AirNav RadarBox 2009 - 3.08 Beta - Released
Started by AirNav Development, November 05, 2009, 04:36:05 PM
Fenris
Quote from: ANDREJ767 on November 09, 2009, 07:13:42 PM
Yes one more thing I found - several false flight ID messages noticed on all Adria Airways CRJs flights - now flight ID are sometimes changed up to 10 times in a minute and none is right,also the same thing with Italian air force Falcons 900EXs.In previous version I used there was no flight IDs for Adria Airways CRJs planes....
RB did not previously decode the particular messages broadcast from things like Embraer, CRJs, Dash 8s etc, in v3.0x it now does decode them.
Not sure why you are seeing flight IDs changing so fast, but it could be a problem with the kit on the aircraft or possibly a problem with the demodulator in the RB hardware I suppose.
As for the lack of network, it's hard to provide that when the server is broken. It is being worked on, but no ETA for it being back yet.
paagats
Last few days have had a problem with Auto-populate. Thread for the 7th mentioned server problems, is this still a problem?
Peter, Sydney
Fenris
Yes, anything requiring server functions will be broken at present.
GreekSpy2001
Quote from: GreekSpy2001 on November 08, 2009, 10:35:59 PM
V3.08 hung
PC had been running for approx 24hrs with v3.08.  This evening had found the program had hung. The machine had been untouched for most of the day so its not a case of me changing any ordering in the myflights table.
Graham
OK now run for 24 hours since last hang with no problems!!!  Very strange.  ONly difference being is that I have used the PC for other things at the same time.  And regularly cleared the alert pop ups.
Graham
Manuel Mendes
Hi AirNav.
I have a small problem, maybe it's not RB related but maybe you can advise me.
The problem is: I try to download the weather, on SmartView, to have my QNH setting correct with my airport, but my Radar almost freezes when downloading the weather and it after says: "Weather:Not Found".
I've checked the ICAO code and it is correct.
Maybe a server breakdown?
We will check, the server is not 100% yet, its getting there.
Weather request working okay here (EGQK).  Manuel, what ICAO code are you using, I'll test if it works here okay.
GreekSpy2001
Every time I start 3.08 I am warned about running AVG.  Every time I answer NO to the question do you want to continue seeing the warning.  And every time time I restart I am warned.  Can this be stopped another way? Is there a registry key to change?
Graham
ANDREJ767
I get false flight IDs also on Lufthansa CRJs and A319s changing letter few times in a minute ....Any idea what should be a reason for that?If I switch back to even version 2.01 I got no flight IDs for CRJs and properly shown flight IDs for Airbus,Boeing .....
EK01
Quote from: Allocator on November 09, 2009, 09:03:14 PM
Quote from: EK01 on November 09, 2009, 12:17:57 PM
I ,too, cannot manage to install 3.08 beta due to the dreaded 'rb.dll not found' message. Having read replies from various others with the same problem, I have decided to stick with the 3.07 version particularly as AN have said that a full download version of 3.08 which is hopefully going to be bug free (and it looks promising that it will be) will be issued within the next couple of weeks.
This is really really simple - I think :-)
You will get the rb.dll not found if you try to run anrb.exe from a directory where rb.dll is not present - and as the rb.dll file is in the default RB directory, then if you have copied the anrb.exe file to the right place, then you won't get this message.
So, rb.dll missing message = anrb.exe not in the same directory as rb.dll
Allocator,
Getting tired now of trying to load 3.08. No permutation seems to work therefore given up and I will wait for 3.08 full downloadable version to come out. I should add that I am using Vista. What  a useless application Vista is. Wish I had kept my old XP now !
Manuel Mendes
Quote from: tarbat on November 10, 2009, 10:02:58 AM
Hi. I'm using ICAO LPFR.
Thanks for the testing.
Quote from: Manuel Mendes on November 10, 2009, 04:43:10 PMHi. I'm using ICAO LPFR.
I'll test when Airnavs METAR server is back up - it appears to be down at the moment.
marcdeklerk
Autopopulate not working today also not updating new flight details received and not even downloading photos?
ANDREJ767
I did switched back to old version of RB till the new one will be a bit better .....
