V3.05 Available
Started by AirNav Development, September 18, 2009, 05:44:56 PM
I'm puzzled by the Luftwaffe + signs - I'm sure Airliners.net used to have them, but they're not there any more - I can't find any, anyway. I had manually set up some photos for many of their A310's with registrations including the + signs, and one of them is on the network at the moment. I changed the registration to leave out the + sign, and RB duly retreived the correct photos. The data was already correct, so no overwriting problem there.
The aircraft is just about to land, so I won't be able to change the details to see if RB overwrites them. Anyway, I suggest we forget this problem for now and see what happens if any more + signs occur in future.
The latest version seems excellent so far.
CAM
Network was OK on 3.06 post #90 from last night until now, will try post #119 for any issues but all seems to be OK.
Seemed to go a lot better from V3.06 is this when the change was made Airnav ?
CAM
This latest version ran without any problems for me all today.  This version gets the okay from me to go to public beta.
EMA
Quote from: RodBearden on September 24, 2009, 03:32:30 PM
Airliners.net does not use the + sign
CAM
Quote from: CAM on September 24, 2009, 04:12:05 PM
CAM
3.06 version from post#119 just threw a wobbler on the network, aircraft 424915 was showing around 600 times as the network number went up to 1339. See attached.
Maybe just a one off ?
CAM
[attachment deleted by admin]
Ouch! - looks nasty - I've certainly never seen anything like that.
Does look strange.  I've never seen that myself, and I've been running the network solid for the last couple of days, and watching it very carefully.
Could it be an internet connectivity or latency thing.  CAM, what's your internet connection?
CAM: we sincerely make no idea about that one. Pls keep it running and report if the problem continues.
EMA
The latest exe is very stable, no issues at all for me.
Like a few other beta members my network is coming to an end it does not seem a year since I had my first radarbox. I will continue beta testing until the release of this version then leave it to those that are far more capable than I.
It has been informative working with you all.
Kevin
CAM
I am on BT Internet and receive around 4mb of the alleged 8mb I should get, the broadband connection is rock solid, I know this because a couple of months ago I lost everything and ended up having a new phone line fitted and its been excellent since then.
Hopefully the problem I had was a glitch, I will check again later and report.
CAM
So next stage is to release this version as a beta to the public.
We would like to have a one by one green light from all of you.
PJM: Green Light;
CAM:
EMA:
Tarbat:
RodBearden:
Allocator:
abrad41:
GlynH:
prbflight:
EI4GXB:
Frank:
RNAGG:
GlynH
Well 3.06 Beta has been running OK for a while here and is definitely the best version I have ever seen regarding stability, menu speed etc.
Still has a tendency to slow everything else down but that could be something specific on my PC and so I wouldn't want that to hold up releasing the long awaited Public Beta.
That means a green light from me then!
Thumbs up here...nice one AirNav.
Now it's time to brace ourselves...:-)
Thanks & kind regards,
-=Glyn=-
CAM
Sorry no green light from me :(
The network seems to be still causing me issues.
I am running the version from post #119 and once running the network the application slows down as previously mentioned. I get the vista " I am thinking of something" swirl, then OK, but;
Once network is running it seems OK but once turned off after running for a while, network aircraft remain on screen, whatever the number was, then, last time I tried 73 aircraft remained, it then eventually fell to 1 aircraft, presumably after they had timed out.
Once this has occurred in my flights selecting the aircraft does not work, it does not show on the map and it does not show the photo and aircraft do not move.
Then all of a sudden all comes back to normal?????? Then stops again.
Also on start up the map returns to China, with no interface showing, which is could be my fault, when I loaded v3.06/#90 it was slow to respond and I selected China instead of default to get it displaying the map and ever since it loads up the same China map with no interface
It is very frustrating as to what it could be.
Could I try a full version download to test a full install or should I try the first V3.06 version again as that seemed to be OK, to verify my results.
Sorry for the bad news.
CAM
