V3.09 (non-beta) Ready
Started by AirNav Development, November 17, 2009, 01:14:15 AM
Corrected: ACARS connect/re-connect problem;
Corrected: log File writing now in real-time
Corrected: RB port now in real-time;
Corrected: Wrong Date/Time in 30003 output (5 minutes in the future);
Corrected: Local to Network Transition;
Corrected: Maps popup menus mirroring main menu selections and vice-versa;
New exe at:
http://www.airnavsystems.com/download/anrb/31/anrb.exe
One request: we need this tested ASAP as we do want to release this version to everyone this week.
pjm
First impressions....
I've installed the new exe, and first thing I noticed when running it is this error message:
I don't recall seeing this before on any of the exe's.....
  • ACARS connect error seems to be fixed :)
  • The port 30003 timestamps seem ok to me
MSG,1,0,0,750030,0,2009/11/18,16:07:46.250,2009/11/18,16:07:46.250,MAS122,,,,,,,,,,,
MSG,1,0,0,7C6D22,0,2009/11/18,16:07:46.250,2009/11/18,16:07:46.250,VOZ526,,,,,,,,,,,
MSG,3,0,0,750030,0,2009/11/18,16:07:46.250,2009/11/18,16:07:46.250,,1500,,,-33.9096,151.1672,,,,,,
pjm
Quote from: tarbat on November 17, 2009, 09:15:18 PM
I haven't checked, but is port 7879 still 5-min delayed?
seems to be real time here
pjm
Just ran SBS Meter Lite and it is not producing any output with the new version, so there's something in the 30003 feed that it doesn't like.
I'm no expert on the port 30003 data, maybe someone else can comment...
fwiw, the previous (ANRB) version was ok with SBS Meter Lite
We have tested here (now) and it does work with SBS Meter Lite.
GlynH
Quote from: pjm on November 18, 2009, 05:14:06 AM
Hi pjm,
I see that requestor after every new .exe I have ever installed!
I just untick the 'Always ask before opening this file' and never see it again...
Kind regards,
-=Glyn=-
pjm
When I run it here the log files have no data in them (are zero length).
SBS Meter Chart (and wordpad) think they are empty too :)
Tested log files here and they are not empty. The log files you are showing were SBS generated, not RB.
pjm
I don't have an SBS, so they definitely came out of the previous ANRB data :)
Very strange as it was working for me until the timestamp change......
We don't know, maybe we should wait for other beta testers feedback.
GlynH
Quote from: AirNav Development on November 18, 2009, 02:19:10 AM
Well some of it is corrected....States, County Boundaries etc...thanks.
But just try turning on/off Major Roads or Regional Roads via the Quick Launch area icon and see what happens to the Map/General Signs entry for example...
One thing I never noticed before though is a similar thing happens in the Aviation Signs menu vs. Quick Launch icon area with Hide Small Airports, ATC Boundaries, Airways & ACARS Stations. All other entries seem OK...anyone else see this?
I also dread saying that the return of that damn busy pointer when navigating menus is back with a vengeance <sigh>
-=Glyn=-
pjm
Quote from: AirNav Development on November 18, 2009, 06:11:37 AM
Yes - I've just tried 2 previous ANRB's now and still getting zero length files, so maybe its something I've done here....
pjm
Very strange - I have logs from it working yesterday, yet today, nothing...
fwiw I have just downloaded the latest version of SBS Meter (v1.2) and it is working now.... Previously I was using v1.0...
Quote from: abrad41 on November 17, 2009, 07:01:22 PMSeems to be running ok this end, tarbat/Allocator can you see my flight ID in planeplotter = Norfolk area, share code gX
Yep, I can currently see 3 aircraft with gX either as the primary sharer, or in the list of other sharers.
#44
Tested the following, all now corrected:
1. Wrong Date/Time in 30003 output (5 minutes in the future)
Both date/timestamps are the same and correct.
2. Local to Network Transition
Smooth transition from local to network on several aircraft incoming from the US over west Scotland.
3. Log File writing now in real-time
Tested using logfile input to Planeplotter.  Aircraft in Planeplotter show as real-time.
4. RB port now in real-time
Tested using port 7879 input to Planeplotter.  Aircraft in Planeplotter show as real-time.
5. Maps popup menus mirroring main menu selections and vice-versa
Appears to be corrected on the few tests I've done - state and country for example.
