V3.09 (non-beta) Ready
Started by AirNav Development, November 17, 2009, 01:14:15 AM
abrad41
GlynH
Quote from: tarbat on November 18, 2009, 08:40:39 AM
Tested the following, all now corrected:
5. Maps popup menus mirroring main menu selections and vice-versa
Appears to be corrected on the few tests I've done - state and country for example.
Yes those also work for me now but have you tried the Major Roads/Regional Roads in that same menu and Hide Small Airports, ATC Boundaries, Airways & ACARS Stations in the Aviation Signs menu Chris?
Kind regards,
-=Glyn=-
abrad41
QuoteQuote from: tarbat on Today at 08:40:39
Kind regards,
-=Glyn=-
I am having no problems here with the above, everything working as it should be.
Andy
Quote from: GlynH on November 18, 2009, 10:03:42 AMYes those also work for me now but have you tried the Major Roads/Regional Roads in that same menu and Hide Small Airports, ATC Boundaries, Airways & ACARS Stations in the Aviation Signs menu Chris?
Sorry, didn't have time to test that before I left home this morning.  I'll test tonight, although I see Andy reports that it's working okay on his setup.
abrad41
AirNav
QuoteWe have V3.1 fully available for download now.
This intends to be a non-beta version (we want to release it to the public this week).
Changes:
- Application name changed to "AirNav RadarBox 2010 3.1"
- Real-time 30003 Output port for everyone
Download the full installation from:
(pls do install it and test it, not only testing the exe):
http://www.airnavsystems.com/download/anrb/ANRB310Setup.exe
Upgrade (from V2.xx or V3.xx to V3.1):
http://www.airnavsystems.com/download/anrb/ANRBUpgradeto310.exe
Will the ftp upload be a live feed or will this still be delayed by 5 Mins.
Andy
pjm
Quote from: abrad41 on November 18, 2009, 10:37:27 AM
Good question, currently (todays latest version) it is delayed 5 minutes.
DVDW
Everything is working well overhere.
RB port is in real-time. Planes in Planeplotter are plotted in real-time.
Dirk.
So all is Ok except the live ftp upload?
Just found a problem - playing back a recording made in 3.1 (now recording is real-time) it appears that where there is no Flight ID, an altitude is displayed instead.
see screensot.
It's not just when there's no flight ID - something else is going on:
We will have look at this. Pls post more problems.
The Polar Diagram is broken again - loads of spikes way over the range that they should be.  This is the bug that was seen and fixed in a previous beta version.
Corrected: "Major Roads/Regional Roads in that same menu and Hide Small Airports, ATC Boundaries, Airways & ACARS Stations in the Aviation Signs menu"
Corrected: Real-Time FTP Upload
Corrected: altitude instead of flight id on replay
Stby: Polar Diagram code has not changed. Any other users experiencing any problem?
New exe at:
http://www.airnavsystems.com/download/anrb/31/anrb.exe
I'm getting the same spikey polar diagram as Allocator - wasn't a problem in 3.08.
Downloaded the latest version, but I have hardly any local traffic at the moment (1.30 AM) and I won't be able to test the recording functions until Thursday afternoon. Perhaps someone else can check the recording/playback problems that I had.
