unable to connect
Started by vonsmalhausen, December 31, 2025, 09:38:34 AM
vonsmalhausen
does somebody else have this ? since yesterday i am unable to run the software on PC, it seems it can not connect.
the program launches normal till the point it should connect with AN server ; it stalls and after some time i get the message that due to security reasons after 3 attempts to register the program the app will be closed.
up to 2 days ago all went fine, and i have it on both my PC and Laptop
tried to contact support yesterday, but no response so far.
hungryasthesea
I reported yesterday morning and got a response from Alex saying
'Apologies there is an issue on our backend that we are working on.'
Hungryasthesea
vonsmalhausen
AviaSpotter
Exactly the same problem since Monday at 5 p.m. On two PCs, one with Windows 10 and the other with Windows 11. I also tried writing to support, but I haven't received a reply yet.
Michel
I thought it was just me. It does work in my old laptop, but it doesn't start on my new laptop. So thought there was some problem on my side. Have reinstalled the programm with same negative result. But ok, we'll just have to wait. No problem.
eagle11
Exactly the same problem here (Windows 11, software 6.01.001). Perhaps it's unnecessary to mention it since it's known to support; I just want to point out that this is happening to more users.
GreekSpy2001
Just to add.  I was running fine as I run 24/7.  Updated DB and restarted now can't log in!! 13:57 GMT 31/12.  Oh well back to ADSB Exchange
vonsmalhausen
i also did a DB update before i got these connection troubles, could it be linked ?
#8
The database updater has no connection to any issue you may be having, all that gets updated is the database and nothing of the software gets updated or altered in any way
I just started in V6 and all is working ok for me
Edit:  Have now carried out a d/b update and restarted and everything is still working ok for me so any issue appears to have been resolved
hungryasthesea
Quote from: Runway 31 on December 31, 2025, 02:36:40 PM
I have just restarted my laptop and is still just hanging trying to connect,
Hungryasthesea
#10
No idea why mines is working ok and yours isnt, see attached shot
Has there been a Windows update on your computer which has caused an upset with the drivers, try updating the drivers.  Windows updated have previously caused driver issue as the drivers are replaced with Microsofts own ones, requiring the correct drivers needing to be reinstalled
I have contacted a Spanish user and he is having no issue
vonsmalhausen
i had no windows update between all working and no longer being able to connect
GreekSpy2001
My reference to the update process was the fact that i had ran to update and so had to restart for it to take effect. not linking the two just the reason for my restart, and now locked out.
I think we have seen this before.  Problem with the authentication system.  Allows some users in whilst blocking others.
Cheers Graham for the info
Other than reinstalling drivers I have no other ideas
cosmefulanito
I have the same problem, I get the message that for security reasons, after 3 attempts to register the program, the application will close.
I also have 2 xrange stations and they are not online either.
