New Silhouettes
Started by RodBearden, August 19, 2008, 11:19:45 PM
0 Members and 32 Guests are viewing this topic.
Quote from: neroon79 on September 03, 2010, 11:56:28 AMC10T (CESSNA     P210 (turbine) ) not very common here, but from time to time
Yes, Turbine 210s are like hen's teeth, AFAIK there are fewer than 10 worldwide, although at least two of those are in Europe.
EK01
I don't seem to have a silhouette for the AS350B or I have inadvertantly deleted it (more likely). Any chance of a redo?
neroon79
Eurocopter AS-350 B, ICAO Designator: AS50
11.75nm ESE of EDDV
HW:
Cable: 25m of ECOFLEX 15+
NB: Asus P53E 24/7 op.
PC: 28"4K + 24" Monitor
AirSpy mini @RPi3
Here come more "silhouettes":
C10T
KL07
B407
B105
More follow...
By special request:
SB29 Saab 29 Tunnen
Quote from: RodBearden on September 12, 2010, 05:12:35 PMSB29 Saab 29 Tunnen
I think you mean Tunnan, although that wasn't an official name, given that it's Swedish for "barrel" !
Must learn to trype better ;-)
anorak
Thanks Rod, tis in my flowder,  Dave.
Dave. Exmoor, North Devon.
#99
Now that we're getting an aircraft code of Test for various Boeings and Airbuses, I thought folk might like something to fill the gaps in the silhouettes column. Take your choice. Rename Test-1.bmp to Test.bmp if you want to use that.
EDIT - I just remembered that the "standard" silhouettes are narrower than the "photo" ones that I normally do, so I've resized it so that it doesn't stick out from the others.
#100
Here's a zip with 23 "silhouettes" including the ones posted here since the previous zip, plus a few extras including the sample here.
I've been using these "silhouettes" for a while and find them fairly useful. There's one for the photo-style and one for the smaller conventional style.
Take your pick and copy/rename them for other examples of wrong type codes which currently appear despite the best efforts of the database updaters. Examples include A380, B77F and BKC3.
neroon79
#102
Hi Rod, it would be great, if could make a photo silhouette for the Aerospatiale    SA-365C Dauphin 2 (S65C), because PHOENIX Hannover/Hildesheim uses one of these for their "surveillance flights"  along the A2 -which is very close to my home position-
EDIT: A link to some Pictures: http://www.planepictures.net/netsearch4.cgi?stype=reg&srng=1&srch=D-HOPE
Thanks for the "wrong code" "silhouettes" they're indeed very useful By< the way: Another very common is B77F instead of the correct B77L
About the TEST "silhouette": I just considered to ask you about doing one by using some "green Aircraft" in one Picture. Now I decided to use the yellow/red one but I will change the RED into Green or the yellow background into green. Have to see which combination looks better ;-)#
Thanks again!
Ingo
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
#103
Hi Ingo
Thanks for that - here's the S65C and a green Wrong Code silhouette, though a lot of te "test" aircraft aren't actually green :-)
EDIT Oops - did a wrong Silhouette instead of a Test one - now rectified.
Hope you like them.
While I'm at it, here's another thai I've done recently, the R722
neroon79
Hi Rod!
Well, the "real" Test AC are usually not green, but the first flights of new Airbus "Birds" on their maiden flights are often green. Same is valid for the ferry flights  from tls to do the "paint-job" in xwf. Anyway, I like the green on yellow TEST icon more, because red on yellow is a kind of to intense/aggressive colour combination for my eys. ;-)
Another Request:
A Photo Silhouette for the Cessna 414 Chancellor (C414) would be great.
11.75nm ESE of EDDV
HW:
AirSpy mini @RPi3
