V3.09 (non-beta) Ready
Started by AirNav Development, November 17, 2009, 01:14:15 AM
We have V3.1 fully available for download now.
This intends to be a non-beta version (we want to release it to the public this week).
Changes:
- Application name changed to "AirNav RadarBox 2010 3.1"
- Real-time 30003 Output port for everyone
Download the full installation from:
(pls do install it and test it, not only testing the exe):
http://www.airnavsystems.com/download/anrb/ANRB310Setup.exe
Upgrade (from V2.xx or V3.xx to V3.1):
http://www.airnavsystems.com/download/anrb/ANRBUpgradeto310.exe
pjm
ARRrrr! I downloaded 3.09 earlier and just got home and installed it.
fwiw - I'm still getting the ACARS error when I try to connect more than once.
shall download 3.1 and try again.....
pjm
ok - no surprise I guess, the ACARS connect error is still there....
All running okay here.   Real-time aircraft displaying in Planeplotter and MilModeSLogger okay.
Only had a very short time to download and install this before I left for work this morning.  Install to new clean directory was straightforward and the program ran as advertised.  Copied my Outline and Color files from the old directory to the new one, otherwise I'm running a 100% as downloaded V3.09.
I'll look at this version in more detail tonight.
#5
There is a problem with the port 30003 output.  The date/timestamps are wrong.
MSG,3,0,0,400F0B,0,2009/11/17,10:06:18.056,2009/11/17,10:11:18.056,,39000,,,54.7512,-3.9470,,,,,,
The first date/time is correct, but the second one is 5 minutes in the future.
tarbat, are you seeing any Flight ID's coming through port 30003?
I'm displaying the RB OK in Planeplotter, but not getting any Flight ID's even with the appropriate PP options box ticked.
#7
I'm seeing Flight IDs okay in Planerplotter.
Make sure you've ticked "SBS1 / RBv3 tcp" as input.
We have made the required changes for port 30003 to be real-time so it is possible we have minor problems with it. Pls try to analyze it in detail today and we will correct everything at around 9 PM BST.
GlynH
Just installed the complete 2010 into a new directory so its early days yet...
I will ignore the sleepy pointer issue all over the menus as I seem to be the only one in the World who suffers from this but I do see another age-old problem of the Map Menu General Signs settings not mirroring the Quick Launch Map Settings again.
For example Map/General Signs/States defaults to showing all of these highlighted and a quick look at the Quick launch Map icon shows them all highlighted also.
However if I deselect States for example via the Quick Launch Map icon the now deselected change is not reflected if I access the same settings from the Map Menu/General Settings/States.
In fact it takes me two tries to deselect this option from the Menu and once selected again this change does not show when I access the Quick Launch Map icon where one click will turn it back on there but not when I look via the Map Menu.
This also seems to affect everything in the General Signs menu such as Highways/Interstates, Major Roads, Regional Roads, County Boundaries, Urban Areas, Cities, Elevation/Sea Depth but not Day/Night Shadow.
It does not seem to affect the entries in the Aviation Signs Menu for example...just General Signs.
Anyone else seen this?
This always seems to creep back in when a new revision is released and makes me wonder what else may be finding its way back in also?
-=Glyn=-
GlynH
Quote from: pjm on November 17, 2009, 05:09:45 AM
I have never seen this problem here on any version of ANRB although that's not to say I have tried them all!
I can run ANRB, then run WiNRADiO, then run ANAD and watch the messages come in.
I then go into my already running ANRB and tick the Connect to ACARS Decoder box and the received messages start to come into ANRB..
I do however have other issues with ANAD but this is not the time or place...
I know that might be of little consolation to you...
Kind regards,
-=Glyn=-
Quote from: tarbat on November 17, 2009, 01:47:04 PM
Thanks tarbat - only had a quick look at this at lunchtime so it's probably a 'switch pigs' on my part.  I'll have more time to play tonight.
Quote from: GlynH on November 17, 2009, 01:55:20 PMAnyone else seen this?
Glyn, I'm seeing exactly the same issue here as well with the map icons.  Not a showstopper in my book, but it is worrying when old bugs re-appear in a new version.
abrad41
Seems to be running ok this end, tarbat/Allocator can you see my flight ID in planeplotter = Norfolk area, share code gX
Andy
I can see jk and ay but not gx
