Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
andrewarles
Alan,
The E190 also needs to be added (it's not in my actype table).
What should we do with the RegionalJet Series.
In the main aircraft table the AT field gives the specific model (CRJ1, CRJ2, CRJ7, CRJ9)
But in the type table there is only CRJ listed.  Should each model be added to this table?
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
#346
Andrew,
You shoudnt need to add these in the table as long as the ICAO short code is in the AT column.  The AT column asks for the silhouette and if you have it in the silhouettes folder, the silhouette will be displayed.  That way as new aircraft types are brought into being you dont need to add it to the table.
If the AT is missing from your myflights or network table then it can be added as described for the particular aircraft.
#347
Quote from: andrewarles on August 12, 2010, 12:36:20 PMThe E190 also needs to be added (it's not in my actype table).
I don't think the ACTYPES table is used for anything, in which case presumably the fact that more than 50% of the ICAO designators are invalid doesn't matter,
andrewarles
OK,
What's the a/c code for a Challenger 850?
Andrew
Arles, France.
Andrew - its CRJ2
This site is the ultimate reference for aircraft designators: http://www.icao.int/anb/ais/8643/
andrewarles
Thanks Rod,
That's just what I need.
Andrew
Arles, France.
John Hargreaves
Can you correct the entry for AC7E89 N904FD please.
Should read -
AC7E89 N904FD B752 Boeing 757-2B7 FedEx Express 27144/544
Currently populates as B755 Boeing 757-544.
Thanks,
John H.
John Hargreaves
Can ypu please add -
C01622  C-FIJX  L188  Lockheed L-188PF Electra  Buffalo Airways  2010
This departed Coventry this evening on delivery. Was N2RK of Reeve Aleutian.
Thanks,
John H.
Amended and added John, many thanks, Alan
b777200er
Guys
A5E96A/N480JJ is showing as a LJ-31 in data base, need to be changed to a Gulfstream 150 c/n 241. Owner is Jimmy Johnson Racing.
Donnie
Its already in the database as a G150 with the details stated.
andrewarles
Found 2 records for TS-IMF in NavData.db3, 0292A5 & 0292A4.
0292A5 should be TS-IMG
Andrew
Arles, France.
The Aircraft OE-HAB (4403DF) CL30 Canadair BD100-1A10 Challenger 300  populates incorrect as
OE-HAB (4403DF) ---- Canadair BD700-1A10 Challenger 300
398CD3 populates with DELETE as Registration. On Airframes.org: Status: wrong ICAO24
Perhabs it's a good Idea to terminate this uncertain AirCraft from the Database until there is a reliable status.
D-IFSH (3E2657) AT:PA42 AN:Piper PA42-720 Cheyenne IIIA AC: Leipsiger Mess CN: 42-5501014
The Bug lies in the AC Column:
Leipsiger Messe is misspelled: It should be Leipziger Messe besides: actually the operator is FSH Luftfahrtunternehmen (LEJ) only their Call Sign is Leipzig Fair.
