AirNav RadarBox 2007 - Version 1.2 (Patch Beta 2) Available for Download
Started by AirNav Development, September 08, 2007, 01:22:12 AM
doro
"The other part you asked me to try failed.  Firmware 1.1 will not do anything as it says Device cant be found, which is the same as 1.2 firmware update.
I have a feeling it screwed the firmware!!!!"
Are you running the firmware 1.1 excutable from the airnav directory?
DaveG
Quote from: doro on September 08, 2007, 07:30:38 PM
Almost "fimware is showing that 1.01.2" no the upgrade screen shows
Version 1.01.0
Updating Version 1.01.2
But I cannot verify if it actually did upgrade... It think it did not. How do I verify?
The green box in the software now and then goed red. There is no data collected, and I had excellent reception, and I can see on the network that there is traffic I normally pick up. So we are not there quite yet...
Is your RB Box got a USB connection then?  lefthand blue light ?
Cornwall, UK
DaveG
Support:
Different USB Port did not change anything and that was one I know it had never been in.
Need a break, so taking dog for 15min walk.  When I get back I'll check the box by moving it onto my other PC.
BRB
Cornwall, UK
Version 1.01.0
- Shut down RadarBox
- Unplug the RB box from your PC
- Pause 2 seconds!
- Plug RB Box back in
- Run Radarbox - keep fingers crossed!
doro
Deleting and reinstall the drivers from the Beta 1.2 with the have disk option.
Make sure you follow the hardware upgrade path:
First Beta 1.1 hardware Upgrade executable from the airnav directory.
After that Beta 1.2 hardware Upgrade executable from the airnav directory.
Reboot the PC.
Start Airnav.
Pull out the USB cable and reconnect it.
Pfeeuwww! Thanks for the support. Ron
Quote from: doro on September 08, 2007, 07:44:07 PM
Reboot the PC.
Start Airnav.
Well done Ron !!!!!!!!
Thank god, ok one customer down. 2 to go.
Lets see if DaveG can do that now and we will be on a hatrick.
DaveG
Cornwall, UK
doro
Quote from: AirNav Support on September 08, 2007, 07:46:21 PM
I'll be here seeing if I can be of any assistance comparing situations.
Thans by the way for the xcellent support.
Ron ATCbox.com
DaveG
okay just tried the following:
Installed clean CD & Drivers  (still installs as "USB Serial Converter"
hardware did connect & no blue USB light lit)
Copied 1.1 patch into folder
tried firmware update - device not found
Copied 1.2 files into folder
Tried updating device driver "USB Serial Converter" to 1.2
result:  "The specified location does not contain information about your hardware"
Cornwall, UK
DaveG
Question:  To test the box,
If I copy the folder Drivers onto the other PC  (excluding radarbox software)
Should I be able to test if the USB connection and drivers work  (Vista PC)
Cornwall, UK
doro
"Copied 1.1 patch into folder
tried firmware update - device not found"
Did you copy it into the airnav folder?
DaveG
yes, my problem seems to be drivers to connect to the box  (No blue USB light)
Cornwall, UK
DaveG:
Its likely Windows is being a pain and we need bypass its methods try:
copy FTDI.SYS (the one in the new patch) to %SystemRoot%\System32\drivers\ and reboot. (backup your old one in cas)
Then go to device manager, find RadarBox (if it appears that way) and try the update as mentione earlier.
doro
Yeah. Did the software work before on a machine? You could use that machine to run the hardware upgrade 1.1
