Author Topic: Duplicate alerts - popup & email  (Read 25859 times)
EMA
Re: Duplicate alerts - popup & email
« Reply #45 on: September 18, 2009, 12:29:00 PM »
Okay
To add to PJM's post, I use email alerts with no problems. I set aircraft to A* and B* and receive an email alert for each type as they are detected.
I then enabled show notification as well and now I have two alerts for each aircraft detected.
Kevin
« Reply #46 on: September 18, 2009, 02:52:50 PM »
Maybe we didn't understand correctly: can you confirm all is working as expected?
« Reply #47 on: September 18, 2009, 02:54:40 PM »
PJM: explaining again what you are getting is not an error. If an aircraft meets more than one condition in the alert fields you will get more than one alert for the same aircraft.
pjm
  • RadarBox Beta Testers
« Reply #48 on: September 18, 2009, 11:54:38 PM »
I don't believe the aircraft are meeting more than one condition. I believe the only condition they are meeting is the Aircraft type.
There is only 1 aircraft in the entire database that would meet 2 conditions and that is a B744 with registration VH-OJK, but I get the duplicates with all types.
Currently I have email alerts disabled and everything is working as expected.
After reading EMA's posts above I'm going to swap the switches - i.e. turn notifications off & email on and see what happens.
pjm
« Reply #49 on: September 19, 2009, 01:05:21 AM »
Strange things happening with email now - possibly problems with the email server again?
Also I haven't been able to email yesterdays log to me.
pjm
« Reply #50 on: September 19, 2009, 02:59:56 AM »
Never mind - I just saw you post in the v3.05 thread about the problems with the mail server.
I'll do some more testing once its back in business again.
« Reply #51 on: September 19, 2009, 06:51:39 AM »
Tks. The duplicate condition that is happening is not being reported by any other beta tester so it has to be something related to your alert setup. Check only one alert option (for example only by registration), set only one alert method and let us know if the problem continues.
EMA
« Reply #52 on: September 19, 2009, 07:33:44 AM »
I can confirm that in my case if I set mulitple alerts I get multiple notifications for the same aircraft if I just set play sound and show notification I only get one alert.
I presume that is how it should work?
« Reply #53 on: September 19, 2009, 08:44:42 AM »
It is the way it should work.
abrad41
« Reply #54 on: September 19, 2009, 08:51:19 AM »
AirNav
Have you resolved your e-mail/server problems, I am not getting any e-mail notifications.
Andy
« Reply #55 on: September 19, 2009, 08:55:49 AM »
Not yet unfortunately. We are still waiting for our ISP answer to this. It is their firewall that is causing the problem. We hope we have it solved in 2 hours.
pjm
« Reply #56 on: September 19, 2009, 08:58:12 AM »
Just so I've got this right.
If I select A320 as the only alert type like so
Then I select email alerts
All works correctly and I get just a single email alert
Then if I also select popup notifications as well
I am supposed to get TWO email alerts for the same A320?
If this is working as designed you can blow me down with a feather!
« Reply #57 on: September 19, 2009, 09:03:09 AM »
I only get one email alert with these settings.
EMA
« Reply #58 on: September 19, 2009, 09:08:54 AM »
PJM
I can confirm that I get the same as you.
pjm
« Reply #59 on: September 19, 2009, 09:11:59 AM »
While we are on this topic, what is the rationale for all email alerts to go via the AirNav email server?
Wouldn't it make sense to allow the users to set their own, or their ISPs SMTP server like we do for all other emails we send?
