User-generated RadarBox Location Map
Started by RodBearden, November 17, 2008, 11:49:58 AM
abrad41
Yes I see the problem tarbat, do you think it would be a good idea to remove the BLACK = Approx. location of all Radarboxes.
Andy
I'm not sure.  The black ones are really useful data provided by Airnav of actual boxes sharing, so potentially more reliable than anything else.
When the Rugby finishes I'll see if there's a better solution.  Unless anyone knows how to get Google Maps to display all pins on a single map?
Tarbat - perhaps you don't need the black dots that duplicate the pins, for example, Chorley doesn't need to be there twice, unlsee you know otherwise!
PS - Sorry I interfered with Australia before I saw what you were doing - I'll leave it to you!
#78
Okay, I've deleted the black ones, and put those onto a separate list.
USER SUPPLIED LOCATIONS
AIRNAV SUPPLIED LOCATIONS
I should add that the second map is based on a list of Towns/Cities, converted to coordinates using http://www.batchgeocode.com/ , so may not be totally correct!!!
CoastGuardJon
dca
Added my location, Burgess Hill, 12 nm south of LGW
9 nm south of LGW
Just a reminder to anyone with a RadarBox connected to the network that you're very welcome to add your pin to the map - you don't need to be precise - just your nearest town would be fine.
If you have a Google ID you can add your own pin, or just ask on this thread, and we'll add it for you.
Click here to view the map: http://maps.google.com/maps/ms?ie=UTF8&hl=en&oe=UTF8&msa=0&msid=105277615186365824795.00045be4dc8f432ddcfba
PS could yulilgit please move his pin to somewhere on the planet? ;-)
nortonbeak
Quote from: RodBearden on November 30, 2008, 12:24:11 PM
I note that yulilgit isn't actually a forum member.
peteeds
Hi Rod, Can you please add me on the map, If you zoom in on Llangollen, then go directly south you will see Glynceiriog that's where I am located.
Many thanks. Peteeds.
mjleprix
Rod -could you add me to the map please. I am in Stone in Staffordshire
mjleprix
Terry
Hi Rod,
           May as well add me to the map if you don`t mind,i`m in Banbury,N.Oxfordshire,thanks.
               Regards Terry.
