Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
Chris and Mike, all added. Many thanks Alan
andrewarles
Quote from: andrewarles on August 10, 2010, 03:58:45 PM
Regarding the wrong ICAO code, is it possible to change a file locally to force the correct airline logo.
Does any one have a solution to this problem ?
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
I would suggest no as the logo comes from the callsign ID.
Andrewarles - you could do what I've done - use Database Explorer (on the File menu), choose the Airlines table, and change the entry for RA (in the C2 column) so that it refers to RAE (in the C3 column), and company name of Régional Compagnie Aérienne Européenne (in the CN column).
For puritans, this is a workround, not a solution, but if you're rarely going to see Nepalese flights and often going to see Regional Airlines flights, it will work fine.
Users in Nepal should probably not do this!
HTH
b777200er
N45MW need to be changed from a SW3 to Learjet 45, cn 45-115 and belongs to Eagle Rock Air Inc.
tks
Donnie
Chris11
Not sure if you want to get ahead of the game but South African Airways has 6 A330-243's on order. 3 have been allocated registrations.
A330-243 CN1191 ZS-SXZ Due March 2011 - Mode S=00B208
A330-243 CN1210 ZS-SXY Due June 2011 - Mode S=00B207
A330-243 CN1223 ZS-SXX Due August 2011 - Mode S=00B206
A330-243 CN1236 ZS- Due October 2011
A330-243 CN1250 ZS- Due November 2011
A330-243 CN1271 ZS- Due February 2012
Donnie and Chris, many thanks
andrewarles
Quote from: RodBearden on August 11, 2010, 04:36:03 PM
HTH
Excellent, that's exactly then type of solution I was looking for.
Andrew
Arles, France.
andrewarles
N621S / A81B84 is currently a Cirrus SR22 c/n 3618 and no longer a G3 (c/n 381).
Arles, France.
On database as an SR22.  Thanks, Alan
andrewarles
Does anyone know why the aircraft type isn't displayed?
Andrew
Arles, France.
besty
Hello the ... must be in the database, open up database explorer enter the ms code and search on the aircraft tab then hightlight the part you want to change. enter the correct data then click show all, this should save the corrected data for you.
hope that helps
Stuart
Andrew,
As Stuart says for some reason on occasions data held on the database doesnt come through or is missing.  Right click on the line and request "Locate mode S in database explorer" When database explorer opens click on the space for the missing or incorrect data, replace it and click somewhere else on the box to save it.  The change will be there for all time thereafter.
andrewarles
Thanks Stuart and Alan,
Also, just realized that the Embraer ERJ170 / E170 isn't in the actype table.
Out of interest, does AirNav keep their db updated for future releases?
Andrew
Arles, France.
#344
E170 is in the AT tables.  The database is being updated, that is what this thread is about, individuals sending in details of missing aircraft and us updaters working away in the background.  Hopefully a new navdata file will be released soon.  In the meantime please feel free to use this thread to forward details of aircraft you note with no details other than its hexcode.
Just in case you dont have the E170 silhouette in your data file I have attached it.  Put it in the silhouettes folder under data.  If however you mean that it is missing in your myflights  table you can add it using the method described before.
