Duplicate alerts - popup & email
Started by pjm, September 06, 2009, 07:47:28 AM
GlynH
Quote from: pjm on September 19, 2009, 09:58:04 AM
I don't get the duplicates for Network flights either, only local ones.
Also running XP SP3 here.
Well for once I can confirm I am not currently getting duplicate alerts here like you show in the screenshot above Peter and I have the same boxes checked as you do.
I also have a lot of Alerts setup.
That is strange...maybe a second entry or something hanging around in the registry?
-=Glyn=-
GlynH
Quote from: Allocator on September 19, 2009, 10:20:39 AM
Glyn, you might have read that the AirNav mail server is having problems at the moment, so you won't get any email alerts until it's up again.
Yes I do realise that Gary but the whole point of my post was to bypass the AirNav servers so killing this problem at a stroke...it is not the first time (nor the last time I suspect) that there will be problems and to me it seems like an unecessary link in the chain.
It only serves to highlights my example...
-=Glyn=-
GlynH
#77
Quote from: tarbat on September 19, 2009, 10:15:45 AM
Please don't delay v3.05 public beta for another feature request.  We need to get v3.0? out to public beta asap.
Glyn, why not add this request to the Future Version Suggestions / Requests thread - http://www.airnavsystems.com/forum/index.php?topic=2885.0
That's exactly what I meant...and exactly what I  have done :-)
Quote from: GlynH on September 19, 2009, 10:04:28 AMHow about it AirNav - maybe not mess with 3.05 Beta/Public Beta but when the dust settles include it in the Public Release?
Meant not to mess with 3.05 Beta/Public Beta but when the dust settles include it in a finished version.[/quote]
Already done...see suggestions under 11. Interestingly at the time of that post in June I read that I had submitted that very list a year previous;
http://www.airnavsystems.com/forum/index.php?topic=2885.msg25713#msg25713
-=Glyn=-
GlynH
I see the RSS feed is back on as it was showing nothing here for me all morning but is the email server working correctly yet?
It's just that I never received the email alerts or log from this morning and about 10 minutes ago I tried to send some more logs and alerts and I have not received those either?
-=Glyn=-
Email alerts should be working again now. Anyway we still have problems with our email server (incoming email). It will take 24 hours for the new email DNS settings to propagate so the problems.
Regarding this duplicate alerts problem: any user experiencing it adding to PJM?
pjm
Quote from: pjm on September 19, 2009, 08:58:12 AM
I am supposed to get TWO email alerts for the same A320?
OK - More testing and I can confirm I only get the duplicate alerts when BOTH
  • Show a Notification Message AND
    Send an EMail to the following address
are checked. Turning either of them off and I only get a single alert.
EMA
#82
This morning I setup RB with several alerts, and turned on PLAY A SOUND, SHOW A NOTIFICATION MESSAGE, and SEND AN EMAIL.
Since then I've had many alerts, none of them duplicates.  Strange.  I'm not denying there's a problem, but there must be something specific to the PC/RB setup that's causing this.  Or does it only happen on a certain TYPE of alert?
EMA
This problem does not bother me but I am sure it will be grabbed by the horns on public release.
I only use notification normally the only reason I set email alerts was to replicate PJM.
abrad41
No problems with duplicates at my end.
Set up below.
Andy
I'm not getting any duplicate alerts, either, but email alerts still aren't working.
Quote from: RodBearden on September 20, 2009, 11:13:17 AMI'm not getting any duplicate alerts, either, but email alerts still aren't working.
Email alerts are working okay for me.  Just received an email alert 6 minutes ago.
They have just started arriving for me now :-)
GlynH
Alerts & emailed logs working OK here now with no duplicates that I can see.
Thanks & regards,
-=Glyn=-
pjm
Quote from: EMA on September 20, 2009, 08:21:14 AM
Only seems to happen with "Aircraft" and "Registration" alerts, but not always!!!
