1090 --input-connect 127.0.0.1:32457 --server mlat1.rb24.com:40900 --lat 43.5xxxx --lon -79.6xxxx --alt 155 --user EXTRPI000036 --results beast,connect,127.0.0.1:32004
             └─630 /usr/bin/dump1090-rb --write-json /dev/shm/ --net --quiet --mlat --forward-mlat --net-bo-port 30105 --lat 43.5xxxx --lon -79.6xxxx --modeac --fix --adaptive-burst --adaptive-range --gnss
Mar 15 04:19:08 raspberrypi rbfeeder[520]: [2022-03-15 04:19:08]  Data sent: 379.3 KB
Mar 15 04:19:08 raspberrypi rbfeeder[520]: [2022-03-15 04:19:08]  Data received: 31 B
Mar 15 04:20:09 raspberrypi rbfeeder[520]: [2022-03-15 04:20:09]  ******** Statistics updated every 60 seconds ********
Mar 15 04:20:09 raspberrypi rbfeeder[520]: [2022-03-15 04:20:09]  Packets sent in the last 60 seconds: 253, Total packets sent since startup: 11680
Mar 15 04:20:09 raspberrypi rbfeeder[520]: [2022-03-15 04:20:09]  Data sent: 387.5 KB
Mar 15 04:20:09 raspberrypi rbfeeder[520]: [2022-03-15 04:20:09]  Data received: 31 B
Mar 15 04:21:10 raspberrypi rbfeeder[520]: [2022-03-15 04:21:10]  ******** Statistics updated every 60 seconds ********
Mar 15 04:21:10 raspberrypi rbfeeder[520]: [2022-03-15 04:21:10]  Packets sent in the last 60 seconds: 251, Total packets sent since startup: 11931
Mar 15 04:21:10 raspberrypi rbfeeder[520]: [2022-03-15 04:21:10]  Data sent: 396.1 KB
Mar 15 04:21:10 raspberrypi rbfeeder[520]: [2022-03-15 04:21:10]  Data received: 31 B
pi@raspberrypi:~ $ sudo systemctl status dump978-rb
● dump978-rb.service - dump978 ADS-B UAT receiver
     Loaded: loaded (/lib/systemd/system/dump978-rb.service; enabled; vendor preset: enabled)
     Active: active (running) since Tue 2022-03-15 03:42:17 GMT; 33min ago
       Docs: https://www.radarbox.com
   Main PID: 534 (dump978-rb)
      Tasks: 4 (limit: 4915)
        CPU: 4min 16.470s
     CGroup: /system.slice/dump978-rb.service
             └─534 /usr/bin/dump978-rb --sdr driver=rtlsdr,serial=00000401 --sdr-auto-gain --format CS8 --raw-port 30978 --json-port 28380
Mar 15 03:42:18 raspberrypi dump978-rb[534]: Found Rafael Micro R820T tuner
Mar 15 03:42:19 raspberrypi dump978-rb[534]: Reattached kernel driver
Mar 15 03:42:19 raspberrypi dump978-rb[534]: Detached kernel driver
Mar 15 03:42:19 raspberrypi dump978-rb[534]: Found Rafael Micro R820T tuner
Mar 15 03:42:19 raspberrypi dump978-rb[534]: Exact sample rate is: 2083333.135571 Hz
Mar 15 03:42:19 raspberrypi dump978-rb[534]: [R82XX] PLL not locked!
Mar 15 03:42:19 raspberrypi dump978-rb[534]: SoapySDR: using automatic gain
Mar 15 03:42:19 raspberrypi dump978-rb[534]: SoapySDR: using stream setting buffsize=262144
Mar 15 03:42:19 raspberrypi dump978-rb[534]: Allocating 15 zero-copy buffers
Mar 15 03:42:20 raspberrypi dump978-rb[534]: 0.0.0.0:28380: accepted a connection from 127.0.0.1:59588
Rotex43
Quote from: abcd567 on March 15, 2022, 03:08:52 AM
pi@raspberrypi:~ $ apt-cache policy dump978-rb
dump978-rb:armhf:
  Installed: (none)
  Candidate: 1.0.2+deb11
  Version table:
     1.0.2+deb11 500
        500 https://apt.rb24.com bullseye/main armhf Packages
        100 /var/lib/dpkg/status
     Loaded: masked (Reason: Unit dump978-rb.service is masked.)
     Active: inactive (dead)
pi@raspberrypi:~ $
It appears that nothing is working.
Rotex43
abcd
reviewing your last:
The dump978-rb matches mine
The edit command for "/usr/share/dump978-rb/start-dump978-rb" returns directory does not exist.
So question should I creat a folder and file to match your post of the start-dump978-rb file?
