Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
andrewarles
Alan,
A/c not populating.
4BBC45 / TC-OBE / A.320-231
4CA78C / EI-DTC / A.320-216
491284 / CS-DTD / Falcon 7X
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
Yes, D-EVSM is a Jetprop DLX Conversion so P46T
Andrew, what do you mean not populating.  TC-OBE, EI-DTC and CS-DTD are all present in the database.  When you click on them do you get nothing or do you mean you dont get a silhouette.  If the later is the casE its the problem that I was mentioning yesterdy.  If you go into databse explorer you will find that eerything is there except for AT which you will require to insert manually I am afraid.
If however you mean that you get no details whatsoever that is indeed a problem I have never come across and I don not know the answer to that.  With new aircraft to your database you normally have to click on them to pull the data from the server which can occur nearly instantly or can take up to 30 seconds depending on how busy it is etc.
andrewarles
Alan,
The 3 aircraft that were not populating at all (just a record with a mode-S code) were noted as such in the MyLog file.
However, since then they have now populated in the main db.  I'm not sure if it was before or after I had forced a populate from the MyLog menu.
Andrew
Arles, France.
AAE32E is in the database as a GLF5.  I had a look at my database explorer and it is in there as a GLF2 which I have manually updated, suggest you do the same.
Having a look at the update shows me that TC-OBE was amended 20th June, EI-DTC 13th June and CS-DTD 30th August.  I would think that clicking on them has forced the update.
Andrew,
Thats your latest batch added / amended.  Thanks again.
#547
Quote from: DaveReid on September 03, 2010, 06:19:08 AM
Quote from: neroon79 on September 02, 2010, 05:25:15 PM3D3DFC D-EVSM PA46 Piper PA-46-350P Malibu Mirage Private 4622072
D-EVSM is a P46T, not a PA46.
Ooops, put the correct designator in my navdata.db3 but posted the incorrect one. Don't know how this happened.
Hi Alan, one to add:
3DF912 D-HOOO EN28 Enstrom F28A-D Private 256
two mixed up Aircraft:
3D2B22 D-EOOW C172 Cessna F172N Skyhawk Private F17201971
3D108A D-EENA TRIN SOCATA TB-21 Trinidad TC Private 1378
This is what I could find out about these two. While receiving D-EENA today it comes with flight id DEOOW and Reims F172N in field AN. Futher there was TB21 as AT. D-EOOW was in the Database as stated above. Would be nice if somebody can crosscheck these two ones.
One to amend:
3D0CE9 D-EDDH is now a C172 Cessna 172S Skyhawk SP of Flugschule Hamburg. MSN: 172S10393
PS. All the BKC5 entries in field AT should also be amended.
Thanks again Ingo.  Unfortunately there is a lot of crap in relation to German light data in the databse which thanks to your help we are gradually weeding out.
D-EOOW is a Reims Cessna F172N Skyhawk c/n F17201971, there is a photo of it in Airliners which has been added to the d/b
D-EENA is as you state a Trinidad and not the old data which you saw.
All have been added / amended.
The BKC5 has been removed from the database if it was ever there but like you I have seen it twice today in Myflight aircraft.  I update my database on a flight by flight basis as it is to much work to go through it and remove all occurunces.
Three to add or to complete
3D118B D-EEWX BE33 Beech F33A Bonanza Private CE-947
3D366D D-ESWB SR22 Cirrus Design Corp SR-22 Private 3227
3E62D3 D-KCPV S6 Stemme S.6/8 Private 6.T.10.011
3D052D D-EAFD C172 Cessna 172S Skyhawk Private 172S10693
3D3D93 D-EVOL C172 Cessna 172S Skyhawk II ASS-Air Service Sachsen, Leipzig 172S9984
3FEF8A D-MYBS ECHO Tecnam P-92 Echo Ultraleicht Flugschule Kassel CN:?
3FEFAD D-MCWC C42 Ikarus C 42 B Privat CN: ?
3D0B39 D-ECMR C172 Reims Aviation FR172H Rocket Private FR17200230
3EDE97 D-KZGH no further info
3FEE75 D-MKSW no further info
3D1807 D-EHIT P32T Piper PA-32RT-300 Lance 2 Private 32R-7885061
That's all for now...
QuoteI update my database on a flight by flight basis as it is to much work to go through it and remove all occurunces.
Same over here...
#552
Just I said that's all two further appeared...
3D17B3 D-EHFN DR40 Robin DR400/180R Schleppflug Plätzer e.V. CN: ?
3D0EE0 D-EDWQ C172 Cessna 172 (Exact AN: ?) Private CN:?
You should proceed a check on this:
46310F OH-SPB AN seems to be not 100% correct.
#553
And two more
478751 LN-HST C750 Cessna 750 Citation10 GE Capital Solutions AB 750-012
3D0D12 D-EDEW C712 Cessna 172R Skyhawk Private 17281237
#554
Photo Error:
3E350A D-ILHA Photo #2 is incorrect.
Edit #1: 3D28DC D-ENSM A210 Aquila A-210 AT01 Aerowest Flug Center GmbH AT01-129
Edit #2: 3D19FD D-EICB C72R Cessna 172RG Cutlass Private 172RG0543
Edit #3: 3D1984 D-EHXK AC11 Rockwell Commander 112TC Berlin Tempelhof Aviators AG CN: ?
Edit #4: 3D1958 D-EHVS C172 Reims Aviation F172N Skyhawk Haeusl'Air 1693
Edit #4: 3D25E8 D-EMPK P28A Piper PA-28-181 Archer 3 Private 2843588
Edit #5: 3D3759 D-ETFD BE33 Beech F33A Bonanza Private CN: ?
Edit #6: 3D2704 D-ENAI C152 Reims Aviation F152 AeroClub Hildesheim-Hannover eV 1737
