Roadrunner
#225
Quote from: EK01 on June 19, 2009, 09:16:30 PM
When I go to 'MAP' at the top of the screen, click on it then 'Set Map To' a list of the various countries comes up but the countries I added on version 2 do not seem to be there. However when I go into C:\AirNav Systems then into AirNav Radarbox 2009 and then into the Map folder all the maps I created in version 2 are there. How do I get these maps to go into the drop down map menu in version 3 without having to individually create them all over again.
I found that V3 beta creates a new set of folders and files specofocally for the beat so you need to be sure you have the maps in the correct folder for the 3beta version....
Cheers,
I found that V3 beta creates a new set of folders and files specifically for the beta so you need to be sure you have the maps in the correct folder for the 3beta version....
Quote from: John Racars on June 20, 2009, 07:26:41 AM
Hi Support and All,
I just made my SQL-report of yesterday flightmovements in my area of reception. I did the same I always did before installing version 3.0 Beta.
The results are to cry so bad. If you like to see the report, please let me know and I will sent it to you. When anlyzing this report maybe it gives you possibly an impression of the problems.
Can you at least give us a clue - what's the problem?  My daily SQL report looks okay - see yesterday's report at http://www.tarbat.gofreeserve.com/data.html
What SQL are you using?
John Racars
Quote from: tarbat on June 20, 2009, 07:50:54 AM
The same as you give to me around 2-3 weeks ago:
SELECT
  Flights.Route,
  Flights.Callsign,
  Flights.EndTime,
  Flights.ModeS,
  Flights.MsgCount,
  Flights.Registration,
  Flights.Session,
  Flights.StartTime,
  Flights.StartPosition,
  Flights.EndPosition,
  Flights.StartAltitude,
  Flights.EndAltitude,
  Flights.StartGS,
  Flights.EndGS,
  Aircraft.Comment,
  Aircraft.LastTime,
  Aircraft.FirstTime,
  Aircraft.AircraftTypeLong,
  Aircraft.AircraftTypeSmall,
  Aircraft.Airline,
  Aircraft.ModeS,
  Aircraft.ModeSCountry,
  Aircraft.Registration,
  Aircraft.ADSB
FROM
Flights
LEFT OUTER JOIN Aircraft ON (Flights.ModeS=Aircraft.ModeS)
WHERE
  (Flights.StartTime LIKE '2009/06/19%')
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
#228
Airnav, I do think we need an adjustment to the length of time used to decide whether a new flight has started.  At the moment, with just a couple of minutes lost signal from an aircraft, Radarbox creates a new flight record in the log.
I would suggest a time interval of 15 minutes.  Does that sound reasonable?  Or is this tied-in to the timeout settings?
See examples in my daily report - G-CIVD is a good example, three flights:
BAW285 ended 12:50
BAW285 ended 12:55
BAW285 ended 13:09
TedLoon
tarbat i agree but looking at your log you would still have picked the flight up twice even with a 15 minute interval. what about 30-45 min
colin
Quote from: freqhopping on June 18, 2009, 10:58:56 PMI'm not getting any KC-135 flight IDs though.  I still need to verify with an SBS user as to whether or not they even have a flight ID.
One in my log yesterday - 58-0093 with FlightID QID95.  See log at http://www.tarbat.gofreeserve.com/data.html
In fact, looking through my previous days' logs, I see several KC-135s with FlightIDs like RCH0345, EXPO88, etc.
#231
Quote from: TedLoon on June 20, 2009, 08:15:49 AMtarbat i agree but looking at your log you would still have picked the flight up twice even with a 15 minute interval. what about 30-45 min
Remember you're only seeing the END TIME in my log report.  I'd expect the time interval to be between the END TIME and the next START TIME.
30-45 minutes could mean that an aircraft lands, and then takes off, and you'd only get one flight record in the log.  Would only be a problem for aircraft without FlightIDs, because typically the FlightID would change between landing and takeoff.
I think anything more than the turnaround time could be a problem.  As an experiment today, I've increased my TIMEOUT time in preferences to see what that does to the log.
Quote from: tarbat on June 20, 2009, 08:20:08 AM
There's a discussion about this issue earlier on in this thread:  www.airnavsystems.com/forum/index.php?topic=2893.msg25878#msg25878
I had the same problem with my LHR database, trying to decide how soon an aircraft can feasibly reappear after landing - the answer IMHO is to make the "new-flight timout" a user-configurable parameter.
Quote from: DaveReid on June 20, 2009, 08:32:01 AMThere's a discussion about this issue earlier on in this thread:  www.airnavsystems.com/forum/index.php?topic=2893.msg25878#msg25878
Agreed.  15 minutes sounds like a useful default, and maybe let the user change that in Preferences.
Airnav, can we get this change included in the next beta?
dumpty
This is a wierd one;
On the map display i keep losing the plane symbol and info from any new planes coming on to the display particuarly fom the bottom of the screen going north.If it weren't for the trails I wouldn't know they were there.
However if i zoom in or out the plane symbol and info appear no problem!
Keep up the good work airnav.
Simon
vruma
Quote from: dumpty on June 20, 2009, 08:56:50 AM
Simon
Somehow my observation seems similar to the quoted post of Simon: having the map open for a while, one can see for instance three flights displayed on that map. When now you zoom out and back in again, suddenly there are many more than those three flights shown. Could this be a screen refresh problem?
EMA
#236
Simon
Looks like a similar problem to what I have experienced and posted earlier. I have seen this in the closed beta and the open one. I guess others are missing this because the aircraft are not there unless you zoom in/out. They do appear in the aircraft list but not the map so it looks like a map redraw issue.
UPDATE
After posting this I looked at my map and no aircraft were visible just a few odd trails, zooming in/out and 8 aircraft popped out of nowhere.
EMA
Another new issue
When starting the program with hardware and network flights enabled I see network flights on the ground at my local airport that take 5 minutes to timeout, this did not happen in V2. They do go if I switch network off/on.
EK01
Quote from: Roadrunner on June 20, 2009, 07:43:47 AM
Cheers,
Roadrunner,
Not computer literate. Which is the best and easiest way to do this.
Quote from: tarbat on June 20, 2009, 08:20:08 AMAs an experiment today, I've increased my TIMEOUT time in preferences to see what that does to the log.
Quick update on this.  Not a definitive answer, it needs more long-term testing, but increasing the timeout times for local flights appears to cure this problem of duplicate entries in MyLog.
Since 09:00UTC I've been running with local timeouts of 110/790 (total of 15 minutes), and have NO duplicate flight records in My Log.  If you want to try this, also remember that you might want to filter the aircraft list on Status<>1Timeout
Would be useful for others to test this to see if they still get duplicate log entries.
