Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
OE-HAB updated
D-IFSH updated
Unfortunately  we cannot delete entries in the database.  I will however change the delete entry and leave the code with only a registration until more data become available for this aircraft.
Many thanks
Andrew,
I have had a look at the database and there is only 1 entry each for the aircraft detailed and all is as should be.
The problem must be at your end and I would suggest you make the required changes in database explorer.
anorak
Can you clarify this please, who do you go for, database or Airframes?
Dave. Exmoor, North Devon.
Dave
It wasnt in the database but is now as 115.  Dont know what Airframes says as I didnt check.
Quote from: neroon79 on August 14, 2010, 07:46:08 AMD-IFSH (3E2657) AT:PA42 AN:Piper PA42-720 Cheyenne IIIA AC: Leipsiger Mess CN: 42-5501014
ICAO isn't PA42, it's a PAY3.
Chris11
484C38 | PH-4E7 | Aerospool Dynamic WT9 |   WT9   DY-318/2009 | Ultra Light Vliegvereniging "Fryslan"
PH-4E7 is already in the D/B Chris
Chris11
Does not populate - for me :(
Is this one there - also does not populate for me:
484766 PH-4C8    Tecnam    P 92-S ECHO   ULAC   1101 484766   Ultra Light Vliegvereniging "Fryslan"
Its also in the d/b.  If you had any info against it previously you will need to input manually.  Its only when you had no info previously they will update.  Hopefully a new navdata file will be available for download shortly and that will sort the problem but thats up to Airnav.
Hawkeye
Currently on my box with only Mode S showing:-
A11D5E.  N171EX, Dassault Falcon, FAL7X. 24. Martini Acquisitions LLC
Syd
Terry, N97HR updated.
BOM1
One for a slight alteration
683093 IL76 UP-I7628 currently populates as UP-17628
Steve
