Author Topic: Radarbox switch to Bullseye ok, but issue with VHF stick.  (Read 22106 times)
RZEE
« on: October 29, 2022, 10:49:42 AM »
Hi, after 1.5 years of flawless running RB + Airband VHF on my Pi3+ i recently upgraded to bullseye [32bit]. I did a complete fresh install and RB working as it should,
[EXTRPI011916]
There however is a problem with the Airband VHF setup:
Code: [Select]
E: Unable to locate package rtl-airband-rb
Also, when plug in the airband VHF stick [and reboot] the number of reported planes drop from 70 to 2, even after a hour. If i unplug the VHF stick [and reboot] all is back to normal.
So, somthing goes wrong in the airband installation.The question is: is the Airband VHF not compatible to bulseye? or is there anything else i overlook. I assume it's related to the airband installation error, however i have no clue where to start troubleshooting.
Thanks in advance.
  • Moderator
Re: Radarbox switch to Bullseye ok, but issue with VHF stick.
« Reply #1 on: October 29, 2022, 12:05:17 PM »
Suggest you ask support
« Reply #2 on: October 30, 2022, 07:56:27 AM »
Hi there Alan recently sent me a VHF stick and I can not  get it to work on a new installion on rasp pi, is there any help out there and how to contact support for something like this?
  • Moderator
« Reply #3 on: October 30, 2022, 09:08:39 AM »
[email protected] is their email
RZEE
« Reply #4 on: October 30, 2022, 05:16:06 PM »
Quote
What os you run ?
abcd567
  • CYYZ - Toronto
« Reply #5 on: October 30, 2022, 11:48:49 PM »
[EXTRPI011916]
Code: [Select]
Airban VHF installation script has packages for Stretch and Buster. There is no package for Bullseye. It therefore fails to install AIRband VHF on Bullseye as it detects the OS is neither Stretch not Buster.
The script can be CHEATED to think that your OS is Buster, and then it will install AIRBand VHF package for Buster on Bullseye. Most likely Buster package will work on Bullseye as well.
(A) Follow this procedure to install by CHEATING:
Download and edit installation file by following commands:
Code: [Select]
wget http://apt.rb24.com/inst_rtl-airband-rb.sh
sudo nano inst_rtl-airband-rb.sh
Scroll down to the line starting with word VERS, i.e. the line below
Code: [Select]
VERS=`lsb_release -c | awk -F ':' '{print $2}' | sed -e 's/^[[:space:]]*//' -e 's/[[:space:]]*$//'`
Add a new line VERS=buster Just BELOW the original line, so it becomes like this
Code: [Select]
VERS=buster
Save file (Press Ctrl and O keys together) and Close File (Press Ctrl and X keys together)
Now give following command, and it will install package rtl-airband-rb
Code: [Select]
sudo bash inst_rtl-airband-rb.sh
After installation is completed and AIRBand VHF is running OK, REMOVE CHEAT by following procedure:
Open sources list file for editing by following command
Code: [Select]
sudo nano /etc/apt/sources.list.d/rb24.list
You will see this line:
Code: [Select]
deb https://apt.rb24.com/ buster main
In above line, replace word buster by bullseye, so the line becomes as below:
Code: [Select]
deb https://apt.rb24.com/ bullseye main
Save file (Ctrl and O Keys together) and Close file (Ctrl and X keys together)
Now update apt
Code: [Select]
sudo apt update
« Last Edit: October 30, 2022, 11:51:18 PM by abcd567 »
RZEE
« Reply #6 on: October 31, 2022, 08:06:15 PM »
Quote
Thanks for this. the Airband installation seems to work flawless  now, but still  no VHF reception possible.
Also, the initial problem remains: when both sticks are plugged in the PI, adsb reception drop from 99 planes to 3 planes. It goes back to normal after removing the VHF stick.
I assume there still is a issue the VHF stick got not recognized correctly causing the issues.
abcd567
  • CYYZ - Toronto
« Reply #7 on: October 31, 2022, 09:17:18 PM »
Seems at startup, dump1090 grabs Yellow AirBand dongle, and Airband grabs Green 1090 Mhz dongle
You will need to Serialize both dongles with different serial numbers, and add this info in the respective config files of dump1090 and Airband.
(1) Please post output of last command below
Code: [Select]
sudo apt install rtl-sdr
sudo systemctl stop rbfeeder piaware dump1090-rb dump1090-fa rtl-airband-rb
rtl_test -t
(2) Please post output of following commands
Code: [Select]
cat etc/rtl-airband-rb.conf
cat /etc/rbfeeder.ini
(3) Please serialize the Green (1090 MHz) and Yellow (AIRBand VHF) dongles to serial numbers below
Green (1090 MHz) Dongle Serial Number = 00001090  (Eight Digits)
Yellow (AirBand VHF) Dongle Serial Number = 00000118  (Eight Digits)
Plug one Dongle at a time, serialize it, unplug it.
Next plug second dongle, serialize, and unplug it.
Finally replug both dongles.
Use How-to here.
https://forum.radarbox24.com/index.php?topic=19831.0
After Serializing, give following command to find which dongle is device 0 and which is device 1.
Quote
pi@raspberrypi:~ $ rtl_test -t
Found 2 device(s):
  0:  Realtek, RTL2832U, SN: 00000118
  1:  Realtek, RTL2838UHIDIR, SN: 00001090
Using device 0: Generic RTL2832U OEM
usb_claim_interface error -6
Failed to open rtlsdr device #0.
In example above, the device 0 is the AirBand Yellow dongle (Serialized by me as 00000118). Therefore in AirBand config file I will use index = 0;.
Thr device 1 is the Green 1090 Mhz dongle (Serialized by me as 00001090), and therefore in file /etc/rbfeeder.ini, under [client], I will add line
dump_device=1
OR better
dump_device=00001090
AIRBAND CONFIG FILE
Quote
cat /etc/rtl-airband-rb.conf
# This is a minimalistic configuration file for rtl-airband
# Please change frequencies that you will use and other settings.
# Note: this configuration will use your second dongle attached
# to you raspberry, not the first one!
# index = 0     => First dongle
# index = 1     => Second dongle
devices:
  type = "rtlsdr";
  index = 0;
  gain = 28;
  correction = 0;
  mode = "scan";
  channels:
          #squelch = 35;  # Uncomment to set squelch manually
      freqs = ( 118000000, 119550000, 126000000 );
      labels = ( "Tower", "Ground", "Approach" );
      outputs: (
          type = "icecast";
          server = "audio.rb24.com";
          port = 8000;
          mountpoint = "EXTVHFXXXXXX";
          name = "My Transmitter";
          genre = "ATC";
          username = "<RadarBox Login E-mail>";
          password = "<radarBox Password>";
          send_scan_freq_tags = true;
                # If you need more outputs, put here
« Last Edit: November 02, 2022, 03:58:35 PM by abcd567 »
RZEE
« Reply #8 on: November 02, 2022, 06:38:32 PM »
Quote
Ok, thanks again! My dongles should be serialized from my previous setup, but i will check and report back asap. It might take a few days.
RZEE
« Reply #9 on: November 05, 2022, 12:23:46 PM »
Ok some more testing done, i added the device serial to the feeder config. this seems to fixed the dissapearing planes when connecting 2 The adsb aswell the VHF stick.
Quote
Code: [Select]
rtl_test -t
Result:
Code: [Select]
pi@raspberrypi:~ $ sudo apt install rtl-sdr
rtl_test -t
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
rtl-sdr is already the newest version (0.6.0-3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Failed to stop piaware.service: Unit piaware.service not loaded.
Failed to stop dump1090-rb.service: Unit dump1090-rb.service not loaded.
Failed to stop dump1090-fa.service: Unit dump1090-fa.service not loaded.
Found 2 device(s):
  0:  Realtek, ADSB, SN: 00001090
  1:  Realtek, VHF, SN: 00000118
Found Rafael Micro R820T tuner
Supported gain values (29): 0.0 0.9 1.4 2.7 3.7 7.7 8.7 12.5 14.4 15.7 16.6 19.7 20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
No E4000 tuner found, aborting.
Quote
Code: [Select]
Code: [Select]
pi@raspberrypi:~ $ cat etc/rtl-airband-rb.conf
cat: etc/rtl-airband-rb.conf: No such file or directory
[client]
network_mode=false
key=557248f783cfc1b6c364bd2d41f0fxxx
sn=EXTRPI011916
lat=52.244320999999999
lon=4.8257599999999998
alt=9
[network]
mode=beast
external_port=30005
external_host=127.0.0.1
[mlat]
autostart_mlat=true
[dump978]
#dump978_enabled=true
pi@raspberrypi:~ $
Quote
Done:
Code: [Select]
Found 2 device(s):
Airband config file:
Code: [Select]
pi@raspberrypi:~ $ cat /etc/rtl-airband-rb.conf
devices:
  type = "rtlsdr";
  index = 0;
  gain = 28;
  correction = 0;
  mode = "scan";
  channels:
      freqs = ( 118105000, 119550000, 126000000 );
      outputs: (
          type = "icecast";
          port = 8000;
          mountpoint = "EXTVHF000594";
          name = "Schiphol Tower";
          genre = "ATC";
          username = "[email protected]";
          password = "********";
pi@raspberrypi:~ $
So the result now is:
ADSB dongle works fine, even with both ADSB & VHF dongles plugged in.
The VHF part still not functional
Any more suggestions ?
abcd567
  • CYYZ - Toronto
« Reply #10 on: November 05, 2022, 01:12:10 PM »
Done:
Found 2 device(s):
From above, the Airband dongle is device index 1
But in Airband config file you have used device index = 0;, (as shown in red below)
Quote
devices:
  type = "rtlsdr";
  index = 0;
  gain = 28;
  correction = 0;
  mode = "scan";
  channels:
Quote
Change index = 0; to index = 1; in Airband config file, Save file, and REBOOT Pi.
« Last Edit: November 05, 2022, 01:23:20 PM by abcd567 »
RZEE
« Reply #11 on: November 05, 2022, 04:09:23 PM »
Quote
Ok thanks, done that:
Quote
devices:
  type = "rtlsdr";
  index = 1;
  gain = 28;
  correction = 0;
  mode = "scan";
  channels:
      outputs: (
          type = "icecast";
          port = 8000;
          genre = "ATC";
          username = "**********";
          password = "**********";
No result for this, so checked the dongle config again. This however seems ok.
Code: [Select]
pi_raspberrypi:~ $ rtl_eeprom
Found 2 device(s):
  1:  Generic RTL2832U OEM
pi_raspberrypi:~ $ rtl_test
Found 2 device(s):
pi_raspberrypi:~ $
Additional test:
Sending a audio stream from the rocketbooster app  [from my windows machine] will show the player in the EXTVHF000594
abcd567
  • CYYZ - Toronto
« Reply #12 on: November 05, 2022, 04:53:39 PM »
You can individually check health of rtl-airband-rb and rbfeeder by following commands
Code: [Select]
sudo systemctl status rtl-airband-rb
You can check the health of each dongle by stopping rbfeeder and Airband software, then twice issue rtl_test -t command, once specifying device index 0 and next specifying device index 1 as follows:
(1) First stop rbfeeder and rtl-airband-rb to free the dongles for test.
Code: [Select]
sudo systemctl stop rtl-airband-rb
(2) Test device with index 0 (test command rtl_test -t -d 0 )
Code: [Select]
rtl_test -t -d 0
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00001090
(3) Test device with index 1 (test command rtl_test -t -d 1 )
Code: [Select]
rtl_test -t -d 1
Found 1 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000188
(4) Restore rbfeeder and rtl-airband-rb, AND test their status
Code: [Select]
sudo systemctl restart rtl-airband-rb
NOTE: In above tests, instead of using device index -d 0 and -d 1, you may use device serial -d 00001090 and -d 00000118
« Last Edit: November 05, 2022, 04:55:22 PM by abcd567 »
RZEE
« Reply #13 on: November 05, 2022, 06:52:59 PM »
As the ADSB runs good i focus on Airband config,
Running:
Code: [Select]
sudo systemctl status rtl-airband-rbresults in:
Quote
~ $ sudo systemctl status rtl-airband-rb
● rtl-airband-rb.service - SDR AM/NFM demodulator
     Loaded: loaded (/lib/systemd/system/rtl-airband-rb.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Sat 2022-11-05 18:16:34 CET; 8min ago
     Process: 1416 ExecStart=/usr/bin/rtl_airband -e -c /etc/rtl-airband-rb.conf (code=exited, status=0/SUCCESS)
   Main PID: 1418 (code=exited, status=1/FAILURE)
        CPU: 116ms
Nov 05 18:16:33 raspberrypi systemd[1]: Starting SDR AM/NFM demodulator...
Nov 05 18:16:33 raspberrypi systemd[1]: Started SDR AM/NFM demodulator.
Nov 05 18:16:34 raspberrypi systemd[1]: rtl-airband-rb.service: Main process exited, code=exited, status=1/FAILURE
Nov 05 18:16:34 raspberrypi systemd[1]: rtl-airband-rb.service: Failed with result 'exit-code'.
abcd567
  • CYYZ - Toronto
« Reply #14 on: November 05, 2022, 08:27:17 PM »
The rtl-airband-rb has failed to start
What is the output of following command:
Code: [Select]
sudo journalctl -u rtl-airband-rb -n 30
