V3.09 (non-beta) Ready
Started by AirNav Development, November 17, 2009, 01:14:15 AM
abrad41
#15
Its gX, it is showing on the user-share map
EDIT - around the Norwich/Yarmouth area
Andy
#16
Sorry Andy, not seen.
I've looked at all the tracks in your area, and I can't see gX
I seem to be sharing as el - that KLM1290 is one of mine.
abrad41
Yes I see yours, but when it was going over North Norfolk, it had changed to mine.
I will see if one of the planeplotter boys can see my a/c.
Thanks Mate
Andy
#18
You do have PP Options>Sharing set to ENABLE do you?
Also, do you have the sharing button on the toobar selected so that it is showing the arrows pointing in both directions?
abrad41
Spot on mate, everything correct here.
Andy
I am getting pretty stunning antenna coverage today, particularly out to the north and north-east of London, so maybe my live coverage is taking priority over your shared data?  There isn't too much traffic out your way and it's all high level.
abrad41
Just changed setting in I/O to SBS1/RBv3 tcp as Chris mentioned earlier.
Might make a difference.
Andy
#22
Yes, I did that and the Flight ID's appeared - thanks Chris :-)
Can you set the PP sharing code manually now?  I've tried changing it from el but it doesn't seem to stay changed.
Sorry this is drifting off thread AirNav.  If you want to split this post into 'V3.09 and Planeplotter', please feel free.
pjm
Quote from: GlynH on November 17, 2009, 02:17:35 PM
I have never seen this problem here on any version of ANRB although that's not to say I have tried them all!
Connection to the ACARS decoder works the first time you connect, but if you disconnect (uncheck the "connect" tick box) and try to reconnect (tick the "connect" check box) you get the message above.
It happens on every version I've tried, and I believe AirNav have replicated the problem.
Quote from: abrad41 on November 17, 2009, 07:55:03 PM
Andy
I see you gX - KLM1499 near OTR :-)
abrad41
Back to thread ;-)
Do we still need to have 5-minute delayed recording now? I see the message still appears when we start one.
I haven't checked, but is port 7879 still 5-min delayed?
EI4GXB
Falcon
Just installed 3.1 2010 from clean, then migrated databases from 3.08. Everything went well. If anything comes up during operation I'll let you know.
